Using Least Mean Squares equalizer
Started by rsashwinkumar ●August 15, 2014
Hi all,
I am new to signal processing; In my application, I need to use an adaptive
LMS equalizer.
I have some doubts regarding that.
I can model my scenario as a signal x[n] passing through a channel with a
transfer function H(z) and output Y(z)=H(z)X(z)+N(z), where N(z) is an
additive noise (which can be filtered). Now I need to design an equalizer
so that the effect of H(z) can be nullified and I expect an output
Y1(z)=X(z)+N1(z), where N1(z) is a noise which can be filtered. Is it
possible to design an adaptive equalizer that could do the above said
function?
Also, when I tried some basic MATLAB simulations for an LMS filter, if the
channel response I assume is an IIR response, the filter coefficients seem
to diverge even with a very small step size 0.0001and a very long training
period 2^15. So does adaptive equalization work only for FIR channel
respones?
_____________________________
On Saturday, August 16, 2014 7:55:42 AM UTC+12, rsashwinkumar wrote:
> Hi all, > > > > I am new to signal processing; In my application, I need to use an adaptive > > LMS equalizer. > > I have some doubts regarding that. > > > > I can model my scenario as a signal x[n] passing through a channel with a > > transfer function H(z) and output Y(z)=H(z)X(z)+N(z), where N(z) is an > > additive noise (which can be filtered). Now I need to design an equalizer > > so that the effect of H(z) can be nullified and I expect an output > > Y1(z)=X(z)+N1(z), where N1(z) is a noise which can be filtered. Is it > > possible to design an adaptive equalizer that could do the above said > > function? > > > > Also, when I tried some basic MATLAB simulations for an LMS filter, if the > > channel response I assume is an IIR response, the filter coefficients seem > > to diverge even with a very small step size 0.0001and a very long training > > period 2^15. So does adaptive equalization work only for FIR channel > > respones? > > > > > > > > _____________________________ > > Posted through www.DSPRelated.com
Ok just try it first on a known FIR system ex coefficients 1, -0.5 and see if it converges. Remember if you are equalizing that the inverse of the filter must be stable! So don't pick a non-min phase IIR filter or it won't work. There are way around this by introducing a delay in one of the paths but first things first.
Try a trivial channel, h = [1 0 0 0].';
Then play around with eq length and target delay. Then change the channel a bit to h = [1 0.2 0 0].';
So small steps, man.
On Saturday, August 16, 2014 11:49:14 AM UTC+12, julius wrote:
> Try a trivial channel, h = [1 0 0 0].'; > > Then play around with eq length and target delay. Then change the channel a bit to h = [1 0.2 0 0].'; > > > > So small steps, man.
The second example is unstable when inverted since its polynomial is z^2-2=0 or z=+/jsqrt(2).
Oh - sorry, didn't see the decimal point - thats z^2-0.2 ok
Hi,
it may be a good idea to look into John G. Proakis, "Digital
communications", chapter 11 "Adaptive equalization". The book is IMHO worth
buying as paper copy even in the electronic age.
As a rule of thumb, the equalizer is the inverse of the channel. An IIR
channel gives an FIR equalizer, because numerator becomes denominator and
vice versa.
For a first step, I'd build a non-adaptive equalizer. You can do this
quickly by putting delayed replicas of the received signal (corresponding
to the eq's FIR taps) into a matrix M as column vectors:
Then, solve least-squares against the training sequence b (also column
vector) for
[1]: M*c ~ b:
[2]: c = pinv(M)*b
c is then the vector of FIR filter coefficients. Plug it into [1]'s "M*c"
to apply it to the signal.
Use this as sanity check for delays and number of taps. It's pure
zero-forcing so it may misbehave for channel nulls. You can add or
concatenate a noise term to the signals, also to manage the equalizer's
unwanted out-of-channel gain boost.
On Saturday, August 16, 2014 6:23:18 PM UTC+12, mnentwig wrote:
> Hi, > > > > it may be a good idea to look into John G. Proakis, "Digital > > communications", chapter 11 "Adaptive equalization". The book is IMHO worth > > buying as paper copy even in the electronic age. > > > > As a rule of thumb, the equalizer is the inverse of the channel. An IIR > > channel gives an FIR equalizer, because numerator becomes denominator and > > vice versa. > > > > For a first step, I'd build a non-adaptive equalizer. You can do this > > quickly by putting delayed replicas of the received signal (corresponding > > to the eq's FIR taps) into a matrix M as column vectors: > > > > Then, solve least-squares against the training sequence b (also column > > vector) for > > > > [1]: M*c ~ b: > > > > [2]: c = pinv(M)*b > > > > c is then the vector of FIR filter coefficients. Plug it into [1]'s "M*c" > > to apply it to the signal. > > Use this as sanity check for delays and number of taps. It's pure > > zero-forcing so it may misbehave for channel nulls. You can add or > > concatenate a noise term to the signals, also to manage the equalizer's >
Easier way is to pick a first order example 1-0.5z^-1 It's inverse is a convergent series 1,0.5,0.25.0.125...etc
Thanks all!!
I found the mistake. The IIR response I assumed turned out to be
non-minimum phase.
On 8/18/14 8:15 AM, rsashwinkumar wrote:
> Thanks all!! > > I found the mistake. The IIR response I assumed turned out to be > non-minimum phase. >
i actually have to disagree with Hardy that LMS won't work to match a non-min phase system. it doesn't really matter. for example, LMS are used to do loudspeaker feedback cancellation for speaker phones. that ain't no minimum-phase system. i would suggest modifying it a little and use the Normalized LMS (NLMS) adaptive filter so that the neither the adaptation speed nor the step size are dependent on the loudness of the excitation signal. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
On Tuesday, August 19, 2014 6:24:43 AM UTC+12, robert bristow-johnson wrote:
> On 8/18/14 8:15 AM, rsashwinkumar wrote: > > > Thanks all!! > > > > > > I found the mistake. The IIR response I assumed turned out to be > > > non-minimum phase. > > > > > > > i actually have to disagree with Hardy that LMS won't work to match a > > non-min phase system. it doesn't really matter. > > > > for example, LMS are used to do loudspeaker feedback cancellation for > > speaker phones. that ain't no minimum-phase system. > > > > i would suggest modifying it a little and use the Normalized LMS (NLMS) > > adaptive filter so that the neither the adaptation speed nor the step > > size are dependent on the loudness of the excitation signal. > > > > > > -- > > > > r b-j rbj@audioimagination.com > > > > "Imagination is more important than knowledge."
It will only work if you introduce a time-delay in the primary path. What he is doing is inverting a transfer function which is impossible (divergent) if NMP. However, with a delay you are using the uncausal part going backwards in time (hard to explain with out maths) which is convergent. The delay makes it causal.
