Hello I am using CCS 2.2 to create a program for the LF240xA from TI. I have made a blinking LED program to test my own target board with, the "hello world" of embedded. I compiled it and then used the "flash programmer" plugin to load it to a board with a LF2402A on. With out doing anything else I can now "reset cpu" and "run". I tried a suggestion from Trampas to use the "load program" and I can now successfully step through the code. As I "step" then the watch window updates with the current values of my variables. I want to be able to set break points. If I can then I will be able to use "run to curser" and jump to code of interest or used probe points, but I get this is the error I get when I try to set one: "Can't Set Breakpoint: Cannot set/verify breakpoint at 0xBC" Does any one know of a way to set break points when running from flash. Tony --- In F28X@yahoogroups.com, "Trampas" <tstern@n...> wrote:> I am not sure, but I was told once. I think after you load the code into > flash you have to load your symbol table into code composer. Then you > can step through the code. I am sure that others out there will know > better. > > Trampas >
LF240xA hardware: JTAG debugging from flash
Started by ●July 15, 2003
Reply by ●July 18, 20032003-07-18
> > I want to be able to set break points. If I can then I will be able to > use "run to curser" and jump to code of interest or used probe points, > but I get this is the error I get when I try to set one: > > "Can't Set Breakpoint: Cannot set/verify breakpoint at 0xBC" >After this get the breakpoint list via menu. Your breakpoint should be in the list. Select it. Change the type of breakpoint to something like "h/w breakpoint" The cpu has exactly one of these "h/w breakpoints".
