Hi All, I would like to re-sample a vector using different sample rates. But I would want to keep the symmetry as it is. E.g. h = [ 0.1 0.3 0.7 0.3 0.1]; % Original vector with 5 samples h2 = resample(h,4,5); % Re-sampled vector into 4 samples But the above command doesn't give a symmetric vector as the original one. Is there any way to re-sample keeping the symmetry around the center sample ? Thanks in advance. _____________________________ Posted through www.DSPRelated.com
Resampling vector from the middle sample (Keeping the symmetry)
Started by ●June 22, 2014
Reply by ●June 23, 20142014-06-23
>Hi All, > >I would like to re-sample a vector using different sample rates. But I >would want to keep the symmetry as it is. > >E.g. h = [ 0.1 0.3 0.7 0.3 0.1]; % Original vector with 5 samples h2 = >resample(h,4,5); % Re-sampled vector into 4 samples > >But the above command doesn't give a symmetric vector as the originalone.>Is there any way to re-sample keeping the symmetry around the centersample>? > >Thanks in advance. > > >_____________________________ >Posted through www.DSPRelated.com >use even (h) e.g 6 samples then you get symmetry on 5 samples _____________________________ Posted through www.DSPRelated.com
Reply by ●June 24, 20142014-06-24
On Sun, 22 Jun 2014 21:01:15 -0500, "Dan25" <98432@dsprelated> wrote:>Hi All, > >I would like to re-sample a vector using different sample rates. But I >would want to keep the symmetry as it is. > >E.g. h = [ 0.1 0.3 0.7 0.3 0.1]; % Original vector with 5 samples h2 = >resample(h,4,5); % Re-sampled vector into 4 samples > >But the above command doesn't give a symmetric vector as the original one. >Is there any way to re-sample keeping the symmetry around the center sample >? > >Thanks in advance.Hi Dan25, Matlab's 'resample' command performs all sorts of processing that doesn't give reasonable results on such a short-length sequence as your 'h' sequence. How about you just perform simple linear interpolation? Such as: h3(1) = h(1) + (h(2)-h(1))/2, h3(2) = h(2) + (h(3)-h(2))/2, h3(3) = h(3) + (h(4)-h(3))/2, h3(4) = h(4) + (h(5)-h(4))/2, Now plot the following: figure(1) plot(h,'-bo') hold on plot([1.5,2.5,3.5,4.5], h3,'-go') hold off Good Luck, [-Rick-]
