I am trying to figure out interpolation (I have given up on decimation for now). My scenario is that I have 8 ksamples per second audio (from a phone line), and I want to interpolate it to 96 ksamples per second. I know my audio is band limited within 0-4kHz, but other than that it could be anything -- human voice, modem tones, etc. I understand the most basic concepts. I could use linear interpolation, where I connect the 8kHz dots with lines and then add 11 evenly spaced dots along these lines. I suppose I could do this and then run the result through a LPF filter and it would improve it. But I suspect these methods are hardly state of the art. I've also read that FIR filters can be created to directly interpolate a signal, and there are other methods that I see mentioned but never described. My question is really whether there exists a good "interpolation for dummies" reference that describes the processes at a high level. I am hoping that such a tutorial could give me some leads on what I really need to be learning to try and understand it (to some degree).
Interpolation for Dummies
Started by ●July 18, 2003
Reply by ●July 18, 20032003-07-18
Ian McBride wrote:> I am trying to figure out interpolation (I have given up on decimation for > now). > > My scenario is that I have 8 ksamples per second audio (from a phone line), > and I want to interpolate it to 96 ksamples per second. I know my audio is > band limited within 0-4kHz, but other than that it could be anything -- > human voice, modem tones, etc. > > I understand the most basic concepts. I could use linear interpolation, > where I connect the 8kHz dots with lines and then add 11 evenly spaced dots > along these lines. I suppose I could do this and then run the result > through a LPF filter and it would improve it. But I suspect these methods > are hardly state of the art. > > I've also read that FIR filters can be created to directly interpolate a > signal, and there are other methods that I see mentioned but never > described. > > My question is really whether there exists a good "interpolation for > dummies" reference that describes the processes at a high level. I am > hoping that such a tutorial could give me some leads on what I really need > to be learning to try and understand it (to some degree).Ian: The dspGuru site at "http://www.dspguru.com/sw/opendsp/alglib.htm" is a great start. They have C-code that performs interpolation/decimation using a FIR filter. I'm using their code and it performs as advertised. This site has some nice comparisons between methods: "http://leute.server.de/wilde/resample.html#RandomNoiseUp". Another good site with lots of detail : "http://ccrma-www.stanford.edu/~jos/Interpolation/Welcome.html". Finally, in general, there are several books available that address "multirate" digital signal processing. Good luck, OUP
Ian McBride wrote:> > My question is really whether there exists a good "interpolation for > dummies" reference that describes the processes at a high level. I am > hoping that such a tutorial could give me some leads on what I really need > to be learning to try and understand it (to some degree).This might help: http://www.dspguru.com/info/faqs/mrfaq.htm -- Jim Thomas Principal Applications Engineer Bittware, Inc jthomas@bittware.com http://www.bittware.com (703) 779-7770 In theory, theory and practice are the same, but in practice, they're not
On Fri, 18 Jul 2003 08:09:16 -0400, "Ian McBride" <ianmcbride2003@yahoo.com> wrote: Hello Ian,>I am trying to figure out interpolation (I have given up on decimation for >now).Humm, I've always found decimation easier to understand than interpolation. Anyway ...>My scenario is that I have 8 ksamples per second audio (from a phone line), >and I want to interpolate it to 96 ksamples per second. I know my audio is >band limited within 0-4kHz, but other than that it could be anything -- >human voice, modem tones, etc. > >I understand the most basic concepts. I could use linear interpolation, >where I connect the 8kHz dots with lines and then add 11 evenly spaced dots >along these lines. I suppose I could do this and then run the result >through a LPF filter and it would improve it. But I suspect these methods >are hardly state of the art.Well, the most common method of interpolation is to stuff the 11 zeros in between your original samples and then lowpass filter the new sequence. (As far as I know, there's no benefit in performing the 'linear interpolation' of putting the 11 dots on a straight line.) There's away to perform accurate interpolation using the FFT, if you're interested, but the above zero-stuffing and lowpass filtering is the most common method.>I've also read that FIR filters can be created to directly interpolate a >signal, and there are other methods that I see mentioned but never >described.Humm. Am not sure exactly what you mean, but almost every DSP textbook discusses interpolation. It's not a terribly difficult subject. You'll figure it out.>My question is really whether there exists a good "interpolation for >dummies" reference that describes the processes at a high level. I am >hoping that such a tutorial could give me some leads on what I really need >to be learning to try and understand it (to some degree). >I noticed that Smith's DSP book (on the web at www.dspguide.com) doesn't discuss interpolation to the depth you're seeking. So you'll have to get a textbook, or search the web. (Ya might seach on "interpolation tutorial'.) Good Luck, [-Rick-]
Reply by ●July 19, 20032003-07-19
"Jim Thomas" <jthomas@bittware.com> wrote in message news:3F1800AA.C0893999@bittware.com...> > This might help: > http://www.dspguru.com/info/faqs/mrfaq.htmGreat! Just shove zeros in there and run it through an FIR.. ..WOW.. OK. Another question. Lets say I have FSK data at 1200 bits per second. I translate 0's to -5000Hz and 1's to +5000Hz and compose a "baseband" of 1 sample per bit. Can I zero stuff this with 79 zeroes, run it through an FIR filter to get my filtered FSK baseband? This seems confusing. I'm surprised that all of those zeroes wouldn't give you DC output with minor "bumps" showing up 1200 times a second. Thanks!> > -- > Jim Thomas Principal Applications Engineer Bittware, Inc > jthomas@bittware.com http://www.bittware.com (703) 779-7770 > In theory, theory and practice are the same, but in practice, they're > not
"Ian McBride" <ianmcbride2003@yahoo.com> wrote in message news:bfagg9$1sv$1@slb3.atl.mindspring.net...> "Jim Thomas" <jthomas@bittware.com> wrote in message > news:3F1800AA.C0893999@bittware.com... > > > > This might help: > > http://www.dspguru.com/info/faqs/mrfaq.htm > > Great! Just shove zeros in there and run it through an FIR.. ..WOW.. > > OK. Another question. Lets say I have FSK data at 1200 bits per second.I> translate 0's to -5000Hz and 1's to +5000Hz and compose a "baseband" of 1 > sample per bit. Can I zero stuff this with 79 zeroes, run it through anFIR> filter to get my filtered FSK baseband? This seems confusing. I'm > surprised that all of those zeroes wouldn't give you DC output with minor > "bumps" showing up 1200 times a second. >Let's see if I understand: FSK +/-5,000Hz Modulation of one bit per symbol: 0=-5,000Hz, 1=+5,000Hz Bit/symbol rate of 1200 bits per second You didn't say what the carrier frequency is. You didn't say what the sample rate is. I guess you consider the FSK baseband to be -1="0" and +1="1", something like that? Assign a carrier frequency of 50,000Hz. Then the data has this as a center frequency and the bandwidth will be something greater than 10kHz. It appears what you would want to do is decimate, not interpolate and in the process you would need to demodulate - which might be part of decimation. I think there's a nonlinear process needed here. Fred
Reply by ●July 21, 20032003-07-21
"Rick Lyons" <ricklyon@REMOVE.onemain.com> wrote in message news:3f1804b6.17234828@news.earthlink.net...> On Fri, 18 Jul 2003 08:09:16 -0400, "Ian McBride" > <ianmcbride2003@yahoo.com> wrote: > > Hello Ian, > > >I am trying to figure out interpolation (I have given up on decimationfor> >now). > > Humm, I've always found decimation easier to understand than > interpolation. Anyway ... > > >My scenario is that I have 8 ksamples per second audio (from a phoneline),> >and I want to interpolate it to 96 ksamples per second. I know my audiois> >band limited within 0-4kHz, but other than that it could be anything -- > >human voice, modem tones, etc. > > > >I understand the most basic concepts. I could use linear interpolation, > >where I connect the 8kHz dots with lines and then add 11 evenly spaceddots> >along these lines. I suppose I could do this and then run the result > >through a LPF filter and it would improve it. But I suspect thesemethods> >are hardly state of the art. > > Well, the most common method of interpolation is to > stuff the 11 zeros in between your original samples > and then lowpass filter the new sequence. (As far as I know, > there's no benefit in performing the 'linear interpolation' > of putting the 11 dots on a straight line.)In fact, "connecting the dots" is usually a "bad idea" for two reasons: 1) If the in-between data is all zeros, the FIR filter can be optimized to execute _much_ faster. The zero valued samples can simply be skipped since they contribute nothing to the result. 2) Linear interpolation is a low-pass filtering operation, and not a very good one at that. It introduces some roll-off in the pass-band which is a problem in some applications. True, it does give you some additional stop-band attenuation, but you are almost always better off to skip the linear interpolation and use the time saved to do a better (longer) single FIR.
Reply by ●July 22, 20032003-07-22
On Mon, 21 Jul 2003 12:24:50 -0700, "Jon Harris" <jon_harrisTIGER@hotmail.com> wrote: (snipped)>> >> Well, the most common method of interpolation is to >> stuff the 11 zeros in between your original samples >> and then lowpass filter the new sequence. (As far as I know, >> there's no benefit in performing the 'linear interpolation' >> of putting the 11 dots on a straight line.) > >In fact, "connecting the dots" is usually a "bad idea" for two reasons: > >1) If the in-between data is all zeros, the FIR filter can be optimized to >execute _much_ faster. The zero valued samples can simply be skipped since >they contribute nothing to the result.Hi Jon, VERY GOOD POINT !!! [-Rick-]>
"Rick Lyons" <ricklyon@REMOVE.onemain.com> wrote in message news:3f1d70f5.21806828@news.earthlink.net...> On Mon, 21 Jul 2003 12:24:50 -0700, "Jon Harris" > <jon_harrisTIGER@hotmail.com> wrote: > > (snipped) > >> > >> Well, the most common method of interpolation is to > >> stuff the 11 zeros in between your original samples > >> and then lowpass filter the new sequence. (As far as I know, > >> there's no benefit in performing the 'linear interpolation' > >> of putting the 11 dots on a straight line.) > > > >In fact, "connecting the dots" is usually a "bad idea" for two reasons: > > > >1) If the in-between data is all zeros, the FIR filter can be optimizedto> >execute _much_ faster. The zero valued samples can simply be skippedsince> >they contribute nothing to the result. > > Hi Jon, > > > VERY GOOD POINT !!! > > > [-Rick-]This is just another way of saying what a time-domain "polyphse" filter is doing, right? I thought your book made it much clearer than most Rick. Fred
"Fred Marshall" <fmarshallx@remove_the_x.acm.org> wrote in message news:YOeTa.3375$Jk5.2341110@feed2.centurytel.net...> > "Rick Lyons" <ricklyon@REMOVE.onemain.com> wrote in message > news:3f1d70f5.21806828@news.earthlink.net... > > On Mon, 21 Jul 2003 12:24:50 -0700, "Jon Harris" > > <jon_harrisTIGER@hotmail.com> wrote: > > > > (snipped) > > >> > > >> Well, the most common method of interpolation is to > > >> stuff the 11 zeros in between your original samples > > >> and then lowpass filter the new sequence. (As far as I know, > > >> there's no benefit in performing the 'linear interpolation' > > >> of putting the 11 dots on a straight line.) > > > > > >In fact, "connecting the dots" is usually a "bad idea" for two reasons: > > > > > >1) If the in-between data is all zeros, the FIR filter can be optimized > to > > >execute _much_ faster. The zero valued samples can simply be skipped > since > > >they contribute nothing to the result. > > > > Hi Jon, > > > > > > VERY GOOD POINT !!! > > > > > > [-Rick-] > > This is just another way of saying what a time-domain "polyphse" filter is > doing, right? > I thought your book made it much clearer than most Rick. > > FredYes. In my way of looking at things, the polyphase filter thing is just a mathematical formalization of some simple optimizations that would be pretty obvious to most people if when implementing interpolation.
