Hi guys, I have recently read an great article about Goertzel Algorithm at https://courses.cs.washington.edu/courses/cse466/12au/calendar/Goertzel-EETimes.pdf I thought you could help me a bit now. I'm building laser rangefinder which use FFT to calculate distance. Firstly I thought I need to implement FFT in code and then look for highest bin in the spectrum to calculate it's phase ( will have 2 signals - one from sine generator and other from diode detector and will compare it's phases to calculate the distance, knowing sine wave length). But then I found the Goertzel Algorithm. This could give me much more easier code and save hardvare resources. The problem is that my sine wave will be about 15MHz and the sampling rate will be about 1MHz or even lower. Are you familiar with Goertzel Algorithm using undersampling ? Is this possible? If yes then maybe you could tell me what changes I need to apply in the code presented in the arcitle (http://m.eetindia.co.in/STATIC/DOWNLOAD/09banks.txt) ? I really don't know how to move further in my project. Implementing FFT for 2k samples on atmega or xmega is very problematic. If the Goertzel could work in undersampling that would be great for me. Thank you in advance :) Regards, Mariusz _____________________________ Posted through www.DSPRelated.com
Started by ●August 7, 2014
Reply by ●August 8, 20142014-08-08
On Thu, 07 Aug 2014 10:47:51 -0500, "MariuszR" <101025@dsprelated> wrote:>Hi guys, >I have recently read an great article about Goertzel Algorithm at >https://courses.cs.washington.edu/courses/cse466/12au/calendar/Goertzel-EETimes.pdf >I thought you could help me a bit now. >I'm building laser rangefinder which use FFT to calculate distance. Firstly >I thought I need to implement FFT in code and then look for highest bin in >the spectrum to calculate it's phase ( will have 2 signals - one from sine >generator and other from diode detector and will compare it's phases to >calculate the distance, knowing sine wave length). >But then I found the Goertzel Algorithm. This could give me much more >easier code and save hardvare resources. >The problem is that my sine wave will be about 15MHz and the sampling rate >will be about 1MHz or even lower. >Are you familiar with Goertzel Algorithm using undersampling ? Is this >possible? If yes then maybe you could tell me what changes I need to apply >in the code presented in the arcitle >(http://m.eetindia.co.in/STATIC/DOWNLOAD/09banks.txt) ? >I really don't know how to move further in my project. Implementing FFT for >2k samples on atmega or xmega is very problematic. If the Goertzel could >work in undersampling that would be great for me. >Thank you in advance :) >Regards, >MariuszHello Mariusz, If you have an analog sinewave in the neighborhood of 15 Mhz and you sample it at a sample rate of 1 MHz, "alaising" will occur and the sinewave will exist (will be present) in your sampled signal. The question is, "What will be the frequency of the original 15 MHz analog sinewave *after* sampling and aliasing occurs?" If, after aliasing, your 15 MHz sinewave appears at a frequency of, say, 255 kHz in your sampled sequence, then set your Goertzel coefficients' values so that the Goertzel filter's center frequency is 255 kHz. It seems to me that you should be able to use the Goertzel algorithm on an undersampled (aliased) input sequence, but what worries me about this idea is the analog signal applied to your A/D converter. That analog A/D input signal will have some measurable spectral energy. And *ALL* of that spectral energy will appear (will exist) in your sampled discete signal, "folded" back-and-forth (aliased), in the freq range of zero to one half of one MHz (500 kHz). It seems to me that you should perform analog bandpass filtering of your detector's analog output signal, to eliminate as much analog spectral energy above and below your sinewave's frequency, before applying that analog signal to your A/D converter. Then again, maybe no analog filtering will be necessary if the value for 'N' in your Goertzel filter is large enough. Who knows. Anyway, just my thoughts. [-Rick-]
On Thu, 07 Aug 2014 10:47:51 -0500, MariuszR wrote:> Hi guys, > I have recently read an great article about Goertzel Algorithm at > https://courses.cs.washington.edu/courses/cse466/12au/calendar/Goertzel-EETimes.pdf> I thought you could help me a bit now. > I'm building laser rangefinder which use FFT to calculate distance. > Firstly I thought I need to implement FFT in code and then look for > highest bin in the spectrum to calculate it's phase ( will have 2 > signals - one from sine generator and other from diode detector and will > compare it's phases to calculate the distance, knowing sine wave > length). > But then I found the Goertzel Algorithm. This could give me much more > easier code and save hardvare resources. > The problem is that my sine wave will be about 15MHz and the sampling > rate will be about 1MHz or even lower. > Are you familiar with Goertzel Algorithm using undersampling ? Is this > possible? If yes then maybe you could tell me what changes I need to > apply in the code presented in the arcitle > (http://m.eetindia.co.in/STATIC/DOWNLOAD/09banks.txt) ? > I really don't know how to move further in my project. Implementing FFT > for 2k samples on atmega or xmega is very problematic. If the Goertzel > could work in undersampling that would be great for me. > Thank you in advance :)The Goertzel algorithm should work as well as the FFT (although slower than a complete FFT) after sampling. You really need to ask two questions: first, will the sampling process preserves the information you need, and second, will the Goertzel be adequate to analyze the sampled data. The Goertzel will work if you expect to need to just look for one tone. If you really need to know about the whole spectrum, then the FFT will be faster. You'll find a short discussion of the sampling issue here: http://wescottdesign.com/articles/Sampling/sampling.pdf -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
