Using an old TMS320 C6713 DSK which has two Ain and two A out. Works brilliantly but I am led to believe that it is a bit old. Is there a newer DSK - same spec ie floating point but faster? I know the TMS320C6713B is pin compatible but I am not going to swap them as their is no socket.
C6713
Started by ●August 14, 2014
Reply by ●August 14, 20142014-08-14
On 2014-08-14 22:44, gyansorova@gmail.com wrote:> Using an old TMS320 C6713 DSK which has two Ain and two A out. Works brilliantly but I am led to believe that it is a bit old. Is there a newer DSK - same spec ie floating point but faster? I know the TMS320C6713B is pin compatible but I am not going to swap them as their is no socket. >Did you check the TI web site? bye, -- piergiorgio
On Friday, August 15, 2014 8:59:44 AM UTC+12, Piergiorgio Sartor wrote:> On 2014-08-14 22:44, gyansorova@gmail.com wrote: > > > Using an old TMS320 C6713 DSK which has two Ain and two A out. Works brilliantly but I am led to believe that it is a bit old. Is there a newer DSK - same spec ie floating point but faster? I know the TMS320C6713B is pin compatible but I am not going to swap them as their is no socket. > > > > > > > Did you check the TI web site? > > > > bye, > > > > -- > > > > piergiorgioYes but there are so many...I wondered if there were people with experience of using some of the newer ones. Mind you even the old one is pretty darned good.
