Hi guys, Can anyone point me to a paper/book describing the analysis of the discrete time PLL? All I could find are books describing the nonlinear analysis of the continuous time PLL -- an analysis that is based on nonlinear differential equations. A discrete time analysis avoids the difficulty of continuous time white noise, etc. This is all for analysing the mean time between phase slips of a decision directed carrier recovery loop. Thanks, Nimrod.
Discrete time PLL - mean time between slips
Started by ●July 16, 2003
Reply by ●July 18, 20032003-07-18
Floyd Gardner's PLL book is one of the best, but I'm not positive that it has probability of slip analysis. I think it does, but you might want to confirm first. Blanchard's book is also good, and likely to have cycle slip analysis. Both are primarily continuous-time analyses but the analyses hold (for the most part, at least the techniques hold) for equivalent discrete-time loop architectures. I've always used step-invariant bilinear transforms to take the continuous time analyses to discrete-time with very good results. Other techniques seem to work as well, as long as one is consistent with the analysis and careful about assumptions. Hope that helps a little bit. Cheers, Eric On 16 Jul 2003 07:05:18 -0700, nimrodm@yahoo.com (Nimrod Mesika) wrote:>Hi guys, > >Can anyone point me to a paper/book describing the analysis of the >discrete time PLL? > >All I could find are books describing the nonlinear analysis of the >continuous time PLL -- an analysis that is based on nonlinear >differential equations. > >A discrete time analysis avoids the difficulty of continuous time >white noise, etc. > >This is all for analysing the mean time between phase slips of a >decision directed carrier recovery loop. > >Thanks, >Nimrod.Eric Jacobsen Minister of Algorithms, Intel Corp. My opinions may not be Intel's opinions. http://www.ericjacobsen.org
