Hi, I want to measure performance gains of some common antenna diversity schemes as used in Mobile Wireless. Can I just simulate uncorrelated multipath fading over two antennas and add the faded signals from two transmit antennas at the receiver ? Do I need to take care of any other issues. Sachin
Simulation of Antenna Diversity
Started by ●July 26, 2003
Reply by ●July 26, 20032003-07-26
sacgupta@hotmail.com (Sachin Gupta) wrote in message news:<1750dd51.0307260339.1fd10a9a@posting.google.com>...> Hi, > > I want to measure performance gains of some common antenna diversity > schemes as used in Mobile Wireless. Can I just simulate uncorrelated > multipath fading over two antennas and add the faded signals from two > transmit antennas at the receiver ? Do I need to take care of any > other issues. > > SachinHi Sachin, I guess you hinted at MRC gain in two-way diversity configuration. If you are interested in static absolute sensitivity and multipath reference sensitivities of the receiver then your model is fine and MRC will improve the receiver sensitivity by 2-3dB for static case and 4-5dB for mutipath case on the average. You will get sufficient gain for ACI and CCI(Co channel interference) reference level measurement but not the best performance. You need to perform IRC (interference Rejection Combining) algorithm which will give the best performance in your case when both faded signals received are uncorrelated and independently faded. Hope this very brief overview helps . Santosh
On 26 Jul 2003 04:39:26 -0700, sacgupta@hotmail.com (Sachin Gupta) wrote:>Hi, > >I want to measure performance gains of some common antenna diversity >schemes as used in Mobile Wireless. Can I just simulate uncorrelated >multipath fading over two antennas and add the faded signals from two >transmit antennas at the receiver ? Do I need to take care of any >other issues. > >SachinSachin, That's the simplest thing to do, but your results may be skewed as a result. Many of the diversity schemes rely on the channels being uncorrelated, so if you always feed uncorrelated signals into the receive antennas you'll always get good results. This isn't always real-world relevant, though, so a good multipath propagation model is useful to further sort the wheat from the chaff. Unfortunately, this is still an area of active research. A lot of people are spending a lot of time and money doing data collection on MIMO propagation (which is also relevant to plain antenna diversity systems), but there doesn't seem to be total agreement yet on good models. Depending on what you're simulating, though, you may be able to get fairly relevant results with some simple models. How decorrelated the receive antenna channels will be depends on how far they're separated. It appears that at least one wavelength of separation is required, and personally I think the more the merrier (i.e., if you can get a few wavelengths of separation, it's a good thing). FWIW, many people are doing exactly what you suggest and just generating indepedent, uncorrelated channels into each input. My reaction is then to interpret the results as an upper bound on performance and not necessarily what you'll get in the real world. Eric Jacobsen Minister of Algorithms, Intel Corp. My opinions may not be Intel's opinions. http://www.ericjacobsen.org
Reply by ●July 28, 20032003-07-28
Aloha, Sachin Gupta schrieb:> I want to measure performance gains of some common antenna diversity > schemes as used in Mobile Wireless. Can I just simulate uncorrelated > multipath fading over two antennas and add the faded signals from two > transmit antennas at the receiver ? Do I need to take care of any > other issues.With two completely independent channels you are simulating only one of the cases you may find in reality. Other cases will be partly or allmost fully correlated channels (from every BS antenna to every MS antenna). The correlation between the channels is the spatial caracteristic of the radio channel based n the geometry. One of the approaches to transform a geometry to a spatial/temporal channel model you can find in 3GPP TR25.996, on www.3gpp.org. Wishing a happy day LOBI
eric.jacobsen@ieee.org (Eric Jacobsen) wrote in message news:<3f22c221.49066687@news.earthlink.net>...> On 26 Jul 2003 04:39:26 -0700, sacgupta@hotmail.com (Sachin Gupta) > wrote: > > >Hi, > > > >I want to measure performance gains of some common antenna diversity > >schemes as used in Mobile Wireless. Can I just simulate uncorrelated > >multipath fading over two antennas and add the faded signals from two > >transmit antennas at the receiver ? Do I need to take care of any > >other issues. > > > >Sachin > > Sachin, > > That's the simplest thing to do, but your results may be skewed as a > result. Many of the diversity schemes rely on the channels being > uncorrelated, so if you always feed uncorrelated signals into the > receive antennas you'll always get good results. This isn't always > real-world relevant, though, so a good multipath propagation model is > useful to further sort the wheat from the chaff.When I started this simulation stuff, the references I had told me to simulate uncorrelated multipaths. So the classical Jakes model which gives correlated multipath was modified (according to one of IEEE papers) to one which now gives uncorrelated multipaths (very less correlation over a long duration). Now you suggest that I start getting correlated multipaths back ! See more on this below.> Unfortunately, this is still an area of active research. A lot of > people are spending a lot of time and money doing data collection on > MIMO propagation (which is also relevant to plain antenna diversity > systems), but there doesn't seem to be total agreement yet on good > models. > > Depending on what you're simulating, though, you may be able to get > fairly relevant results with some simple models. How decorrelated > the receive antenna channels will be depends on how far they're > separated. It appears that at least one wavelength of separation is > required, and personally I think the more the merrier (i.e., if you > can get a few wavelengths of separation, it's a good thing). > > FWIW, many people are doing exactly what you suggest and just > generating indepedent, uncorrelated channels into each input. My > reaction is then to interpret the results as an upper bound on > performance and not necessarily what you'll get in the real world.I may have given the wrong impression that I wanted to measure performance of Diversity combining schemes. I actually want to get my simulation model right and then get my diversity combining schemes right. I am not evaluating/performance benchmarking different combining schemes - they are predefined. Do I need to look into Spatial Channel Modelling ? (I tried to take a look at it but it seems very complicated for my application - the channel model itself would take more time than the combining schemes) What about the Modified Jakes' fading model - do I go back to the original (correlated) Jakes model ?> Eric Jacobsen > Minister of Algorithms, Intel Corp. > My opinions may not be Intel's opinions. > http://www.ericjacobsen.orgThanks a lot for your thoughts, they have helped a lot. Sachin
Andreas Lobinger <andreas.lobinger@netsurf.de> wrote in message news:<3F24EC17.9700EAF0@netsurf.de>...> Aloha, > > Sachin Gupta schrieb: > > I want to measure performance gains of some common antenna diversity > > schemes as used in Mobile Wireless. Can I just simulate uncorrelated > > multipath fading over two antennas and add the faded signals from two > > transmit antennas at the receiver ? Do I need to take care of any > > other issues. > > With two completely independent channels you are simulating only one > of the cases you may find in reality. Other cases will be partly or allmost > fully correlated channels (from every BS antenna to every MS antenna). > The correlation between the channels is the spatial caracteristic of > the radio channel based n the geometry. > One of the approaches to transform a geometry to a spatial/temporal > channel model you can find in > 3GPP TR25.996, on www.3gpp.org. > > Wishing a happy day > LOBILOBI, Thanks for the reference. Looks very complicated ! Any tutorial (back to basics) type paper on this ? I have one more question, the performance would degrade with correlated multipaths. But the diversity combining scheme itself should not change ? (no MUD or interference cancellation being used) Sachin
Aloha, Sachin Gupta schrieb:> Andreas Lobinger <andreas.lobinger@netsurf.de> wrote in message > > Sachin Gupta schrieb: > > > I want to measure performance gains of some common antenna diversity > > > schemes as used in Mobile Wireless. Can I just simulate uncorrelated > > > multipath fading over two antennas and add the faded signals from two > > > transmit antennas at the receiver ? Do I need to take care of any > > > other issues.> > One of the approaches to transform a geometry to a spatial/temporal > > channel model you can find in > > 3GPP TR25.996, on www.3gpp.org.> Thanks for the reference. Looks very complicated ! Any tutorial (back > to basics) type paper on this ?Of course the SCM is a very detailed version of a spatial channel model. But you should see here, that the Jakes (uncorrelated omnidirectional multipath) Spectrum is dropped for a more geometric approach. If you have one omnidirectional antenna at the MS you could do (as everyone starting with) working with independent uncorrelated channels and correlate them with the Channel Covariance Matrix. A view in 25.869 V1.00 can give you a few hints here.> I have one more question, the performance would degrade with > correlated multipaths. But the diversity combining scheme itself > should not change?Putting it this way: If you have a diversity receiver concept that depends on uncorrelated channels, you will see a degradation with increasing correlation. But there are other concepts which can deal with partially correlated channels or concepts that exploit the spatial nature of the channel... (MIMO etc.). Wishing a happy day LOBI
On 28 Jul 2003 06:00:54 -0700, sacgupta@hotmail.com (Sachin Gupta) wrote:>eric.jacobsen@ieee.org (Eric Jacobsen) wrote in message news:<3f22c221.49066687@news.earthlink.net>... >> On 26 Jul 2003 04:39:26 -0700, sacgupta@hotmail.com (Sachin Gupta) >> wrote: >> >> >Hi, >> > >> >I want to measure performance gains of some common antenna diversity >> >schemes as used in Mobile Wireless. Can I just simulate uncorrelated >> >multipath fading over two antennas and add the faded signals from two >> >transmit antennas at the receiver ? Do I need to take care of any >> >other issues. >> > >> >Sachin >> >> Sachin, >> >> That's the simplest thing to do, but your results may be skewed as a >> result. Many of the diversity schemes rely on the channels being >> uncorrelated, so if you always feed uncorrelated signals into the >> receive antennas you'll always get good results. This isn't always >> real-world relevant, though, so a good multipath propagation model is >> useful to further sort the wheat from the chaff. > >When I started this simulation stuff, the references I had told me to >simulate uncorrelated multipaths. So the classical Jakes model which >gives correlated multipath was modified (according to one of IEEE >papers) to one which now gives uncorrelated multipaths (very less >correlation over a long duration). Now you suggest that I start >getting correlated multipaths back ! See more on this below.Yeah, sorry. ;)>> Unfortunately, this is still an area of active research. A lot of >> people are spending a lot of time and money doing data collection on >> MIMO propagation (which is also relevant to plain antenna diversity >> systems), but there doesn't seem to be total agreement yet on good >> models. >> >> Depending on what you're simulating, though, you may be able to get >> fairly relevant results with some simple models. How decorrelated >> the receive antenna channels will be depends on how far they're >> separated. It appears that at least one wavelength of separation is >> required, and personally I think the more the merrier (i.e., if you >> can get a few wavelengths of separation, it's a good thing). >> >> FWIW, many people are doing exactly what you suggest and just >> generating indepedent, uncorrelated channels into each input. My >> reaction is then to interpret the results as an upper bound on >> performance and not necessarily what you'll get in the real world. > >I may have given the wrong impression that I wanted to measure >performance of Diversity combining schemes. I actually want to get my >simulation model right and then get my diversity combining schemes >right. I am not evaluating/performance benchmarking different >combining schemes - they are predefined. > >Do I need to look into Spatial Channel Modelling ? (I tried to take a >look at it but it seems very complicated for my application - the >channel model itself would take more time than the combining schemes) > >What about the Modified Jakes' fading model - do I go back to the >original (correlated) Jakes model ?I think it just depends on what you want to do and how much time you want to spend on it. As Lobi suggested you can correlate independant channels according to some channel covariance matrix, and you may be able to make some assumptions to generate the covariance matrix (or just simulate across some representative samples of covariance matrices). It is very time consuming to try to "accurately" model a multi-antenna system since it is so dependant on the assumed environment, spacing and directivity of the antennas, etc., etc. No matter what you assume it will probably cover only a fraction of the possible cases. I think this is why a lot of people just punt and assume uncorrelated channels, and then wave their hands that that can be assured with adequate antenna separation. If you're working on a cellular system then the Jakes model is a reasonable thing to use. It is well understood and seems to be widely accepted among the cellular community, although it does have limitations. If you're working on some other application, however, you may want to look at other methods (e.g., Jakes won't be appropriate for WLAN, sensor networks, etc.). Cheers, Eric Jacobsen Minister of Algorithms, Intel Corp. My opinions may not be Intel's opinions. http://www.ericjacobsen.org
eric.jacobsen@ieee.org (Eric Jacobsen) wrote in message news:<3f256466.221706514@news.earthlink.net>...> On 28 Jul 2003 06:00:54 -0700, sacgupta@hotmail.com (Sachin Gupta) > wrote: > > >eric.jacobsen@ieee.org (Eric Jacobsen) wrote in message news:<3f22c221.49066687@news.earthlink.net>... > >> On 26 Jul 2003 04:39:26 -0700, sacgupta@hotmail.com (Sachin Gupta) > >> wrote: > >> > >> >Hi, > >> > > >> >I want to measure performance gains of some common antenna diversity > >> >schemes as used in Mobile Wireless. Can I just simulate uncorrelated > >> >multipath fading over two antennas and add the faded signals from two > >> >transmit antennas at the receiver ? Do I need to take care of any > >> >other issues. > >> > > >> >Sachin > >> > >> Sachin, > >> > >> That's the simplest thing to do, but your results may be skewed as a > >> result. Many of the diversity schemes rely on the channels being > >> uncorrelated, so if you always feed uncorrelated signals into the > >> receive antennas you'll always get good results. This isn't always > >> real-world relevant, though, so a good multipath propagation model is > >> useful to further sort the wheat from the chaff. > > > >When I started this simulation stuff, the references I had told me to > >simulate uncorrelated multipaths. So the classical Jakes model which > >gives correlated multipath was modified (according to one of IEEE > >papers) to one which now gives uncorrelated multipaths (very less > >correlation over a long duration). Now you suggest that I start > >getting correlated multipaths back ! See more on this below. > > Yeah, sorry. ;) > > >> Unfortunately, this is still an area of active research. A lot of > >> people are spending a lot of time and money doing data collection on > >> MIMO propagation (which is also relevant to plain antenna diversity > >> systems), but there doesn't seem to be total agreement yet on good > >> models. > >> > >> Depending on what you're simulating, though, you may be able to get > >> fairly relevant results with some simple models. How decorrelated > >> the receive antenna channels will be depends on how far they're > >> separated. It appears that at least one wavelength of separation is > >> required, and personally I think the more the merrier (i.e., if you > >> can get a few wavelengths of separation, it's a good thing). > >> > >> FWIW, many people are doing exactly what you suggest and just > >> generating indepedent, uncorrelated channels into each input. My > >> reaction is then to interpret the results as an upper bound on > >> performance and not necessarily what you'll get in the real world. > > > >I may have given the wrong impression that I wanted to measure > >performance of Diversity combining schemes. I actually want to get my > >simulation model right and then get my diversity combining schemes > >right. I am not evaluating/performance benchmarking different > >combining schemes - they are predefined. > > > >Do I need to look into Spatial Channel Modelling ? (I tried to take a > >look at it but it seems very complicated for my application - the > >channel model itself would take more time than the combining schemes) > > > >What about the Modified Jakes' fading model - do I go back to the > >original (correlated) Jakes model ? > > I think it just depends on what you want to do and how much time you > want to spend on it. As Lobi suggested you can correlate independant > channels according to some channel covariance matrix, and you may be > able to make some assumptions to generate the covariance matrix (or > just simulate across some representative samples of covariance > matrices). > > It is very time consuming to try to "accurately" model a > multi-antenna system since it is so dependant on the assumed > environment, spacing and directivity of the antennas, etc., etc. No > matter what you assume it will probably cover only a fraction of the > possible cases. I think this is why a lot of people just punt and > assume uncorrelated channels, and then wave their hands that that can > be assured with adequate antenna separation. > > If you're working on a cellular system then the Jakes model is a > reasonable thing to use. It is well understood and seems to be widely > accepted among the cellular community, although it does have > limitations. If you're working on some other application, however, > you may want to look at other methods (e.g., Jakes won't be > appropriate for WLAN, sensor networks, etc.).Eric, Could you elaborate a bit here why Jakes model won't be appropriate for WLAN? Santosh> > Cheers, > > > > Eric Jacobsen > Minister of Algorithms, Intel Corp. > My opinions may not be Intel's opinions. > http://www.ericjacobsen.org
Reply by ●July 29, 20032003-07-29
Andreas Lobinger <andreas.lobinger@netsurf.de> wrote in message news:<3F2525CE.DD6B9EE7@netsurf.de>...> Aloha, > > Sachin Gupta schrieb: > > Andreas Lobinger <andreas.lobinger@netsurf.de> wrote in message > > Sachin Gupta schrieb: > > > > I want to measure performance gains of some common antenna diversity > > > > schemes as used in Mobile Wireless. Can I just simulate uncorrelated > > > > multipath fading over two antennas and add the faded signals from two > > > > transmit antennas at the receiver ? Do I need to take care of any > > > > other issues. > > > > One of the approaches to transform a geometry to a spatial/temporal > > > channel model you can find in > > > 3GPP TR25.996, on www.3gpp.org. > > > Thanks for the reference. Looks very complicated ! Any tutorial (back > > to basics) type paper on this ? > > Of course the SCM is a very detailed version of a spatial channel > model. But you should see here, that the Jakes (uncorrelated > omnidirectional multipath) Spectrum is dropped for a more geometric > approach. If you have one omnidirectional antenna at the > MS you could do (as everyone starting with) working with independent > uncorrelated channels and correlate them with the Channel > Covariance Matrix. A view in 25.869 V1.00 can give you a few hints > here.Thanks for this reference. I'll try to look into it also and see what I can do.> > I have one more question, the performance would degrade with > > correlated multipaths. But the diversity combining scheme itself > > should not change? > > Putting it this way: If you have a diversity receiver concept that > depends on uncorrelated channels, you will see a degradation with > increasing correlation. But there are other concepts which can > deal with partially correlated channels or concepts that exploit > the spatial nature of the channel... (MIMO etc.).Thanks for this thought also. As I wrote I was under impression that nothing much could be done about correlation with TX antenna diversity alone. I'll try this also.> Wishing a happy day > LOBIWishing the same for you. Your comments have been most helpful. Sachin
