On 12/24/2014 3:24 AM, Rob Doyle wrote:> On 12/23/2014 9:40 PM, rickman wrote: >> On 12/23/2014 11:02 PM, Rob Doyle wrote: >>> On 12/23/2014 6:10 PM, robert bristow-johnson wrote: >>>> >>>> this did not seem to get posted so i am reposting. sorry for any >>>> repeated post. >>>> >>>> On 12/22/14 5:17 PM, Rob Doyle wrote: >>>>> On 12/21/2014 5:13 PM, Eric Jacobsen wrote: >>>>>> On Sun, 21 Dec 2014 14:52:40 -0500, robert bristow-johnson >>>>>> <rbj@audioimagination.com> wrote: >>>>>> >>>>>>> On 12/19/14 11:04 PM, Eric Jacobsen wrote: >>>>>>>> On Fri, 19 Dec 2014 18:19:24 -0500, robert bristow-johnson >>>>>>>> <rbj@audioimagination.com> wrote: >>>>>>>> >>>>>>>>> On 12/19/14 10:06 AM, rickman wrote: >>>>>>>>>> I want to analyze the output of a DDS circuit and am >>>>>>>>>> wondering if an FFT is the best way to do this. I'm >>>>>>>>>> mainly concerned with the "close >>>> in" >>>>>>>>>> spurs that are often generated by a DDS. >>>>>>>>> >>>>>>>>> i still get the concepts of DDS and NCO mixed up. what are >>>>>>>>> the differences? >>>>>>>> >>>>>>>> One is spelled DDS and the other is spelled NCO. >>>>>>> >>>>>>> is the NCO the typical table-lookup kind (with phase >>>>>>> accumulator)? or can it be algorithmic? like >>>>>>> >>>>>>> y[n] = (2*cos(omega_0))*y[n-1] - y[n-2] >>>>>>> >>>>>>> where omega_0 is the normalized angular frequency of the >>>>>>> sinusoid and with appropriate initial states, y[-1] and y[-2] >>>>>>> to result in the amplitude and initial phase desired. >>>>>>> >>>>>>> is that an NCO that can be used in this DDS? or must it be >>>>>>> LUT? >>>>>> >>>>>> Generally NCO or DDS refers to a phase accumulator with a LUT, >>>>>> since it is easily implemented in hardware. That's a general >>>>>> architecture that is well-known and can be adjusted to produce >>>>>> very clean local oscillators. If somebody tried to sell me a >>>>>> block of IP with an "NCO" built some other way I'd be asking a >>>>>> lot of questions. >>>>> >>>>> I have built NCOs using CORDIC rotators. No lookup tables. They >>>>> pipeline nicely and are therefore very fast, they require no >>>>> multipliers [1], >>>> >>>> ??? >>>> >>>> i don't s'pose Ray Andraka is hanging around (he was Dr. CORDIC here >>>> a while back), but i always thought that CORDIC did essentially >>>> >>>> x[n] = cos(2*pi*f0/Fs) * x[n-1] - sin(2*pi*f0/Fs) * y[n-1] >>>> y[n] = sin(2*pi*f0/Fs) * x[n-1] + cos(2*pi*f0/Fs) * y[n-1] >>> >>> Yes. So far. So good. These are my notes if anyone is interested... >>> >>> [snip] >>> >>> Assume theta = 2*pi*f0*t/fs, i.e., theta is the output of a phase >>> accumulator for an NCO application. >>> >>> Factor out the cos(theta): >>> >>> x[n] = cos(theta) {x[n-1] - y[n-1] tan(theta)} >>> y[n] = cos(theta) {y[n-1] + x[n-1] tan(theta)} >>> >>> If you select tan(theta) from the set of 1/(2**i) then [1] this becomes: >>> >>> x[n] = cos(theta) {x[n-1] - y[n-1] / 2**i} >>> y[n] = cos(theta) {y[n-1] + x[n-1] / 2**i} >>> >>> At this point you might be thinking "Holy crap. That's one heck of a >>> constraint!" Yeh... but keep reading anyway. >>> >>> You can drop the cos(theta) common term. It's just a gain term that >>> rapidly converges to 1.647. Therefore the gain of a CORDIC is not 0 dB. >>> >>> x[n] = x[n-1] - y[n-1] / 2**i >>> y[n] = y[n-1] + x[n-1] / 2**i >>> >>> or (assuming twos complement math) - simply: >>> >>> x[n] = x[n-1] - y[n-1] >> i >>> y[n] = y[n-1] + x[n-1] >> i >>> >>> where >> is a shift right operation >>> >>> [1] As this point it seems as if an *extreme* limitation has been placed >>> on the selection of rotation angles. The equation above only describes >>> how to rotate an input signal by tan(theta) = 1/(2**i) - or by one of >>> the following angles: >>> >>> atan(1) (45.000000000000000000000000000000 degrees) >>> atan(1/2) (26.565051177077989351572193720453 degrees) >>> atan(1/4) (14.036243467926478582892320159163 degrees) >>> atan(1/8) (7.1250163489017975619533008412068 degrees) >>> atan(1/16) (3.5763343749973510306847789144588 degrees) >>> atan(1/32) (1.7899106082460693071502497760791 degrees) >>> >>> ...and so forth. >>> >>> The equation above does not describe how to rotate an input signal an >>> arbitrary angle! Although this is true; all is not lost. >>> >>> Notice that in general that theta/2 < tan(theta). >>> >>> This truth allows the CORDIC to be used iteratively to rotate any input >>> to any angle with any precision. IMO this is the genius of the CORDIC. >>> >>> I probably should have mentioned that you swap the rotation direction by >>> flipping the additions and subtractions. >>> >>> The term z[n] is introduced to accumulate the angle as the CORDIC >>> iterates. The term d[n] swaps the direction of rotation. Finally the >>> familiar recursive CORDIC equation can be written as follows: >>> >>> x[n] = x[n-1] - d[n] y[n-1] >> i >>> y[n] = y[n-1] + d[n] x[n-1] >> i >>> z[n] = z[n-1] - d[n] tan(1/2**i) >>> >>> where: >>> >>> d[n] is +1 for z[n-1] < theta. Clockwise rotation next. >>> d[n] is -1 for z[n-1] > theta. Counter-clockwise rotation next. >>> >>> No multiplies here. >> >> But this is the same as a multiply in terns of complexity, no? One >> large difference is that a multiply can be supported in commonly >> available hardware while this algorithm requires dedicated hardware or >> iterative software. > > I agree that the CORDIC has the same complexity as a multiply. I agree > that table-based algorithms using multipliers use less FPGA fabric. > > I was simply pointing out that there might be places where a CORDIC has > advantages over LUT-based NCOs. > > Especially if have ROM or multiplier limitations. > > I also wanted to point out that if you need to do a 20-bit (using your > 120dB example) complex downconversion for example, the CORDIC still > requires zero multipliers. > > If you want to do a 20-bit complex downconversion using a table-based > NCO followed by a complex mixer, you might need a *lot* of multipliers. > If you only have an 18-bit multiplier, each multiplication requires > (maybe up to) 4 multiplier blocks and you need 8 multiplications. > > I also /suspect/ that for any given device technology the CORDIC will > execute at higher speeds. > > Thats all...I understand, but the distinction between a multiplier and a CORDIC implementation is pretty pointless these days. If you have the space to implement a CORDIC wouldn't you have the space to implement an iterative multiply? I did a linear interpolation just because I could do the multiply iteratively while the previous sample was shifted out to the CODEC. One adder is the same as the CORDIC, no? I guess the difference is you only need one CORDIC while for a sine that is not an approximation you need two multipliers. I don't see how one would be faster than the other except for the case of a dedicated multiplier being much faster. -- Rick
Spectral Purity Measurement
Started by ●December 19, 2014
Reply by ●December 24, 20142014-12-24
On 12/24/14 4:13 AM, rickman wrote:> On 12/24/2014 3:24 AM, Rob Doyle wrote: >> On 12/23/2014 9:40 PM, rickman wrote: >>> On 12/23/2014 11:02 PM, Rob Doyle wrote: >>>> On 12/23/2014 6:10 PM, robert bristow-johnson wrote: >>>>> >>>>> ..... (a whole bunch of stuff) >so, Rick, did that built-in notch filter make any sense to you? it's so cheap in software that i would think it would be cheap in VHDL or whatever your hardware language is. and i would just do LUT with linear interpolation. extend the table by one point so that LUT[N] = LUT[0] and you won't have to worry about an additional wrap-around in the linear interpolation. linear interpolation has a sinc^2 frequency response, so it puts zeros smack into the middle of images which reduces their amplitude a lot if the content frequency is much less than the sample rate. if your LUT length is decently long (like 512 or 1K or more), you'll do pretty good regarding the "purity" of your sinusoid. and with a perfectly tuned notch filter with, say, a 1/3 octave BW, you'll know exactly what your impurities are in either time domain or frequency domain (if you FFT it). -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
On 12/24/2014 3:19 PM, robert bristow-johnson wrote:> On 12/24/14 4:13 AM, rickman wrote: >> On 12/24/2014 3:24 AM, Rob Doyle wrote: >>> On 12/23/2014 9:40 PM, rickman wrote: >>>> On 12/23/2014 11:02 PM, Rob Doyle wrote: >>>>> On 12/23/2014 6:10 PM, robert bristow-johnson wrote: >>>>>> >>>>>> ..... (a whole bunch of stuff) >> > > so, Rick, did that built-in notch filter make any sense to you? it's so > cheap in software that i would think it would be cheap in VHDL or > whatever your hardware language is. > > and i would just do LUT with linear interpolation. extend the table by > one point so that LUT[N] = LUT[0] and you won't have to worry about an > additional wrap-around in the linear interpolation. linear > interpolation has a sinc^2 frequency response, so it puts zeros smack > into the middle of images which reduces their amplitude a lot if the > content frequency is much less than the sample rate. if your LUT length > is decently long (like 512 or 1K or more), you'll do pretty good > regarding the "purity" of your sinusoid. > > and with a perfectly tuned notch filter with, say, a 1/3 octave BW, > you'll know exactly what your impurities are in either time domain or > frequency domain (if you FFT it).I thought I replied about the notch filter. I"m not clear on what it buys me. If I FFT the data without the filter I get the same spectrum with the signal present which does not interfere with the spectrum. So what is the point? None of the analysis stuff will be implemented in hardware, so that is not an issue. BTW, in a sine table for linear interpolation, I don't use sine(0) as the value in LUT(0). I give the points a half step phase offset with the linear interp signed. I also offset the values to minimize the error over the step range which will be interpolated. BTW, LUT(N) won't equal LUT(0). Only 90° is stored so that in your table LUT(0) = 0 and LUT(256) = 1. In my table each of the values are non-zero and not 1 although if the table is large enough, the value of LUT(N-1) is also 1. Having a table of 2^N+1 entries is a PITA in hardware. -- Rick
On 12/24/14 4:43 PM, rickman wrote:> On 12/24/2014 3:19 PM, robert bristow-johnson wrote: >> On 12/24/14 4:13 AM, rickman wrote: >>> On 12/24/2014 3:24 AM, Rob Doyle wrote: >>>> On 12/23/2014 9:40 PM, rickman wrote: >>>>> On 12/23/2014 11:02 PM, Rob Doyle wrote: >>>>>> On 12/23/2014 6:10 PM, robert bristow-johnson wrote: >>>>>>> >>>>>>> ..... (a whole bunch of stuff) >>> >>...>> >> and with a perfectly tuned notch filter with, say, a 1/3 octave BW, >> you'll know exactly what your impurities are in either time domain or >> frequency domain (if you FFT it). > > I thought I replied about the notch filter. I"m not clear on what it > buys me. If I FFT the data without the filter I get the same spectrum > with the signal present which does not interfere with the spectrum.do you know exactly what to subtract from the FFT to get whatever your residual nasty stuff is? is that bump a sidelobe of your windowed sinusoid or is it part of the "impurity" that you're measuring?> So > what is the point? None of the analysis stuff will be implemented in > hardware, so that is not an issue. > > BTW, in a sine table for linear interpolation, I don't use sine(0) as > the value in LUT(0).i don't think that matters.> I give the points a half step phase offset with the > linear interp signed.nor that.> I also offset the values to minimize the error > over the step range which will be interpolated.so it's kinda an optimal phase offset that gets your quantized sine values the least error (however the total error is defined).> BTW, LUT(N) won't equal LUT(0).it's N+1 points instead of N. so it's the same N points you would have had anyway, with one more added.> Only 90° is stored so that in your table LUT(0) = 0 and LUT(256) = 1.okay. i guess i'm looking at resources more like a software guy would. if i were coding this for a DSP chip or something, i would just quadruple the number of entries and have a single cycle of the waveform, whatever it is.> In my table each of the values are non-zero and not 1 although if > the table is large enough, the value of LUT(N-1) is also 1. Having a > table of 2^N+1 entries is a PITA in hardware.i understand. ((2*pi)/N)/2 radians offset so the points are the same symmetry for each quadrant. and then it's sign manipulation that the hardware folk don't mind fiddling with. but you still know the frequency in advance and a notch filter can be tuned to that frequency. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
On 12/24/2014 6:56 PM, robert bristow-johnson wrote:> On 12/24/14 4:43 PM, rickman wrote: >> On 12/24/2014 3:19 PM, robert bristow-johnson wrote: >>> On 12/24/14 4:13 AM, rickman wrote: >>>> On 12/24/2014 3:24 AM, Rob Doyle wrote: >>>>> On 12/23/2014 9:40 PM, rickman wrote: >>>>>> On 12/23/2014 11:02 PM, Rob Doyle wrote: >>>>>>> On 12/23/2014 6:10 PM, robert bristow-johnson wrote: >>>>>>>> >>>>>>>> ..... (a whole bunch of stuff) >>>> >>> > ... >>> >>> and with a perfectly tuned notch filter with, say, a 1/3 octave BW, >>> you'll know exactly what your impurities are in either time domain or >>> frequency domain (if you FFT it). >> >> I thought I replied about the notch filter. I"m not clear on what it >> buys me. If I FFT the data without the filter I get the same spectrum >> with the signal present which does not interfere with the spectrum. > > do you know exactly what to subtract from the FFT to get whatever your > residual nasty stuff is? is that bump a sidelobe of your windowed > sinusoid or is it part of the "impurity" that you're measuring?I believe you are making this too complex. The measurement is a one time thing. I can use as large a transform as I am willing to wait for and therefore minimize the sidelobes. The measurement should be good enough that if I can't measure it, I won't really care about it. Check out these plots... https://sites.google.com/site/fpgastuff/dds_oddities.pdf The last page has some interesting data.>> So >> what is the point? None of the analysis stuff will be implemented in >> hardware, so that is not an issue. >> >> BTW, in a sine table for linear interpolation, I don't use sine(0) as >> the value in LUT(0). > > i don't think that matters. > >> I give the points a half step phase offset with the >> linear interp signed. > > nor that. > >> I also offset the values to minimize the error >> over the step range which will be interpolated. > > so it's kinda an optimal phase offset that gets your quantized sine > values the least error (however the total error is defined). > >> BTW, LUT(N) won't equal LUT(0). > > it's N+1 points instead of N. so it's the same N points you would have > had anyway, with one more added. > >> Only 90° is stored so that in your table LUT(0) = 0 and LUT(256) = 1. > > okay. i guess i'm looking at resources more like a software guy would. > if i were coding this for a DSP chip or something, i would just > quadruple the number of entries and have a single cycle of the waveform, > whatever it is.Even in software that can get expensive. The LUT is O(2^N) in size so you don't want N to get too large. *Much* better to use your N for storing useful data rather than duplicate info.>> In my table each of the values are non-zero and not 1 although if >> the table is large enough, the value of LUT(N-1) is also 1. Having a >> table of 2^N+1 entries is a PITA in hardware. > > i understand. ((2*pi)/N)/2 radians offset so the points are the same > symmetry for each quadrant. and then it's sign manipulation that the > hardware folk don't mind fiddling with. > > but you still know the frequency in advance and a notch filter can be > tuned to that frequency.If there is a purpose to it. -- Rick
On 12/24/2014 7:48 PM, rickman wrote:> On 12/24/2014 6:56 PM, robert bristow-johnson wrote: >> On 12/24/14 4:43 PM, rickman wrote: >>> On 12/24/2014 3:19 PM, robert bristow-johnson wrote: >>>> On 12/24/14 4:13 AM, rickman wrote: >>>>> On 12/24/2014 3:24 AM, Rob Doyle wrote: >>>>>> On 12/23/2014 9:40 PM, rickman wrote: >>>>>>> On 12/23/2014 11:02 PM, Rob Doyle wrote: >>>>>>>> On 12/23/2014 6:10 PM, robert bristow-johnson wrote: >>>>>>>>> >>>>>>>>> ..... (a whole bunch of stuff) >>>>> >>>> >> ... >>>> >>>> and with a perfectly tuned notch filter with, say, a 1/3 octave BW, >>>> you'll know exactly what your impurities are in either time domain or >>>> frequency domain (if you FFT it). >>> >>> I thought I replied about the notch filter. I"m not clear on what it >>> buys me. If I FFT the data without the filter I get the same spectrum >>> with the signal present which does not interfere with the spectrum. >> >> do you know exactly what to subtract from the FFT to get whatever your >> residual nasty stuff is? is that bump a sidelobe of your windowed >> sinusoid or is it part of the "impurity" that you're measuring? > > I believe you are making this too complex. The measurement is a one > time thing. I can use as large a transform as I am willing to wait for > and therefore minimize the sidelobes. The measurement should be good > enough that if I can't measure it, I won't really care about it. > > Check out these plots... > > https://sites.google.com/site/fpgastuff/dds_oddities.pdf > > The last page has some interesting data.I hit send too quickly. I also meant to point out that the spurs of interest are the ones closer to the carrier. How well can I filter the carrier without filtering the side lobes?>>> So >>> what is the point? None of the analysis stuff will be implemented in >>> hardware, so that is not an issue. >>> >>> BTW, in a sine table for linear interpolation, I don't use sine(0) as >>> the value in LUT(0). >> >> i don't think that matters. >> >>> I give the points a half step phase offset with the >>> linear interp signed. >> >> nor that. >> >>> I also offset the values to minimize the error >>> over the step range which will be interpolated. >> >> so it's kinda an optimal phase offset that gets your quantized sine >> values the least error (however the total error is defined). >> >>> BTW, LUT(N) won't equal LUT(0). >> >> it's N+1 points instead of N. so it's the same N points you would have >> had anyway, with one more added. >> >>> Only 90° is stored so that in your table LUT(0) = 0 and LUT(256) = 1. >> >> okay. i guess i'm looking at resources more like a software guy would. >> if i were coding this for a DSP chip or something, i would just >> quadruple the number of entries and have a single cycle of the waveform, >> whatever it is. > > Even in software that can get expensive. The LUT is O(2^N) in size so > you don't want N to get too large. *Much* better to use your N for > storing useful data rather than duplicate info. > > >>> In my table each of the values are non-zero and not 1 although if >>> the table is large enough, the value of LUT(N-1) is also 1. Having a >>> table of 2^N+1 entries is a PITA in hardware. >> >> i understand. ((2*pi)/N)/2 radians offset so the points are the same >> symmetry for each quadrant. and then it's sign manipulation that the >> hardware folk don't mind fiddling with. >> >> but you still know the frequency in advance and a notch filter can be >> tuned to that frequency. > > If there is a purpose to it. >-- Rick
Reply by ●December 25, 20142014-12-25
In comp.dsp Rob Doyle <radioengr@gmail.com> wrote:> On 12/23/2014 6:10 PM, robert bristow-johnson wrote:(snip)>> i don't s'pose Ray Andraka is hanging around (he was Dr. CORDIC here >> a while back), but i always thought that CORDIC did essentially>> x[n] = cos(2*pi*f0/Fs) * x[n-1] - sin(2*pi*f0/Fs) * y[n-1] >> y[n] = sin(2*pi*f0/Fs) * x[n-1] + cos(2*pi*f0/Fs) * y[n-1]> Yes. So far. So good. These are my notes if anyone is interested...> [snip]> Assume theta = 2*pi*f0*t/fs, i.e., theta is the output of a phase > accumulator for an NCO application.> Factor out the cos(theta):> x[n] = cos(theta) {x[n-1] - y[n-1] tan(theta)} > y[n] = cos(theta) {y[n-1] + x[n-1] tan(theta)}> If you select tan(theta) from the set of 1/(2**i) > then [1] this becomes:Nice if you are doing it in binary, but many hand calculators do it in decimal. I believe I have seen the explanation once, but it is much harder to find than the binary version. This goes back to at least the beginning of HP hand calculators.> x[n] = cos(theta) {x[n-1] - y[n-1] / 2**i} > y[n] = cos(theta) {y[n-1] + x[n-1] / 2**i}> At this point you might be thinking "Holy crap. That's one heck of a > constraint!" Yeh... but keep reading anyway.> You can drop the cos(theta) common term. It's just a gain term that > rapidly converges to 1.647. Therefore the gain of a CORDIC is not 0 dB.> x[n] = x[n-1] - y[n-1] / 2**i > y[n] = y[n-1] + x[n-1] / 2**i> or (assuming twos complement math) - simply:> x[n] = x[n-1] - y[n-1] >> i > y[n] = y[n-1] + x[n-1] >> i> where >> is a shift right operation> [1] As this point it seems as if an *extreme* limitation has been placed > on the selection of rotation angles. The equation above only describes > how to rotate an input signal by tan(theta) = 1/(2**i) - or by one of > the following angles:> atan(1) (45.000000000000000000000000000000 degrees) > atan(1/2) (26.565051177077989351572193720453 degrees) > atan(1/4) (14.036243467926478582892320159163 degrees) > atan(1/8) (7.1250163489017975619533008412068 degrees) > atan(1/16) (3.5763343749973510306847789144588 degrees) > atan(1/32) (1.7899106082460693071502497760791 degrees)(snip) -- glen
On Tue, 23 Dec 2014 18:10:43 -0500, rickman <gnuarm@gmail.com> wrote:>On 12/23/2014 4:48 PM, Eric Jacobsen wrote: >> On Tue, 23 Dec 2014 11:06:39 -0500, rickman <gnuarm@gmail.com> wrote: >> >>> On 12/23/2014 10:35 AM, Eric Jacobsen wrote: >>>> On Mon, 22 Dec 2014 15:17:23 -0700, Rob Doyle <radioengr@gmail.com> >>>> wrote: >>>> >>>>> On 12/21/2014 5:13 PM, Eric Jacobsen wrote: >>>>>> On Sun, 21 Dec 2014 14:52:40 -0500, robert bristow-johnson >>>>>> <rbj@audioimagination.com> wrote: >>>>>> >>>>>>> On 12/19/14 11:04 PM, Eric Jacobsen wrote: >>>>>>>> On Fri, 19 Dec 2014 18:19:24 -0500, robert bristow-johnson >>>>>>>> <rbj@audioimagination.com> wrote: >>>>>>>> >>>>>>>>> On 12/19/14 10:06 AM, rickman wrote: >>>>>>>>>> I want to analyze the output of a DDS circuit and am wondering if an FFT >>>>>>>>>> is the best way to do this. I'm mainly concerned with the "close in" >>>>>>>>>> spurs that are often generated by a DDS. >>>>>>>>> >>>>>>>>> i still get the concepts of DDS and NCO mixed up. what are the differences? >>>>>>>> >>>>>>>> One is spelled DDS and the other is spelled NCO. >>>>>>> >>>>>>> is the NCO the typical table-lookup kind (with phase accumulator)? or >>>>>>> can it be algorithmic? like >>>>>>> >>>>>>> y[n] = (2*cos(omega_0))*y[n-1] - y[n-2] >>>>>>> >>>>>>> where omega_0 is the normalized angular frequency of the sinusoid and >>>>>>> with appropriate initial states, y[-1] and y[-2] to result in the >>>>>>> amplitude and initial phase desired. >>>>>>> >>>>>>> is that an NCO that can be used in this DDS? or must it be LUT? >>>>>> >>>>>> Generally NCO or DDS refers to a phase accumulator with a LUT, since >>>>>> it is easily implemented in hardware. That's a general architecture >>>>>> that is well-known and can be adjusted to produce very clean local >>>>>> oscillators. If somebody tried to sell me a block of IP with an >>>>>> "NCO" built some other way I'd be asking a lot of questions. >>>>> >>>>> I have built NCOs using CORDIC rotators. No lookup tables. They pipeline >>>>> nicely and are therefore very fast, they require no multipliers [1], >>>>> they generate quadrature outputs for free, they can perform frequency >>>>> translations for free (again no multipliers), and they are simple prove >>>>> numerical accuracy. >>>> >>>> CORDICs are fine when and where they make sense, but they are often >>>> not the best tradeoff. If you have no memory, no multipliers, or >>>> gates are way cheaper than memory, and if the latency is tolerable, >>>> then a CORDIC may be a good option. >>>> >>>>> [1] Maybe not a huge issue these days. The LUT-based NCOs requires two >>>>> multipliers to combine the coarse and fine LUTs (four multipliers if you >>>>> need a complex NCO output) and perhaps another four multipliers if you >>>>> need to do a frequency translation. >>>> >>>> Many applications don't need separate LUTs to get the required >>>> performance, and even then, or even in the case of complex output, it >>>> can be done without multipliers. >>> >>> Care to elaborate on this? I'm not at all clear on how you make a LUT >>> based NCO without LUTs and unless you are using a very coarse >>> approximation, without multipliers. >> >> Not sure what you're asking. You a need a LUT, but just one in many >> cases. Having a dual-ported single LUT is easy in an FPGA and >> usually in silicon as well. >> >> What makes a multiplier necessary? I've never found the need, but my >> apps are limited to comm. > >Maybe we aren't on the same page. The multiplier is there for the fine >adjustment. If you are happy with some -60 or -80 dB spurs one LUT is >fine. But if you want better performance the single LUT approach >requires *very* large tables.There are a lot of tricks that can be used to keep the table size down. I've mentioned one already. Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
On Wed, 24 Dec 2014 01:24:42 -0700, Rob Doyle <radioengr@gmail.com> wrote:>On 12/23/2014 9:40 PM, rickman wrote: >> On 12/23/2014 11:02 PM, Rob Doyle wrote: >>> On 12/23/2014 6:10 PM, robert bristow-johnson wrote: >>>> >>>> this did not seem to get posted so i am reposting. sorry for any >>>> repeated post. >>>> >>>> On 12/22/14 5:17 PM, Rob Doyle wrote: >>>>> On 12/21/2014 5:13 PM, Eric Jacobsen wrote: >>>>>> On Sun, 21 Dec 2014 14:52:40 -0500, robert bristow-johnson >>>>>> <rbj@audioimagination.com> wrote: >>>>>> >>>>>>> On 12/19/14 11:04 PM, Eric Jacobsen wrote: >>>>>>>> On Fri, 19 Dec 2014 18:19:24 -0500, robert bristow-johnson >>>>>>>> <rbj@audioimagination.com> wrote: >>>>>>>> >>>>>>>>> On 12/19/14 10:06 AM, rickman wrote: >>>>>>>>>> I want to analyze the output of a DDS circuit and am >>>>>>>>>> wondering if an FFT is the best way to do this. I'm >>>>>>>>>> mainly concerned with the "close >>>> in" >>>>>>>>>> spurs that are often generated by a DDS. >>>>>>>>> >>>>>>>>> i still get the concepts of DDS and NCO mixed up. what are >>>>>>>>> the differences? >>>>>>>> >>>>>>>> One is spelled DDS and the other is spelled NCO. >>>>>>> >>>>>>> is the NCO the typical table-lookup kind (with phase >>>>>>> accumulator)? or can it be algorithmic? like >>>>>>> >>>>>>> y[n] = (2*cos(omega_0))*y[n-1] - y[n-2] >>>>>>> >>>>>>> where omega_0 is the normalized angular frequency of the >>>>>>> sinusoid and with appropriate initial states, y[-1] and y[-2] >>>>>>> to result in the amplitude and initial phase desired. >>>>>>> >>>>>>> is that an NCO that can be used in this DDS? or must it be >>>>>>> LUT? >>>>>> >>>>>> Generally NCO or DDS refers to a phase accumulator with a LUT, >>>>>> since it is easily implemented in hardware. That's a general >>>>>> architecture that is well-known and can be adjusted to produce >>>>>> very clean local oscillators. If somebody tried to sell me a >>>>>> block of IP with an "NCO" built some other way I'd be asking a >>>>>> lot of questions. >>>>> >>>>> I have built NCOs using CORDIC rotators. No lookup tables. They >>>>> pipeline nicely and are therefore very fast, they require no >>>>> multipliers [1], >>>> >>>> ??? >>>> >>>> i don't s'pose Ray Andraka is hanging around (he was Dr. CORDIC here >>>> a while back), but i always thought that CORDIC did essentially >>>> >>>> x[n] = cos(2*pi*f0/Fs) * x[n-1] - sin(2*pi*f0/Fs) * y[n-1] >>>> y[n] = sin(2*pi*f0/Fs) * x[n-1] + cos(2*pi*f0/Fs) * y[n-1] >>> >>> Yes. So far. So good. These are my notes if anyone is interested... >>> >>> [snip] >>> >>> Assume theta = 2*pi*f0*t/fs, i.e., theta is the output of a phase >>> accumulator for an NCO application. >>> >>> Factor out the cos(theta): >>> >>> x[n] = cos(theta) {x[n-1] - y[n-1] tan(theta)} >>> y[n] = cos(theta) {y[n-1] + x[n-1] tan(theta)} >>> >>> If you select tan(theta) from the set of 1/(2**i) then [1] this becomes: >>> >>> x[n] = cos(theta) {x[n-1] - y[n-1] / 2**i} >>> y[n] = cos(theta) {y[n-1] + x[n-1] / 2**i} >>> >>> At this point you might be thinking "Holy crap. That's one heck of a >>> constraint!" Yeh... but keep reading anyway. >>> >>> You can drop the cos(theta) common term. It's just a gain term that >>> rapidly converges to 1.647. Therefore the gain of a CORDIC is not 0 dB. >>> >>> x[n] = x[n-1] - y[n-1] / 2**i >>> y[n] = y[n-1] + x[n-1] / 2**i >>> >>> or (assuming twos complement math) - simply: >>> >>> x[n] = x[n-1] - y[n-1] >> i >>> y[n] = y[n-1] + x[n-1] >> i >>> >>> where >> is a shift right operation >>> >>> [1] As this point it seems as if an *extreme* limitation has been placed >>> on the selection of rotation angles. The equation above only describes >>> how to rotate an input signal by tan(theta) = 1/(2**i) - or by one of >>> the following angles: >>> >>> atan(1) (45.000000000000000000000000000000 degrees) >>> atan(1/2) (26.565051177077989351572193720453 degrees) >>> atan(1/4) (14.036243467926478582892320159163 degrees) >>> atan(1/8) (7.1250163489017975619533008412068 degrees) >>> atan(1/16) (3.5763343749973510306847789144588 degrees) >>> atan(1/32) (1.7899106082460693071502497760791 degrees) >>> >>> ...and so forth. >>> >>> The equation above does not describe how to rotate an input signal an >>> arbitrary angle! Although this is true; all is not lost. >>> >>> Notice that in general that theta/2 < tan(theta). >>> >>> This truth allows the CORDIC to be used iteratively to rotate any input >>> to any angle with any precision. IMO this is the genius of the CORDIC. >>> >>> I probably should have mentioned that you swap the rotation direction by >>> flipping the additions and subtractions. >>> >>> The term z[n] is introduced to accumulate the angle as the CORDIC >>> iterates. The term d[n] swaps the direction of rotation. Finally the >>> familiar recursive CORDIC equation can be written as follows: >>> >>> x[n] = x[n-1] - d[n] y[n-1] >> i >>> y[n] = y[n-1] + d[n] x[n-1] >> i >>> z[n] = z[n-1] - d[n] tan(1/2**i) >>> >>> where: >>> >>> d[n] is +1 for z[n-1] < theta. Clockwise rotation next. >>> d[n] is -1 for z[n-1] > theta. Counter-clockwise rotation next. >>> >>> No multiplies here. >> >> But this is the same as a multiply in terns of complexity, no? One >> large difference is that a multiply can be supported in commonly >> available hardware while this algorithm requires dedicated hardware or >> iterative software. > >I agree that the CORDIC has the same complexity as a multiply. I agree >that table-based algorithms using multipliers use less FPGA fabric. > >I was simply pointing out that there might be places where a CORDIC has >advantages over LUT-based NCOs. > >Especially if have ROM or multiplier limitations. > >I also wanted to point out that if you need to do a 20-bit (using your >120dB example) complex downconversion for example, the CORDIC still >requires zero multipliers. > >If you want to do a 20-bit complex downconversion using a table-based >NCO followed by a complex mixer, you might need a *lot* of multipliers. >If you only have an 18-bit multiplier, each multiplication requires >(maybe up to) 4 multiplier blocks and you need 8 multiplications. > >I also /suspect/ that for any given device technology the CORDIC will >execute at higher speeds. > >Thats all...That's been my experience; that if multipliers are scarce or too expensive, or memory is scarce or too expensive, then a CORDIC is a nice back-up option. These days multipliers and memory are both plentiful in most platforms, so CORDICs just aren't as useful as they used to be. The latency is sometimes an issue as well. There are still some places where they make sense, though.>>> The CORDIC simply does a successive approximation to the angle - >>> rotating the angle clockwise or counter-clockwise by these limited >>> selection of angles as necessary to converge on the desired angle. Each >>> time the iteration occurs, the angle error is reduced by at least half. >>> >>>> doesn't that require a few multiplications? >>> >>> Nope. Just adds/subtracts - the sign of the angle error determines which >>> direction to rotate on the next iteration. If this is pipelined, the >>> shifts aren't real - they just select which bits of the previous >>> iteration are used on the next iteration. The tan(1/2**i) term is a >>> constant for each iteration. >>> >>> As an implementation detail, it saves hardware if you iterate from >>> the angle toward zero instead of from zero toward the angle. If you do >>> that, the sign of z[i] is the direction of rotation. It saves a >>> magnitude compare for each iteration. >>> >>> Rob. >> >> >Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
On Wed, 24 Dec 2014 18:56:41 -0500, robert bristow-johnson <rbj@audioimagination.com> wrote:>On 12/24/14 4:43 PM, rickman wrote: >> On 12/24/2014 3:19 PM, robert bristow-johnson wrote: >>> On 12/24/14 4:13 AM, rickman wrote: >>>> On 12/24/2014 3:24 AM, Rob Doyle wrote: >>>>> On 12/23/2014 9:40 PM, rickman wrote: >>>>>> On 12/23/2014 11:02 PM, Rob Doyle wrote: >>>>>>> On 12/23/2014 6:10 PM, robert bristow-johnson wrote: >>>>>>>> >>>>>>>> ..... (a whole bunch of stuff) >>>> >>> >... >>> >>> and with a perfectly tuned notch filter with, say, a 1/3 octave BW, >>> you'll know exactly what your impurities are in either time domain or >>> frequency domain (if you FFT it). >> >> I thought I replied about the notch filter. I"m not clear on what it >> buys me. If I FFT the data without the filter I get the same spectrum >> with the signal present which does not interfere with the spectrum. > >do you know exactly what to subtract from the FFT to get whatever your >residual nasty stuff is? is that bump a sidelobe of your windowed >sinusoid or is it part of the "impurity" that you're measuring? > >> So >> what is the point? None of the analysis stuff will be implemented in >> hardware, so that is not an issue. >> >> BTW, in a sine table for linear interpolation, I don't use sine(0) as >> the value in LUT(0). > >i don't think that matters. > >> I give the points a half step phase offset with the >> linear interp signed. > >nor that.Actually, not having a zero entries in the table for the zero crossings can help solve some common problems with artifacts like spurs (for oscillators) and jitter (for clock generators). The case for the clock output is easy to explain, since the MSB duty cycle is not symmetric when there are two zero entries. Just offsetting the phase a tiny bit, even to just one LSB present in the table output near the zero crossing, makes the MSB duty cycle 50% in the table.>> I also offset the values to minimize the error >> over the step range which will be interpolated. > >so it's kinda an optimal phase offset that gets your quantized sine >values the least error (however the total error is defined). > >> BTW, LUT(N) won't equal LUT(0). > >it's N+1 points instead of N. so it's the same N points you would have >had anyway, with one more added.Which means you just doubled the size of the memory.>> Only 90° is stored so that in your table LUT(0) = 0 and LUT(256) = 1. > >okay. i guess i'm looking at resources more like a software guy would. > if i were coding this for a DSP chip or something, i would just >quadruple the number of entries and have a single cycle of the waveform, >whatever it is.A quarter cycle is all that's really needed.>> In my table each of the values are non-zero and not 1 although if >> the table is large enough, the value of LUT(N-1) is also 1. Having a >> table of 2^N+1 entries is a PITA in hardware. > >i understand. ((2*pi)/N)/2 radians offset so the points are the same >symmetry for each quadrant. and then it's sign manipulation that the >hardware folk don't mind fiddling with. > >but you still know the frequency in advance and a notch filter can be >tuned to that frequency.If there's only one frequency needed and it's known in advance, you may not need a DDS/NCO. Usually an NCO is used because it needs to vary a bit either for tracking or tuning or other adjustments. Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
