On 4/9/2014 2:23 PM, robert bristow-johnson wrote:> On 4/9/14 5:13 PM, Tim Wescott wrote: >> On Wed, 09 Apr 2014 16:48:58 -0400, robert bristow-johnson wrote: >> >>> On 4/9/14 4:29 PM, Rob Gaddi wrote: >>>> >>>> Is http://en.wikipedia.org/wiki/Fast_inverse_square_root at all handy? >>>> >>>> >>> sqrt(x) = x * (1/sqrt(x)) >> >> I was about to tell Rob "no, how could the _inverse_ possibly be useful". >> >> Thanks for heading me off! >> > > > when the SHArC first came out, they had an instruction that's a > primitive iteration for 1/sqrt(x) and i wondered *why* an iterative for > that instead of for sqrt(x). > > the fact that a simply multiplication turns the one into the other was > pointed out early, but it wasn't until years later that the > implementation of Newton's Method (to solve for the inverse of > f(x) = 1/(x^2)) came out to be so clean. then it all made sense to me. >The Power PC has a frsqrte (Floating Reciprocal Square Root Estimate) instruction that looks up the initial value of Newton's method. The initial estimate is correct to one part in 32. Each iteration thereafter is a single instruction and a single clock cycle (I think). There's also an instruction for doing reciprocals by Newton's method. Rob.
Computationally efficient sqrt(x^2 + y^2 + z^2)
Started by ●April 9, 2014
Reply by ●April 9, 20142014-04-09
Rob Doyle <radioengr@gmail.com> wrote: (snip)> The Power PC has a frsqrte (Floating Reciprocal Square Root Estimate) > instruction that looks up the initial value of Newton's method. The > initial estimate is correct to one part in 32. Each iteration > thereafter is a single instruction and a single clock cycle (I think).The software square root algorithms I know of, from the days before SQRT in hardware, do an approximation using fixed point instructions, divide the exponent by two and splice it in, with a special case for odd exponent, then two cycles (single precision) or four cycles (double precision) of Newton-Raphson. The initial approximation is known to be close enough for that number of cycles. -- glen
Reply by ●April 10, 20142014-04-10
There are a bunch of algorithms for integer approximations of square roots. They target for FPGA implementation and weak uC hardware. See http://en.wikipedia.org/wiki/Methods_of_computing_square_roots for overview. This http://www.cc.utah.edu/~nahaj/factoring/isqrt.legalize.c.html is tricky and fast. C source for two different square root algos and cubic roots as well: http://www.mikrocontroller.net/topic/246322#new Cheers Detlef _____________________________ Posted through www.DSPRelated.com
Reply by ●April 11, 20142014-04-11
On Wed, 09 Apr 2014 15:15:00 -0500, Tim Wescott <tim@seemywebsite.please> wrote:>Subject line says it: I need a quick, approximate (+/- 1%) 3D vector >length given its Cartesean components. >Here is a very fast 2-D method that you might be able to extend to 3-D. It involves calculation by cases. Take absolute values and sort so that y < x. You just need to cover 45 degrees of the first quadrant. That you can do by precomputing the secants of 2,4,6,8,...,44 degrees (22 values). For each of these angles, use the pre-computed secant as an approximation to the secant for angles within 1 degree of the central angle. So if (x,y) is closest to 36 degrees, use x * secant(36) as the approximation to the length of (x,y). The worst errors will be at the boundaries where the real angle is 35 or 37 degrees. A little checking shows that secant(35)/secant(36) = 0.9876 and secant(37)/secant(36) = 1.023. This is not quite within your tolerance of 1%, but that can be fixed by using finer subdivisions of angles. As for finding which angle is closest for a given x and y, that you can do by a binary search using precomuted tangents. If y > tangent(angle) * x, the angle needs to be higher. Otherwise lower. With the 22 angles listed above, the closest angle can be found in 5 comparisons. You could double the resolution at the cost of twice as much precomuted lookup and just one more comparision in the binary search. Then you would get your 1% accuracy. This method so far does not involve any divides, so is great for extremely limited micros. If you do have a divide instruction, then the method can be vastly improved by pre-computing not only the secant but also the slope of the secant with respect to the tangent. We know the actual tangent is (y/x). And we can precompute the nominal tangent for the central angle. So by subracting the actual tangent from the nominal tangent and multipling by the slope of the secant with respect to the tangent, we can add this first order correction onto the precomputed secant. So instead of approximating the secant function by a step function we would be approximating it with a piecewise linear function. If this gives you more accuracy than you need, you can reduce the number of angle subdivisions and save on some code space. To extend to 3-D, maybe there is a faster way, but one way is to use this method twice. The first time you approximate the length of (x,y). Then using that length as "v", apply the 2-D method again to find the length of (v,z). I used a techniqe like this to calculate the arctangent of (y/x) in a very resource-limited micro with tight timing requirements. Robert Scott Hopkins, MN
Reply by ●April 12, 20142014-04-12
On 09.04.2014 22:15, Tim Wescott wrote:> Subject line says it: I need a quick, approximate (+/- 1%) 3D vector > length given its Cartesean components. > > Processor is a nuthin-special ARM m4, without the coprocessor. The > vector is in floating point at the moment, but it could be in integers if > that would speed things up. > > I haven't tested it yet, but my mind says "sqrt == expensive", so I want > to avoid that. >1st: get the leading zero count of your magnitude and the first few bits of the mantissa. Use this to lookup a good approximation of sqrt(x) from a table. 2nd: Iterate once or twice using newton/raphson until you've reached your desired precision. You can save some time here by fusing multiple iteration into a single high order iteration. Details on high order iterations for square roots are available here: http://numbers.computation.free.fr/Constants/Algorithms/newton.html As usual you can trade space for speed. If you increase your lookup table you may be able to save a iteration or two. /Nils
Reply by ●April 13, 20142014-04-13
Hi,
there is a Verilog implementation in iverilog's example directory (haven't
tried it myself yet).
According to the documentation, it'll give the result in 16 clock cycles
using only binary operations.
Of course, Verilog isn't too useful for an ARM processor but the algorithm
might work just the same.
original file: sqrt-virtex.v Copyright (c) 2002 Stephen Williams
(steve@icarus.com), GPL
module sqrt32(clk, rdy, reset, x, .y(acc));
input clk;
output rdy;
input reset;
input [31:0] x;
output [15:0] acc;
// acc holds the accumulated result, and acc2 is the accumulated
// square of the accumulated result.
reg [15:0] acc;
reg [31:0] acc2;
// Keep track of which bit I'm working on.
reg [4:0] bitl;
wire [15:0] bit = 1 << bitl;
wire [31:0] bit2 = 1 << (bitl << 1);
// The output is ready when the bitl counter underflows.
wire rdy = bitl[4];
// guess holds the potential next values for acc, and guess2 holds
// the square of that guess. The guess2 calculation is a little bit
// subtle. The idea is that:
// guess2 = (acc + bit) * (acc + bit)
// = (acc * acc) + 2*acc*bit + bit*bit
// = acc2 + 2*acc*bit + bit2
// = acc2 + 2 * (acc<<bitl) + bit
// This works out using shifts because bit and bit2 are known to
// have only a single bit in them.
wire [15:0] guess = acc | bit;
wire [31:0] guess2 = acc2 + bit2 + ((acc << bitl) << 1);
(* ivl_synthesis_on *)
always @(posedge clk or posedge reset)
if (reset) begin
acc = 0;
acc2 = 0;
bitl = 15;
end else begin
if (guess2 <= x) begin
acc <= guess;
acc2 <= guess2;
end
bitl <= bitl - 5'd1;
end
endmodule // sqrt32
