Hi, The following link shows the ADC values of 1024 samples of a waveform and 512 bins of the corresponding FFT. http://pho.to/7ofZe This represents a rather week input signal of aprox. 11.7mv p-p obtained by placing the accelerometer near a speaker emitting a 121Hz tone. While there is a small amount of noise present occasionally there is a larger spike that appears for only one sample. This spike causes an equal amount energy to be distributed across the entire spectrum as expected. Essentially this lifts the baseline of the FFT from near zero to a value proportional to the amplitude of the spike. Is there a standard method of detecting this and compensating for it? I am considering taking an average across the spectrum to find the baseline and then subtract this value from the magnitude of the peaks I am interested in. Another question, I have two identical channels being sampled simultaneously and I need to calculate the FFT of both. If I recall correctly I can calculate two 1024 pt FFTs simultaneously by using a 2048 pt FFT and loading the even samples from one channel and the odd samples from the second channel. In the resulting FFT the even bins will hold the result for one channel and the odd bins the second channel. Is this correct? Thanks again for all your help. Rob _____________________________ Posted through www.DSPRelated.com
Dual FFT
Started by ●November 7, 2014
Reply by ●November 7, 20142014-11-07
On Fri, 07 Nov 2014 13:29:08 -0600, Robd wrote:> Hi, > > The following link shows the ADC values of 1024 samples of a waveform > and 512 bins of the corresponding FFT. > > http://pho.to/7ofZe > > This represents a rather week input signal of aprox. 11.7mv p-p obtained > by placing the accelerometer near a speaker emitting a 121Hz tone. While > there is a small amount of noise present occasionally there is a larger > spike that appears for only one sample. This spike causes an equal > amount energy to be distributed across the entire spectrum as expected. > Essentially this lifts the baseline of the FFT from near zero to a value > proportional to the amplitude of the spike. Is there a standard method > of detecting this and compensating for it? I am considering taking an > average across the spectrum to find the baseline and then subtract this > value from the magnitude of the peaks I am interested in.I don't see the spike in your picture. Time domain problems should be dealt with in the time domain, not after you get things into the frequency domain. If you can reliably detect such spikes, then deal with them in your data. Better yet, fix your measuring system so that you don't get spurious spikes!> Another question, I have two identical channels being sampled > simultaneously and I need to calculate the FFT of both. If I recall > correctly I can calculate two 1024 pt FFTs simultaneously by using a > 2048 pt FFT and loading the even samples from one channel and the odd > samples from the second channel. In the resulting FFT the even bins will > hold the result for one channel and the odd bins the second channel. Is > this correct?That doesn't sound right at all. Why confuse things? Just do two FFTs. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
>On Fri, 07 Nov 2014 13:29:08 -0600, Robd wrote: > >> Hi, >> >> The following link shows the ADC values of 1024 samples of a waveform >> and 512 bins of the corresponding FFT. >> >> http://pho.to/7ofZe >> >> This represents a rather week input signal of aprox. 11.7mv p-pobtained>> by placing the accelerometer near a speaker emitting a 121Hz tone.While>> there is a small amount of noise present occasionally there is a larger >> spike that appears for only one sample. This spike causes an equal >> amount energy to be distributed across the entire spectrum as expected. >> Essentially this lifts the baseline of the FFT from near zero to avalue>> proportional to the amplitude of the spike. Is there a standard method >> of detecting this and compensating for it? I am considering taking an >> average across the spectrum to find the baseline and then subtract this >> value from the magnitude of the peaks I am interested in. > >I don't see the spike in your picture. Time domain problems should be >dealt with in the time domain, not after you get things into the frequency>domain. If you can reliably detect such spikes, then deal with them in >your data. > >Better yet, fix your measuring system so that you don't get spurious >spikes! > >> Another question, I have two identical channels being sampled >> simultaneously and I need to calculate the FFT of both. If I recall >> correctly I can calculate two 1024 pt FFTs simultaneously by using a >> 2048 pt FFT and loading the even samples from one channel and the odd >> samples from the second channel. In the resulting FFT the even binswill>> hold the result for one channel and the odd bins the second channel. Is >> this correct? > >That doesn't sound right at all. Why confuse things? Just do two FFTs. > >-- > >Tim Wescott >Wescott Design Services >http://www.wescottdesign.com >Hi Tim, No, the image I posted was a "clean" one. I can also post one with noise if anyone is interested. Of course I am working on determining the source of this noise (spike) and eliminate it. I have removed the accelerometer and grounded the input and the noise is still present so it appears to be being coupled into the analogue signal after the filtering. It would seem to be external noise entering through the power lines. I plan to try adding a ferrite core to my DC power lines. Internally all my voltages are supplied from switching regulators which appear to be clean. As for the dual FFT, I remember reading something similar in the past and have been trying to find it again. From what I have found so far I understand that the samples from one channel are loaded into the real part and the second channel into the imaginary part. The two results are then extracted from the resulting FFT. The FFT is still only 1024 and not 2048. I am still reading. Rob _____________________________ Posted through www.DSPRelated.com
On 11/7/2014 2:29 PM, Robd wrote:> Hi, > > The following link shows the ADC values of 1024 samples of a waveform and > 512 bins of the corresponding FFT. > > http://pho.to/7ofZe > > This represents a rather week input signal of aprox. 11.7mv p-p obtained by > placing the accelerometer near a speaker emitting a 121Hz tone. While there > is a small amount of noise present occasionally there is a larger spike > that appears for only one sample. This spike causes an equal amount energy > to be distributed across the entire spectrum as expected. Essentially this > lifts the baseline of the FFT from near zero to a value proportional to the > amplitude of the spike. Is there a standard method of detecting this and > compensating for it? I am considering taking an average across the spectrum > to find the baseline and then subtract this value from the magnitude of the > peaks I am interested in. > > Another question, I have two identical channels being sampled > simultaneously and I need to calculate the FFT of both. If I recall > correctly I can calculate two 1024 pt FFTs simultaneously by using a 2048 > pt FFT and loading the even samples from one channel and the odd samples > from the second channel. In the resulting FFT the even bins will hold the > result for one channel and the odd bins the second channel. Is this > correct?I'm not sure you are describing it correctly, but yes, there is a way to save computations when performing FFTs on real data. What I have seen wraps the real data into half as many points of complex data. In the end you perform one less passes using half as many points, then follow it up with a final pass to correctly produce the final result. I'm pretty sure this does not use "odd" and "even" data samples in the sense you are referring to. Odd and even pertain to symmetry properties of the FFT which I believe this process is making use of in the final pass. It has been too long since I did this sort of work to remember the details. If you search on "real FFT" I expect you can find all sorts of references. Unfortunately most of them will be rather theoretical rather than a simple explanation of what you need to do. I will say that I'm pretty sure Tim is right. Your savings in computation will come from the fact that your data is real and not complex. Rather than combining the data into one FFT, I expect you will find more info on how to do a half size FFT to process your real data and you can then just do two of them. But I could be wrong. There may very well be an equivalent way to process two independent real data sets in a single FFT by taking advantage of the odd and even symmetries of the FFT. -- Rick
Your dB scale must be wrong, there's no way a speaker plus accelerometer will give you 170dB distortion. Bob
On 11/7/2014 3:12 PM, Robd wrote:> > As for the dual FFT, I remember reading something similar in the past and > have been trying to find it again. From what I have found so far I > understand that the samples from one channel are loaded into the real part > and the second channel into the imaginary part. The two results are then > extracted from the resulting FFT. The FFT is still only 1024 and not 2048. > I am still reading.That sounds like what I remember. I don't remember for sure, but there is a way to separate the data from the imaginary and the real components. A spectrum from all real data is symmetrical about the Nyquist frequency. I want to say the real input data produces even symmetry in the spectrum and the imaginary input data produces odd symmetry. So to recover the spectrum from the real part of the data you add the two halves of the spectrum. To get the spectrum from the imaginary portion the two halves of the spectrum are added. Please don't take this as accurate. It was some 15 years ago I worked with FFTs. -- Rick
On Fri, 07 Nov 2014 14:12:58 -0600, Robd wrote:>>On Fri, 07 Nov 2014 13:29:08 -0600, Robd wrote: >> >>> Hi, >>> >>> The following link shows the ADC values of 1024 samples of a waveform >>> and 512 bins of the corresponding FFT. >>> >>> http://pho.to/7ofZe >>> >>> This represents a rather week input signal of aprox. 11.7mv p-p > obtained >>> by placing the accelerometer near a speaker emitting a 121Hz tone. > While >>> there is a small amount of noise present occasionally there is a >>> larger spike that appears for only one sample. This spike causes an >>> equal amount energy to be distributed across the entire spectrum as >>> expected. >>> Essentially this lifts the baseline of the FFT from near zero to a > value >>> proportional to the amplitude of the spike. Is there a standard method >>> of detecting this and compensating for it? I am considering taking an >>> average across the spectrum to find the baseline and then subtract >>> this value from the magnitude of the peaks I am interested in. >> >>I don't see the spike in your picture. Time domain problems should be >>dealt with in the time domain, not after you get things into the >>frequency > >>domain. If you can reliably detect such spikes, then deal with them in >>your data. >> >>Better yet, fix your measuring system so that you don't get spurious >>spikes! >> >>> Another question, I have two identical channels being sampled >>> simultaneously and I need to calculate the FFT of both. If I recall >>> correctly I can calculate two 1024 pt FFTs simultaneously by using a >>> 2048 pt FFT and loading the even samples from one channel and the odd >>> samples from the second channel. In the resulting FFT the even bins > will >>> hold the result for one channel and the odd bins the second channel. >>> Is this correct? >> >>That doesn't sound right at all. Why confuse things? Just do two FFTs. >> >>-- >> >>Tim Wescott Wescott Design Services http://www.wescottdesign.com >> >> > Hi Tim, > > No, the image I posted was a "clean" one. I can also post one with noise > if anyone is interested. Of course I am working on determining the > source of this noise (spike) and eliminate it. I have removed the > accelerometer and grounded the input and the noise is still present so > it appears to be being coupled into the analogue signal after the > filtering. It would seem to be external noise entering through the power > lines. I plan to try adding a ferrite core to my DC power lines. > Internally all my voltages are supplied from switching regulators which > appear to be clean. > > As for the dual FFT, I remember reading something similar in the past > and have been trying to find it again. From what I have found so far I > understand that the samples from one channel are loaded into the real > part and the second channel into the imaginary part. The two results are > then extracted from the resulting FFT. The FFT is still only 1024 and > not 2048. I am still reading.That you can do. You utilize the fact that when you take the FFT of all- real data, the result is a function whose real part is even around zero, and whose imaginary part is odd around zero. By superposition, if you take the FFT of all imaginary data, the even-ness and odd-ness are reversed. It's conceptually pretty easy to extract an even and an odd part from an arbitrary function, although you end up doing more math. All of this is in pursuit of a small reduction in execution time, which can be gotten far more easily by using an FFT routine that's optimized to work on all-real data, calling it twice with the different data, and then not having to do the math on the results. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
On Friday, November 7, 2014 6:15:33 PM UTC-5, Tim Wescott wrote:> On Fri, 07 Nov 2014 14:12:58 -0600, Robd wrote: > > >>On Fri, 07 Nov 2014 13:29:08 -0600, Robd wrote: > >> > >>> Hi, > >>> > >>> The following link shows the ADC values of 1024 samples of a waveform > >>> and 512 bins of the corresponding FFT. > >>> > >>> http://pho.to/7ofZe > >>> > >>> This represents a rather week input signal of aprox. 11.7mv p-p > > obtained > >>> by placing the accelerometer near a speaker emitting a 121Hz tone. > > While > >>> there is a small amount of noise present occasionally there is a > >>> larger spike that appears for only one sample. This spike causes an > >>> equal amount energy to be distributed across the entire spectrum as > >>> expected. > >>> Essentially this lifts the baseline of the FFT from near zero to a > > value > >>> proportional to the amplitude of the spike. Is there a standard method > >>> of detecting this and compensating for it? I am considering taking an > >>> average across the spectrum to find the baseline and then subtract > >>> this value from the magnitude of the peaks I am interested in. > >> > >>I don't see the spike in your picture. Time domain problems should be > >>dealt with in the time domain, not after you get things into the > >>frequency > > > >>domain. If you can reliably detect such spikes, then deal with them in > >>your data. > >> > >>Better yet, fix your measuring system so that you don't get spurious > >>spikes! > >> > >>> Another question, I have two identical channels being sampled > >>> simultaneously and I need to calculate the FFT of both. If I recall > >>> correctly I can calculate two 1024 pt FFTs simultaneously by using a > >>> 2048 pt FFT and loading the even samples from one channel and the odd > >>> samples from the second channel. In the resulting FFT the even bins > > will > >>> hold the result for one channel and the odd bins the second channel. > >>> Is this correct? > >> > >>That doesn't sound right at all. Why confuse things? Just do two FFTs. > >> > >>-- > >> > >>Tim Wescott Wescott Design Services http://www.wescottdesign.com > >> > >> > > Hi Tim, > > > > No, the image I posted was a "clean" one. I can also post one with noise > > if anyone is interested. Of course I am working on determining the > > source of this noise (spike) and eliminate it. I have removed the > > accelerometer and grounded the input and the noise is still present so > > it appears to be being coupled into the analogue signal after the > > filtering. It would seem to be external noise entering through the power > > lines. I plan to try adding a ferrite core to my DC power lines. > > Internally all my voltages are supplied from switching regulators which > > appear to be clean. > > > > As for the dual FFT, I remember reading something similar in the past > > and have been trying to find it again. From what I have found so far I > > understand that the samples from one channel are loaded into the real > > part and the second channel into the imaginary part. The two results are > > then extracted from the resulting FFT. The FFT is still only 1024 and > > not 2048. I am still reading. > > That you can do. You utilize the fact that when you take the FFT of all- > real data, the result is a function whose real part is even around zero, > and whose imaginary part is odd around zero. By superposition, if you > take the FFT of all imaginary data, the even-ness and odd-ness are > reversed. > > It's conceptually pretty easy to extract an even and an odd part from an > arbitrary function, although you end up doing more math. > > All of this is in pursuit of a small reduction in execution time, which > can be gotten far more easily by using an FFT routine that's optimized to > work on all-real data, calling it twice with the different data, and then > not having to do the math on the results. > > -- > > Tim Wescott > Wescott Design Services > http://www.wescottdesign.comYes, you can transform two real valued sequences by using one complex-in/out FFT: http://fftguru.com/fftguru.com.tutorial2.pdf The first technique desribed above is the one you want. You end up doing one N size complex-in/out FFT plus some bookkeeping instead of two N size complex-in/out FFTs (and no bookkeeping). But if you have an FFT optimized for real-only inputs, you may (or may not) be better off doing two N size real-in/complex out FFTs - it all depends on the relative efficiency of the programs. Kevin McGee
On Friday, November 7, 2014 1:29:12 PM UTC-6, Robd wrote:> Hi, > > The following link shows the ADC values of 1024 samples of a waveform and > 512 bins of the corresponding FFT. > > http://pho.to/7ofZe > > This represents a rather week input signal of aprox. 11.7mv p-p obtained by > placing the accelerometer near a speaker emitting a 121Hz tone. While there > is a small amount of noise present occasionally there is a larger spike > that appears for only one sample. This spike causes an equal amount energy > to be distributed across the entire spectrum as expected. Essentially this > lifts the baseline of the FFT from near zero to a value proportional to the > amplitude of the spike. Is there a standard method of detecting this and > compensating for it? I am considering taking an average across the spectrum > to find the baseline and then subtract this value from the magnitude of the > peaks I am interested in. > > Another question, I have two identical channels being sampled > simultaneously and I need to calculate the FFT of both. If I recall > correctly I can calculate two 1024 pt FFTs simultaneously by using a 2048 > pt FFT and loading the even samples from one channel and the odd samples > from the second channel. In the resulting FFT the even bins will hold the > result for one channel and the odd bins the second channel. Is this > correct? > > Thanks again for all your help. > Rob > > > > _____________________________ > Posted through www.DSPRelated.comLook into the median filter. If the spike is only one sample wide, then a 5-element median filter will eliminate it.
On 11/7/2014 7:04 PM, kevinjmcee wrote:> On Friday, November 7, 2014 6:15:33 PM UTC-5, Tim Wescott wrote: >> On Fri, 07 Nov 2014 14:12:58 -0600, Robd wrote: >> >>>> On Fri, 07 Nov 2014 13:29:08 -0600, Robd wrote: >>>> >>>>> Hi, >>>>> >>>>> The following link shows the ADC values of 1024 samples of a waveform >>>>> and 512 bins of the corresponding FFT. >>>>> >>>>> http://pho.to/7ofZe >>>>> >>>>> This represents a rather week input signal of aprox. 11.7mv p-p >>> obtained >>>>> by placing the accelerometer near a speaker emitting a 121Hz tone. >>> While >>>>> there is a small amount of noise present occasionally there is a >>>>> larger spike that appears for only one sample. This spike causes an >>>>> equal amount energy to be distributed across the entire spectrum as >>>>> expected. >>>>> Essentially this lifts the baseline of the FFT from near zero to a >>> value >>>>> proportional to the amplitude of the spike. Is there a standard method >>>>> of detecting this and compensating for it? I am considering taking an >>>>> average across the spectrum to find the baseline and then subtract >>>>> this value from the magnitude of the peaks I am interested in. >>>> >>>> I don't see the spike in your picture. Time domain problems should be >>>> dealt with in the time domain, not after you get things into the >>>> frequency >>> >>>> domain. If you can reliably detect such spikes, then deal with them in >>>> your data. >>>> >>>> Better yet, fix your measuring system so that you don't get spurious >>>> spikes! >>>> >>>>> Another question, I have two identical channels being sampled >>>>> simultaneously and I need to calculate the FFT of both. If I recall >>>>> correctly I can calculate two 1024 pt FFTs simultaneously by using a >>>>> 2048 pt FFT and loading the even samples from one channel and the odd >>>>> samples from the second channel. In the resulting FFT the even bins >>> will >>>>> hold the result for one channel and the odd bins the second channel. >>>>> Is this correct? >>>> >>>> That doesn't sound right at all. Why confuse things? Just do two FFTs. >>>> >>>> -- >>>> >>>> Tim Wescott Wescott Design Services http://www.wescottdesign.com >>>> >>>> >>> Hi Tim, >>> >>> No, the image I posted was a "clean" one. I can also post one with noise >>> if anyone is interested. Of course I am working on determining the >>> source of this noise (spike) and eliminate it. I have removed the >>> accelerometer and grounded the input and the noise is still present so >>> it appears to be being coupled into the analogue signal after the >>> filtering. It would seem to be external noise entering through the power >>> lines. I plan to try adding a ferrite core to my DC power lines. >>> Internally all my voltages are supplied from switching regulators which >>> appear to be clean. >>> >>> As for the dual FFT, I remember reading something similar in the past >>> and have been trying to find it again. From what I have found so far I >>> understand that the samples from one channel are loaded into the real >>> part and the second channel into the imaginary part. The two results are >>> then extracted from the resulting FFT. The FFT is still only 1024 and >>> not 2048. I am still reading. >> >> That you can do. You utilize the fact that when you take the FFT of all- >> real data, the result is a function whose real part is even around zero, >> and whose imaginary part is odd around zero. By superposition, if you >> take the FFT of all imaginary data, the even-ness and odd-ness are >> reversed. >> >> It's conceptually pretty easy to extract an even and an odd part from an >> arbitrary function, although you end up doing more math. >> >> All of this is in pursuit of a small reduction in execution time, which >> can be gotten far more easily by using an FFT routine that's optimized to >> work on all-real data, calling it twice with the different data, and then >> not having to do the math on the results. >> >> -- >> >> Tim Wescott >> Wescott Design Services >> http://www.wescottdesign.com > > Yes, you can transform two real valued sequences by using one complex-in/out FFT: > > http://fftguru.com/fftguru.com.tutorial2.pdf > > The first technique desribed above is the one you want. You end up doing one N size complex-in/out FFT plus some bookkeeping instead of two N size complex-in/out FFTs (and no bookkeeping). > > But if you have an FFT optimized for real-only inputs, you may (or may not) be better off doing two N size real-in/complex out FFTs - it all depends on the relative efficiency of the programs.I think the two are largely equivalent, N point FFT plus house keeping to separate the two separate results or two N-1 point FFTs plus a special butterfly pass to complete the final pass of each FFT. I expect the two processes will be very similar in processing time. BTW, I did a quick search and the odd/even thing the OP mentioned is how they do the FFT of a single block of real data. By splitting the input into odd and even data the output of the N/2 FFT is the appropriate input for the final pass of the N point FFT. The FFT of two real sequences does not deal with odd and even samples from the two sequences, but processes them intact. -- Rick
