capacitors
Started by glen herrmannsfeldt ●June 5, 2014
I don't know any other group to ask, but I presume people here
use capacitors.
Has anyone else notice that electrolytic capacitors don't
last as long as they used to?
I have some electronics from 20 or 30 years, or even older,
that still works fine.
Some things from two or three years ago with dead electrolytics.
If the can expands, it is easy to find which one, but they don't
always do that.
-- glen
On 6/5/2014 2:48 PM, glen herrmannsfeldt wrote:
> I don't know any other group to ask, but I presume people here > use capacitors. > > Has anyone else notice that electrolytic capacitors don't > last as long as they used to? > > I have some electronics from 20 or 30 years, or even older, > that still works fine. > > Some things from two or three years ago with dead electrolytics. > If the can expands, it is easy to find which one, but they don't > always do that. > > -- glen >
May be, it's a case of the "capacitor plague", a problem which emerged in 2000s? http://en.wikipedia.org/wiki/Capacitor_plague However, my hands on experience with capacitors is very limited. Evgeny.
Hm, not really.
It's a flawed comparison. Due to advances in technology, caps in todays electronics have ripple currents that are vastly greater than your 30 year old pedants. Power supplies are almost uniformly SMPS constructions (switched) where 30 years ago they rarely were. So it's not really a fair comparison. If anything at all, capacitors have become a lot better than they were before. It is very possible to construct high quality electronics today. The question is how you design (i.e. which value you choose and where you place them on your PCB).
Most certainly all cheap consumer electronics. Cheers, Johannes --
>> Wo hattest Du das Beben nochmal GENAU vorhergesagt? > Zumindest nicht �ffentlich!
Ah, der neueste und bis heute genialste Streich unsere gro&#4294967295;en Kosmologen: Die Geheim-Vorhersage. - Karl Kaos &#4294967295;ber R&#4294967295;diger Thomas in dsa <hidbv3$om2$1@speranza.aioe.org>
glen herrmannsfeldt <gah@ugcs.caltech.edu> writes:
glen, I have an aged NAD power amplifier, probably 20 years old, that has a capacitor going bad in one channel. Haven't checked it out yet. But yeah, I have experienced that. -- Randy Yates Digital Signal Labs http://www.digitalsignallabs.com
Randy Yates <yates@digitalsignallabs.com> wrote:
(snip, I wrote)
>> Has anyone else notice that electrolytic capacitors don't >> last as long as they used to?
(snip)
> I have an aged NAD power amplifier, probably 20 years old, that has a > capacitor going bad in one channel. Haven't checked it out yet. But > yeah, I have experienced that.
My now 35 year old amplifier had two capacitors in the power-on delay circuit replaced some years ago, and some years apart. That was easy to figure out, as the relay took longer and longer to close, until it didn't. Some of the switches, such as the subsonic and high-cut filters, have gotten noisy over the years. Time to bypass them, as I never use them. (I bought the service manual when it was new, just in case.) But then one channel started to get some hum. To delay the need to fix it, I bought a used one from a goodwill store. The latest is a HomePlug power-line network device. (Which came from the goodwill store.) That one the capacitor top had expanded so I knew which one it was. I have a Sony DVD recorder that has some power supply problem, probably a capacitor but I didn't find it yet. I bought a used one of similar model (so the same remote works) but might still fix that one. But the worst one is digital TV converters, which last about 2 or 3 years, each. One had an expanded capacitor so was easy. Two more I still haven't fixed yet, but since one works, I am not in so much of a hurry. Oh well. -- glen
On Thursday, June 5, 2014 10:48:14 PM UTC+12, glen herrmannsfeldt wrote:
> I don't know any other group to ask, but I presume people here > > use capacitors. > > > > Has anyone else notice that electrolytic capacitors don't > > last as long as they used to? > > > > I have some electronics from 20 or 30 years, or even older, > > that still works fine. > > > > Some things from two or three years ago with dead electrolytics. > > If the can expands, it is easy to find which one, but they don't > > always do that. > > > > -- glen
Most of us just use a line of code to replace capacitors
In today's devices caps seem to be the components that fail
first, especially in the low-voltage side of switched mode
power supplies which run in standby for long.
Have seen quite a lot of DVD-players, set-top-boxes etc with
blown-up caps.
Andre
On Thu, 5 Jun 2014 19:21:50 +0000 (UTC), glen herrmannsfeldt
<gah@ugcs.caltech.edu> wrote:
>Randy Yates <yates@digitalsignallabs.com> wrote: > >(snip, I wrote) >>> Has anyone else notice that electrolytic capacitors don't >>> last as long as they used to? > >(snip) > >> I have an aged NAD power amplifier, probably 20 years old, that has a >> capacitor going bad in one channel. Haven't checked it out yet. But >> yeah, I have experienced that. > >My now 35 year old amplifier had two capacitors in the power-on >delay circuit replaced some years ago, and some years apart. >That was easy to figure out, as the relay took longer and longer >to close, until it didn't. > >Some of the switches, such as the subsonic and high-cut filters, >have gotten noisy over the years. Time to bypass them, as I never >use them. > >(I bought the service manual when it was new, just in case.) > >But then one channel started to get some hum. To delay the need >to fix it, I bought a used one from a goodwill store. > >The latest is a HomePlug power-line network device. (Which came >from the goodwill store.) That one the capacitor top had expanded >so I knew which one it was. > >I have a Sony DVD recorder that has some power supply problem, >probably a capacitor but I didn't find it yet. I bought a used >one of similar model (so the same remote works) but might still >fix that one. > >But the worst one is digital TV converters, which last about 2 >or 3 years, each. One had an expanded capacitor so was easy. >Two more I still haven't fixed yet, but since one works, I am not >in so much of a hurry.
I also have encountered a DTV converter with bad capacitors. When I Googled, it turned out that model was notorious for a particular cap going bad, probably a design under-spec. (This was a cheapie unit.) Best regards, Bob Masta DAQARTA v7.50 Data AcQuisition And Real-Time Analysis www.daqarta.com Scope, Spectrum, Spectrogram, Sound Level Meter Frequency Counter, Pitch Track, Pitch-to-MIDI FREE Signal Generator, DaqMusiq generator Science with your sound card!
On Thursday, June 5, 2014 5:48:14 AM UTC-5, glen herrmannsfeldt wrote:
> don't last as long as they used to?
Most of us don't, either! :-) (I can't believe I wrote that)
dvsarwate <dvsarwate@yahoo.com> writes:
> On Thursday, June 5, 2014 5:48:14 AM UTC-5, glen herrmannsfeldt wrote: > > .... > >> don't last as long as they used to? > > Most of us don't, either! :-)
That's what she said... -- Randy Yates Digital Signal Labs http://www.digitalsignallabs.com
