"Ian Buckner" <Ian_Buckner@agilent.com> asserts:>Seems to me we could remove one of life's confusions by >changing the direction clock hands rotate. After all, if >increasing time causes counter clockwise rotation.....No, no, no. We should all contradict Jerry and insist that *only* negative frequencies exist; it is the positive frequencies that do not exist! That way, increasing time causes clockwise rotation which every one knows is correct.... So, why does the FCC allocate positive frequencies? Well, it is kind of hard to "sell" negative frequencies, and, of course, selling positive frequencies is the same as selling negative frequenciess -- it all comes out correctly through the miracle of modern mathematics. It's like the electric power company charging for positive current delivered to the user even though we all know that it is the negatively-charged electrons that are doing all the work! Come to think of it, could someone explain *why* I have to pay for electricity? After all, I return one electron to the power company to replace each and every electron it sends to me. Not the same electron, of course, but another one that is identical in all respects... -- .-. .-. .-. .-. .-. .-. .-. / D \ I / L \ I / P \ / S \ A / R \ W / A \ T / E \ `-' `-' `-' `-' `-' `-'
Negative Frequencies
Started by ●July 15, 2003
Reply by ●July 18, 20032003-07-18
On Tue, 15 Jul 2003 23:04:09 GMT, "Glen Herrmannsfeldt" <gah@ugcs.caltech.edu> wrote:>Consider polarized light. It can be described in a linear system, x and y, >or sin() and cos(), or circular polarization which is the exp(i w t) or >exp(- i w t) case. But there is also eliptic polarization, where the >amplitude on one axis is larger than on another axis.Oh, I like that one. I'll have to remember the circular polarization example.>Negative frequency could also be considered the time reversed solution to >the same equation. Note, though, that neither parity (the symmetry >operation converting (x,y,z) to (-x,-y,-z)) nor time reversal (converting t >to -t) are conserved in nature in all cases. > >-- glenHas anybody kept track of how long it's been since this topic last came up? Eric Jacobsen Minister of Algorithms, Intel Corp. My opinions may not be Intel's opinions. http://www.ericjacobsen.org
On Fri, 18 Jul 2003 20:43:59 +0000, Eric Jacobsen wrote:> Has anybody kept track of how long it's been since this topic last > came up?I just assume it is one of those things that is always going on, much like the Springfield tire fire... -- Matthew Donadio (m.p.donadio@ieee.org)
On 16 Jul 2003 13:19:14 -0700, yates@ieee.org (Randy Yates) wrote:>itsbhanu@yahoo.com (Bhanu Prakash Reddy) wrote in message news:<28192a4d.0307142216.4c6ee88@posting.google.com>... >> Hi, >> Can anyone explain the concept of Negative frequencies clearly. Do >> they really exist? > >Now we get to the bottom line, which Clay Turner already discussed. >The basic difference between frequency when thinking in terms of >real numbers versus complex numbers is the concept of dimension. In >some sense, real numbers are one-dimensional while complex numbers >are two-dimensional. So, as Clay illustrated, the sign of the >frequency can be used to indicate the direction in the plane >(clockwise or counterclockwise) that a rotating vector is traveling. >So, in this sense, negative frequency is real because it matters >in the complex numbers and complex numbers are real if we base >our definition of "real" on rings. Further, this concept of >negative frequencies being real is not due to real numbers but >complex numbers since the real numbers are not isomorphic to >the complex numbers. > >And that's my $0.02. > >--RandyI think it's even slightly simpler than that. All you really need for negative frequency to "really exist" (although we can discuss what that means for a long time, too) is some arbitrary reference. e.g., I construct two pinwheels and put them on sticks and stick them on a fence across which a nice breeze blows. I've twisted the petals of the two pinwheels in opposite directions so that as the wind blows one pinwheel rotates clockwise and the other counter-clockwise. I will argue that in order to have negative numbers all one needs is a reference across which any counting produces the same magnitude but different signs, where the signs add information to the quantity that would otherwise create ambiguity. For negative numbers the reference is zero which is a physically recognizable reference. Consider that in many cases the definition of zero can be arbitrarily set against a practical physical quantity. An inventory of shelf stock can be taken during the day to record net product flow of a particular item. In order to see how many units of product move in a particular day the quantity on the shelf is measured at the beginning of the day and the end, and flow is then counted from zero at the beginning of the day. Flow out of the store at the end of the day can be negative if a shipment arrives that is greater than the quantity sold that day. From this standpoint I argue the negative numbers are "real" in the sense of being useful to count physical things in this manner. The same is true for frequency: If I count revolutions of the pinwheels over some equal time and get the same number for each, this means only that the magnitude (quantity) of rotations is the same, but there is an ambiguity in direction. I can resolve this ambiguity in direction by defining an arbitrary reference across which not only the quantity of rotations is recognizable but the direction as well. I can then distinguish the clockwise and counter-clockwise revolutions with a mathematical sign, consistent mathematically with the negative number sign. I can observe the rotations of the pinwheels and clearly see a difference that is consistently represented with the negative sign meaningfully attached to the quantity (magnitude) of the rotations. To me this makes negative frequency as real as negative quantities (which is also philosophical), and I happily accept negative quantities as "real". From the above reasoning I have a hard time seeing why people who accept negative numbers as being relevant to physical quantities don't accept negative frequencies as being equally relevant to physical quantities. Whether "relevance" leads to "reality" will be philosophical as well, but I hope I've made the drift reasonably clear... I always like these philosophical threads... Cheers, Eric Jacobsen Minister of Algorithms, Intel Corp. My opinions may not be Intel's opinions. http://www.ericjacobsen.org
"Eric Jacobsen" <eric.jacobsen@ieee.org> wrote in message news:3f184fb4.61088902@news.earthlink.net...> On 16 Jul 2003 13:19:14 -0700, yates@ieee.org (Randy Yates) wrote: > > >itsbhanu@yahoo.com (Bhanu Prakash Reddy) wrote in messagenews:<28192a4d.0307142216.4c6ee88@posting.google.com>...> >> Hi, > >> Can anyone explain the concept of Negative frequencies clearly. Do > >> they really exist? > > > >Now we get to the bottom line, which Clay Turner already discussed. > >The basic difference between frequency when thinking in terms of > >real numbers versus complex numbers is the concept of dimension. In > >some sense, real numbers are one-dimensional while complex numbers > >are two-dimensional. So, as Clay illustrated, the sign of the > >frequency can be used to indicate the direction in the plane > >(clockwise or counterclockwise) that a rotating vector is traveling. > >So, in this sense, negative frequency is real because it matters > >in the complex numbers and complex numbers are real if we base > >our definition of "real" on rings. Further, this concept of > >negative frequencies being real is not due to real numbers but > >complex numbers since the real numbers are not isomorphic to > >the complex numbers. > > > >And that's my $0.02. > > > >--Randy > > I think it's even slightly simpler than that. > > All you really need for negative frequency to "really exist" (although > we can discuss what that means for a long time, too) is some arbitrary > reference. e.g., I construct two pinwheels and put them on sticks > and stick them on a fence across which a nice breeze blows. I've > twisted the petals of the two pinwheels in opposite directions so that > as the wind blows one pinwheel rotates clockwise and the other > counter-clockwise. > > I will argue that in order to have negative numbers all one needs is a > reference across which any counting produces the same magnitude but > different signs, where the signs add information to the quantity that > would otherwise create ambiguity. For negative numbers the reference > is zero which is a physically recognizable reference. > > Consider that in many cases the definition of zero can be arbitrarily > set against a practical physical quantity. An inventory of shelf > stock can be taken during the day to record net product flow of a > particular item. In order to see how many units of product move in a > particular day the quantity on the shelf is measured at the beginning > of the day and the end, and flow is then counted from zero at the > beginning of the day. Flow out of the store at the end of the day > can be negative if a shipment arrives that is greater than the > quantity sold that day. From this standpoint I argue the negative > numbers are "real" in the sense of being useful to count physical > things in this manner. > > The same is true for frequency: If I count revolutions of the > pinwheels over some equal time and get the same number for each, this > means only that the magnitude (quantity) of rotations is the same, but > there is an ambiguity in direction. I can resolve this ambiguity in > direction by defining an arbitrary reference across which not only the > quantity of rotations is recognizable but the direction as well. I > can then distinguish the clockwise and counter-clockwise revolutions > with a mathematical sign, consistent mathematically with the negative > number sign. > > I can observe the rotations of the pinwheels and clearly see a > difference that is consistently represented with the negative sign > meaningfully attached to the quantity (magnitude) of the rotations. > To me this makes negative frequency as real as negative quantities > (which is also philosophical), and I happily accept negative > quantities as "real". > > From the above reasoning I have a hard time seeing why people who > accept negative numbers as being relevant to physical quantities don't > accept negative frequencies as being equally relevant to physical > quantities. Whether "relevance" leads to "reality" will be > philosophical as well, but I hope I've made the drift reasonably > clear... > > I always like these philosophical threads... >Cool..
"Jerry Avins" <jya@ieee.org> wrote in message news:3F172675.5FB4F015@ieee.org...> Fred Marshall wrote: > > > > "Jerry Avins" <jya@ieee.org> wrote in message > > news:3F16006C.4E35B67@ieee.org... > > > Rune Allnor wrote: > > > > > > > > ... > > > > > > > My point was merely that the lower side band > > > > appears because of the negative ferquency components of the baseband > > > > representation are shifted by modulation as well. If you do aspectrum> > > > analysis (positive frequencies only) at baseband and then of the > > modulated > > > > signal, I have been told[*] that you find that the bandwidth of the > > > > modulated signal is twice the bandwidth of the baseband signal. > > > > > > That's a possible viewpoint, and a productive one. It's not conclusive > > > because it isn't the only one. AM modulation of a carrier by a single > > > baseband cosine is defined by the equation > > > > > > f(t) = cos(w_c*t)*[1 + m*cos(w_m*t), > > > > > > where f(t) is the modulated waveform, w_c is the carrier frequency,w_m> > > is the modulating frequency, and m is the modulation percentage. > > > Trigonometric identities show that f(t) consists of the originalcarrier> > > from the 1 in the bracket term, and two additional frequencies, > > > w_c + w_m and w_c - w_m, each with amplitude m/2. The math in no way > > > insists that w_c - w_m be construed as w_c + -w_m, although that's > > > not ruled out. > > > > Jerry, > > > > The point is addressed by: > > > > f(t) = cos(w_c*t)*[1 + m*cos(w_m*t) > > > > expressed using complex exponentials: > > > > f(t) = [exp(w_c*t)/2 + exp(-w_c*t)/2]*{1 + m*[exp(w_m*t)/2 + > > exp(-w_m*t)/2]}, > > > > Multiplying out: > > > > f(t) = [exp(w_c*t)/2 + exp(-w_c*t)/2] + m*{.... > > ...exp(w_c*t)*exp(w_m*t)/2 + exp(w_c*t)*exp(-w_m*t)/2 > > + exp(-w_c*t)*exp(w_m*t)/2 + exp(-w_c*t)*exp(w_m*t)/2} > > > > Collecting exponents in products of exponentials: > > > > f(t) = [exp(w_c*t)/2 + exp(-w_c*t)/2] + m*{.... > > ...exp[(w_c+w_m)*t]/4*exp[(w_c-w_m)*t]/4*+ exp[(-w_c+w_m)*t]/4+ > > exp[(-w_c-w_m)*t]/4} > > > > Collecting terms at or near positive and negative carrier frequencies: > > > > f(t) = exp(w_c*t)/2 + [exp(w_c+w_m)*t]/4 +[exp(w_c-w_m)*t]/4 > > + exp(-w_c*t)/2 + [exp(-w_c+w_m)*t]/4 +[exp(-w_c-w_m)*t]/4 > > > > So, there is a positive and a negative carrier component and there is a > > positive and negative sideband associated with each of those carrier > > components. > > > > Addition is an operation whether the specific addition ends up in > > subtraction - so that's not the point. For example, if we saidexp-(+w_c*t)> > or exp(-w_c*t) it wouldn't matter. The function is the same. I really > > think this isn't about the specific operations being performed, it'sabout> > the function that results. > > > > Fred > > Fred, > > That's one way to do the math. Here's another that yields the same > result, but invites a different interpretation (it's shorter, too): > > f(t) = cos(w_c*t)*[1 + m*cos(w_m*t) > = cos(w_c*t) + m*cos(w_c*t)*cos(w_m*t) > > Given the trig identity 2cos(a)cos(b) = cos(a-b) + cos(a+b), we get > > f(t) = cos(w_c*t) + .5m[cos((w_c - w_m)t) + cos((w_c + w_m)t)] > > directly. I see no negative frequencies there. Do you? We can both > hypothesize them if we want, but neither of us has to. > > JerryJerry, OK - that is reasonable as far as it goes. But, the question was about negative frequencies and where they come from, right? As I tried to say before, which agrees with your notation above, if all you care about is the time domain, then you can use the real number notation. That it can be expressed as the sum of complex numbers isn't an issue if that's all you want to do. However, if you're wanting to express the Fourier Transform / spectrum then you're going to get complex quantities - in general. These complex quantities will show up at positive and negative points on the frequency scale with amplitude and phase or, correspondingly, to real and imaginary parts. Examining the Fourier Transform confirms that this is the case. The integral is taken over all time (from minus infinity to plus infinity) and results in a function of frequency. The Fourier Transform looks like a correlation at one frequency at a time over all frequencies. So, sin(wt) correlates at both +w and -w. That makes intuitive sense, no? "Phase" means there is a relationship to a rotating reference vector in that same complex plane, right? The bottom line is: - we *can* express *real time domain signals* without using negative frequencies or complex quantities. Although, as you know, using complex quantities is pretty useful for doing some of the math. - we *can't* express the *spectra of real time domain signals* without using complex quantities and negative frequencies. I think that's correct. So, one would also conclude from this that "negative" frequency is only necessary when examining the spectrum / transform. That's where it shows up. I don't know how to avoid it either! It appears that using sums of complex exponentials in expressing a real time domain signal is overkill. It appears that using sums of diracs at positive and negative frequencies in order to represent the spectrum of real time domain sinusoids is unavoidable. The "argument" seems to overlook which domain is being discussed. There are negative "frequencies" in the *spectrum* for a real signal made up of only positive frequency terms. This is confirmed by using the complex exponential notation in time (which is overkill perhaps but instructive nonetheless). Take the counter example: Put a Dirac in the spectrum at a positive radian frequency w (only). What is the corresponding time domain function? It is a complex sinusoid something like (coswt +/- jsinwt). However, starting with coswt, you get a double Dirac in frequency - one at positive frequency and one at negative frequency. Same with sinwt (n.b.: not jsinwt). It's the complex spectrum that has terms at those negative ordinates...... for a real function. Just transform the real function you provided above and see what you get - you get six Diracs. Fred
Dilip V. Sarwate <sarwate@uiuc.edu> wrote in message news:<giURa.2858$o7.37232@vixen.cso.uiuc.edu>...> "Ian Buckner" <Ian_Buckner@agilent.com> asserts: > > >Seems to me we could remove one of life's confusions by > >changing the direction clock hands rotate. After all, if > >increasing time causes counter clockwise rotation..... > > > No, no, no. We should all contradict Jerry and insist > that *only* negative frequencies exist; it is the positive > frequencies that do not exist! That way, increasing time > causes clockwise rotation which every one knows is correct.... > > So, why does the FCC allocate positive frequencies? Well, > it is kind of hard to "sell" negative frequencies, and, of > course, selling positive frequencies is the same as selling > negative frequenciess -- it all comes out correctly through > the miracle of modern mathematics. It's like the electric > power company charging for positive current delivered to > the user even though we all know that it is the > negatively-charged electrons that are doing all the work! > > Come to think of it, could someone explain *why* I have to > pay for electricity? After all, I return one electron to > the power company to replace each and every electron it > sends to me. Not the same electron, of course, but another > one that is identical in all respects...conservation of energy - the earlier one carried some electrical energy in his pocket and enlighten your room with bright light and go back to take rest or get another call to some other place. You know, he has to get paid for this work -is n't? Regards, Santosh
Fred Marshall wrote:>...> > Jerry, > > OK - that is reasonable as far as it goes. But, the question was about > negative frequencies and where they come from, right?I thought the question was, "Are negative frequencies real?" I objected to the answer that they had to be real because we couldn't calculate properly without them. My position was and it that they can be assigned at least arm-waving significance, they are sometimes a convenience but never a necessity for calculating, and they may optionally be considered real by those so inclined. It seems to me from what you wrote below, we agree on most points.> > As I tried to say before, which agrees with your notation above, if all you > care about is the time domain, then you can use the real number notation. > That it can be expressed as the sum of complex numbers isn't an issue > if that's all you want to do. > > However, if you're wanting to express the Fourier Transform / spectrum then > you're going to get complex quantities - in general.Not in general, but specifically when using complex exponential notation. Fourier transforms can calculated using trigonometry, as Fourier himself did. (There is no mention of vector analysis -- curl, divergence, etc. -- In Maxwell's Treatise on Electricity and Magnetism. He used triple integrals instead. It's usually silly to claim that something has to be real because math can't be accomplished without it.> These complex > quantities will show up at positive and negative points on the frequency > scale with amplitude and phase or, correspondingly, to real and imaginary > parts. > Examining the Fourier Transform confirms that this is the case. The > integral is taken over all time (from minus infinity to plus infinity) and > results in a function of frequency. The Fourier Transform looks like a > correlation at one frequency at a time over all frequencies. So, sin(wt) > correlates at both +w and -w. That makes intuitive sense, no? > > "Phase" means there is a relationship to a rotating reference vector in that > same complex plane, right? > > The bottom line is: > > - we *can* express *real time domain signals* without using negative > frequencies or complex quantities. Although, as you know, using complex > quantities is pretty useful for doing some of the math. > - we *can't* express the *spectra of real time domain signals* without using > complex quantities and negative frequencies.> > I think that's correct. So, one would also conclude from this that > "negative" frequency is only necessary when examining the spectrum / > transform. That's where it shows up. I don't know how to avoid it either! > > It appears that using sums of complex exponentials in expressing a real time > domain signal is overkill. > It appears that using sums of diracs at positive and negative frequencies in > order to represent the spectrum of real time domain sinusoids is > unavoidable. > > The "argument" seems to overlook which domain is being discussed. There are > negative "frequencies" in the *spectrum* for a real signal made up of only > positive frequency terms. This is confirmed by using the complex > exponential notation in time (which is overkill perhaps but instructive > nonetheless). > > Take the counter example: > Put a Dirac in the spectrum at a positive radian frequency w (only). > What is the corresponding time domain function? > It is a complex sinusoid something like (coswt +/- jsinwt). > > However, starting with coswt, you get a double Dirac in frequency - one at > positive frequency and one at negative frequency. Same with sinwt (n.b.: > not jsinwt). > > It's the complex spectrum that has terms at those negative ordinates...... > for a real function. Just transform the real function you provided above > and see what you get - you get six Diracs. > > FredIn the early part of the last century, several people, notably Kelvin, I think, designed machines that read out the first N coefficients of the Fourier series of a curve that the stylus traced. (Gibbs showed that the ringing near sharp transitions which appeared in reconstructed waveforms were not defects of workmanship or design, hence "Gibbs' phenomenon.) No negative frequencies appeared in the spectra those harmonic analyzers produced. Just as in the time domain, negative frequencies arise from the way we chose to calculate. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Eric Jacobsen wrote:>...> > From the above reasoning I have a hard time seeing why people who > accept negative numbers as being relevant to physical quantities don't > accept negative frequencies as being equally relevant to physical > quantities. Whether "relevance" leads to "reality" will be > philosophical as well, but I hope I've made the drift reasonably > clear... > > I always like these philosophical threads...Me too, provided they remain civil.>Relevance is clear. But you can't really illustrate frequency with rotation. A better model is vibration, some sort of pendulum. That would address the actual point, not a related one. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●July 19, 20032003-07-19
Jerry, Fred: [snip]> > As I tried to say before, which agrees with your notation above, if allyou> > care about is the time domain, then you can use the real numbernotation.> > That it can be expressed as the sum of complex numbers isn't an issue > > if that's all you want to do.[snip] You can also implement complex time domain waveforms and numbers in physically real systems. And hence make use of [very real] positive and negative frequencies in such signal processing systems. Most common physical systems don't use complex waveforms but that does not mean they don't or can't exist. There are just not many applications for which there is an advantage to using complex waveforms or signals in the signal processing systems and so most system designers never implement complex systems using complex waveforms and signals. But it's easy to do so... since complex waveforms or signals are simply pairs of [ordered/labeled] real waveforms. The signal processing in complex physical systems simply has to be designed to accomodate the complex [pairs of signals] waveforms and to process them according to the rules of complex arithmetic/mathematics. This style of processing pairs of signals can easily be done in both analog and digital networks. It does require a level of "matching" of components on a similar scale to that needed to implement fully differential systems. For complex analog signal processing systems most folks can accept doing this with active RC analog networks using Op Amps, but fewer beleive that it can also be done in completely passive networks, using transformers, to do the sums, etc. it's just that most "modern" engineers don't understand how to use transformers in analog computations :-). [snip]> Not in general, but specifically when using complex exponential > notation. Fourier transforms can calculated using trigonometry, as > Fourier himself did. (There is no mention of vector analysis -- curl, > divergence, etc. -- In Maxwell's Treatise on Electricity and Magnetism. > He used triple integrals instead. It's usually silly to claim that > something has to be real because math can't be accomplished without it.[snip] Maxwell did indeed use some triple integrals, but his original treatise on electromagnetics was all cast in terms of Hamilton's "quaternions". Quaternions were a popular mathematical technique for handling "complex vectors" at the time. Most folks today could not decipher Maxwell's work since like the dead language of Latin the dead language of quaternions is now known only to a few niche area mathematicians. Maxwell's original formulation of his celebrated equations comprised twenty two different quarternion equations! It was left to Oliver Heaviside to recast Maxwell's equations into the modern four equation vector form as we now know them. Heaviside knew quaternions but he hated them and he applied Williard Gibbs modernization of vector calculus to recast Maxwell's 33 quaternion equations down into 4 very concise vector differential equations. Maxwell was a doctoral level graduate of Cambridge, a Fellow of the Royal Society, and a full professor at Edinburgh University, while Oliver Heaviside was a poor disadvantaged youth from the London slums who quit school at age 16 and never studied mathematics or physics formally but taught himself quaternions, vector mathematics and who invented what we now call the LaPlace Transform techniques for solving differential equations. It was known as the Heaviside Operational Calculus, it always gave the correct answers but the Mathematicians said it was just not right because it had no rigorous proofs. Nevertheless he used it to "fix" the first transatlantic cable systems. Which he did for free by publishing the correct analysis and designs in popular magazines of the day. All this to say that... Heaviside knew well the meaning of negative frequencies, from his writings you can tell that he knew that they were real and he explained them often to doubters. Heaviside was eventually appointed a Fellow of the Royal Society and admired on a par with Lord Kelvin and Maxwell himself, but they all had given him so much grief and criticizm over his unorthodox approaches that he never bothered to go down to the Royal Society HQ to receive his Fellow appointment and certificate! [snip]> > The bottom line is: > > > > - we *can* express *real time domain signals* without using negative > > frequencies or complex quantities. Although, as you know, using complex > > quantities is pretty useful for doing some of the math. > > - we *can't* express the *spectra of real time domain signals* withoutusing> > complex quantities and negative frequencies.[snip] What are you gonna do for "complex time domain signals"? [snip]> In the early part of the last century, several people, notably Kelvin, I > think, designed machines that read out the first N coefficients of the > Fourier series of a curve that the stylus traced. (Gibbs showed that the > ringing near sharp transitions which appeared in reconstructed waveforms > were not defects of workmanship or design, hence "Gibbs' phenomenon.) No > negative frequencies appeared in the spectra those harmonic analyzers > produced. Just as in the time domain, negative frequencies arise from > the way we chose to calculate.[snip] Heaviside was a contemporary of Kelvin's and he clearly presented negative and positive frequencies as counter-rotating pairs of signals and outlined how one would need two harmonic analyzers to discern the negative frequencies from the positive. It's interesting how Heaviside back at the turn of the nineteenth century already knew of, accepted and illustrated the meaning of negative frequencies and today folks still doubt and argue about it! What? -- Peter Consultant Indialantic By-the-Sea, FL.
