Hello All, I am reading DFT topic where quantization effect is described. One of the example in the book calculates the number of bits needed to compute the DFT of a 1024 point sequence with a SNR of 30 dB. Here b = 15 bits. My question is whether the size of the sample size does not matter at all for computation of the DFT? If input is composed of 24 bits (for example), would number of bits used for DFT internally would be independent of 24-bit size? Thanks, _____________________________ Posted through www.DSPRelated.com
number of bits to compute DFT
Started by ●November 10, 2014
Reply by ●November 10, 20142014-11-10
On 10.11.14 14.37, sharanbr wrote:> I am reading DFT topic where quantization effect is described. > > One of the example in the book calculates the number of bits needed to > compute the DFT of a 1024 point sequence with a SNR of 30 dB. > > Here b = 15 bits. My question is whether the size of the sample size does > not matter at all for computation of the DFT?It depends on your algorithm. The fast FFT algorithm does not produce optimal results with respect to SNR. But if you compute the DFT by a matrix multiplication, there is no significant dependency on the DFT size, since every resulting coefficient is just a scalar product of the input vector withe the matching coefficient vector.> If input is composed of 24 bits (for example), would number of bits used > for DFT internally would be independent of 24-bit size?What algorithm do you intend to use? Marcel
On 2014-11-10 19:24:21 +0000, Marcel Mueller said:> On 10.11.14 14.37, sharanbr wrote: >> I am reading DFT topic where quantization effect is described. >> >> One of the example in the book calculates the number of bits needed to >> compute the DFT of a 1024 point sequence with a SNR of 30 dB. >> >> Here b = 15 bits. My question is whether the size of the sample size does >> not matter at all for computation of the DFT? > > It depends on your algorithm. The fast FFT algorithm does not produce > optimal results with respect to SNR.The FFT gets it speed by careful factoring of the Fourier transform matrix and that results in lower error bounds which are also observed in practice. Well known in the literature for almost 50 years now.> But if you compute the DFT by a matrix multiplication, there is no > significant dependency on the DFT size, since every resulting > coefficient is just a scalar product of the input vector withe the > matching coefficient vector.And each of those inner products has a error coefficient which depends on the length of the inner product. See any numerical analysis text published since WWII.>> If input is composed of 24 bits (for example), would number of bits used >> for DFT internally would be independent of 24-bit size? > > What algorithm do you intend to use? > > > Marcel
On 11/10/14 3:06 PM, Gordon Sande wrote:> On 2014-11-10 19:24:21 +0000, Marcel Mueller said: > >> On 10.11.14 14.37, sharanbr wrote: >>> I am reading DFT topic where quantization effect is described. >>> >>> One of the example in the book calculates the number of bits needed to >>> compute the DFT of a 1024 point sequence with a SNR of 30 dB. >>> >>> Here b = 15 bits. My question is whether the size of the sample size >>> does >>> not matter at all for computation of the DFT? >> >> It depends on your algorithm. The fast FFT algorithm does not produce >> optimal results with respect to SNR. > > The FFT gets it speed by careful factoring of the Fourier transform matrix > and that results in lower error bounds which are also observed in practice. > Well known in the literature for almost 50 years now.i would say that, yes, the FFT does better if a single-precision accumulator is used. but if single-precision word width for the coefficients and data continue to be used just as with the FFT, but a double-wide accumulator is used, as is a common DSP practice, then i also think the simple dot-product DFT might have better SNR. (because there would be only one rounding operation immediately before writing X[k], whereas with the vanilla-flavored radix-2 Decimation-in-whatever FFT alg, there would be many different rounding operations accumulating. but i don't think they would accumulate very far because it would be like 1 + 1/4 + 1/16 + ... i think that would converge pretty fast. so i don't see the straight DFT to be useful unless you're doing something like the sliding DFT.) -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
Reply by ●November 11, 20142014-11-11
On 10.11.14 14.37, sharanbr wrote: ... (snip) From the wikipedia entry on FFT: "The upper bound on the relative error for the Cooley–Tukey algorithm is O(ε log N), compared to O(εN3/2) for the naïve DFT formula (Gentleman and Sande, 1966)," There is an extensive literature covering FFT and DFT error analysis, some of it quite recent. A simple Google search on the subject will probably provide you with far more reading material than you can handle. And, of course, the issue has been mentioned before on comp.dsp, such as, for example: http://www.dsprelated.com/showmessage/150283/1.php Kevin McGee
On 11/10/2014 8:37 AM, sharanbr wrote:> Hello All, > > I am reading DFT topic where quantization effect is described. > > One of the example in the book calculates the number of bits needed to > compute the DFT of a 1024 point sequence with a SNR of 30 dB. > > Here b = 15 bits. My question is whether the size of the sample size does > not matter at all for computation of the DFT? > > If input is composed of 24 bits (for example), would number of bits used > for DFT internally would be independent of 24-bit size?I think you are saying you wish for the output spectrum to have 30 dB of SNR. To achieve that you need to consider the size of your FFT. My understanding is that you add about 1/2 bit of noise from roundoff error with each pass of the FFT. So a 1024 point FFT will have 10 passes and add 5 bits. To get 30 dB out (ENOB = 5) you would need to start with input data with 10 bits of significant data or 60 dB of SNR. You would need to do all calculations with at least 10 bits of precision. -- Rick
On Tue, 11 Nov 2014 02:23:43 -0500, rickman wrote:> On 11/10/2014 8:37 AM, sharanbr wrote: >> Hello All, >> >> I am reading DFT topic where quantization effect is described. >> >> One of the example in the book calculates the number of bits needed to >> compute the DFT of a 1024 point sequence with a SNR of 30 dB. >> >> Here b = 15 bits. My question is whether the size of the sample size >> does not matter at all for computation of the DFT? >> >> If input is composed of 24 bits (for example), would number of bits >> used for DFT internally would be independent of 24-bit size? > > I think you are saying you wish for the output spectrum to have 30 dB of > SNR. To achieve that you need to consider the size of your FFT. My > understanding is that you add about 1/2 bit of noise from roundoff error > with each pass of the FFT. So a 1024 point FFT will have 10 passes and > add 5 bits. To get 30 dB out (ENOB = 5) you would need to start with > input data with 10 bits of significant data or 60 dB of SNR. You would > need to do all calculations with at least 10 bits of precision.I think you're doing your computation backwards. Each bin of an N-point FFT acts like a bandpass filter, N points long. So for white noise at the input, the achievable SNR at each bin is (input SNR) + 3dB * N. So for a 30dB _input_ SNR you could expect (at best) a 60dB _output_ SNR. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
On Mon, 10 Nov 2014 07:37:13 -0600, sharanbr wrote:> Hello All, > > I am reading DFT topic where quantization effect is described. > > One of the example in the book calculates the number of bits needed to > compute the DFT of a 1024 point sequence with a SNR of 30 dB. > > Here b = 15 bits. My question is whether the size of the sample size > does not matter at all for computation of the DFT? > > If input is composed of 24 bits (for example), would number of bits used > for DFT internally would be independent of 24-bit size?It's complicated. If the input is composed of 24 bits, with a signal that uses the full range of available values, then the bottom 19 bits are, roughly, random junk. (It's more like the bottom 17 bits or so, if you add guard bits -- I'm being a bit fast and loose with my math). When you finish the FFT, then if the signal were a pure tone that fell exactly on a bin's frequency, the SNR of the signal in that one bin would be roughly 60dB, meaning that the bottom 14 (OK, 12) bits are junk. If by "sample size" you mean the number of samples in the FFT (i.e. 1024), then it matters, because the SNR of that hypothetical pure tone improves by 3dB for each doubling in the sample size. If by "sample size" you mean the number of bits in the sample, then (a) you are not using the correct nomenclature ("precision" or "word width" is the word you seek), and (b), if the signal is significantly noisier than the quantization noise imposed by the word width then increasing the word width will yield no effective increase in SNR. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
On 11/11/14 12:08 PM, Tim Wescott wrote:> On Mon, 10 Nov 2014 07:37:13 -0600, sharanbr wrote: > >> Hello All, >> >> I am reading DFT topic where quantization effect is described. >> >> One of the example in the book calculates the number of bits needed to >> compute the DFT of a 1024 point sequence with a SNR of 30 dB. >> >> Here b = 15 bits. My question is whether the size of the sample size >> does not matter at all for computation of the DFT? >> >> If input is composed of 24 bits (for example), would number of bits used >> for DFT internally would be independent of 24-bit size? > > It's complicated. > > If the input is composed of 24 bits, with a signal that uses the full > range of available values, then the bottom 19 bits are, roughly, random > junk. (It's more like the bottom 17 bits or so, if you add guard bits -- > I'm being a bit fast and loose with my math). > > When you finish the FFT, then if the signal were a pure tone that fell > exactly on a bin's frequency, the SNR of the signal in that one bin would > be roughly 60dB, meaning that the bottom 14 (OK, 12) bits are junk. >it appears we're talking fixed-point DFT. then, to be sufficiently slow and tight with the math, besides being clear on the 24-bit words of the signal (and how many guard bits are on the left) and presumably 24-bit words for the DFT coefficients (or "twiddle factors"), we need to be clear what is the word width of the intermediate values. and we need to be clear if we're doing: N-1 X[k] = SUM{ x[n] e^(j 2 pi nk/N) } n=0 in which the signal is growing in amplitude and we'll need log2(N) guard bits on the left, or if we're doing N-1 X[k] = (1/N) SUM{ x[n] e^(j 2 pi nk/N) } n=0 in which the signal is actually decreasing in amplitude and bits are falling off the edge on the right, or if we're doing N-1 X[k] = (1/sqrt(N)) SUM{ x[n] e^(j 2 pi nk/N) } n=0 and the signal amplitude is *not* growing or shrinking (in an r.m.s. sense), but there is still the need for 1/2 log2(N) guard bits on the left and another 1/2 log2(N) bits are gonna fall of the edge on the right. if the vanilla-flavored radix-2 FFT is used, the first case there is no division by 2 in the butterflies. in the second case, every butterfly has a division by 2 (a right shift by one bit) so a bit falls offa the edge for each pass. in the final case, for every *alternate* pass, there is a division by 2 (and a right shift by one bit) and for the other passes, there is no divide nor shift in the butterflies. this is something i worried about two decades ago when i was coding this for the good-old DSP56K (before the DSP56002 and later, which had a special overflow-anticipation bit that was used efficiently implement a block-floating-point FFT). -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
On Tue, 11 Nov 2014 12:41:01 -0500, robert bristow-johnson wrote:> On 11/11/14 12:08 PM, Tim Wescott wrote: >> On Mon, 10 Nov 2014 07:37:13 -0600, sharanbr wrote: >> >>> Hello All, >>> >>> I am reading DFT topic where quantization effect is described. >>> >>> One of the example in the book calculates the number of bits needed to >>> compute the DFT of a 1024 point sequence with a SNR of 30 dB. >>> >>> Here b = 15 bits. My question is whether the size of the sample size >>> does not matter at all for computation of the DFT? >>> >>> If input is composed of 24 bits (for example), would number of bits >>> used for DFT internally would be independent of 24-bit size? >> >> It's complicated. >> >> If the input is composed of 24 bits, with a signal that uses the full >> range of available values, then the bottom 19 bits are, roughly, random >> junk. (It's more like the bottom 17 bits or so, if you add guard bits >> -- >> I'm being a bit fast and loose with my math). >> >> When you finish the FFT, then if the signal were a pure tone that fell >> exactly on a bin's frequency, the SNR of the signal in that one bin >> would be roughly 60dB, meaning that the bottom 14 (OK, 12) bits are >> junk. >> >> > it appears we're talking fixed-point DFT. then, to be sufficiently slow > and tight with the math, besides being clear on the 24-bit words of the > signal (and how many guard bits are on the left) and presumably 24-bit > words for the DFT coefficients (or "twiddle factors"), we need to be > clear what is the word width of the intermediate values. > > and we need to be clear if we're doing: > > N-1 > X[k] = SUM{ x[n] e^(j 2 pi nk/N) } > n=0 > > in which the signal is growing in amplitude and we'll need log2(N) guard > bits on the left, or if we're doing > > N-1 > X[k] = (1/N) SUM{ x[n] e^(j 2 pi nk/N) } > n=0 > > > in which the signal is actually decreasing in amplitude and bits are > falling off the edge on the right, or if we're doing > > N-1 > X[k] = (1/sqrt(N)) SUM{ x[n] e^(j 2 pi nk/N) } > n=0 > > and the signal amplitude is *not* growing or shrinking (in an r.m.s. > sense), but there is still the need for 1/2 log2(N) guard bits on the > left and another 1/2 log2(N) bits are gonna fall of the edge on the > right. > > if the vanilla-flavored radix-2 FFT is used, the first case there is no > division by 2 in the butterflies. in the second case, every butterfly > has a division by 2 (a right shift by one bit) so a bit falls offa the > edge for each pass. in the final case, for every *alternate* pass, > there is a division by 2 (and a right shift by one bit) and for the > other passes, there is no divide nor shift in the butterflies. > > this is something i worried about two decades ago when i was coding this > for the good-old DSP56K (before the DSP56002 and later, which had a > special overflow-anticipation bit that was used efficiently implement a > block-floating-point FFT).You just HAD to go and make it complicateder. Yes to all that, but within a lot of reasonable assumptions I don't think it changes the conclusions -- it just affects the details in how you implement your FFT so that the assumptions you do make remain valid. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
