Hello, I am trying to implement an FIR and an IIR filter in fixed point arithmetic. The actual filter is of no importance(so I have implemented the simplest filter possible),as long as it is in fixed point,and moreover as I can give as input the desirable precision. I wrote the following piece of code,but the results are totaly bogus.. Can anybody suggest some help?I dont know if I have to blame my programming skills(I am a total newbie in C) or the fixed point implementation scheme. I implement fixed point arithmetic by : 1.Multipying coefficients by 2^precision,findind the 2 least significant bits of the output,and my final result is the floor[(output/2^precision)+lsb's of output)] Thanks in advance Code follows : //Fixed Point FIR filter #include <stdio.h> #include <iostream.h> #include <math.h> #define SAMPLE double /* type used for data samples */ // Zero the delay line of the filter before beginning void clear(int ntaps,SAMPLE d[]) { int i; for(i=0;i<ntaps;i++){ d[i]=0; } } //FIR FILTER FUNCTION SAMPLE fir(int input,int ntaps,const SAMPLE c[],SAMPLE d[]) { int i=0; SAMPLE acc; //store input at the beginning of delay d[0]=input; //calculate filter acc=0; for (i=0;i<ntaps;i++){ acc+=c[i]*d[i]; } //shift delay for (i=ntaps-2;i>=0;i--){ d[i+1]=d[i]; } return acc; } int main(void) { #define ntaps 7 //#define precision 8 static SAMPLE c[ntaps]={-0.06453888262870, -0.04068941760916, 0.41809227322162, 0.78848561640558, 0.41809227322162, -0.04068941760916, -0.06453888262870}; SAMPLE true_c[ntaps]; static SAMPLE d[ntaps]; #define inp_size 3*ntaps static SAMPLE inp[inp_size]; SAMPLE output,output1; int precision; int lsb,temp_output; int bit_true_out; int i,j; FILE *fp; cout<<"Give precision of bit true operations:\n"; cin>>precision; //perform bit true operation on coefficient matrix for(j=0;j<ntaps;j++){ true_c[j]=pow(2,precision)*c[j]; } //create impulse input signal clear(inp_size,inp); inp[4]=1.0; inp[5]=1.0; inp[6]=1.0; //apply filter to inputs and print results to file res.txt fp=fopen("res.txt","a"); clear(ntaps,d); for (i=0;i<inp_size;i++){ output1=fir(inp[i],ntaps,c,d); output=fir(inp[i],ntaps,true_c,d); temp_output=output; lsb=3&temp_output; bit_true_out=floor((temp_output/pow(2,precision))+lsb); fprintf(fp,"---------------------------------------\n"); fprintf(fp,"Precision = %d \n",precision); fprintf(fp,"Normal Output\n"); fprintf(fp,"%3.4f",(double)output1); fprintf(fp,"\n"); fprintf(fp,"Temp_out=%d,lsb=%d\n",(int)temp_output,(int)lsb); fprintf(fp,"\nBit true output\n"); fprintf(fp,"%d",(int)bit_true_out); fprintf(fp,"\n"); fprintf(fp,"---------------------------------------\n"); } fclose(fp); }
Fixed Point issues
Started by ●July 22, 2003
Reply by ●July 22, 20032003-07-22
Reply by ●July 23, 20032003-07-23
Mike Rosing <rosing@neurophys.wisc.edu> wrote in message <snipped>> > I haven't looked at the code, but I think to implement fixed point > you should either stick with integer math or use a simple limit test. > After every computation, check if your double is > 1.0 or < 2^(-precision). > if > 1.0, set the result to .99999999.... (1.0-2^(-precision) actually) > and if < 2^(-precision) set the result to 0.0. That simulates saturation > and round off in a better way. > > Patience, persistence, truth, > Dr. mikeMike, Comments seem to imply only non-negative results. Seem to address saturation but not rounding except for the smallest numbers. Dirk Dirk A. Bell DSP Consultant
X, A couple of comments after a quick scan of your code. Your code assumes the filter is even symmetric. It is, but you need to realize that if you violate the assumption after you have fixed your code, then you will break your code again. What is 'lsb' supposed to be? The way you are using it makes no sense. Set to 0 for now, and figure out what it is supposed to do later. You are using small floats as inputs, scaling the filter coefficients to be ints, removing the filter scaling from the result (adding 'lsb' which you should not be doing the way you are doing) and taking the integer part. The outputs would be expected to be very small floats that when converted to integer are severely quantized (a few small integers). If you want to output int then scale the input floats up to a corresponding int range before you filter. Suggestion: Get this working for floating point computations. Then scale the inputs up to be large integers and verify still working. Then change the filter over from float to fixed and verify still working. Then quantize the output and verify you are getting what you expect. There are some other things to keep in mind when you start scaling things up for int computation like what range of numbers you can handle. Dirk Dirk A. Bell DSP Consultant xest@intracom.gr (Xefteris Stefanos) wrote in message news:<db79ad24.0307212243.67ad70d5@posting.google.com>...> Hello, > I am trying to implement an FIR and an IIR filter in fixed point > arithmetic. > The actual filter is of no importance(so I have implemented the > simplest filter possible),as long as it is in fixed point,and moreover > as I can give as input the desirable precision. > I wrote the following piece of code,but the results are totaly bogus.. > Can anybody suggest some help?I dont know if I have to blame my > programming skills(I am a total newbie in C) or the fixed point > implementation scheme. > I implement fixed point arithmetic by : 1.Multipying coefficients by > 2^precision,findind the 2 least significant bits of the output,and my > final result is the floor[(output/2^precision)+lsb's of output)] > Thanks in advance > > Code follows : > //Fixed Point FIR filter > #include <stdio.h> > #include <iostream.h> > #include <math.h> > > #define SAMPLE double /* type used for data samples */ > > // Zero the delay line of the filter before beginning > void clear(int ntaps,SAMPLE d[]) > { > int i; > for(i=0;i<ntaps;i++){ > d[i]=0; > } > > } > > //FIR FILTER FUNCTION > SAMPLE fir(int input,int ntaps,const SAMPLE c[],SAMPLE d[]) > { > int i=0; > SAMPLE acc; > //store input at the beginning of delay > > d[0]=input; > //calculate filter > acc=0; > for (i=0;i<ntaps;i++){ > acc+=c[i]*d[i]; > } > //shift delay > for (i=ntaps-2;i>=0;i--){ > d[i+1]=d[i]; > } > return acc; > } > > int main(void) > { > #define ntaps 7 > //#define precision 8 > static SAMPLE c[ntaps]={-0.06453888262870, -0.04068941760916, > 0.41809227322162, > 0.78848561640558, 0.41809227322162, -0.04068941760916, > -0.06453888262870}; > SAMPLE true_c[ntaps]; > static SAMPLE d[ntaps]; > #define inp_size 3*ntaps > static SAMPLE inp[inp_size]; > SAMPLE output,output1; > int precision; > int lsb,temp_output; > int bit_true_out; > int i,j; > FILE *fp; > > cout<<"Give precision of bit true operations:\n"; > cin>>precision; > > //perform bit true operation on coefficient matrix > for(j=0;j<ntaps;j++){ > true_c[j]=pow(2,precision)*c[j]; > } > > //create impulse input signal > > clear(inp_size,inp); > inp[4]=1.0; > inp[5]=1.0; > inp[6]=1.0; > > > //apply filter to inputs and print results to file res.txt > fp=fopen("res.txt","a"); > clear(ntaps,d); > for (i=0;i<inp_size;i++){ > output1=fir(inp[i],ntaps,c,d); > output=fir(inp[i],ntaps,true_c,d); > temp_output=output; > lsb=3&temp_output; > bit_true_out=floor((temp_output/pow(2,precision))+lsb); > fprintf(fp,"---------------------------------------\n"); > fprintf(fp,"Precision = %d \n",precision); > fprintf(fp,"Normal Output\n"); > fprintf(fp,"%3.4f",(double)output1); > fprintf(fp,"\n"); > fprintf(fp,"Temp_out=%d,lsb=%d\n",(int)temp_output,(int)lsb); > fprintf(fp,"\nBit true output\n"); > fprintf(fp,"%d",(int)bit_true_out); > fprintf(fp,"\n"); > fprintf(fp,"---------------------------------------\n"); > } > fclose(fp); > }
Reply by ●July 28, 20032003-07-28
Dear Dirk, My "scheme" for the fixed point implementation is this : a.Multiply filter coefficients with 2^precision b.Multiply inputs with 2^additional bits c.Convolution d.Divide output with 2^precision e.Mask the result with 3,to find the two least significant bits(lsb) of it (is this where I made the mistake???and how should I do it??) f.The fixed point output is the floor[output/2^add_bits + lsb] Where is the mistake in this??I read this fixed point implementation in the following paper : "A VLSI architecture for Lifting-Based Forward and Inverse Wavelet Transform ",by Andra,Chakrabarti,Acharya-IEEE Transactions on Signal Processing,Vol 50. N 4,April 2002..The ultimate goal is to implement fixed point wavelet transforms sometime... thanks in advance Stefanos Ksefteris
