itsbhanu@yahoo.com (Bhanu Prakash Reddy) wrote in message news:<28192a4d.0307142216.4c6ee88@posting.google.com>...> Hi, > Can anyone explain the concept of Negative frequencies clearly. Do > they really exist?Of coarse they don't. But they are handy. Does phase (negative or positive) really exist ? It doesn't. But as a mathematical abstraction it is even more handy than a negative frequency. For an explaination - the negative frequency is a case of a phase going backward.
Negative Frequencies
Started by ●July 15, 2003
Reply by ●July 15, 20032003-07-15
"Jerry Avins" <jya@ieee.org> wrote in message news:3F1418BA.822C806@ieee.org...> > > No amount of math will reach a conclusion here, because the issue is not > math, but philosophy. What is clear is that a Fourier transform with > sines and cosines doesn't use negative frequencies in the analysis. >Hello Jerry, I agree with you here in the sense that if one takes the trivial definition of frequency as to how often something repeats - then the answer is certainly a simple positive number. But if we expand our viewpoint to two dimensional things, a natural extension is to say not only how often something repeats but, we can now include a direction. While this is a natural philisophical idea, it is motiviated in some by mathematics. The primary reason complex numbers (two dimensional) were developed, was that one dimensional numbers proved inadequate for large classes of problems. The comment about the sines and cosines being purely real and not requiring negative frequences (explicitly) gets buried in the old "solutions of differential equations" idea. The functions: exp(iwt), exp(-iwt), sin(wt), and cos(wt) are all solutions to the same 2nd order equation. So when you do an analysis with two of these functions, you really have done it with all of these functions! Clay
"Clay S. Turner" wrote:> > ... The functions: exp(iwt), exp(-iwt), sin(wt), > and cos(wt) are all solutions to the same 2nd order equation. So when you do > an analysis with two of these functions, you really have done it with all of > these functions!It needs only a very small shoehorn it fit sinh and cosh into there too. It's just a matter of where the i's (or j's) go. My point is that it's a waste of time to argue about what's real. Those concepts that the regularly use to think about our trade become real to us soon enough. It's a waste of attention (and sometimes friendships) to get hung up about what is demonstrably real, what might reasonably be treated as real, and what is hypothetical but useful. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Jerry Avins wrote:> > "Clay S. Turner" wrote: > > > > ... The functions: exp(iwt), exp(-iwt), sin(wt), > > and cos(wt) are all solutions to the same 2nd order equation. So when you do > > an analysis with two of these functions, you really have done it with all of > > these functions! > > It needs only a very small shoehorn it fit sinh and cosh into there too. > It's just a matter of where the i's (or j's) go. My point is that it's a > waste of time to argue about what's real. Those concepts that the^^^ we> regularly use to think about our trade become real to us soon enough. > It's a waste of attention (and sometimes friendships) to get hung up > about what is demonstrably real, what might reasonably be treated as > real, and what is hypothetical but useful. > > Jerry > -- > Engineering is the art of making what you want from things you can get. > �����������������������������������������������������������������������
Bhanu Prakash Reddy wrote:> Hi, > Can anyone explain the concept of Negative frequencies clearly. Do > they really exist?I do not know why, but S(t)=sin(2*pi*f*t) with "f" negative makes sense to me. bye, -- piergiorgio
"Rune Allnor" <allnor@tele.ntnu.no> wrote in message news:f56893ae.0307150151.658d101e@posting.google.com...> itsbhanu@yahoo.com (Bhanu Prakash Reddy) wrote in messagenews:<28192a4d.0307142216.4c6ee88@posting.google.com>...> > Hi, > > Can anyone explain the concept of Negative frequencies clearly. Do > > they really exist? > > Negative frequencies must be treated as if they exist. I'll give > two examples: > > - In AM modulated systems the signal is represented as two sidebands > "mirrored" around the carrier frequency. The upper side band comes > from modulating the baseband signal. The lower side band is due to > the negative frequencies. To save bandwidth one sideband > can be removed, in which case you have a single-sideband (SSB) > modulation scheme.But consider that the carrier is a sine, and so has both positive and negative frequencies. So in addition to the upper and lower sidebands of the positive frequency carrier there should be upper and lower sidebands of the negative carrier.> - When sampling real-valued signals, the negative frequencies are > repeated in the band between Fs/2 and Fs (Fs is sampling frequency). > The existence of these frequency components are the sole cause of > Nyquist's sampling theorem, that restricts the bandwidth of the signal > to be sampled to f<Fs/2. If you have a complex-valued signal, > you don't need to worry about the Fs/2 limit, only Fs.The displacement of a violin string, the air pressure in an organ pipe, or the voltage on a coaxial cable are always real. You can make mathematical transformations that will convert some of the real numbers to imaginary numbers, such that Fn/2 complex samples can be used. Each of those complex numbers should represent two real measurements. If, for example, you said that your complex valued signal was the real and imaginary displacement of a violin string, with the imaginary value always zero, I would say that you could not call that a complex valued signal and sample at Fn/2. (If Fs is the sampling frequency then sampling at Fs/2 doesn't make any sense. Fn/2 (half the Nyquist frequency) does.) -- glen
Piergiorgio Sartor wrote:> > Bhanu Prakash Reddy wrote: > > Hi, > > Can anyone explain the concept of Negative frequencies clearly. Do > > they really exist? > > I do not know why, but S(t)=sin(2*pi*f*t) with > "f" negative makes sense to me. > > bye, > > -- > > piergiorgioIt is exactly the same quantity when "f" is positive and "t" is negative. How can you tell which is is the real way? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
"Clay S. Turner" <physicsNOOOOSPPPPAMMMM@bellsouth.net> wrote in message news:5wVQa.5233$r35.1292@fe03.atl2.webusenet.com...> > "Jerry Avins" <jya@ieee.org> wrote in message > news:3F1418BA.822C806@ieee.org... > > > > > No amount of math will reach a conclusion here, because the issue is not > > math, but philosophy. What is clear is that a Fourier transform with > > sines and cosines doesn't use negative frequencies in the analysis.> I agree with you here in the sense that if one takes the trivialdefinition> of frequency as to how often something repeats - then the answer is > certainly a simple positive number. But if we expand our viewpoint to two > dimensional things, a natural extension is to say not only how often > something repeats but, we can now include a direction. While this is a > natural philisophical idea, it is motiviated in some by mathematics. The > primary reason complex numbers (two dimensional) were developed, was that > one dimensional numbers proved inadequate for large classes of problems.For a physics example, k, wave number if a scaler or wave vector if a vector, can have a direction. omega is temporal frequency always a scalar. In such problems one can always make w positive and apply any direction change to k.> The comment about the sines and cosines being purely real and notrequiring> negative frequences (explicitly) gets buried in the old "solutions of > differential equations" idea. The functions: exp(iwt), exp(-iwt), sin(wt), > and cos(wt) are all solutions to the same 2nd order equation. So when youdo> an analysis with two of these functions, you really have done it with allof> these functions!Consider polarized light. It can be described in a linear system, x and y, or sin() and cos(), or circular polarization which is the exp(i w t) or exp(- i w t) case. But there is also eliptic polarization, where the amplitude on one axis is larger than on another axis. Negative frequency could also be considered the time reversed solution to the same equation. Note, though, that neither parity (the symmetry operation converting (x,y,z) to (-x,-y,-z)) nor time reversal (converting t to -t) are conserved in nature in all cases. -- glen
"Jerry Avins" <jya@ieee.org> wrote in message news:3F1473F2.47CF9A7D@ieee.org...> It is exactly the same quantity when "f" is positive and "t" is > negative. How can you tell which is is the real way?Remember, though, that the universe does not conserve time reversal symmetry. Close, but not exactly. -- glen
Jerry Avins <jya@ieee.org> wrote in message news:<3F141D7A.5E25EF1@ieee.org>...> Rune Allnor wrote: > > > ... > > > > Negative frequencies must be treated as if they exist. I'll give > > two examples: > > Rune, > > I appreciate your moderation in writing "as if". It follows that > negative coconuts must be treated _as_if_ they exist. The example is in > another message of mine in this thread. > > > - In AM modulated systems the signal is represented as two sidebands > > "mirrored" around the carrier frequency. The upper side band comes > > from modulating the baseband signal. The lower side band is due to > > the negative frequencies. To save bandwidth one sideband > > can be removed, in which case you have a single-sideband (SSB) > > modulation scheme. > > Just as the answer to the coconut puzzle can be had without recourse to > negative coconuts, so can AM sidebands be analyzed without recourse to > negative frequencies. In both cases, the analyses that forgo the use of > negative quantities are more awkward.I am sure you are right. My point was merely that the lower side band appears because of the negative ferquency components of the baseband representation are shifted by modulation as well. If you do a spectrum analysis (positive frequencies only) at baseband and then of the modulated signal, I have been told[*] that you find that the bandwidth of the modulated signal is twice the bandwidth of the baseband signal. The negative frequencies may very well be a mathematical abstraction, but with a measurable manifestation. The only reason for the observable doubling of bandwidth is the negative frequency components. Thus, it is tempting to conclude that negative frequencies exist.> > - When sampling real-valued signals, the negative frequencies are > > repeated in the band between Fs/2 and Fs (Fs is sampling frequency). > > The existence of these frequency components are the sole cause of > > Nyquist's sampling theorem, that restricts the bandwidth of the signal > > to be sampled to f<Fs/2. If you have a complex-valued signal, > > you don't need to worry about the Fs/2 limit, only Fs. > > Every real-valued sample can be written as a complex number x + j0. What > does that imply about the becessary sample rate for signals so > expressed? Anyhow, the representation you describe above is an artifact > of the elegant computation, but not inevitably necessary. Wiechert and > Sommerfeld's harmonic analyzer used only positive frequencies.I suspect I may be too close to a mine field for comfort, but it's important to distinguish between "representation" and "one and only truth". A representation is one that takes care of some aspect of the data, while leaving others out. There are several reasons for using ferquencies, either in sin(wt) or exp(iwt) in mathematical physics. I don't know Wiechert and Sommerfeldt's work, so I don't want to comment on that. What I do know is that the complex numbers and the complex exponentials, with their negative and positive frequencies, are useful. I don't think it's a problem with negative frequencies as such, but with the properties of time. When analysisn wave propagation the poitive and negative wavenumbers (that play the same role in the spatial Fourier transform as ferquency in the temporal transform) relate to the direction waves travel.> Jerry > > P.S. Does -sin(at) imply -[sin(at)], sin(-a*t), or sin(a*-t)? Maybe, > instead of being composed of (relatively) negative frequencies, the > lower sideband runs in (relatively) negative time. Really! :-)Again, it's a problem with time, not the frequency concept as such. What you say appear to make no sense, but only because you explicitly talk about time. Start out with -sin(kx) and you have outlined the basis for one of many clues that are used to identify various types of waves in a seismic data record. Rune [*] The phrase "I have been told" is included because I haven'y actually done that exercise myself, but that's what pop out of the maths. I do put sufficiently trust in maths and physics to predict that's what's going to happen.
