Help with cleaning up noisy 10 bps communication
Started by BasicPoke August 12, 2014
>>>> then there are frequencies up to 10MHz or more that matter. >>Erm, no. That would be a million times the baud rate. >> >>As a rule of thumb, fit two bits into one cycle (look at the fundamental >>component of a 010101... sequence). Analog Telefax is the classical >>textbook example. Some excess bandwidth is OK, a factor of 10 maybe. >> >>Bandwidth must be limited, otherwise the cable becomes the antenna of a >>long range thunderstorm detector. >> >That is something we were just talking about, limiting the rise and fall >time of the signal (at the driver), which is not being done now. This >would reduce the ringing I believe. But we are very reluctant to add >active components because of reliability issues. We are working at high >temps. > >The cable is underground, vertical, to a well motor, so I don't believe
it
>can act as an antenna. >Ron
It sounds like you don't have proper termination at the reciever and are fighting transmission line effects of your long cable. Seems like there should be a simple solution to that...... _____________________________ Posted through www.DSPRelated.com
On Wed, 13 Aug 2014 08:39:34 -0500, BasicPoke wrote:
>>>> then there are frequencies up to 10MHz or more that matter. >>Erm, no. That would be a million times the baud rate. >> >>As a rule of thumb, fit two bits into one cycle (look at the fundamental >>component of a 010101... sequence). Analog Telefax is the classical >>textbook example. Some excess bandwidth is OK, a factor of 10 maybe. >> >>Bandwidth must be limited, otherwise the cable becomes the antenna of a >>long range thunderstorm detector. >> > That is something we were just talking about, limiting the rise and fall > time of the signal (at the driver), which is not being done now. This > would reduce the ringing I believe. But we are very reluctant to add > active components because of reliability issues. We are working at high > temps. > > The cable is underground, vertical, to a well motor, so I don't believe it > can act as an antenna. > Ron > > _____________________________ > Posted through www.DSPRelated.com
This "ringing" is at such a low frequency that I suspect that you have some reactive elements other than just the connecting cable. Could the motor somehow be part of the circuit? Is your signaling over differential lines (which might help guard against various problems), or single-ended WRT some 'ground' that might actually be different on receiving and transmitting ends? You should be able to control risetimes with a simple passive circuit. While you haven't AFAICR said how long your line is, using differential signalling would help deal with many potential problems.
some
>reactive elements other than just the connecting cable. Could the motor >somehow be part of the circuit? Is your signaling over differential
lines
some
ends?
While
signalling
>would help deal with many potential problems. > >
The 3-phase motor windings are part of the circuit, in series with 10k feet of the motor's power cable. The signal passes over the power cable. There are other reactive components. It is not a simple things to terminate the cable apparently. We do not know the type of motor that will be installed, the type of cable, or the length of cable. It is not an option to use a different type of cable to optimize communications. The primary purpose of the cable is to power the motor. I have used an active low pass filter, using an op amp, and got a much cleaner signal, so I think that will have to be part of my solution. But we have yet to see how this filter will work with the motor running, which we will do today. This may be ugly. Ron _____________________________ Posted through www.DSPRelated.com
On 13/08/14 17:35, BasicPoke wrote:
>> This "ringing" is at such a low frequency that I suspect that you have > some >> reactive elements other than just the connecting cable. Could the motor >> somehow be part of the circuit? Is your signaling over differential > lines >> (which might help guard against various problems), or single-ended WRT > some >> 'ground' that might actually be different on receiving and transmitting > ends? >> >> You should be able to control risetimes with a simple passive circuit. > While >> you haven't AFAICR said how long your line is, using differential > signalling >> would help deal with many potential problems. >> >> > The 3-phase motor windings are part of the circuit, in series with 10k feet > of the motor's power cable. The signal passes over the power cable. There > are other reactive components. It is not a simple things to terminate the > cable apparently. We do not know the type of motor that will be installed, > the type of cable, or the length of cable. It is not an option to use a > different type of cable to optimize communications. The primary purpose of > the cable is to power the motor.
General rule of thumb: if you can "optimise" do so, but if you can't then "randomise". Classic reasons you might not be able to optimise are that parameters are unknown and/or changing. Randomise, in this case, implies spread spectrum, either slow frequency hopping or, arguably more likely, direct sequence.
Hi,
the driver bandwidth is not the problem here, fortunately. Bandwidth is
largely a receiver design decision.
Try the CIC filter I lined out earlier. It's simple to implement and seems
like the most straightforward solution to limit the bandwidth. The
(digital) filter will simply reject high frequency components, which is
here as good as not creating them in the first place.
If., properly filtered, the ringing causes intolerable intersymbol
interference, an equalizer would seem the next logical step, as was
mentioned. From a practical perspective, this is quite a step up in
complexity, though.
On Wed, 13 Aug 2014 11:35:49 -0500, "BasicPoke" <101269@dsprelated>
wrote:
>>This "ringing" is at such a low frequency that I suspect that you have >some >>reactive elements other than just the connecting cable. Could the motor >>somehow be part of the circuit? Is your signaling over differential >lines >>(which might help guard against various problems), or single-ended WRT >some >>'ground' that might actually be different on receiving and transmitting >ends? >> >>You should be able to control risetimes with a simple passive circuit. >While >>you haven't AFAICR said how long your line is, using differential >signalling >>would help deal with many potential problems. >> >> >The 3-phase motor windings are part of the circuit, in series with 10k feet >of the motor's power cable. The signal passes over the power cable. There >are other reactive components. It is not a simple things to terminate the >cable apparently. We do not know the type of motor that will be installed, >the type of cable, or the length of cable. It is not an option to use a >different type of cable to optimize communications. The primary purpose of >the cable is to power the motor. > >I have used an active low pass filter, using an op amp, and got a much >cleaner signal, so I think that will have to be part of my solution. But >we have yet to see how this filter will work with the motor running, which >we will do today. This may be ugly. >Ron
If it were me, I'd find a way to characterise the channel with the motor off and with the motor running. You may be able to do this with your modulator, or with a sweep circuit or something substituted for the modulator. That will give you a much more full picture of what you're up against. Are you transmitting the signal at baseband? If so, and the reactance of the cable/motor circuit is distorting the signal, it may be possible to move the signal spectrum to a higher frequency and get a much cleaner channel. Again, this is the sort of thing you can discover with channel characterization. There may be a sweet spot within the frequency range of your hardware that could significantly improve the reliability of the link. The good news for you is that your signal spectrum is pretty narrow, so you don't need a very big chunk of clean spectrum. Characterizing the channel will also give you a good idea whether equalization will be needed and how much. Since your symbol rate is so low, I'm now a bit skeptical as to whether an equalizer would do you any good, but it is the sort of thing that becomes more clear once the channel characteristics are known. Also, characterizing the interference environment by turning the modulator off and just listening to the noise, with the motor on and off, will also help isolate portions of the available spectrum that may be happier than others. Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
On Wed, 13 Aug 2014 11:35:49 -0500, BasicPoke wrote:
>>This "ringing" is at such a low frequency that I suspect that you have > some >>reactive elements other than just the connecting cable. Could the motor >>somehow be part of the circuit? Is your signaling over differential > lines >>(which might help guard against various problems), or single-ended WRT > some >>'ground' that might actually be different on receiving and transmitting > ends? >> >>You should be able to control risetimes with a simple passive circuit. > While >>you haven't AFAICR said how long your line is, using differential > signalling >>would help deal with many potential problems. >> >> > The 3-phase motor windings are part of the circuit, in series with 10k > feet of the motor's power cable. The signal passes over the power > cable. There are other reactive components. It is not a simple things > to terminate the cable apparently. We do not know the type of motor > that will be installed, > the type of cable, or the length of cable. It is not an option to use a > different type of cable to optimize communications. The primary purpose > of the cable is to power the motor. > > I have used an active low pass filter, using an op amp, and got a much > cleaner signal, so I think that will have to be part of my solution. > But we have yet to see how this filter will work with the motor running, > which we will do today. This may be ugly. > Ron
You must be modulating the signal onto some sort of a carrier. I think we've all been assuming a separate pair of wires for the signal. Details, please, unless you have NDA constraints. Your problem just got hugely more complicated. On the bright side, as long as your carrier frequency is well above line frequency I suspect that the motor won't change the line characteristics whether it's running or not. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
BasicPoke wrote:
>[*SNIP*] >> >> > The 3-phase motor windings are part of the circuit, in series with 10k feet > of the motor's power cable. The signal passes over the power cable. There > are other reactive components. ...
You *HAVE* problems! You need someone competent dealing with low level signals in presence of interference orders of magnitude larger. I have experience as an engineering tech. I once was fired for refusing to pretend to be an engineer. [On a subsequent job I got a positive review for same stance ;] I'm past 3 score and 10, so I'm safe ;) See thread on "good questions".
On Wed, 13 Aug 2014 19:23:50 -0500, Richard Owlett wrote:
> BasicPoke wrote: >>[*SNIP*] >>> >>> >> The 3-phase motor windings are part of the circuit, in series with 10k >> feet of the motor's power cable. The signal passes over the power >> cable. There are other reactive components. ... > > You *HAVE* problems! > You need someone competent dealing with low level signals in presence of > interference orders of magnitude larger. > > I have experience as an engineering tech. > I once was fired for refusing to pretend to be an engineer. [On a > subsequent job I got a positive review for same stance ;] > I'm past 3 score and 10, so I'm safe ;) > > See thread on "good questions".
Line carrier communications have worked since the 1940's or earlier (apparently it's what some frustrated amateur radio operators did during WW-II -- there's a chapter on it in one of my wartime ARRL Handbooks). AFAIK it's mostly done by choosing a frequency that's high enough so that the line frequency stuff is easy to filter out, and low enough that it's not horribly attenuated by the wires. And then use a really high-power amp on the transmit side! -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
On Wed, 13 Aug 2014 19:58:02 -0500, Tim Wescott
<seemywebsite@myfooter.really> wrote:
>On Wed, 13 Aug 2014 19:23:50 -0500, Richard Owlett wrote: > >> BasicPoke wrote: >>>[*SNIP*] >>>> >>>> >>> The 3-phase motor windings are part of the circuit, in series with 10k >>> feet of the motor's power cable. The signal passes over the power >>> cable. There are other reactive components. ... >> >> You *HAVE* problems! >> You need someone competent dealing with low level signals in presence of >> interference orders of magnitude larger. >> >> I have experience as an engineering tech. >> I once was fired for refusing to pretend to be an engineer. [On a >> subsequent job I got a positive review for same stance ;] >> I'm past 3 score and 10, so I'm safe ;) >> >> See thread on "good questions". > >Line carrier communications have worked since the 1940's or earlier >(apparently it's what some frustrated amateur radio operators did during >WW-II -- there's a chapter on it in one of my wartime ARRL Handbooks). > >AFAIK it's mostly done by choosing a frequency that's high enough so that >the line frequency stuff is easy to filter out, and low enough that it's >not horribly attenuated by the wires. And then use a really high-power >amp on the transmit side!
I think he really needs to do a decent channel characterization. He has some advantages in that there should not be much rf interference other than what their own system is generating, and his carrier is very small spectrally. So the chances are reasonable that there is, or can be made to be, a suitable chunk of spectrum on the line within their usable system bandwidth so that the signal survives reliably. Don't know how much info he can share, but I'd be interested in more details about the architecture. Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
