Last week I posted blog article on Chapter 4 of Think DSP, which is about noise: http://thinkdsp.blogspot.com/2015/01/think-dsp-chapter-4-noise.html The article includes this notebook, where I present the missing fundamental effect, where we hear a low pitch even if the signal contains no power at that frequency: http://nbviewer.ipython.org/github/AllenDowney/ThinkDSP/blob/master/code/saxophone.ipynb This week I posted Chapter 5, which is about autocorrelation http://thinkdsp.blogspot.com/2015/01/think-dsp-chapter-5-autocorrelation.html The article includes this notebook, which uses autocorrelation to crack the case of the missing fundamental: http://nbviewer.ipython.org/github/AllenDowney/ThinkDSP/blob/master/code/saxophone2.ipynb As always, comments from Comp.DSP are welcome (but let's try not to get bogged down on the plural of spectrum :) _____________________________ Posted through www.DSPRelated.com
Update on Think DSP, and an explanation of the missing fundamental effect
Started by ●January 21, 2015
Reply by ●January 21, 20152015-01-21
This effect is the basis for bass extension algorithms where you create harmonics to get fake bass from small speakers. But my experience is that it doesn't work so well. What happens when the input signal is not a solo instrument with a periodic waveform? Then it just makes a mess of things. Commercial bass-boost algorithms combine harmonic generation with old-fashioned dynamic bass boost to handle the non-harmonic cases like a kick drum. But they don't mention this in their advertising. Regarding the mechanism for how the ear perceives the missing fundamental, I don't believe that there is any explicit autocorrelation mechanism. A more likely explanation is the modulation of the envelope of the signal which will occur at the fundamental frequency even if the fundamental is not present. Bob
On Wed, 21 Jan 2015 09:52:00 -0800, radams2000 wrote:> This effect is the basis for bass extension algorithms where you create > harmonics to get fake bass from small speakers. But my experience is > that it doesn't work so well. What happens when the input signal is not > a solo instrument with a periodic waveform? Then it just makes a mess of > things. Commercial bass-boost algorithms combine harmonic generation > with old-fashioned dynamic bass boost to handle the non-harmonic cases > like a kick drum. But they don't mention this in their advertising. > > Regarding the mechanism for how the ear perceives the missing > fundamental, I don't believe that there is any explicit autocorrelation > mechanism. A more likely explanation is the modulation of the envelope > of the signal which will occur at the fundamental frequency even if the > fundamental is not present. > > BobNot an autocorrelation function as such, since the ears sense sound in a sort of combination frequency/time manner (oooh! Wavelets!). The ear senses sound with something like a massive bank of filters ("hair cells", which are embedded in the cochlea, which has a definite frequency/ distance dependence). If you grow up in an environment where sounds tend to have lots of overtones, your brain will naturally tend to correlate f, 2f, 3f, etc. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Tim Wescott <seemywebsite@myfooter.really> wrote:> On Wed, 21 Jan 2015 09:52:00 -0800, radams2000 wrote:>> This effect is the basis for bass extension algorithms where you create >> harmonics to get fake bass from small speakers. But my experience is >> that it doesn't work so well.(snip)> Not an autocorrelation function as such, since the ears sense sound in a > sort of combination frequency/time manner (oooh! Wavelets!).> The ear senses sound with something like a massive bank of filters ("hair > cells", which are embedded in the cochlea, which has a definite frequency/ > distance dependence). If you grow up in an environment where sounds tend > to have lots of overtones, your brain will naturally tend to correlate f, > 2f, 3f, etc.Some years ago I had a book that included a floppy-ROM (also known as an analog audio recording) with stretched octaves. They made musical sounds that used 2.1x instead of 2x for an octave, and of course they sounded very non-musical. The experiment they didn't do (for a good reason) was to raise babies so that they only heard stretched octaves. The neural connections would form differently. Similarly, as far as I know they way our brains learn to figure out color vision is through the correlations in the signals coming in. If babies were raised in a colorless environment, they might not learn how to decode colors. It might be that the feeling each of us feels when we see a color depends on how the wiring was done when we were young. That is, on the first colors that we saw, and how we saw them. But again, an experiment not likely to be done. -- glen
On Wed, 21 Jan 2015 19:33:56 +0000, glen herrmannsfeldt wrote:> Tim Wescott <seemywebsite@myfooter.really> wrote: >> On Wed, 21 Jan 2015 09:52:00 -0800, radams2000 wrote: > >>> This effect is the basis for bass extension algorithms where you >>> create harmonics to get fake bass from small speakers. But my >>> experience is that it doesn't work so well. > > (snip) >> Not an autocorrelation function as such, since the ears sense sound in >> a sort of combination frequency/time manner (oooh! Wavelets!). > >> The ear senses sound with something like a massive bank of filters >> ("hair cells", which are embedded in the cochlea, which has a definite >> frequency/ >> distance dependence). If you grow up in an environment where sounds >> tend to have lots of overtones, your brain will naturally tend to >> correlate f, 2f, 3f, etc. > > > Some years ago I had a book that included a floppy-ROM (also known as an > analog audio recording) with stretched octaves. > > They made musical sounds that used 2.1x instead of 2x for an octave, and > of course they sounded very non-musical. > > The experiment they didn't do (for a good reason) was to raise babies so > that they only heard stretched octaves. The neural connections would > form differently. > > Similarly, as far as I know they way our brains learn to figure out > color vision is through the correlations in the signals coming in. If > babies were raised in a colorless environment, they might not learn how > to decode colors. > > It might be that the feeling each of us feels when we see a color > depends on how the wiring was done when we were young. That is, on the > first colors that we saw, and how we saw them. But again, an experiment > not likely to be done.Kittens raised in an environment that has no visible edges cannot, after a certain age, ever learn to see edges. So it's similar. You could maybe do the sound experiment with songbirds, then analyze what comes out when they grow up. It'd be hard, though, since one hears the sounds one produces, and those have harmonically related overtones. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Reply by ●January 22, 20152015-01-22
On 1/21/2015 8:29 AM, AllenDowney wrote:> Last week I posted blog article on Chapter 4 of Think DSP, which is about > noise: > > http://thinkdsp.blogspot.com/2015/01/think-dsp-chapter-4-noise.html >Allen: Your opus rocks!! I am learning and installing Python just so I can run your examples. Congrats and thanks. -Ramon
This is a multi-part message in MIME format. --------------070103070707040001090005 Content-Type: text/plain; charset=windows-1252; format=flowed Content-Transfer-Encoding: 7bit Allen: Please find attached a noise that is the bane of my existence, my "Ahab's Whale". The sample includes the breath of the speaker (who *did* inhale), and it comes from here: https://www.youtube.com/watch?v=Aju752l0tP4 (the noise starts at minute 1 and goes all the way to the end) Feel free to add a chapter on how to remove it. ;-) TIA, -Ramon On 1/21/2015 8:29 AM, AllenDowney wrote:> Last week I posted blog article on Chapter 4 of Think DSP, which is about > noise: > > http://thinkdsp.blogspot.com/2015/01/think-dsp-chapter-4-noise.html >--------------070103070707040001090005 Content-Type: audio/wav; name="WhatKindOfNoiseIsThis.wav" Content-Transfer-Encoding: base64 Content-Disposition: attachment; filename="WhatKindOfNoiseIsThis.wav" UklGRqRIAgBXQVZFZm10IBAAAAABAAIARKwAABCxAgAEABAAZGF0YYBIAgDl//D/sv/R/6L/ yP+2/9T/5P/w/xoADwBGACkAZwA9AIMATwChAGAAvwByANAAfADMAHoAsQBpAIcAUQBaADYA LAAbAP3////V/+f/vP/Y/7D/0v+i/8n/dv+u/yb/fv/R/kz/qf40/87+S/8z/4f/pP/K/+v/ 8//u//b/v//a/4H/tf9X/5v/VP+b/3v/sf+3/9X/7f/z/////v/u//X/2//o/+z/9P8xABwA hQBNAKMAYABRAC8Ai/+6/4X+H/+E/YT+uPwM/iv8uP3C+3r9Xvs+/fX6AP2Y+sj8VPqg/DL6 i/wW+nz86flh/Kz5PPyI+Sf8uvlF/Fz6pvxH+zH9Ivy0/av8BP7i/CT+BP06/k79Zf6t/Z/+ 2/26/ov9i/6+/BH+uft1/dn68PxQ+p78Evp6/O/5ZvzJ+U/8k/ku/FL5CPwF+dr7svip+2T4 e/sz+F37JvhV+zb4X/tK+Gv7XPh2+3H4gvuV+Jf7xfiz+/T4z/sW+eT7Mfn0+1H5Bvxz+Rv8 h/km/Ir5KPyL+Sn8oPk1/ML5SvzE+Uv8d/kc/OT4xPtd+HT7Tfhq+9T4u/un+Tn8RPqV/Ev6 mvzO+U/8M/nz+934wPvl+MX7G/nm+zr5+Psf+ej71Pi7+3z4iPs3+F77G/hO+zj4X/uG+I37 7PjK+zz5+vtZ+Qz8R/kB/Cv58fsv+fL7VvkK/If5KPyj+Tj8nPk0/Hr5IPxQ+Qf8J/nt+/z4 1vvV+L/7tfit+6L4oPuS+Jb7gPiM+3H4hPtz+IX7jviU+7n4rvvh+MX79vjS+/v41fsE+dv7 HPnp+zn5+ftL+QT8S/kE/EH5/vs5+fr7Pvn7+075Bfxs+Rf8mvkz/Nj5WPwO+nf8IPqA/AD6 bvzH+Uz8q/k6/NH5Ufw5+o/8rPrV/PH6/Pzn+vf8pvrQ/F36pPwv+on8JfqD/DT6jPxJ+pj8 YPqm/HP6sfx/+rj8evq1/Gf6qvxc+qT8dfqz/Lj62/wR+xD9Uvs3/Vv7O/0v+yL9+PoB/d76 8vz0+gD9Lvsi/Wr7R/2P+1z9l/th/Yz7XP2B+1X9g/tW/Zj7Y/3A+3r99PuZ/SX8tv1G/Mv9 UPzQ/UT8yf0r/Lv9IPy1/UH8yP2l/AT+Sf1l/gD+0f58/hz/hf4g/xb+3/5z/X7++Pw0/tz8 JP4R/UP+Vv1r/nH9ev5d/XD+Pf1b/jP9Vv5D/WD+Wf1s/mP9c/5q/Xf+gP2E/q/9oP7k/b7+ B/7S/hH+2f4Q/tj+Gf7d/jL+6v5O/vz+Zv4K/3b+FP+F/h3/k/4l/5P+JP98/hb/UP79/iT+ 4/4P/tb+G/7e/jz+8v5i/gj/gv4c/5/+LP/B/kD/7P5b/x//eP9G/5D/U/+Y/0f/kv8s/4L/ Fv91/xb/df8m/37/L/+E/xj/dv/e/lT/mv4t/3T+Fv9//h3/tP48//L+Yv8f/33/Nv+J/zn/ jf8x/4f/Gf95//T+Y//N/kv/uP4//7P+Pf+g/jH/YP4L//X9zP6Y/ZP+lP2R/gj+1v7V/k// pf/L/zYAIQBoAD8ASwAtAPn//f+E/7f/Af9o/4r+Iv83/vD+C/7W/vH9x/7S/bP+r/2f/qT9 l/6//af+9v3J/h3+3/4d/t7+Bf7R/v39zP4Z/tv+RP71/lr+A/9L/vr+Kv7l/hH+2P4M/tX+ D/7V/gz+1f4O/tX+Iv7i/kb++P5g/gf/Yv4I/1T+Af9S/v/+ZP4K/3H+Ev9h/gn/R/76/lv+ Bv/L/kj/d/+v//3///8JAAYAkv/A/+3+X/9s/hL/Kf7q/v/90v7E/a/+ff2F/lf9bP5n/Xf+ m/2W/sb9r/7X/br+5v3C/hT+3f5d/gn/n/4w/7T+PP+Z/i3/bP4T/0X++/4o/un+GP7g/hz+ 4f41/vD+VP4C/1P+Av8f/uL+zv2y/p79lf6s/Z7+2/26/ur9wv63/aT+Z/10/kD9XP5d/W3+ lv2P/q79nf6g/ZX+sv2f/i/+6f4Q/2//8f/1/2UAOwBNACsA4P/r/3b/q/85/4f/F/9z//L+ Xf/F/kP/nf4r/3v+F/9Q/v7+DP7W/sr9r/64/aT+5P2+/i/+6v5a/gT/Rf74/gj+1f7U/bb+ w/2s/sn9r/7R/bT+1f23/uT9wP4B/tL+HP7i/iP+5f4b/uD+Gf7g/i7+7f5D/vn+OP7z/gr+ 2P7f/b7+3P28/gD+0v4e/uP+Df7a/uH9v/7X/bn+J/7p/sz+Sv+L/7z/KwAbAKcAZAAdAawA oQH5AB4CQwFvAnMBjAKEAZ8CjwHaArMBQQPwAaQDKgKyAzMCQgPwAWsCbwFtAdkAkABVAAAA ///B/9n/uv/V/8j/3v/J/97/rv/O/4H/s/9d/53/U/+Y/1//nv9n/6P/Wf+a/zj/h/8Z/3X/ C/9t/wn/a/8A/2X/7v5b/+3+W/8j/3v/mf/C/zMAHQC7AG4ACAGcABkBpwAOAaAA/wCXAPkA lADvAI4A2gCBAL0AcQCiAGEAjwBVAHsASQBdADkANQAgAAgABQDc/+z/t//W/5z/xv+S/7// nf/H/7b/1f/L/+P/x//g/6T/yv9z/6//Uv+a/0//mP9q/6n/lP/C/7//2//a/+v/2f/r/7H/ 0/9i/6T/CP9u/8P+Rf+m/jT/of4x/4r+I/9J/vv+6v3D/pn9kv5w/Xr+af12/mH9cf5M/WT+ S/1k/pD9jP4z/u3+Cv9t/8b/3P8ZAA4A+P/6/4z/uf8Y/3b/0f5L/8P+Q//j/lT/EP9w/zD/ g/8v/4H/B/9r/8/+SP+l/jD/ov4u/8v+Rv8D/2j/NP+E/03/lP9d/53/ef+u/6v/zf/q//L/ GgAOACQAFAAEAAIAyf/f/4z/u/9f/6H/UP+X/1v/nv98/7H/qv/N/93/7P8PAAoAOQAjAFoA NwBxAEUAiABSAKsAZwDjAIkAKAGxAGQB1gB5AeMAWQHQAAsBoQCtAGkAYwA+AEkALQBbADgA hQBSAKsAZwC6AHAArwBpAJsAXQCSAFgApQBkANMAfwALAZ8AKwGzACABrADhAIUAfgBMACAA EwDq//L/8f/3/y4AGwCCAEwAxAB0ANYAfgC2AGsAgABKAFsANABiADgAjABQALYAagC5AGsA hABMAC8AGgDq//D/3P/n/wMA//86ACAAVAAwADgAHwDz//b/pv/I/2v/pf9G/5D/Lf+B/xH/ cf/0/l//1/5O/7z+Pv+Z/iv/cv4T/1P+Af9W/gL/h/4g/93+U/82/4j/cv+s/4f/uf+G/7r/ g/+4/4L/tv92/6//VP+c/yT/f//+/mn/8v5i//f+Zf/z/mP/1v5R/6H+Mf9t/hP/UP4D/0n+ /f5G/vz+Pv73/jz+9v5Z/gf/nv4v//X+Y/80/4n/QP+O/yP/ff8F/2z/F/92/2r/p//v//b/ jwBVADsBuwDlASABfwJ7AfQCwAEwA+QBPAPrAT8D7AFoAwQCxAM7AjgEfwKJBK4CkQS1AmEE lwIjBHMCAwRgAvcDWQLLAz8CTwP1AXsCdgGAAeEArwBmAEAAIwArABgAOwAhADYAHwACAP// tv/T/4H/s/+A/7T/p//L/9H/5P/j//D/6f/z/wgABQBcADcA2wCDAEUBwwBcAdAACAGfAG0A QwDU/+f/b/+t/07/mv9X/5//Zv+n/2z/q/9q/6v/aP+p/2f/qP9p/6n/cf+u/4f/uv+r/9H/ 0P/n/9r/7P+4/9j/dv+x/y//hf8F/2z/Bv9t/yT/fv8//47/P/+N/yH/e//3/mL/2f5R/87+ Sf/L/kj/w/5C/6T+MP9y/hL/Of7v/gL+z/7a/bb+xv2q/sb9qv7P/a/+2/23/t39t/7Y/bX+ 2f21/uX9vf71/cb+/P3K/v/9zP4e/uD+if4e/0//lP9XADIAXwHPACwCSgGoApIB5AK2AfQC wAHQAqwBZwJtAbgBBAHoAIoANQAgAMv/4f+s/8//u//Y/9T/6P/q//T/9v/8//L/+f/b/+3/ vf/b/6r/z/+8/9n/6//4/xoAEgAlABoADwAMAPD/+f/m//P/+v8AABQADgAUAA8A+////9v/ 7P/E/9//vv/a/7z/2v+7/9n/wP/b/9H/5f/l//D/7f/0/+//9v8PAAkAfQBIAEsBwwBZAmMB UgP2AeADTALcA0oCWQP8AZcChwHgARoBYwHPACcBrAAVAaIABQGYAN0AgACkAF4AewBGAH0A RgCsAGIA5QCFAAABlgDvAIsAxgByAKUAYACfAFwAoABdAJQAVgByAEIASgAqADQAHQAzAB4A NwAhAC0AHAAZABAADAAIABoAEAA/ACgAZAA9AHEARgBlAD4ATQAxAEAAKQBNADEAdQBJALQA cAD1AJYAGgGsAA4BpQDLAH0AZQBBAP7/AwCx/9X/hv+8/3P/r/9s/6v/bf+r/3T/sP+C/7j/ mP/E/7n/1//u//f/NgAhAH8ASwCrAGYAqQBlAIgATwBuAEAAggBMAMgAdAAUAaIAMAGyAP8A lQCbAFkAPAAgABEABgAnABQAYwA3AJUAVACcAFgAdwBCAEEAIwAeAA4AIAAOADwAHwBWAC8A VgAvADgAHgAgABAARgAnANEAewDIAQ0B+QLDARsEcALwBO4CZAU0A48FTgOcBVYDpQVdA6QF XAN3BUIDCAX/Ak4EkwJiAwYCawJ0AZIB8wD1AJYAmgBgAHoATQB2AEsAdwBLAHMASQByAEkA fwBRAJoAYQCxAG4AqwBrAHoATQAtAB8A4//y/7v/2f/A/97/5v/z/xMADQAxAB8APgAmAEUA KQBPAC8AWwA1AFkANABBACYAGgANAAcAAQAuABgAnABZADABsgDBAQcBMAJIAXgCcgGiAowB sgKTAYwCfQEkAkEBjwHnAAEBkwCtAGEAnwBZAK4AYgCqAF8AeABDACgAEwDO/97/d/+r/yb/ ev/e/lH/u/48/8r+Rv8B/2j/Ov+L/07/l/87/4z/IP98/yD/ff9C/5L/df+x/6T/zf/E/+D/ 1//s/9r/7v/Q/+n/v//f/8D/4P/j//X/HgAZAFQAOAB0AEsAnwBlAA0BpgDYAR4B0AKzAZgD KALfA1ICpwMwAjID6gHPAq4BmwKPAXwCfQFVAmUBHAJDAeUBIAHDAQsBtAEDAa4B/gCvAf4A uQEDAcQBCgG/AQYBmAHtAFgBxwAfAaUACwGYAB4BowA9AbYAUAHBAFIBwgBIAbwAMgGvAAwB mQDaAHsAuABoAMoAcgAQAZwAZQHPAJQB6wCGAeMAVgHIADEBswAnAa0AJQGsABQBpAD7AJUA 9QCSABQBpAA/Ab8ATwHKADcBuwAQAaUACQGiADMBvAB2AeQArAEEAcIBEQHGARUBzwEaAdcB HgHEARMBggHtABwBsACvAG4AVwA7ACIAGwAPAA8AHQAXAFIANQCqAGoAGgGsAIsB7wDoASYB HgJFASYCSQEEAjQBxgEPAYIB5QBFAcEADwGfANIAewCMAFAAVgAvAFEAKwCNAE4A7QCHAEEB uQBlAc4AZAHNAGcBzwCJAeMAvQEBAdsBFAHJAQkBlQHqAGoB0QBpAdAAjAHmALEB/AC4AQEB nAHxAHEB1wBRAcQARAG9AD8BuwAvAbMACwGeANsAggC3AG4AtgBuAOUAiwAzAboAhwHtAMoB EwH0AS4BGAJEAUYCYAF4An4BlwKRAYUChwE8AlsB1QEeAXoB6ABMAc0AVAHSAH4B6gCzAQoB 6AEoARUCQwE5AlgBSAJfAToCVwESAkAB8AEqAQACMwFgAmsBFQPWAf4DYALqBOsCtgVjA1YG wQPQBgoENAdGBIsHeATTB6IEDQjEBDkI3QRVCO4EXQjyBFEI6wQ7CN8EKgjVBC4I1QRICOUE cQj9BKAIGwXXCDsFFglgBVsJigWbCbEFwgnIBcYJywWwCb8FlAmvBXwJoQVkCZIFQAl+BQ0J YAXPCD0FnQggBYYIEwWSCBwFtQgxBdwISAXwCFUF4ghMBboINQWMCBsFbggKBWsIBwV0CA0F dQgOBWcIBwVaCP8EZAgEBYgIGQWvCDAFsAgxBXYIDQUNCM8EmQeKBD0HUgQABy4E1gYTBKsG +QN8Bt0DTwbBAzEGrwMoBqoDLgarAzwGtANNBr4DWwbFA18GxgNaBsMDWAbCA2gGygOTBuQD 1AYKBBQHLwQ6B0YEOwdHBCEHNgT+BiIE5gYUBOQGEgT0BhwEBAcmBAMHJgTlBhQErAbyA2oG zAM5Bq8DLgapA0wGuwOEBt4DwwYEBPYGIwQQBzIEDAcxBOsGHQSxBv0DdAbZA0QGvAMrBq8D KQauAy8GsgMwBrMDKQavAyAGqgMbBqcDGAamAw8GoQP2BZID0wV8A7AFaAOcBVsDkwVWA4YF TgNiBTgDIgUSA9oE6AKgBMUCigS2ApkEvgK2BNACyATZAsUE1wK1BM0CrATHArUEzALLBNcC 2QTgAtME3ALABNACsgTIArUEyALMBNUC6QTmAvkE8AL1BO0C4wTiAsoE1AKvBMMClASzAnkE ogJdBJMCRwSGAjkEfgIsBHYCGwRtAgwEZAL/A10C+QNZAvcDWgL2A1gC8ANVAugDUgLoA1MC 7wNXAvgDXQL9A2AC8wNaAtsDTgK8AzoCmAMmAnUDEQJMA/kBHgPfAfECxQHLAq0BswKgAagC mQGdApMBigKIAW4CdwFKAmEBKwJPARUCQQEBAjYB6wEoAdQBGgHIARIB0wEYAfQBLAEhAkcB TgJgAXECdAGRAoYBsAKZAcgCpwHKAqcBowKQAVcCYgH2ASgBmQHwAFEBxQAgAagAAQGVAO8A igDmAIUA5QCEAOkAhgDtAIkA8wCMAAIBlQAfAaYAQwG8AF4BzABiAc8ATAHDAC8BsQAhAakA LgGxAFABxgB0AdsAjQHsAJsB9ACoAfsAuAEGAcEBCwG3AQYBlwH0AHUB4ABiAdQAYQHVAGQB 1wBeAdIAVAHOAGcB2QCtAQIBGAJBAXcCewGdApIBhgKFAVYCaAE8AlgBQgJbAVUCZgFSAmQB MAJQAf8BMgHRARcBqgEAAYEB5gBUAcsALQG0ABsBqQAbAagAHQGpABEBoQD4AJIA3QCCAMgA dQCuAGUAiQBPAGYAOwBgADYAgwBLALcAagDMAHcAkQBTAAYAAQBN/5P/jP4g/9f9tP4y/VL+ ovz9/Tj8vv0A/J395vuN/cb7e/2J+1f9NPsl/e/6+/zN+uj8wPrh/KX60fx2+rX8Ufqg/HL6 s/zs+vz8nvtl/UL8x/2v/Ar+8fww/i79VP5+/YT+1/26/iT+5/5X/gb/gf4g/7P+Pf/b/lT/ zv5L/3P+Fv/X/br+Lf1V/qf8Bf5V/NP9JPy2/f/7oP3d+439yfuA/cn7f/3S+4X91vuG/cr7 gP26+3X9r/tv/bH7cP27+3f90fuD/f/7nf1a/NL95/wm/pb9j/5C/vX+w/5B/wb/af8Y/3P/ Dv9u//v+Yv/i/lT/r/42/03+/P65/aT+B/05/lz81P3X+4b9g/tT/VT7OP09+yv9Pvsq/Vj7 O/2G+1f9s/ty/cL7e/2p+239d/tO/UP7MP0c+xn98voB/bX62/xi+qr8D/p5/Nf5V/zB+Ur8 v/lK/Lv5Rvyu+T/8pPk4/Kf5O/yz+UH8vflH/Lz5SPy8+Ub8yPlN/OL5XPz2+Wj87/lk/Mn5 TfyZ+TH8d/kd/Gz5Fvxx+Rn8ePkd/Hz5H/yE+SX8kvkt/KD5Nvyi+Tf8lfkv/ID5I/xw+Rn8 YvkR/FT5B/xC+f77N/n3+0D5/Ptf+RD8ifko/Kz5PPzG+Uv81/lV/OL5Xfzk+V780vlT/Kn5 O/xy+Rj8Ovn4+w/53/v2+ND79fjP+wv53Pst+fH7TfkE/F75D/xn+RT8efkf/KP5N/zU+Vf8 6vli/Mz5UfyS+S78dvke/KT5OfwX+n78kvrI/Nf68fzU+u78ovrQ/Gj6rfww+oz88fln/Kz5 Pfx4+R/8evkf/Kn5OvzY+Vb80flS/Ib5Jfwj+en75fjF++z4yfsk+en7WfkJ/Gn5E/xV+Qf8 O/n3+y/58PtA+fr7ZPkP/JD5Kfyz+T78v/lG/LX5Qfym+Tj8qPk6/Mf5TPzx+Wf8/vlv/NL5 VfyB+Sb8Qfn/+0T5AfyP+S789Plr/D36lvxW+qT8W/qn/HH6tfyb+s78svrc/JT6yfxD+pj8 9vlq/PD5Zvw9+pT8tfrb/BD7EP0i+xr98Pr9/Kr60/x4+rX8cPqw/I/6wvzD+uD8+PoB/R77 GP0m+xz9EPsO/e/6/Pzd+vH85fr2/Pr6A/0I+wv9//oG/ef6+PzW+u781frt/N368vzl+vb8 5vr4/OH69PzY+u78yPrm/K361fyL+sD8dPqz/HL6sfyC+rn8lfrF/KX6z/y5+tr82Prs/AL7 Bf0i+xj9IfsY/Qf7CP31+v78DvsN/Vr7Ov28+3X9Bvyi/ST8s/0n/Lb9Lvy7/Ur8zf11/Of9 l/z8/aj8Bv62/A/+1Pwi/gf9QP5A/WL+ZP14/nH9gP52/YT+hf2L/qH9nP68/az+yP2z/sT9 sf7B/a7+yf2y/uD9vv7+/c/+IP7j/kL+9f5k/gr/f/4Y/5D+If+u/jP/BP9l/6r/yP+NAE8A ZAHOAN4BFQHWARIBbAHSAOIAgQBxAD0AJwASAPH/8v/A/9X/kf+7/2z/pf9R/5b/N/+H/xv/ d/8H/23/Cv9v/yH/fP86/43/SP+V/0r/l/9V/57/fP+0/7r/2v/3//7/FgAQAA0ACgDh/+// p//N/27/q/8+/43/EP9y/9z+Uv+f/i3/X/4H/zT+7f4p/uf+N/7v/kT+9v48/vP+Mv7s/kr+ /P6i/jH/J/+A/5f/w/+2/9f/e/+z/xD/df+x/j3/dv4a/1z+C/9Q/gT/Uv4F/2v+FP+U/iz/ sP49/6v+Of+G/iL/X/4L/0n+/v48/vX+G/7f/tz9uf6Y/ZD+cP13/m/9df57/Xr+d/13/mj9 bv5t/XH+nP2L/uH9tP4W/tP+JP7b/hv+1f4X/tT+IP7b/iP+3P4G/s3+0v2v/qb9l/6c/ZL+ pv2Z/q/9oP6z/aP+xf2x/gH+0/5Q/gX/hv4n/4T+Jv9b/g7/Pf79/k7+Bv93/h//iv4q/3T+ Hf9P/gf/TP4D/3j+Hf+w/j7/yf5M/7r+Qf+o/jT/s/47/+H+Vf8N/27/GP9z/wr/a/8G/2j/ H/92/0v/j/9w/6X/gP+v/4X/s/+Y/7//tv/R/8n/3P/D/9r/q//N/5j/w/+c/8X/qv/O/6// 0v+i/8n/hf+6/2v/qv9X/5//RP+T/zP/if88/47/gv+3/x4AEwAFAZsABgIzAeYCtgF6Aw4C vwM1AtUDQgLsA04CKARxAo4ErQICBfICVAUjA1MFIgPzBOgCSASEAoMDEALTAqgBUQJbAfsB KQG+AQgBjQHsAF4B0gA4AbwAJAGxACQBtAAvAbwANgHCACcBuQD8AKEAwQCAAIcAXQBVAEAA KQAmAPX/BQCv/9v/Y/+v/yX/h/8B/3H/8v5m/+j+X//a/lX/0f5O/9r+Uf/8/mP/Kv99/1T/ k/9x/6P/j/+0/7j/y//t/+v/HwAJAEQAHQBYACkAagA1AIEAQgCOAEsAfgBEAFAAKAAQAAMA 2P/j/7b/0f+i/8f/kf++/4P/tv+H/7v/rf/S/+z/+P8rAB4AWAA5AHEASACGAFUAnABhAKQA ZgCQAFkAYgA8ACwAHAAJAAYA+v/9/+3/9P/Y/+f/xv/a/8j/2//j/+v////6/wEA+//y//T/ AAD8/1wAMwAKAZsAywEPAUoCXAFVAmQB+QEuAXIB3wD8AJsArQBtAHoAUABUADoANQApAB4A HAARABUABQAOAO7/AQDO/+3/rP/Y/5L/yP99/7n/Zv+r/0j/l/8g/3///f5n/+b+WP/j/lT/ 8f5Z/wP/Y/8H/2T/9f5X/9X+Qv+2/i//qP4m/6r+J/+w/ir/pv4k/4j+E/9i/v3+Pf7o/h/+ 2P4F/sr+8P3A/ur9vv78/cn+Gf7e/i3+7P4l/un+Cf7a/vH9zv74/dP+H/7r/kn+Bv9Z/g// Q/4C/xT+6P7p/c3+0v2//tj9wf71/dH+Hf7p/kT+//5Z/gj/Vv4G/0r+/f5E/vj+T/7+/mD+ B/9k/gf/V/7+/kr+9v5X/v7+gP4V/6X+LP+q/i//if4c/2D+BP9V/v7+Zf4K/2/+EP9R/v/+ Ff7c/uX9wv7v/cn+K/7s/mf+Ef9z/hn/Tv4E/yL+6v4j/un+Xv4M/7P+P//5/mf/Gv96/xr/ ef8O/3D/Av9o//X+X//n/lT/2v5M/8j+QP+x/jL/mP4h/43+Gv+j/if/4P5K/yn/dv9Q/43/ N/+A/+b+UP+H/hj/SP7z/jr+7f5H/vj+Vv4B/1T+Av9J/v7+Rv7+/k7+Bf9d/g//Z/4X/23+ HP95/iP/jf4x/6r+Q//G/lL/2P5d/+H+Yv/h/mH/2v5c/83+U/+9/kj/wv5I//j+Z/91/6// NgAgABoBpQD1ASYBtAKUAVoD9gH8A1YCmgSyAhgF/AJLBRoDFgX7AokEpwLLAzUCCQPEAVsC XAHFAQUBRAG6ANwAfQCVAFQAaQA7AEYAKQAfABQA+v/+/+f/9f/v//v/CQALABMAEgDy//// r//X/2P/qv8t/4r/E/94/wH/b//k/l3/vP5D/53+L/+Z/iz/s/46/9z+Uf/8/mT/Ev9v/yn/ fP9R/5L/jP+1/8v/2//4//b/DQACABQABwAeAA4AMgAaAEoAKgBaADQAVwA0AEcAKwAzACEA HQAVAAcACAD2/wAA8v///wYADAAtACQAUwA6AGAAQgBLADYAIwAdAP7/BgDo//n/4f/y/93/ 7//Z/+r/2v/q//L/9v8vABgAnQBYAD4BtwD8ASYBpgKJAfsCuwHbAqcBWgJbAcAB/gBXAcAA MwGrACYBowD8AIwArABdAHAAPACQAFAAKQGsAAECLwHIAqcBPwPxAWQDCAJXAwMCMgPuAfIC yQGXApUBMQJZAdsBJwGmAQcBgwHzAF4B3QAsAb8ABAGmAPkAngAEAaQADAGmAPkAmADQAIAA sgBrALIAaQDDAHEAxwBzALMAZQCZAFUAlwBSALIAYQDSAHQA3QB6AMwAcAC4AGQAsABhAK8A YQCdAFYAdABAAE4AKgBHACcAXAA1AGQAOwA2ACEA3v/t/5f/xv+p/8//FgARAKEAZQD1AJcA 6gCQAJcAXwBCACwAGgATAB8AFQA0ACEAPgAmADgAIQAoABcAFQAKAPb/9f/P/97/s//N/7b/ z//e/+X/GQAIAEkAJgBeADIAXgAzAF0AMwBiADYAZwA6AFoANQA1AB8AAAACANL/6f+5/9r/ tP/Z/7j/3P+6/9//t//d/7T/3f+7/+L/y//r/9v/9f/j//n/3v/3/93/9P/t//3/FgATAE8A MwB+AE4AkgBYAIwAUgCDAEsAjQBPAKsAYADMAHEA3AB5ANQAcwC/AGYAsABcAKwAWQCsAFgA owBUAJMASwCGAEQAiABGAJcAUACsAF0AvQBpAMwAdADgAIIA/ACUABoBqQAzAboAQgHDAEwB ywBVAdIAXgHYAGIB2wBaAdgASAHNADMBwQAqAboAMQG/AE4B0AB8AeoArAEHAdIBGwHhASMB 3AEeAdsBHgEEAjUBdAJ2AS0D4wENBGcC3AThAmsFNgOvBV0DxgVqA+AFegMfBqADdwbUA7IG +AOWBugDBgaTAyQFDgMzBH8CcwMOAvkCxgGvApoBagJyARUCPwGzAQYBWgHQABgBqQDsAI4A 0AB9AMAAcwDBAHQA0QB8AOUAhwDxAI0A8QCNAPIAjAAGAZYAMQGwAGwB0QCjAfEAyAEHAdsB EgHdARMB0wEMAcEBAgGuAfcApwH0ALgB/wDaARQB9wEmAfoBKgHjAR0BwgELAasBAQGuAQQB vwEQAcsBGQHGARcBtgEOAaEBBAGYAf8AmwEBAaMBBwGoAQoBpgEJAZoBAgGNAfoAkQH7AKkB BwHRAR0B9QEyAQECNwHzAS0B2AEbAcgBDgHNARAB4QEaAesBHwHkARgBzgEJAbcB+gCqAfIA ogHtAJgB5wCKAd8AhQHbAJEB4wCqAfIAuAH7AKwB9QCPAeQAhwHhAMUBCAFkAmgBUwP3AVkE lAIwBRUDoAVaA5gFVQMsBRcDjAS3Au0DWQJyAxECIQPiAeYCvgGpApoBYAJtARUCQAHcAR0B vwEMAb0BCgHEAQ0BxQENAbkBBgGmAfoAkQHtAIAB4gB0Ad0AcQHaAHIB2wB3Ad8AgQHkAI4B 7gCjAfoAvQENAdkBHAHlASYB2gEfAbcBDAGKAfIAYQHbAEMByAApAbkADQGpAPIAmQDkAJEA 7wCXABUBrQBAAcUAWAHSAEwByAAgAawA6ACJAL8AbwC4AGkAzgBzAO8AhQANAZUAHwGeACsB pAA4AawATAG1AFwBvgBcAb8ARgGxACMBnQD/AIkA4QB4AMcAaQCxAF8ArQBeANEAdgAlAasA jgHrANwBHAHdAR8BkwH1ACsBuQDeAI4AxQCAAMcAgwC4AHsAiQBfAFkARABVAEEAkgBlAPYA nwBKAdIAcwHoAHkB6gCAAe0AnAH8ALgBCwGzAQcBfwHkADIBtQD5AJIA8ACMAAsBmwAnAaoA KQGrABgBnwAQAZsALAGrAGcB0ACtAfoA4gEaAfkBKQH2ASgB5gEfAdEBFAHCAQwBwAEKAdAB FQH3ASwBJgJJAU8CYQFlAm0BbgJyAXkCeAGSAoYBuAKbAdECqQHKAqMBoQKJAWoCZwFMAlUB XAJdAZMCfAHVAqIBAgO9AQ0DwwEBA7sB8AKxAeMCqgHeAqkB2QKnAdYCpwHcAqwB7wK5AQQD yAEKA84B6wK+AacCmAFOAmYB+gE2AbgBEQGSAfwAgwH1AIIB9QB+AfIAbAHpAEQB0QASAbIA 7wCcAPQAngAmAbkAbwHkALEBCgHfASEB9wEsAQoCNQEeAj4BLwJGATgCSgFAAksBVwJWAX8C bwGxAosB0gKdAdYCngHHApYBuAKMAbECiQGtAocBoQKBAZcCfAGhAoQBygKcAfoCuwELA8cB 5wKzAaYCjAF6AnQBhAJ8AbkCnAHnArgB6QK5Ab4CnwGLAoABaQJsAVcCYAFAAlMBIQI/ARAC NAEkAj4BVwJbAYICdQGAAnIBVQJYASoCPgEpAj0BTwJTAXICaQFpAmQBLwJDAeUBGAGpAfYA gAHfAFMBxgAWAaMA2ACAALMAbAC1AG4AxQB5AMoAfAC4AHMAqQBrALoAdADkAI0ADwGmACQB sQAzAbkAbQHZAPsBKwHWAqsByQM6Ap8EtwJABRQDvQVbAywGnAOPBtMDzQb3A9sG+wO+BukD mwbSA4kGyAONBskDjQbJA3QGuQNABpwDAgZ4A9cFYAPOBVsD6AVsAxcGigNDBqcDWwa2A1AG sQMpBpsD+AV/A9EFagO/BWEDvgVhA8UFZgPNBWsD1wVxA98FdQPfBXUDywVqA6AFTgNoBS0D OAUOAxoF/AIQBfUCDgXyAgoF7wIABekC+gTlAvsE5AL/BOcCAgXoAv4E5gL0BOAC5wTZAt0E 1ALZBNIC2gTUAtsE1QLbBNYC2QTUAtEE0QLCBMcCqAS5AoIEoQJTBIYCKgRsAg4EXAICBFMC +QNMAt4DOwKpAxkCbgPzAUED1wE4A9ABUQPcAXkD8gGfAwcCvgMXAtgDJgLuAzEC9AMzAukD LALXAyECzwMdAt8DJgL4AzYCBQQ+AvYDNwLXAycCvQMYArQDFQK4AxgCtwMbArADGAKtAxcC sgMcArMDHwKkAxcCfQMAAlMD6AFGA+ABWwPsAX4DAgKRAwsChQMEAmcD8QFTA+MBUQPhAVcD 5AFcA+UBXQPlAWgD6wGAA/gBmQMGApoDBQKBA/UBXQPgAUwD1gFbA98BfAP0AZYDAgKTAwEC dwPxAVAD2gEsA8YBEAO3Af4CrAH1AqcB8QKlAekCoQHQApEBngJzAVsCSwEeAiUB/gERAQkC FQE2Ai8BbgJOAZoCaAGuAnIBsQJyAbkCdAHUAoIB+gKYARMDpgEDA5oBwQJzAWgCPgEfAhIB +QH+APcB/QACAgUBDwINARwCFwEwAiQBPwIvATgCLgEQAhcB0AH0AJcB1AB6AcQAcgHCAGMB ugA+AaUACAGGANgAaAC4AFYAqABMAJ4ARgCYAEEApABIAM0AXwAEAX4AMgGWAEYBoQBKAaMA WAGpAHoBuwCdAdAApAHSAH8BvABCAZYACwF1AO0AYwDXAFcArQA/AGIAEgAHANz/u/+x/4// mP96/43/av+G/1X/ef9D/3D/Pf9v/0P/c/9H/3T/Qv9z/zv/bv9C/3L/Wv+B/3//lf+c/6T/ qf+r/7D/r/+9/7P/zv+9/9X/v//D/7L/l/+Y/2P/eP84/13/Gv9K/wT/Pv/v/jD/3f4m/9j+ JP/c/in/4P4r/87+I/+n/g//fv74/nH+8/6Q/gj/zf4v/wz/Vv8t/23/LP9u/xb/ZP8D/1n/ BP9a/xz/a/9E/4P/bf+a/4v/rP+U/7H/if+q/3L/mv9W/4f/Ov92/yT/Z/8T/1v/BP9R//z+ Sv/9/kr/DP9Q/yX/Xv9B/27/WP97/2D/gf9b/37/Uf94/07/d/9Z/3//bv+N/3//mf+E/53/ eP+Z/2f/kv9d/43/YP+Q/2n/l/9w/53/c/+h/3j/pP+I/67/pP+//8n/1f/w/+z/FAABADoA FwBgACwAhwBDAK0AWADTAG0A/ACFACcBnQBMAbIAXwG8AFsBugBGAa0AMQGhADIBoQBLAbEA cQHJAI4B3QCaAeUAkwHiAIUB3QB9AdsAgwHhAI8B7ACdAfYAqQEBAbQBCAG+AREBzQEcAd8B JwHzATUBCgJEASECUgE1Al4BRQJnAVACbQFXAnABWAJwAVICawFIAmMBQQJfAUsCYgFrAnUB lgKNAbsCogHGAqcBtgKcAZ4CjgGQAoYBkgKIAY4ChQFiAm0B9wEvAVQBzwCWAF8A5//6/2r/ sf8n/4z/DP99//P+cP/E/lb/eP4q/yL++v7g/dP+vv3B/rP9u/6k/bP+gP2e/k39f/4b/WH+ 9vxM/uL8QP7V/Df+y/ww/sb8Lf7D/Cr+s/wh/o78Cv5Y/Or9LvzR/ST8yv0n/M39E/zC/cb7 lf1U+1L9+/oe/fL6HP04+0f9j/t9/bT7lf2a+4f9bPtu/WL7av2L+4T9wfun/db7tv3E+6z9 pPub/aH7mf27+6n90fu3/cD7rf2K+4z9Uftr/Tr7Xf1M+2f9cvt8/Yr7i/2K+4n9ffuA/Xf7 fP2F+4P9nvuS/bL7nP2v+5z9mfuO/X37fv1r+3P9a/t0/Xv7ff2M+4r9mvuT/aT7m/2y+6T9 wvuv/c37uP3G+7b9sPuq/Zj7nf2O+5n9lPud/Zv7ov2O+5z9ZvuE/TH7Zv0G+0z97/o//ev6 Pf3l+jr92Poy/cP6Jv2z+hz9rvoZ/bn6H/3Q+iz96fo7/fv6Rv0A+0n98/pD/dT6Mf2v+hv9 kPoJ/YD6Af2C+gP9k/oO/an6HP26+ij9w/ov/cH6L/21+in9nvod/YP6Df1h+vv8O/rk/BH6 zPzj+bD8tPmW/Iz5fvx0+XD8b/lt/H/5dvyb+Yb8vvmc/Oz5tvwz+t/8pfoj/Uj7g/0G/PP9 ufxe/j/9rP6P/d3+w/37/vn9HP87/kP/dP5k/3b+Z/8n/jj/j/3e/tf8cf4s/A3+rfvC/Vn7 kf0d+2796PpQ/bX6Mv2J+hr9a/oJ/Vv6//xY+v/8YvoF/XT6EP2O+iD9qvox/bz6O/3E+kD9 x/pC/c76Rv3Z+k393vpQ/dL6Sv26+jv9p/ov/af6L/29+jz90vpJ/dX6S/3J+kT9zPpH/Qf7 af2G+7b9PPwi/gT9mP60/QL/NP5Q/3n+ef92/nf/J/5I/6D9+f4C/Zr+dvxI/hX8Dv7Z++r9 rvvR/Yv7vP1v+6v9Y/uk/Wb7pf1r+6j9Y/uj/VT7mv1R+5f9afuk/Zr7wf3T++P9/fv7/RL8 B/4U/An+C/wC/vn7+f3m++392fvk/dv75v3y+/X9FPwJ/iv8F/4x/Bz+KPwW/h78EP4j/BT+ M/wd/kH8Jv5F/Cj+RPwp/kv8Lf5f/Dn+evxK/pL8V/6h/GH+tPxr/tX8fv4F/Zv+Nv25/lP9 yv5T/cj+P/29/jP9tv5G/cD+e/3g/sX9DP8J/jT/L/5K/y3+SP8I/jH/0/0T/6r9+v6Y/e/+ mv3w/p398v6O/en+av3T/jz9uP4V/aD+9/yO/tv8f/6//G3+pfxe/pb8Vv6T/FP+lPxR/of8 S/5v/Dz+VPwr/j78Hf4k/A7+/vv3/dr73/3g++T9Rvwf/iH9oP5J/lH/eP8EAGoAkwAJAfIA ZgEoAZYBRQGwAVMBvwFdAdkBbAENAooBUQKzAYACzwFmAr8B8QF6AUEBEQGIAKMA7v9HAHL/ /v8C/7v/mf58/z3+Rv///SL/2f0J/7r99/6b/eX+j/3d/qn97P7m/RD/KP43/0z+S/9J/kj/ Nf49/y3+OP84/j3/R/5G/0v+SP9C/kP/N/46/yf+Mf8M/iD/6P0K/9X9//7u/Q3/Nf42/4P+ ZP+m/nn/j/5r/1j+Sv8p/i7/Ef4e//j9EP/M/fX+kf3S/m/9vv6D/cj+u/3q/u39B//4/Q3/ 4f3//s398v7S/fX+5v0A//X9B//2/Qj/Af4P/y7+Kf91/lL/sP52/8H+f/+j/m3/d/5R/1z+ Qf9W/j3/Uf46/z/+MP8p/iL/Hv4a/yf+H/8x/iX/LP4i/xP+Ev/1/QH/5/34/uz9+v4C/gf/ MP4j/4r+Vv8j/7L/7/8rALkAowBFAfQAbQEMATwB7wDbALUAagByAPP/KwBw/9v/6f6L/3j+ R/83/h//Lv4Z/0f+KP9h/jf/b/4//3f+Q/+J/k3/qv5h/9P+eP///pH/Lf+s/2L/zP+W/+r/ tP/8/6z/9v+H/+D/Z//M/3D/0v+n//H/7/8dAB8AOAAiADkABQAoAOL/EwDP/wcAxP8BAK// 8/+H/9z/Wf++/0L/sf9e/8L/vf/6/1sAVwAvAdQAJgJnASwDAgIgBJMC5QQHA2gFVgO0BYED 3wWaAwEGsAMiBsEDLAbIA/sFqgN0BVkDnwTaAqIDRAK4ArgBCAJQAacBFAF9AfwAbAHxAFkB 5wA7AdMAIQHEAB8BwQA7AdMAaQHtAIcB/wB0AfQAJgHEALcAggBXAEgAJwAsAC4ALwBNAEIA YgBNAF4ASwBDADoAIQAlAP7/EADf//7/1v/4/wAAEQBnAE0A7wCdAFcB3ABlAeMADwGvAIcA XgASABkA2//3/9T/8//S//P/sv/e/3H/t/8j/4r/4f5h/7n+SP+y/kT/yv5S//D+af8K/3j/ 9v5t/6r+Pf8y/vf+tv2t/lL9cf4Q/Un+4/wu/r38F/6U/P/9Z/zj/Tb8x/0L/K398vue/fb7 oP0U/LH9M/zD/UL8zP1C/Mv9UPzU/YX88/3d/Cf+LP1W/k39av5E/WT+PP1f/lv9b/6d/Zf+ 1f24/tb9uf6i/Zr+Yv10/kD9X/5A/WD+Sv1l/kr9Zf5I/WP+WP1s/nj9gP6S/Y/+jP2L/m/9 ef5e/W/+cf17/p/9lf64/aT+nv2U/lr9a/4R/UH+5/wm/tn8H/7W/B3+zPwW/rv8DP6q/AP+ mfz4/Xr85f1R/M39Mfy5/Tb8vf1q/Nv9ufwK/v/8NP4e/UX+Cv06/s78Ff5+/OX9Nvy8/Rb8 qP0u/LX9b/zc/bH8A/7O/BT+uPwI/pH88P2G/Or9rPwA/un8JP4N/Tn++Pwt/rT8BP5h/NL9 Jfyw/Q/8ov0h/Kz9UvzJ/ZL88P3M/BL+5fwi/tT8F/60/AT+r/wB/tz8HP4r/Uv+bf1y/nz9 ev5f/Wn+Sf1b/mL9av6q/ZX+/f3F/i3+4/4y/ub+Jv7f/ij+4P48/uz+Vf76/ln+/v5M/vT+ Pf7s/kH+7v5R/vj+YP4B/2z+B/+I/hj/2v5J/3r/qf9aACwARgG6AAcCLAFtAmkBbAJpARkC NwGUAecAAwGRAIsASgBEAB8ALwAUADkAGQBJACQATAAlAEIAHwAzABcAMQAVAD4AHABUACoA cgA7AKMAWAD4AIsAgQHdADACRQHbAqoBSgPsAVMD8QHwArYBSAJTAZkB6wAbAZ4A6ACCAPwA jgA2Aa8AbwHSAIoB4gB1AdQANQGvAO0AhADGAG0A4gB/AEIBtwC6Af4ABAIqAf0BJgG5Af0A dgHWAHIB0wCvAfgA+QEjAQ8CMQHeARQBhwHgAEIBuAAtAasAMAGtACgBqAACAZIAzwBzAKkA XQCiAFgArQBfAMQAbQDiAH4ABQGUACYBqAAxAa4AGQGgAO4AhgDWAHcA5AB/AAYBlAAXAZ0A 9wCLALUAYwB4AEAAaAA1AIcASQC+AGkA7wCFAAABkADqAIIArQBfAF8AMAAuABMASQAkAMMA bABsAdEA7QEdAf4BKAGeAe8AEgGcAK0AYACRAFAApQBaAK4AYACRAFAAXgAxACwAEwAAAPn/ yv/Z/3v/qv8i/3b/3P5L/8P+PP/P/kP/5P5R/+3+Vf/m/lH/2f5J/9f+SP/m/lH/Bf9j/yn/ eP9E/4n/Tf+N/0T/iP9J/4z/hP+t/wIA+f+nAFsALgGsAF8ByQAvAa0AyABwAGMAMwAfAAsA 9//0/+v/7f8NAAAAfABDAEIBuQAxAkgBAQPDAX8DDQK1Ay4C1gNCAhAEZQJhBJUCpQS7ArAE xAJ4BKICDARiAoQDEAL1ArsBbQJrAf0BJwGyAfsAiwHjAHQB1gBSAcEAGQGfANEAdACUAE8A cAA7AGMAMwBiADIAXQAuAE0AJQAsABEA+f/z/77/0f+R/7b/iv+x/63/xv/g/+X/9//y/9P/ 3f9//6z/J/93//X+Wv/4/lz/IP9z/07/j/9y/6T/jP+z/6f/xP/L/9j/7P/s/wAA+P8BAPn/ /f/2//3/9v8EAPr/BQD7//D/7v++/8//fP+o/0L/hf8j/3P/JP90/zr/gP9U/4//bP+e/4P/ q/+a/7j/r//F/8D/z//O/9j/4//j//X/7//1/+//0P/Z/4n/r/9E/4X/Kv92/03/i/+W/7b/ 1//d//D/7P/u/+z/8f/t/wgA+v8dAAcAEAD//9f/3P+d/7v/pv+//xwABADtAIEA3AEPAaMC hQEUA8kBKQPVAfICswGHAnQBBQInAYUB2wAfAZ0A2AB0AKwAWACGAEIAXgArADQAEAAKAPj/ 6f/k/9L/2P/K/9L/0//X//D/5/8cAAMATgAhAHYANwCGAEIAfgA8AGIAKwBAABcAJQAIABMA /P/9//D/2P/a/6D/uP9d/5D/Kf9w/xP/Y/8h/2v/Rv+B/3L/m/+b/7L/uv/F/9L/0//h/9z/ 6//i//v/7P8QAPj/IQACACQABAAPAPj/6v/h/8f/zP+x/7//pP+4/5f/r/+J/6j/h/+m/6X/ t//W/9X/BwDy/x8AAAAcAP7/EAD3/xAA9/8XAPv/HQD+/xoA/f8dAP//NgANAGAAJgB9ADcA agAqACEAAADF/8j/iP+j/43/pv/I/8n/EAD0/zcACgAhAP7/1//Q/3//nv9K/37/Uf+B/4n/ o//M/8v/8f/h//L/4P/q/93/9v/k/xUA9v8pAAIADQDx/7z/wf9R/4L/8P5I/6T+G/9l/vX+ L/7V/hH+xP4f/sz+VP7r/o/+Dv+k/hn/ff4C/zP+1v7w/a7+0v2d/ub9p/4k/s3+fv4C/+D+ O/8s/2j/R/94/zL/a/8K/1T///5N/yb/Y/9q/4z/pP+v/7X/uf+Z/6j/af+L/0T/df9B/3X/ bf+P/7z/vv8TAPL/QQANACkA/v/c/9H/lv+o/5v/q//5/+P/gQAzAOwAdAAUAYwADQGHAAEB fwD/AH8A+QB7ANcAZgCeAEUAaAAjAEgAEAApAP7/5//W/3n/k/8D/0//wf4m/87+Lf8V/1j/ bP+L/7T/tv/w/9n/KgD9/2EAHACAAC4AeAArAFAAEwAcAPP/5//V/7b/uP+L/5//dv+S/4X/ nP+6/7z/+P/h/x4A9v8bAPX////k/9//0v/C/8H/nv+t/2z/jv8+/3L/O/9x/2//j//F/8L/ CADq/xcA8//9/+P/6P/X//3/4v81AAQAZQAfAFwAGgARAO3/qf+w/1//hP9j/4X/uP+5/zcA AwCcAEAAswBNAG0AJAD8/+H/q/+x/6//tP8DAOb/bQAlAKwATACxAE4AowBHALYAUgDzAHcA KwGYACABkgDDAFwAQgANAN//1P++/8H/yv/H/9X/zv/G/8X/r/+2/6r/tP/K/8j/CADr/2UA IgDrAHMArgHlAJcCcAF1A/QBGgRVAo8EnAISBeoCzQVYA6cG2QM8BzIEHAcgBDIGlAPHBL0C ZgPrAXwCYQEpAjABRAJAAYICZQGdAnYBcQJcAQICGgGFAdEAQAGoAFwBuQDIAfkAOAI8AWMC VgE2AjsB3wEIAaYB5QC1Ae8ADQIiAZECcQEoA8sBtAMeAgoEUAL8A0gChAMBAuECoAFzAl4B bQJbAa0CgAHRApQBoQJ5AU0CRgE6AjsBngJ4AUoD3gHKAyoCyQMpAl8D7AHrAqYBrwKDAaQC fgGRAnIBUgJNAf4BHAHAAfcAoQHmAIEB0wBDAa0A8gB/AMAAYQDIAGYA/ACFADIBpQBUAboA awHIAIMB1gCJAdkAXAG+APUAgQCKAEAAYAAnAJEARQDlAHYAAgGGALcAWgArAAcAuf/D/5// s//g/9r/PAASAHYAMwBjACgAAQDu/2v/lf/d/kD/pf4h/wD/Vv/g/9z/4AB2AHgB0QBZAb4A pQBUAND/1v9C/4L/EP9k/wT/Xv/o/k3/s/4v/4P+Ef9m/gD/S/7w/hf+0v7X/az+xv2i/hH+ zv6w/iz/U/+N/6T/vP+I/6z/Nv97/wf/X/83/3r/tf/G/0UAGwCYAEwAhwBCACUACQCy/8X/ cP+d/4f/q//k/+L/RQAcAG8ANgBQACQADAD7/9b/3P/G/9L/yP/U/8L/0v/D/9P/AQD4/7gA ZADjARcBNgPhAUwEhgLhBOACBQX0AvUE6wLzBOsCEgX9AjQFEQMsBQwD4gTeAl4EkALDAzUC LwPcAasCjQEyAkYBvQEAAVIBvwADAZEA3gB8AOMAfgD8AI0AEQGZABYBnQAVAZ0AEwGbAAgB lQDvAIcAywBxALAAYQCxAGIAywByANsAfQDJAHIAmQBWAHUAQACEAEkAvwBtAPgAjwAIAZkA +ACOAP8AkgBdAcoAIQJAAScD2wEzBHoCGgUDA8cFagM3Bq0DbQbMA3IG0ANgBsUDUwa8A1UG vgNjBscDdgbSA48G4AO4BvoD8gYcBBoHNAQLBysEwQYABGgGygM9BrIDYQbHA7UG+QMBBycE HQc5BBEHMQT9BiYE+wYkBP8GJwT9BiUE7QYdBNsGEgTKBgYErgb3A4kG4ANtBs8DgAbbA9IG CwQ7B0kEawdlBDAHQgSkBu8DKQalAyAGoAOkBu4DcQdoBCAIzgRrCPsEVgjwBB4IzgT8B7sE Agi+BBIIyAQCCL8EwQeaBGEHYAQLBzAE5AYYBOkGGwT2BiME3QYWBJAG6AMtBq4D7wWIAwEG lANeBssDxgYIBPYGJQTLBgsEYgbNAwUGlQPtBYYDJwaoA4kG4QPUBg4E5QYXBMgGBQSrBvQD sQb2A88GBwTaBg0EpAbuAywGpgORBUkDCwX5AroEygKrBMEC0gTYAiQFCgOQBUkD/AWKA0kG ugNsBs8DbQbRA24G0gOEBuADqgb3A8gGCgTRBhEE1QYTBOcGHgT/Bi4E/AYsBL4GCQRVBsoD 9QWQA80FdwPYBX8D4gWDA7cFaANUBS0D7QTuAqsExgKcBLwCowS+AqIEvgKXBLYCkQSxAooE rAJuBJwCLARzAskDOAJoA/0BHgPSAeQCsAGfAogBSQJTAfEBIQG4AQABqgH4ALYBAAHEAQoB 0wEVAekBIgECAjMBBgI4AeUBJAGuAQUBlQH4AMUBFQEvAlQBlgKSAbcCpQGAAoUBGgJIAb4B EAGLAfIAiwHxALMBCQEAAjQBYgJtAbUCnQHOAqsBngKNAUkCWQEMAjMBEQI0AUoCVQGGAnYB lwKAAXsCcAFHAlABDAItAckBBAFzAdIAFwGbANMAdADGAG4A7QCGACUBqQBEAb4AQAG8ACIB rQAKAaAADAGiACUBsgBDAccAUwHRAE0B0ABAAcgASgHOAHkB6wC3AREBzwEfAZAB+AD8AKAA XABAAAIACQAXABUAdABKAMcAeADZAIIAugBtAKUAXgDKAHMAIwGnAH4B2gCpAfMAlQHlAFgB wQAWAZoA9QCFAAsBkABbAcIAywEFASICOQEvAkIB6gEbAYYB4QBAAboAMAGxAC0BsgD9AJgA kgBZAB4AFgDn//j/BAALAEsANwB2AFIAbABMAE0AOgBOADwAfABXAK8AdgC6AHoAjwBhAFUA PQA7ACwATwA2AHwATwCeAGIAoABfAIUATQBnADoAYgA0AIoASgDfAHsAPgGyAHMB0QBWAb8A 8QCBAIUAQQBfACoAkgBJAOcAfAABAY0AqQBaAPj/8v80/3//lP4j/xz+3f6r/Zz+NP1X/s78 HP6d/AL+pvwJ/sL8HP6+/Bv+iPz8/T380f0L/LT9Evy3/Uj82P2V/Af+5fw1/i/9YP57/Yz+ zf26/i7+8/6m/jj/Mf+I/7f/1f8GAAIA8v/0/2r/of+K/hr/j/2D/rj8Av4t/K799vuM/f37 j/0d/KL9Lfys/Rn8oP3j+4L9rvti/aT7Xf3d+4H9SPzC/bD8Af7Z/B3+pvz//SD8sv13+1D9 6Pr9/KL61vy3+uX8E/sd/Yj7ZP3d+5f98vul/cP7if1t+1b9F/sj/ef6Bf32+g79UPtB/e37 nv2n/Ar+N/1e/lf9b/7z/DH+RfzI/b77dv2w+2v9EPyi/Xj83v13/N397vuI/Sf7Ev2l+sP8 svrL/DH7F/27+2j98vuK/cn7cv13+0P9QPsj/Tz7Iv1Q+zD9W/s4/Uz7Mv0s+yH9BfsL/dD6 7vyI+sb8L/qS/Nz5Yvyg+UH8fvks/F/5G/wy+QL8Afnk++T40/vx+Nn7IPn2+1b5FPxy+SX8 c/kk/HT5IvyQ+TH80/lY/B/6g/xR+p/8Wfqh/Ej6lfxQ+pf8lPq+/BX7Cf2l+179Dfyb/S38 rv0U/J/98fuJ/eT7gv3q+4X93ft//Zv7Wf0r+xb9vvrY/Jb6wvzR+uf8W/s7/fL7lv1L/Mz9 OvzF/cf7gv0h+yL9kvrP/E76pvxe+rL8pPrc/O36CP0f+yb9Pfs3/WP7Tv2c+3D92PuS/fT7 of3l+5j9xfuD/bf7ef3L+4P97PuV/f/7n/0R/Kj9VPzO/fn8Lf77/cb+HP9w/woA/P+bAFMA 4AB6AAEBjQAVAZoAFwGaAPcAhgDCAGgAkwBNAHUAPABLACUA5P/o/yf/e/8w/uj+Qf1c/p78 /f1d/Nj9aPzh/Yf89f2J/Pf9T/zX/ej7mv2H+2H9aftR/a/7ev03/Mz9rPwR/r38Gv5e/OL9 3/uW/aj7dP3s+5v9ffzw/fH8M/7z/DP+hvzw/fH7l/2O+1n9hftT/dP7gP1Y/Mz98/wn/or9 gP4E/sf+Pv7q/jT+4/77/cH+xP2g/rH9lf7B/aD+0f2q/rH9l/5R/WD+yvwS/lX8zf0l/LL9 SfzK/ab8Av4B/Tv+K/1V/iH9Uf4O/Ub+JP1V/nn9iv7q/c3+Mf75/iL+8P7A/bb+PP1n/tP8 KP6e/Aj+lvwC/qT8Cv67/Bb+2fwn/v38O/4a/Ur+KP1P/ij9Tv4y/VP+Wf1p/qT9k/4E/sr+ bP4H/97+Sv9u/57/KgAOAAgBkADcAQ4BbgJlAZkCfwFgAl4B9QEgAZEB5QBPAb8AHgGjAM4A dgBEACYAkv+///j+ZP+r/jj/r/49/9L+VP/V/lf/nv43/0n+Bv8K/uL+AP7d/if+9P5s/hz/ wv5Q/yb/i/+H/8P/tf/e/4z/w/8O/3f/gv4i/0D++P54/hn/BP9p/33/r/+D/7H/9v5c/w7+ 0f43/U7+1/wU/ir9RP4i/tb+Z/+Y/3sAOwDlAHsAfwA+AIT/q/+C/hH///3F/ij+3/67/jn/ Pf+H/0r/kv/j/lb/Xf4I/yT+6f5q/hT/B/90/5b/yv+7/+L/Yf+t/7n+Sv8T/uj+m/2h/kj9 cf7+/ET+tvwY/pb8Bf7N/CT+WP11/un9yf4Y/uP+sv2k/uD8Jf4Z/Kz9x/t7/QX8nP2J/Or9 8Pwl/vr8Kv66/AL+gPze/aP88/1O/Vj+Yf77/oT/qP9JAB8AagAzAOr/6P8f/3D/gP4T/1v+ AP+l/i7/Cf9r/yb/f//a/lT/Vv4H//L9zv7i/cb+FP7m/kP+A/8w/vj+3P3G/n/9kf5b/Xz+ g/2U/sz9v/7r/c/+tv2w/kH9Z/7E/Bv+ffzv/X/87/2z/Av+9/wz/jn9WP52/Xj+oP2Q/qf9 k/5//Xn+Of1P/gv9Mv4d/Tz+bf1q/r39mv7P/aT+lP2C/j/9UP4T/Tf+LP1I/nD9cf6p/ZX+ vP2i/rP9oP6k/Zj+if2L/lT9bv4N/UX+5Pwu/hj9T/7A/bT+oP45/1T/pv+R/8v/Sv+h/67+ RP/8/dv+Y/1//gD9Qv7p/DT+KP1X/qL9nv4e/ub+Yv4N/2D+Cf9E/vb+Q/7z/l7+Av9m/gX/ If7b/pX9hf4P/Tb+6/wf/kb9Vf7m/bT+av4C/5z+IP+J/hX/Z/4B/2D+AP97/hD/pf4r/9H+ SP/2/l//Bv9q/+7+X/+0/j7/ff4g/4r+KP/p/mL/Zf+t/5f/zP8+/5j/f/4n/9L9v/6o/af+ Ef7l/rj+SP8p/4v/LP+L/9f+V/9o/hP/Av7V/rf9pv6V/ZH+vP2m/kf++P4S/27/xP/X/xAA AwDt/+z/qP/C/5f/t//L/9b/AAD1/+L/5P9h/5f/v/44/1b++v5M/vT+gf4V/77+PP/k/lP/ 8f5c/+T+Vv+1/jz/c/4X/1r+Cf+3/kP/pf/Q/84AgQCkAQIBwwEVAU4BzwDJAIAAqwBvAAIB ogBvAeMAiAHxAC8BvACPAFsA4f/z/0L/lP+7/kL/Z/4N/3H+Ev/n/lb/hv+z/+T/6v+9/9P/ Ov+E/8/+Q//d/kz/Yv+a/wMA+v9eADAAVQArABAAAgDK/9j/qf/G/7r/0P/1//T/SwAoAJYA VwCYAFoALgAcAHj/sv/Q/k//jv4q/8n+T/9I/5r/uv/f/wIACQAxACQAaQBFAKsAbADSAIIA vgB2AHsATQAnABsA2v/t/4j/vf8j/3//q/44/0P++v77/c3+v/2o/mX9cf7X/Bz+RfzC/RD8 of2I/On9sP2X/iP/dP9RACcAvwBrAFkAMABz/6n/m/4p/07+/f6q/jT/af+m/wYABAAkABQA uf/V/x3/eP+3/j3/vP5A/wn/b/9O/5j/RP+U/+X+Xv9h/hD/Bf7b/gj+3f5w/hr/C/91/4n/ vv+r/9H/bf+p/w3/bv/g/lL/EP9v/3r/rf/R/+L/1v/m/4z/u/8x/4T/Av9o/xn/d/9p/6X/ 1f/k/zsAIACAAEYAfABEACIADACS/7j/IP91/xz/c/+Q/7r/MQAcAJIAWAByAEcA7P/5/1P/ nv/6/mr//P5q/zv/j/+H/7r/tv/U/7b/1P+V/8D/bv+o/2P/o/98/7P/k//D/2v/rP/t/mP/ Sv4B/+/9yv40/vL+Gv95/1AALwBsAdUANwJLAa4CkQHqArMB9wK9Ae0CtwH8AsIBXQP+AQwE ZwKnBMUCmwS/Ap8DKAL5AS0BZQA8AIL/s/9p/6T/tP/P/+f/7f/S/+H/mv/B/27/qf9V/5z/ Of+O/xf/e/8K/3X/Kv+J/2L/qv90/7P/Pv+S/9/+Vf+l/jL/y/5G/0j/kP/o/+7/bgA/AK4A ZQCKAFEA6f/y/+z+Xf8B/tH+vf2q/n3+G/8HAAQAowH3AKECiwHdAq0BwgKcAd8CrQFiA/sB DQRjAo4EsgLVBN8CEQUEA1oFMgODBUwDQQUmA4UEtgKZAygC5QK8AYQCgQE+AlUBxAEOARYB pAB9AEoARAApAGwAQwCqAGkAtQBxAIQAVAA/ACsABQAIANr/7f+3/9f/sP/R/93/6f8sABYA UAAqAAoA//9z/6b/BP9l/y3/fv/h/+v/kQBUAKEAXwAAAP//Nv+I//n+Y/+F/7b/eABFADYB tQB1AdkAZAHQAGABzwCGAeUAlwHxAEYBwwCPAFgAyP/j/1X/oP9e/6b/s//Z//n/AQDw//z/ lf/F/x//ff/P/kz/2f5S/zj/iv+r/83/0P/k/2X/pv+D/h//lv2R/h/9S/5T/Wn++/3M/qb+ Mf8E/2j/Ef9u//X+XP/N/kP/iP4b/x7+2/6u/Zn+hv2C/tv9tv6U/iX/Uf+W/7//2P/M/+H/ s//S/7P/0//O/+P/0//n/5T/wv8c/3j/n/4w/07+AP8l/un+Af7U/sX9sP5+/Yf+UP1s/kX9 Zf5I/Wj+NP1a/gf9P/7j/Cn+9fwy/kz9Zv7M/bL+TP79/rb+PP8O/2//X/+e/6H/xf/E/9n/ vv/V/6f/yP+t/8v/5//t/0QAJACRAFMAnQBaAGEANgD+//v/qv/K/4H/sv+G/7b/pf/I/9j/ 5/8iABQAgABMANgAgQD3AJUAtABuABcAEQBf/6T/6v5f//n+Z/+F/7v/RwAvANwAiAD6AJkA mABfAO3/+P9Q/5r/Ef9z/03/lf/m//D/kwBXAA4BoQAzAbcAFgGlAOQAhwDDAHMAuQBtAL0A bwDPAHgABAGXAGoB1ADcARYBBQIuAZcB7QCTAFMAV/+X/3D+Dv81/u3+ov4u/2D/oP8aABAA qwBnABsBqQBxAd0ApAH6AKcB/QCKAewAeAHgAI8B7gC/AQwB1wEaAb4BDAGSAfMAjgHxAMMB EAHyASwBtgEJAeUAjADP/+X/Ff91/zf/if8sABkAXgHOABMCOgHnAR8BCgGcABMACgCe/8T/ 6v/y/8wAeADUARQBlwKIAdwCsQGqApIBMQJLAbAB/gBbAcsATgHDAIsB6ADzAScBTAJcAU4C XgHZARkBEgGlAGMAPQBAACkAzQB8AL4BDAGDAoABqQKXASoCTAF1Ad8AEgGlAEcBxQDyASsB qwKYAQIDzAHEAqgBCAI3ARsBqQBdADcAFgAOAFMAMQDZAIAAQgG/AEwBxAABAZcArgBmAKIA XgDhAIQALwGzAEgBwgAnAa0ABAGZABkBpQBiAdEApQH4AKQB+QBnAdMAKAGvAB8BqgBIAcEA YAHQACgBsACTAFgAy//i/xP/dP+i/jH/j/4m/9/+Vv99/7T/NwAiAMUAdgDsAI4ApwBlADAA HQDk//L/FwAQAOMAiQAnAkkBkAMfArIEzAIuBRUD1gThAsgDPgJqAm8BNwG3AIUATQBZADMA fQBJAKYAYQClAGIAbwBBABYADQC+/9j/iv+6/5H/vf+//9j/3//r/77/1/9d/5//Av9n//b+ Yf9N/5b/xP/c//b/+/++/9r/Sf+U//D+YP/T/k7/y/5K/5v+LP9K/vv+Hv7h/lb+Av/U/k7/ Lf+D/wX/a/9s/hH/0f21/qb9m/4D/tL+q/43/1r/nv8BAAEAugBvAIwB6gBFAlgBqQKUAakC lAF6AncBaAJsAZYCiAHwAr4BTgP3AZsDJQLUA0cC9gNbAv0DXwLxA1gC+gNdAkgEiwLSBN0C UAUoA2kFNwMDBfoCawSfAg8EaQIwBH0CqQTGAiIFDwNeBTIDXwUzA1MFKwNRBSsDUAUpA0cF JANGBSIDbgU5A8EFawMYBp4DNgaxAxcGngPvBYgDDgaaA5UG6gNhB2MEHwjVBIwIFwWOCBcF NgjiBLMHlARMB1YERQdRBMUHngSnCCQFiwmsBf0J8QXOCdUFKwl0BXcICQUACMME0QenBMIH nQS7B5kEyQehBAkIxwR+CAwF+ghWBUcJhAVRCYsFOgl9BTEJdwVJCYUFawmbBW4JnAU6CX0F 3ghFBX8IDQVICO0ESwjuBIAIDgXFCDcF8ghRBewITgW5CC8FeAgJBVAI8QRQCPEEbAgBBY8I FgW1CCwF5QhJBSAJbAVLCYYFQQmABfcIVAWTCBoFYQj7BJEIGQUWCWgFqQm/BfgJ7QXkCeEF iAmqBR8JbAXVCEAFrwgoBZcIHAV1CAYFQAjnBAUIxQTZB6wEygejBN0HrgQFCMYENAjiBF0I +QR6CAoFhAgPBXMIBgU7COQE3QesBHEHbAQlBz8EGQc4BD0HTwRZB2AENAdKBMwGDARfBssD Pwa4A5UG6QMwB0YEsweTBM8HowRzB2sE0QYMBDIGrwPHBW8DnwVYA7AFYgPjBYIDGQaiAyQG qQPlBYIDXgUyA74E0gJKBIsCLAR5AlAEjgJ3BKUCYgSaAvsDXAJlAwUC4gK5Aa4CmwHhArkB ZQMIAgAEZAJhBJwCSASMAqgDLQLGAqUBFgI8AQMCMAGhAo4BlAMfAkYEigJABIcCewMSAmAC bAGDAekAQAHCAI4B7wATAj0BdAJ1AY0ChAGBAnsBiQKAAbcCmwHuArsB8wK/AbICmgFMAl4B AwIzAQICNQE7AlYBbgJ1AWQCbgEeAkIBzwEUAbAB/wDLAQ4B9wEoAQICLwHYARYBmQHxAHgB 3gCTAfEA5gEjAUkCXgGBAoABWwJpAb4BCwHDAHUAvv/Y/xf/df8V/3P/o//G/1sAMwDLAHYA yAB1AIQATgBOAC8ATAAwAF8APABVADQAIwAXAPr//v8EAAIAMQAeAE4ALgA4AB8AFAAJACoA FgCRAFQA/wCXAPwAlgBNAC8AOf+M/1f+Bv8c/uP+hv4h/zz/jf/j/+//ZQA8ANwAggBUAcgA rwH+AMMBCgGSAe0AUQHIAEEBwAB5AeEA2gEcATcCUwFsAnMBcAJ1AUYCWwHwASgBhQHnACgB rwD5AJMA8QCOAOsAiwDNAHkArgBmAMMAdAAmAbAApwH9AO0BJgHBAQwBUQHKAAQBmwAXAaYA aAHWAJoB8wB0AdwAJQGsAAoBngBfAc8A9gEpAWcCbgFqAnABAwIzAW8B2wDnAIoAhQBQAGQA PACoAGQAZAHTAGMCbAEmA+ABKwPhAVICYAESAaMAIwAUAAAA//+XAFsAbAHYAPQBKQH2ASoB hgHpAO4AjwBzAEQARgAqAH0ASgAFAZwAkgHvAMoBDwF6AeEA0wB9AEgAKgBBACUAxQB0AHcB 3gDkAR8B1wEYAXQB3QAEAZwAtQBtAHgASQAyACAA6f/z/7v/1v/K/9//DAAHAFEALwBrAD4A VAAxACsAGQAaAA4ANwAhAHwATADJAHoA9ACSANAAfgBTADMAo//J/xL/cv/1/mD/Y/+h/xYA DACWAFYAhABNAOD/6/8I/2z/cP4T/17+CP/G/kf/Zf+m/+P/8v///wEAmf/D/8v+SP/s/cP+ ef1//s79r/7a/k7/GAAMANIAewCTAFcAfv+z/y3+7P5R/Wv+Sv1n/v390f76/mf/wv/c//3/ /v+f/8X/4/5U/z3+8f4g/uD+tf44/6n/y/9dADcASQAsAGL/pP8q/uv+Vv1u/lH9av70/cr+ vP5B/yb/fv8J/2z/j/4i///9zP6G/YT+H/1G/q38BP4b/K/9Z/tF/aj61fwD+nT8kfkw/FD5 Cvwk+e/77fjN+6z4pPuM+JD7s/im+xz55PuF+SL8m/kw/Ej5APzE+LL7cviD+5j4nPs++f/7 Rfqb/IP7WP3O/Bv+1/23/jL+7f6S/Yz+Fvyp/V/6o/w++fj7J/nr++j5X/zV+u38Q/sx/fL6 Av0X+n/8Ffnm+z/4Zvu29xP7e/fu+nv37vqT9/v6mff++nH35vos9776+vah+v32pPok97z6 KffA+tH2jfoi9iX6ZPWz+f70d/kt9ZL55/X++eH2kvqz9w37BPg9+7j3EfsH96j6dvZT+o/2 ZfqP9/76KPny+7T63fyZ+2X9s/tz/Vf7O/0W+xP9Qfss/cL7eP0y/Lr9LPy2/Yz7WP2H+r78 h/kn/PX40fv9+Nj7efki/AH6cfww+o784vle/EP5/vun+KD7U/hu+1X4bfuQ+JH75/jF+0H5 /PuA+SP8h/kn/EP5AfzW+MD7fviN+3L4hfus+Kf78fjO+xP54PsZ+eT7L/nw+1/5DPx1+Rr8 Ofn3+7v4rfti+Hn7pPih+475Lfyq+tf8Y/tE/W/7S/39+gb9Xfqm/Lj5QvwC+dT7QPhh+8T3 F/vx9zP73vjC+x36gPwD+wv9K/sj/bb63vwY+oH8uvlI/Lv5R/wV+nr8wfrf/Kz7bP2V/PX9 Cv06/sD8D/7h+4v9B/sL/bj63/z6+gb9RPsz/QP7Df0s+o38Pvn9+9j4v/s3+fX7FPp4/Pr6 //yb+1/98vuU/RL8qP0O/Kb99PuY/eb7kv0U/K79jfz3/Sv9Vf6x/aP+Cf7V/lD+/v61/jj/ NP+E/6P/xf/W/+P/3v/o//P/9/8uABsAXgA6ACcAGQBf/6X/Rf79/lj9b/74/DX+HP1J/mn9 dP58/X7+N/1V/sn8Ev53/OH9aPza/ZD89P24/Az+qPwG/lH80/3P+4f9ZPtH/UL7Mf11+079 0/uE/SD8sP09/MH9Nvy7/Sz8tf04/L39XPzS/Yz88v3N/Br+Hv1M/m/9fv6e/Zn+j/2R/lf9 bv4w/VT+Rv1g/o79if7N/a3+zP2t/pP9iv5Z/Wj+TP1j/mX9c/5u/Xr+R/1m/gz9Qv73/Db+ MP1Y/qD9mf7//dD+Gf7e/uX9vf6J/YX+Nv1U/g79PP4i/Un+cv16/uz9xP5h/gv/nf4v/4n+ JP9G/v3+C/7a/v790P4M/tf+Bf7R/tP9sv6V/Yz+kf2J/vH9xP6Y/if/KP9+/0b/kf/g/lf/ RP76/uz9xv45/vX+L/+G/2UAPgBHAcMAcwHbAOsAigAdAA4AiP+2/2H/nv98/6//dP+r/wn/ bf9K/vz+h/2K/v78Of6z/A3+ePzp/Sf8uP3J+3/9ivtZ/Yv7WP3D+3n9BPyf/Sf8tP0n/LX9 Hfyx/Sn8t/1W/NP9mvz9/eL8KP4Y/Uf+Mv1X/jP9V/4u/VP+Ov1a/mT9cv6b/ZL+tf2h/on9 h/4N/T3+dfzk/Rb8rP07/MP95/wp/s39sv51/hf/jf4l/xf+3/5r/Xf+7fwt/sv8F/7h/CT+ 7/wt/tH8Gv6j/P/9m/z7/dv8If5G/WD+p/2b/tT9tv7M/bD+n/2X/lr9bv78/Db+lPz3/VP8 0f1y/OP9/vw1/r79p/5J/vr+V/4C/+P9vv48/Vv+wvwS/rH8Cf4H/Tz+hP2H/tD9tf6r/Z3+ D/1B/kb8yv3J+3/98fuW/bb8C/6k/Zn+Jf7j/ub9v/4U/UL+M/y8/bz7dv3P+4P9M/y//Y/8 9/2k/AL+Yvzb/ev7k/1y+0v9M/sm/V/7P/39+5v91fwd/o79iv7X/bb+pv2Y/jD9VP7D/BT+ iPzx/Xr86f1+/Oz9g/zw/ZL89/20/Av+8fwu/j39W/6E/YT+p/2Z/of9hf4R/T/+YvzY/bv7 df1l+0T9fvtS/d37jP07/MT9c/zm/Y/89v28/BD+A/05/k39Zf59/YD+m/2S/tn9tf5M/vv+ 0v5M/xj/df/o/ln/ZP4N//T9yv7x/cr+Yv4N//r+Zv9T/5r/Ov+L/8H+QP8d/t/+jf2I/iz9 T/4A/TX+9fwv/vD8Lf7g/CT+yPwY/sL8FP7V/CD+8vwy/vr8Nf7Y/CH+rfwF/rb8Cv4V/UH+ nf2R/u79wv61/aL+/fw1/iv8uP3B+3r9Cfyn/en8LP7w/cj+nP4u/6T+Mv8T/tv+T/1m/tf8 Hv4A/Tb+uP2i/o/+Iv8O/2//AP9n/5/+Lv9K/vz+P/73/mL+DP9v/hT/SP78/gz+2P74/cv+ Hv7g/lb+Av9p/gz/Uv7//kH+9P5g/gf/oP4v/73+Qf98/hv/8v3J/oT9iP6b/Zb+VP4D/2H/ ov8/ACYAhwBPACgAFgBv/6j/yv5F/4b+Hv+f/i3/xv5F/6r+Nf82/vH+qv2f/mj9dv6g/Zf+ Jf7n/o7+JP+S/ib/TP76/hz+3/5h/gf/Jf98/x0AEADtAIsAYwHUAIsB6wCGAegAXwHSABEB pACYAFwADgAJAKX/yv96/7D/gf+0/4b/tv9P/5b/zv5J/y7+6/7H/a3+1f23/lP+Av/l/lj/ F/93/7b+PP/9/c7+fP2A/q79nv6f/i7/3f/q/8oAdwAFAZsApwBiABMACwCs/87/kP+9/5r/ xP+T/8H/Xf+f/wb/bP+//kL/vP4//xz/ef/b/+j/yQB2AKgB+wBEAlkBkgKHAbECmQHKAqkB +ALFATID6AFeAwECWQP/ARYD1wGdAo0BDQI3AYsB6gAxAbUA/gCXANIAfACOAFQANwAhAPj/ +//8//7/TQAvAL8AcgAaAakASwHFAGUB1ACDAeYAlAHwAGsB1wDsAIwAQAAlAL//2f+0/9L/ IgAWAM0AewBnAdYAzAERAfYBKwHvAScBuwEHAV4B0AD2AJIAqwBkAJIAVwCwAGgAAQGYAJoB 9ACRAoYB2ANLAioFEwMpBqoDpwb2A8QGBgTGBgcE0wYPBNUGEQSnBvQDSAa7A+UFgQOoBVwD gwVFA0oFJQP+BPgC6ATrAl4FMQNdBsgDawdqBO0HtwStB5AEBQcsBIwG5QOIBuEDtQb8A44G 5QPRBXUDtQTMAqsDLQLyAsEBegJ6AQ0COQGjAfoAcQHbAKEB+QAXAj8BbwJyAUgCWwGXAfIA uABtADIAHgBiADoATgHGAKQCkgH2A1wC8ATxAnkFQgOmBVwDpgVcA5sFVgOSBU8DiQVKA4kF SwOYBVMDqwVeA5YFUgMmBQ8DQwSIAhED0wHXARgB2ACBADUAHwDq//P/5v/x/w8ACQA7ACMA KwAZAK3/z//W/k//C/7V/s39sv5f/gf/hP+2/6IAYQAbAagAtQBsALD/0f+e/i7/Av7R/hL+ 2f6W/in/Gv93/zH/hf/F/kX/M/7t/g3+1/6w/jj/8P/2/yYBrwClAfoALgG0ABIACwDm/lj/ Ff7c/rT9ov6c/ZT+uf2k/gj+1P6E/h7//f5l/yv/gf/o/lr/Xf4H/9v9uf6r/Zz+2/25/k3+ /P7X/k//Uf+Y/5f/wv+H/7j/Hv96/5D+Jv80/u/+TP78/sn+R/9T/5n/g/+2/yr/gf9u/hH/ qP2c/jj9Wf5U/Wr+9v3K/tj+UP+I/7n/o//I/w//cf8i/uT+eP1//pT9j/6M/iP/AQABAGQB 0wBBAlgBaQJvAeABHgHNAHoAdf+u/zf+8P5o/XX+LP1R/mH9cP69/af+Df7X/kj++v50/hT/ f/4c/1L+Af///c7+4P29/l/+CP+F/7f/1wCAAJ0B9QBsAdgAhgBQAJH/vv8T/3T/FP90/z3/ jP9G/5L/N/+I/0H/jv9x/6r/lf/B/3T/rP8O/3D/qf40/5P+J//a/lH/Sf+S/5n/w/+r/83/ jv+9/17/oP8x/4T/Ef9y/wv/bv8e/3r/OP+K/zH/hf/6/mX/rv43/4j+If+r/jb///5n/0D/ jv86/4v/+/5k/8r+SP/v/l3/cf+q/xUADQB4AEcAUAAvAJ//x/++/kH/M/7u/nH+E/96/7D/ 0wB+AMMBDQHJAQ8B9gCRANr/6v8U/3T/6P5a/yT/ff9t/6j/k//A/6j/y//H/93/8f/3/wsA BwAWAA4AOwAjAKYAYwBBAb8AswEDAaEB+QD/AJgAJwAXAJP/v/+G/7j/2//q/yoAGQAcABEA oP/H//H+X/9o/g7/UP4A/7f+PP9m/6T/AAAAACoAGwDP/+L/JP99/5f+Kf+D/h3/AP9o/9v/ 6f+yAGsALwGzABYBpQBvAEIAgv+2/8n+SP+y/jr/WP+c/14AOAAlAa4APAG7ALEAaQAHAAQA z//j/zUAHwDvAI8AgwHmAJwB9QBBAb8ArQBnACIAFADN/+H/wv/b//7//v9bADUAmgBcAIcA UAAiABQAqP/M/2j/pf+B/7X/0//l/yIAFABKACsATwAuAEcAKwA4ACEAHQARAPf/+//W/+f/ yP/e/7f/1P9//7L/Hf96/8v+SP/V/k7/Vf+c/xMACwCiAGAAxAB1AI4AVABKACwAOgAiAFsA NwCJAFEApwBiALoAbgDMAHoAywB4AI8AVQAUAAsAi/+7/1H/mP+f/8f/ZgA9AEYBwgDSARUB wgEMARgBpQAdABIAP/+N/+D+Vf8p/4D/7P/0/78AcgA7AbsAPAG7AOwAjACSAFYAWAA0ADgA IgAmABgAOAAhAJIAVwA5AboA7QElAUcCWgECAjIBPAG7AFYANAC1/9T/gv+1/7n/1v9IACsA IAGrABgCPgHSAq4B4wK4AR0CQQHLAHkAn//G/zH/hP+c/8T/cQBDAAgBnQAFAZsAhABPAPr/ +//V/+f/OAAhAO4AjgCjAfkAFgI9ATQCUAEaAkAB5gEhAawB/gBqAdcAIAGqAN4AhADHAHYA 7gCNADoBugBqAdcARAHBAMcAdgA5ACIA+f/8/zEAHAC2AGsAJwGvAEEBvgALAaAA0gB9ANoA gQAqAbAAgQHlAJMB8ABIAcIAvwBxAD8AJAD3//v/7//2/wsABgApABkAPQAkAEMAJwBDACgA SQAsAFoANQCEAE0AzwB6ADsBuwC3AQQBHwJDAVQCYgFCAlcB8gEnAYYB5wAkAa4A6QCKANEA ewDEAHQArABlAIEASwBhADgAcgBEAMwAeABNAcQArwH/AKsB/QAnAa4AUQAvAIb/t/8h/3r/ TP+V//H/9v/GAHQAbgHYAKAB9gBFAcAAigBRANT/5P+N/7r/2//p/3wASADpAIkAtgBrAOz/ 8/8J/2z/pv4y/wj/a//x//X/2QCAAFcBygBZAcwAEwGhAMoAdgCjAF8ApQBgAMYAdADzAI4A BwGaAN0AgQBtAD8A6//y/6n/yv/b/+j/ZgA7AO8AjAAsAbAAFwGjAOQAhADFAHQAxQBzANEA eADgAIIABQGZAEABuwBpAdQAQQG9ALgAagADAP7/fv+v/1v/m/+C/7H/t//S/+L/6/8ZAAwA cQA/AMYAcgDTAHoAfwBIABEABgD4//j/XQA0AP0AkwBZAcoANgG0ANQAegCnAF8A6QCHAHkB 3AASAjcBogKNAVAD9AExBHkCEwUAA6AFVQO1BWADgAVAA0kFIQMXBQIDnwS7Aq4DKgJ1AnEB gQHgAEMBuwCjAfQAGQI7ASwCRQHTARABYwHPACkBqgAYAaEAAgGVANcAewDDAG8A7wCJAD8B uQBfAcsAHAGjAKIAWgBUACwAZgA3AKEAWgCYAFQAEAADAEH/if+l/iz/lv4j/xf/b//j/+n/ pgBdABoBogAaAaIAqABeAPz/+f93/6n/Zf+f/8T/1/8+ACAAdQBAAFkAMAArABUAMAAXAFsA MQBdADIA+v/3/1X/lP/K/kL/j/4g/4r+G/91/g//UP76/mj+CP8D/2X/9//2/6sAYQCgAFoA 2v/k/+3+WP9s/gv/df4Q/6/+Mv+6/jr/iv4e/1j+//5H/vb+N/7s/ub9vP5O/WL+vPwM/oX8 6/2r/AH+3vwg/tP8Gv6Y/Pb9k/z1/TD9Uv58/hf/KAAWAL8BCAHzAr8BvQM3Aj8EhQKzBMkC NwUYA8wFcQNDBrkDUgbCA70FaQOWBLsCOQPrARgCPgFpAdYAEgGkAMgAeABcADkA3//u/37/ tP9Q/5n/SP+U/1D/mv9m/6f/lf/E/93/7/8TAA8ABwAJALX/2P9R/5z/Kv+G/2j/q//g//P/ NQAlABYAEwCF/73/2/5Y/4/+LP/q/mL/vf/g/4MAVgCyAHIAJgAfAEb/m//E/k7/Cf92/+D/ 9/+XAGQAiwBdAK//2v+U/jP/8/3T/hr+6/7G/lL/ZP+v/47/yf9K/6D/5P5k/6P+P/+T/jb/ lv43/4n+Mf9l/hz/Nv4A/w/+6f4E/uL+Hv7y/lz+GP+v/kr/Av97/0//qf+Z/9b/5/8EACoA LABHAD4ALQAuAPD/CwC2/+n/n//b/6X/4P+z/+j/vP/t/8//+f/9/xYAQQA9AHIAXAB1AF0A TwBIACQALQAMACAAAwAbAOj/CwCs/+j/Xv+5/xT/jv/h/nD/1f5p/xP/jv+5//H/tQCHAKIB EwHzAUQBYQHuAEYARgBt/8X/i//X/6gAgAAUAlkB5ALVAZ4CrAF4Af0AJwA1AFj/uv9Z/7r/ BgAiAPIArwClARgBzwEyAXkB/wABAbgA4QCkAFsB7QBGAnoBJwP+AYkDOQJWAxsCxALEAR4C YgGKAQoBHwHKAAEBtwBtAfgAcgKUAcoDXwLuBA0DhQVmA6YFegPMBZEDWAbkA0EHbwQoCPcE sQhJBc4IWQWsCEYFewgoBT8IBQX+B94E0AfCBNoHyAQdCPAEWQgTBUEIBQXSB8IEYgd9BFoH egTfB8gEoAg7BSYJigUkCYkFoQg7Bd4HxgQnB1kEvAYZBNIGJgRuB4MEVggLBQcJdQUVCXwF fwghBcQHtASJB48EBgjYBOQIXQWHCb4FlwnHBSwJhQWbCDAFGgjhBKQHmwQ1B1gE/gY3BD4H XQT4B8sEugg+Be4IXAVSCP4EOQdXBE4GygMRBqYDfgblAyUHSASUB4oElweLBEwHXQTlBiAE iAboAz4GuwMHBpoD5AWEA9sFfgPwBYoDHwakA04GwANYBsUDGwagA6EFVwMwBRQDIAUJA5YF TgNOBrsDygYEBLEG9AMbBpoDggU+A1gFJQOwBVgDOwaqA6YG6gPhBgwEFgcpBGAHVQSlB34E rgeCBHAHXQQoBzEEIwctBHAHWwTSB5QE8AelBKsHewQwBzEEyQb0A5UG1AN9BsUDWgauAyUG jwP5BXMD8wVvAxQGgwNDBp8DZQaxA2kGswNKBqAD+gVwA3oFIwPjBMkCbwSDAlcEcwKnBKMC OAX4AsYFTAMfBoEDOwaQAyQGggPnBV0DgAUfA/UEzAJnBHcCEgREAhwESgJxBHwCugSnAqkE nAI1BFcCwQMRAsoDFQKABIICgAUaA/wFYwNZBQEDsgMGAtkB7QDUAFEAHQF8AFsCOAGuAwAC WARlAjEETwKTA/AB8wKRAYECTQEzAh4B+AH7AO0B9QA3AiABxQJ0ATsDuwEiA6sBQAIlAdwA UgCb/5L/Lv9R/+H/vP9pAaUA/gKVAcADCAI8A7sBuQHTABYA2v9G/1//pf+Y/8cARAC8AdYA zwHgAP4AZQD0/8f/d/99/9j/tv/EAEIAnAHEAO8B9QC1AdMAOwGKANIATQCjADIApwAzAMsA SAACAWsATAGWAKQBywDyAfkADwILAd8B7wBmAacAzgBOAF4ACwBTAAUArwA9ADUBjQCIAb8A cwGyAAcBcwCZADEAeQAdAL0ARgA2AZAAlAHIAJwBzQBKAZ4AygBTAFsAEQAmAPH/MwD6/10A EwBvAB8AQQAFANn/x/9k/4L/G/9W/xj/V/9T/3r/pP+q//T/2v9DAAwAqABGACIBkQCfAdsA /AETASoCMAErAjEBGgIpARUCJQEoAjEBTgJJAWoCWQFUAk4B8wEUAUwBsgCEADwAxf/L/w7/ YP9E/uj+Uv1Y/lb8w/2o+1z9lftS/Rb8n/24/AH+8Pwj/nD81/1k+zj9UvqX/Ln5PPzJ+Uf8 VPqb/P/6AP1u+0P9Zvs//eD67/wD+m38MPnw+8z4tfsZ+eT7/Pls/Av7Dv3F+3393PuM/V37 Qf2c+s78Afpz/NH5WPwY+oP8qPrY/DL7Kv1p+039KPsn/Yj6yPzQ+Vv8U/kT/EP5CfyT+Tn8 Bvp+/Fb6rvxb+rL8GPqK/Lb5Ufxy+Sr8evkv/NP5ZPxW+rL8w/r0/Of6Cv29+vD8afq//Bz6 k/zw+Xj83vlu/OT5cvwO+oz8evrN/Cv7N/31+679e/z//Wb88/2h+379bfrI/FL5IPze+Nv7 a/kw/Of6Ev3e/D3+qv5O/7//9f/y/xMAgP/P/9f+a/9W/h7/Fv74/vL95P68/cP+X/2M/u38 Sv6H/A7+Q/zm/Sn81v0x/Nr9Vfzx/Yb8Dv6v/Cb+vPwv/qf8Iv55/Af+TPzs/TL83P0z/N39 Rvzq/WD89/10/AT+gPwM/oz8Ev6Z/Br+o/wh/qX8If6c/B3+lPwZ/qD8H/69/DD+yfw3/pn8 G/4n/Nb9tvuU/bP7kf1c/Pf9dP2d/lz+Jv91/jX/qf27/n78C/69+5j93Puq/an8JP6P/az+ +/3s/sT9zP4l/W3+gfwM/if81v0t/Nj9gfwL/vL8T/5H/YD+VP2I/h79aP7a/D/+yPw0/vr8 U/5L/YP+ff2f/nT9mv5L/YL+J/1s/hf9Yv4b/WX+Qf17/q79vP5s/iz/NP+j/4L/0f/3/n7/ x/3K/qr8IP5b/PD9AP1T/hj++P7r/nX/Kf+a/w7/i/8O/4r/Uv+y/5j/2/+D/87/+f59/zT+ CP+B/Zz+/PxN/qL8Gf55/P/9nPwU/hz9YP7A/cH+Gv72/tn90P4d/V/+a/z2/Uf83/3J/C3+ kv2k/iD++P4w/gH/6f3X/qb9sP6v/bT+A/7m/mn+Iv+W/j3/Yf4e/9j9y/45/Wz+2vw1/vT8 RP6E/Zj+QP4I/83+XP/2/nX/zP5b/4r+M/9t/iL/g/4v/6/+Sf/O/lv/2f5i//T+cv9R/6j/ DAAYABQBtQAmAlcB9ALRAVQDCgJbAw4CVAMKAoQDJgL/A28CmATKAhAFEQM8BSsDIwUcA9YE 7wJfBKcCqQM7AqoCowF/AfEAZABJAI3/yP8S/4D/7f5q/xL/f/9u/7b/3//4/xkAHADY//T/ CP94//T90/4Y/VH+0/wp/ir9W/7N/bv+Z/4X/9L+V/8b/4L/UP+i/2L/rf80/5H/zv5T/2f+ F/9E/gH/fP4j/+b+Yv84/5L/Qv+Y/wn/dv+t/j//S/4F//D9z/6e/Z3+Yv16/j79ZP4d/VH+ 2Pwm/lP82f2x+3b9OPsw/S/7Kv2M+2H9+/uj/Rv8tv3R+4n9YftH/T/7Mf2m+3D9bPzl/Rn9 S/5S/W3+Fv1K/rv8FP6Z/P79y/wc/ij9Uv5u/X3+hP2J/nT9f/5f/XP+Xf1y/nH9fP6W/ZP+ yP2w/uX9wv7E/a7+S/1l/pz8/v0f/LP9P/zF/R39Sv5v/hP/rP/P/2oAQACaAFwAcABDACgA GADb/+n/g/+0/xn/dv+n/jH/Kv7n/o39if7J/BT+CPyh/aj7af33+5f93/wh/uD9uf5b/gH/ Av7M/g79O/4X/Kf9nvtf/cv7ev1g/NP9+vwu/kP9Wf4i/UX+rfz+/SD8q/3B+3L9uvtt/Qj8 m/18/OD93PwZ/gj9M/4C/S7+4fwa/sD8Bv60/P/91vwS/kL9U/7//cT+8f5T/+n/5v/HAGkA lAHjAGUCXwEvA9YBuAMnAr0DKwI6A9wBcwJlAdABAwGUAd8AxAH8AEMCRwH2ArEBuwMmAlUE gQJqBI0CywMuArEChwG/AfYAkAHZAD8CQgFSA+UBEwRWAh0EXAKkAxQCKQPLAQwDuQFGA9sB jQMFAp8DEAJ7A/oBRQPaASIDwwEcA8ABLgPKAU0D3QF2A/QBpQMQAtoDMAIjBFsCiwSYAgMF 3wJXBRADTwULA90EyAI9BGgCzgMmAsoDIwIdBFUCdQSIAosElQJWBHQCBQRGAs4DIwK+AxoC wAMbArkDFgKhAwgChAP3AWUD5AFCA88BFQO0AeYCmQHQAooB5wKXATEDxAGeAwUCDgRGAlsE dQJsBH8COQRhAsoDHgI7A8kBtwJ7AW0CTwF9AlgB3gKRAVAD1AFsA+UB5QKVAdUB9ADGAFIA bAAcACYBigClAnABJQRUAuoExwLKBLUCLgRZAqsDCgKEA/MBowMFAtADIAIFBD8CXwR1At0E wQJGBf8CTgUEA+gEyAJeBHUC/gM9AtgDJgKgAwUCDQOuASMCIgEwAZIAhwAuADEA+/8CAOD/ xP+7/2n/hv/3/kH/af7t/rz9hv4V/ST+yfz2/RL9Iv68/Yj+LP7L/tT9lv65/O79ifs6/Q77 8fyD+zj9bPzC/Qf9H/7p/A3+QPyp/YP7Of3/+uz8uPrB/JH6q/yO+qn8x/rM/C37Cf2G+z79 lvtI/V77Jv0c+wH9Fvv9/Ez7Hv2E+0D9hftB/UT7Gv3b+t38bvqd/Bn6avz++Vv8UvqN/DP7 E/1j/Mn9Wv1b/or9ef7U/A7+pPtZ/an6xPxf+pr80vre/KL7W/1d/Mr9sfz8/Yb84/0E/Jf9 hvtM/Xj7Rf0T/KL9If1E/gj+zv4p/uH+Vv1l/v77mf3g+u/8k/rC/D37Kf2a/Pf9OP7v/qb/ yf99AEkAgQBOAM7/4//i/lb/Zf4O/67+Of9v/67/8f/6/5//y/+H/iX/T/1s/q/8Df7r/DL+ vv2w/qT+Of8u/43/Kf+K/5X+M/+c/Z/+rvwR/lD82/3T/Cr+9v3X/vH+bf8G/3n/Gv7w/tz8 Mf4s/Mr9a/zx/Tj9a/7V/cj+1f3J/mX9h/4B/U3++/xJ/jz9cP57/Zf+k/2k/o79ov6G/Z7+ ev2X/mH9if5Q/X/+fP2a/gX+7P6//lr/Pv+n/zT/ov+x/lX/Iv4A/+/94v4l/gP/dP4y/3f+ NP8M/vX+cP2Y/gv9XP4n/W7+vv3J/nX+Nf/R/mz/f/47/5D9r/6E/A/+AvzC/XP8Bv6y/cL+ Cf+P/7D/9P9K/7j/I/4H///8Wv6U/Bz+Fv1p/hr+A//e/nn/yP5q/8D9z/5K/PD9N/tN/S/7 SP1J/PD9/f3z/nf/1P8hADoA8/8dAFn/wv/Y/nf/pv5Y/6f+Wf+f/lb/bv43/xH+Af+K/bH+ 1vxE/gz8zf2E+3z9qvuS/an8K/4k/gv/U/+//4P/3f+M/kn/8PxU/ob7fP3u+iL9Vvtg/Xf8 DP7H/dP+uv5j//P+hv9m/jH/af2b/ov8Fv5B/Ov9lfwd/if9c/6E/ar+kf2y/qX9vf4k/gj/ C/+R/8//BgDA//3/n/5Q/9z8Rf5h+2P96vob/Z/7h/0U/WT+kv5G/4H/1P+e/+b/C/+O/zb+ D/+n/bn+vP3F/mT+Kf8s/5//fv/R/yH/mf9g/ib/1P3S/uf93P58/jX/EP+M/yH/lv+T/kH/ tv2+/vz8Tv6m/Br+svwi/v/8Tv5r/Y/+2v3Q/if+/v4f/vn+q/2z/vb8SP5b/Or9L/zP/X78 /v0D/Uz+V/1//kb9c/7t/D7+n/wP/pT8Cf7I/Cf+9vxB/tH8K/5H/Nn9hftm/ej6B/23+un8 /voT/Yv7Zv0O/LP9TPzZ/T/80f0V/Lf9Bvyu/TX8yv2T/P/96Pwy/gT9Qv7i/C7+sPwQ/q38 Df74/Dn+cf2B/tv9wP4K/tv+B/7a/gn+2/4z/vL+ev4c/6z+Ov+o/jb/dv4Y/zz+9f4E/tT+ tf2l/jP9Vv6b/Pz9TvzN/Z78/f19/YH+av4O/9H+S/9+/hr/zf2v/lz9bP6X/Y/+af4L/27/ pv9GACYAzAB2AA8BnQAkAakAJQGpADUBsgCFAeEAKAJCAegCtAFYA/cBHgPTAT8CTgEYAZ4A FAAEAGX/m/8H/2P/8v5W/zz/gv/p/+n/rQBdAAIBkACJAEcAcf+h/2z+Bf8e/tX+mP4f/1L/ jv+i/73/XP+S/9j+RP+U/hz/uv4x/xL/Zv9R/4v/Zf+W/2b/l/9k/5b/Sf+G/wH/W/+z/iz/ qv4n/wf/Xv+O/63/1//Z/7n/x/+F/6j/wP/L/6UAUwDrARUB9wK0AWQD9AEwA9YBmgJ9Ac0B AgHNAGoAqP+9/7T+K/9a/vX+yv42/7f/xP+OAEUA2ABwAH4AOwDA/8n/8P5O/0/+7v4G/sL+ Ov7h/vH+Tv/p/+L/rQBWANgAbwBnACwAxP/L/2T/k/92/5z/w//L//T/6P/j/97/rv+//4f/ p/+H/6j/rP+9//L/5/9bACYAzwBrAA8BkADQAGsADQD3/yj/bv+s/iX/6/5L/7L/wP9xADMA rABVAFAAHgC0/8H/Sf+C/1D/hv+7/8b/RgAYAKsAVQDBAGIAlABHAF0AJwBaACYApgBRAA4B kAAwAaQA0ABrABgA//+L/6n/pv+5/3gANwCKAdsANAI/AQoCJgEmAZ8ABADy/yX/bf/a/kL/ LP9y/+//5//aAHEAjgHcALsB+ABEAbEAXAAnAH3/ov8b/2j/bP+Z/1AAHwByAc0AgAJsAVID 6QHiAz8CPQR1AnEElQKUBKkCxATFAh0F+wKrBU8DSwavA7IG7AOGBtEDmAVFAxUEXwKCAm8B fgHVAGEBxAD/ASEBuwKSAfcCtQF3AmgBgwHYAK8AWgBoAC8AqABVABABkwAzAagA7QCAAG4A MwAJAPj/9P/q/yAABABMACAAPgAXAO7/6P+T/7H/c/+f/6D/uv/f/9//1P/Y/17/k//K/jr/ of4i/zX/ev9HAB4AKAGjAD4BsACBAEEAif+u/xX/af92/6L/ZAAwAEcBtwCoAfAAcwHQAOMA fABGAB4A3f/g/9T/2/80ABQA1gB0AFkBwgBfAcYA3AB3ACgADgDQ/9n/IAAIAPQAhwDUAQwB WQJbAWICYAECAigBXQHFAJMATgDm/+f/v//Q/20AOADSAQwBQQPmAegDSgJmA/wBDwIxAasA XQDa/+H/sv/J/+P/5/8hAAsAdQA+ACEBpABFAlIBpQMkAsYE0QI7BRYD4wTiAuoDTQKoAo4B dwHZAJ0AVwAvABYAIAANAEEAIQBmADgAgQBIAJYAVACoAF4ApQBdAHwARQBFACQAOAAdAHwA RwD5AJEASQG/AAkBmQAtABgAGv90/1/+Bf9g/gb/HP92/0IAJABjAdAAGwI/ASkCSAF5Ad4A QQAlAAb/af9e/gf/kP4l/2D/oP8xAB0AgQBNAEIAJwDT/+X/of/I/9D/5P8kABYATwAwADUA IAD+/wEA3//t/+z/9f8MAAkAIgAWACEAFgATAA4ABAAFAOz/+P+6/9r/YP+k/+f+XP9//h7/ Yv4O/77+RP93/7L/KwAeAF8APADd//D/+P5n/1n+CP99/h7/Sv+Z/xIAEAAkABkAav+s/3/+ IP8m/uz+pv44/4j/vv8OAA0AyP/k/+/+Y/8T/uL+rv2k/tD9uf5I/gD/1/5W/1L/n/+P/8T/ Z/+s/9v+WP8u/vL+2v3A/iL+6v7Y/lf/cf+y/3j/t//v/mX/Q/4A//P9z/4n/u7+qv48/y3/ iv9//7v/m//N/4//xf9j/6r/J/+G//n+bf/x/mf//P5u/+X+YP+U/jD/Qf7+/l3+EP8s/4r/ ZwBGAGEB2wCAAe0AuwB3AKX/0//t/mT/2/5b/zL/jv91/7b/Yv+q/xf/ff/x/mf/NP+O/97/ 9P+uAHEAUAHQAIsB8wBuAeIAVwHUAMEBEwHsAsUBlgTDAgsGoAOZBvQDHgarAywFGwObBMUC 7AT0AusFjAP2BisEjweHBKoHlgSNB4UEZwduBBkHQARxBtwDfgVMA6sEzgJsBKkC1QTnAoQF TwPtBY0D2wWCA4QFTgNeBTcDsQVpA2AG0QP/BjEEIAdDBJkG8gOhBWADrQTOAjMEhgJuBKkC PgUkAz8GvQMEBzIEWgdlBF4HZwRMB10EUAdfBGIHaQRdB2YEKQdIBNwGGQSlBvgDrQb9AwMH MQSdB4sEYQgABScJdgW9CdAF8AnuBaYJwQXoCFEF8Ae9BBIHOASfBvMD0AYSBKMHjwTNCEAF xQnTBQMK+AVZCZIFFwjTBOMGHARPBsQDfwbfAyYHQwTcB7AEZQgABcoIPQUfCW8FVgmQBUYJ hgXaCEUFOAjlBKkHkQRnB2kEeAdzBLYHlwT2B70EFAjPBPgHvgSUB4QEBgcvBJgG7QOiBvMD QAdRBCUI2QTHCDgFvgg0BR0I1QRTB1sEzgYNBLIG/APSBg8E9wYlBA4HMgQhBz0EKQdCBAcH LgSmBvUDMAavA/AFiAMTBp4DdAbXA7cG/gOfBvADQwa5A/YFiwP1BYsDMwavA2oG0ANbBscD /gWQA3MFPgPpBOsCgwSvAmQEnAKmBMMCRwUjAwcGlQOABtwDXwbKA6oFXQPABNICHQRxAv8D XwJGBIsCrATHAvEE7wILBf8CGgUHAz8FHgODBUYD0wV2AwYGlAPwBYgDdgU+A6UEwQK8AzcC FgPVAfwCxgF3Aw8CSwSNAhQFBAN2BT4DPgUdA3kEqAJwAwkClAKHAUkCWwGvApcBhgMXAkoE jAKSBLgCSgSMArUDNAIzA+UB8AK+Ad4CswHfArUB+wLEAVUD+gH+A18CwgTUAjsFGwMbBQgD ZQScAnMDDQKvApgBWAJjAWMCagGXAooBuAKdAaECjwFVAmIB7AEjAYwB6wBcAc4AcwHbANkB GQGLAoMBdQMNAmoEoAImBQ4DYAUxA/cE8gIWBG0CIwPdAXkCeAEzAk4BIAJDAQwCNwH5AS0B JwJHAcACogGdAyUCQwSIAjwEhAJ1Aw4CVAJjAWwB1wAfAaoAeQHgAD4CVAEeA9oBywNBAgkE ZQKxAzEC3AKyAfEBJwFxAdsAqgH9AHYCdgFXA/sB0gNFAsADOwJaA/4B/ALGAeQCtwEVA9QB cAMLAs0DQwL+A18C3ANMAlYD/AGMAoMBzAESAWgB1QBzAdwAuwEHAfQBKQH8AS0B6gEkAewB JgEBAjEB6wEkAWoB1wCAAEwAi/+5/wf/bP84/4n//f/+/+AAhQBlAdQAUQHIAL8AcQAPAAkA of/H/6H/xv/6//3/ZQA7AI4AVABQAC8Axf/d/z//jP8S/3L/c/+s/1IAMQBZAc4ACgI3Af4B LwErAbEA/v///y3/hP9E/5D/OAAhAHEB2wAoAkgB/gEvATIBtgBhADkA+//9//r//f8LAAcA //8AAP//AABaADUAGAGnAN0BGwEjAkYBuQEGAeQAiAA0AB8ABQADAEsALQCvAGgA3wCFAMcA dwCFAE8ARwArADAAHQBIACsAggBOAKoAZgCJAFEAAwACAEr/k//H/kb/1f5O/3X/rf9HACoA 4wCHACgBsABOAcYAkwHwAPIBKAEnAkgB+QEtAYgB6AAvAbQAKgGxAFcBywBSAckA6QCLAFIA MQANAAgAbwBDAE4BxwAqAkoBgwJ+ATgCUQGCAeUAxwB3AEoALAAoABgAUAAwAJ8AXgDkAIgA +gCVANcAgQCVAFgAVQAyACIAFADu//X/sv/R/47/vP/B/9r/XwA5ACkBsACaAfQATwHGAE8A LgAg/3v/af4N/37+Gv9B/47/RAApABYBpgB5AeAAWgHNAMcAdwDn//H/+f5k/0f++v4T/tr+ bf4R/y//g/8NAAgAtABsAOAAhQBuAEIAdP+t/0L+9/5B/V7+vvwQ/rb8C/7l/Cb+/fw2/vz8 Nf4l/Uz+u/2n/rX+O/+c/8T/5f/w/1b/nf9B/vb+SP1i/vf8Mv5t/Xf+Tv7+/hT/dP9Y/5z/ A/9q/0r+/P5//YP+8/wv/tn8If47/Vr+7/3G/qn+NP8T/3P/+v5j/2j+Df+k/Zn+DP0//uT8 J/4m/U7+lP2Q/t79vP7X/bf+hf2G/hX9Qv65/A3+mPz5/b/8Ef4f/Ur+iv2K/rv9pf5+/YL+ 4Pwk/i38uf3D+3r9wPt5/eD7i/28+3b9Mvsk/aP60Py0+tr8uPt0/VL9af6p/jT/+/5k/zb+ 8P79/Db+Jfy1/ST8tP3V/B3+rv2f/jL+7v45/vL++/3N/tj9uP4Z/t/+v/5B/2j/pv+M/7r/ 0f5M/3j9fv5K/Mv9HPyw/Sj9T/7I/kb/4f/u/7j/1v99/hn/GP1G/m784P2y/An+Zf10/tb9 tv61/aP+Pv1d/ur8K/4K/T7+l/2S/lb+A////mf/Xv+g/1v/nv8G/2v/kv4n/0H+9f42/u/+ aP4O/7H+Of/0/mH/Kf+B/1H/mP9d/57/Qv+P/yP/ff9L/5T/4//u/68AaAAKAZ4AaQBAAOL+ Vv85/Vn+YvzY/cX8E/73/cv+Kf+A/8X/3f/Q/+T/qv/N/5X/wf+O/73/eP+v/13/n/91/67/ 2P/o/1QAMwCHAE8AMwAfAHX/rf+i/jD/Av7Q/qb9mv53/X/+Vv1r/h/9Sf6v/Af+8fuW/Q77 D/1i+qj8RfqX/LD61vwn+x79I/sc/YP6vvy/+Uf8dvkd/Ob5Yfyx+tf8Nfsn/ST7HP2v+tf8 SfqZ/Cf6h/wr+on8GPp8/O35Y/zw+WX8b/qx/Hf7Tv3O/Bn+I/7l/jL/hf/G/97/x//f/1L/ mP/K/kj/u/4//3X/rf+9AHEA6QEjAV8CaQEFAjQBUwHJANcAgAC/AHEAwgBzAHcARgC0/9L/ pv4y/5H9jv6d/Pz93fuL/XD7Sf17+1D9BPyi/b38D/4f/Ur+1fwe/vv7nP0R+xH9l/rH/K36 1fwS+xL9XPs+/U77Nv3y+v/8f/q6/DX6jvxG+pn8wvrh/JD7Xf1y/OT9IP1L/nL9e/6B/YT+ mv2T/v39zf6v/jj/gP+0/ywAGgCMAFQAqgBlAJ4AXgCKAFEAdwBIAGwAQABkADwAXQA4AGEA OQB+AEoAwQBzAB8BrABuAdoAeAHfACkBsQCuAGcAXAA2AGgAPgDCAHMAFgGmABoBqADHAHYA WgA1ABkADwAgABMAVQAzAJUAWADVAH8AIQGsAHsB4gDMAREB7gEmAc8BEgF9AeMAHwGqANQA fQC3AG0A3gCDAEkBxADeARwBXAJnAXoCeQEcAkEBcwHdAOgAiQDQAHwAOAG6ANkBGQFHAloB QAJWAccBDwEWAaUAawBAAOP/7/9r/6f/1/5P/wj+0/4F/Tr+/vuf/S77Iv2x+tn8fPq4/Gv6 r/xs+q/8gvq7/LT62vzu+vz89/oC/aX60PwF+nH8Z/kU/CH57PtO+QT8pvk5/MP5S/xp+RT8 wPix+y34WvsU+Ez7nvic+6/5PvwD+wj9RfzI/SD9S/5X/Wz+7Pws/ir8uP2N+1r9bvtJ/cj7 fv03/MD9VfzS/QP8ov19+1D9FfsU/e36/Pza+vH8pfrQ/D36k/zK+U/8d/ke/Er5Avwo+e77 //jW+9b4vvu6+K37nfib+074bfu79xb7Hfe3+uD2lPpf9976ffiJ+7X5Qvxg+qn8NPqN/F/5 Dvxl+Hv7yfce+9D3Ivt0+IP7evkf/ID6uvwc+xj9C/sN/Vf6ovxv+Rn87PjL+zr5+vtQ+p78 w/t7/Qz9Pv7T/bT+FP7b/vv9zP69/af+gf2D/l79b/5V/Wv+Vf1p/jr9Wv7u/C3+f/zr/Q78 p/27+3f9d/tO/R/7Gf2j+s/8KfqH/P/5bvxJ+pr81vru/DH7JP3++gb9QfqW/GL5Efzp+Mj7 HPnn+9v5WPyt+tb8GvsW/ef69/wy+oz8YfkQ/Ob4x/sK+dv70PlS/AX7Cf1c/Nb9lv2R/nv+ GP/d/lP/n/4v/8/9sv7A/BH+5vuP/ZH7Xf22+3P98vuY/eT7j/14+0796fr6/Ib6vvxp+q38 dvq1/JT6x/zR+ur8QPsu/cn7f/0T/Kv90fuD/RP7E/1D+pb80flS/Mj5TfzV+VX8rfk9/F/5 D/xR+Qf8zPlR/Kn60/xk+0L9l/th/Ub7Mf3N+un8d/q2/E/6nvw6+pH8P/qU/JD6xPw9+yv9 +PuZ/Tv8w/3K+3/9CPsM/bz63/xt+0j93fwi/in+6P54/hf/nf2V/i38uf3++gX9kvrG/Nr6 8fxn+0T9yft+/dP7hf2b+2T9Vfs6/Tb7J/1f+z/9zPt//Uz8zP2h/P/9ovz//WH82f0t/Lr9 WvzW/Qf9O/78/c3+x/5F/wD/aP+J/iH/o/2Y/r/8EP41/L79D/yo/Rb8rf0Q/Kf9Avyh/Tr8 wv36/DT+K/7p/kv/lf/L/+D/df+s/6H+L//r/cP+sf2h/tb9tv7s/cP+p/2b/iH9Sv7B/BH+ 4fwk/nr9gP4v/uv+g/4d/zP+7v5e/W7+cfzh/fb7mf1H/Mr9WP1r/qz+Nv+c/8T/tf/U/wn/ bf8O/tj+VP1p/iH9S/5d/W7+vf2o/gT+0v4N/tf+w/2s/hn9Rv4p/Lf9Rvsw/eL69fw2+yf9 CPyk/cH8Ev7i/Cb+X/zY/an7a/1Q+zf9nvtk/WT82/0v/VP+hv2G/jr9Wv52/OX9rftu/Wr7 Rv0A/J/9UP1o/sX+RP+l/8r/k/+//8T+Rf/R/bT+N/1Y/gz9Pv4Q/UH+Dv0//hH9QP5J/WT+ v/2o/jL+7f5U/gH/E/7b/q39nf5x/Xv+h/2I/tP9tf4o/uj+Yf4J/2v+D/8m/uf+jv2M/tT8 Hf5y/OL92fwg/gf+1P5j/6L/GAAPALv/1/+R/iX/W/1t/r78EP7W/B7+Rv1h/pv9lP6d/Zb+ X/1x/h39Sf4Z/Ub+gv2F/lv+Bf9U/5n/6v/y/67/z/+6/j7/tP2j/mn9df4e/uL+Vf+b/zIA HQApABgAb/+q/7P+Ov95/hj/t/49/+3+XP+s/jb/8P3G/hn9R/6h/P79yfwX/oz9i/6g/i// jf+8/9j/6P9M/5X/Nv7v/kf9Yv4r/VH+/P3O/iP/fP/A/9v/W/+e/zL+7f4Q/UD+qvwF/kH9 X/6T/ib/IAATAHYB3wBKAlwBiwKDAW8CcwFoAm4B4gK3AeUDUQLsBO0CLAUTAz0EhQJyAnUB swBrANT/5v8BAAEAuQBvADwBuwAcAakAbABAAIj/uf/Y/lD/q/41/x3/ef8ZABAARgHCABYC PgEgAkMBXgHQAEUAKQBr/6f/Iv98/1X/mv+w/9D/+P/7/yQAFQA6ACIAJwAYAML/2////mf/ FP7c/mL9cv44/Vn+rv2f/p3+Lf+//9n/ugBvAD0BvAAUAaQAZQA8ALn/1f+p/8z/XgA4AFsB zgDGAQ4BLgG0APD/9//w/l7/0v5N/1r/nv+p/8z/Fv91/+b9wP4V/UT+ff2D/gb/bP+xAGgA ZwHWANwAgwCu/8//x/5G/6T+Mv8R/3L/fP+x/3n/sP8A/2j/Uv4A/8P9rP6j/Zf+G/7g/h3/ eP8xABwApQBjAAIAAQB2/hf/4Pwk/jj8wP3b/CH+Of7y/k3/lf9f/6D/iP4h/4L9hf4R/UL+ ff2B/oD+G/+E/7b/AQAAALH/0f+x/jn/gP2D/sz8Gf4a/Uf+VP4B/8n/3/+TAFcASAAqAED/ jv9D/vj+4/2+/gn+1f4x/uz+8v3H/m39eP4L/T/+EP1C/kv9ZP5V/Wn+/fw2/n786v0+/MT9 dPzl/QP9Of6i/Zj+GP7d/lX+A/9a/gX/Lf7q/uv9w/7V/bX+Hf7i/r3+QP9j/6H/wv/b//L/ +P9iADoAbwHaAOwCvQEsBHoCjwS2AhwEcgJ4Aw8CTQP3AbQDMwIdBHIC7gNWAhQD1AELAjgB YAHRACwBswAaAagA4wCHAJgAWwCKAFIA1AB+AB8BqgDgAIQA3v/s/3v+Gf9x/Xv+S/1k/gz+ 1v5A/47/VAAyAO0AjQAEAZoAyQB3AIIATgBkADsAfQBLAK0AZwC4AG4AhgBQADgAIQAdABIA ZAA8AOkAiwA/Ab4ABgGdAEsALQB+/7P/Iv98/1n/nf/M/+D/9v/7/5z/xf/8/mb/ov4x//P+ YP/e/+z/6QCLAH0B4gBTAckAkQBWALD/0P8l/33/JP99/5L/v/8nABgAnQBdANMAfQDVAH4A 0wB+AAUBnACPAe0AXQJnASED3AFzAw0CFQPWASUCRgEWAaUAZwA9AFIAMQCzAGoAKwGyAHEB 2gBoAdcAFQGlAIYATwDg/+3/gv+1//f/+v+aAfQAGwRxAoAG3QOdB4gE+gYmBCQFDwNeAwAC pgKTAQ4D0gHGAz4C4wNQAiMD3gESAjwBhwHpAOkBIwHgArYBngMmAnwDEgJuAnIBBwGcAAsA BwD8//3/wwB0ANEBFAF4AncBWwJnAaMB+ADZAIEAhwBQANkAggCKAesAEwI7AQkCNgFjAdQA eABHANf/5//3//r/5ACIADACTgEZA9cBBAPLAfYBKgGqAGUALAAbABoBpwAsA+MBaAU3A84G CwQHBy4EhwbiAxMGnAMfBqMDnQbvAykHQgR1B28EdwdwBFMHWwQ2B0kESQdVBKwHkARmCP4E QgmBBcYJzwWDCagFbggCBQ4HMwQzBq8DVAbDAz4HTwQ5COQEjwgXBRUIzgQzB0gEkgbpA6IG 8QNgB2IEcAgEBVYJjQXDCc4FrwnDBWAJkwUvCXYFRgmEBW8JnAU3CXoFVQj0BAAHKgTlBYED uAVmA58G7wMSCMwEOwl+BY0JrgUVCWcFWAj2BN8HrQTkB7AEUgjyBPQIUwWdCbcFIQoFBlUK JQYdCgMGjAmtBeIISAVqCAEFOwjlBCgI2gTtB7YEYAdiBJwG7wPtBYYDnQVXA8kFcQNZBsYD /QYnBFMHWwQUBzUEQwa5A0QFIgOoBMQC2AThAs0FcwMXBzcEHwjUBIwIFQVbCPgExQegBP4G KAQlBqcDXgUwA+kE6wINBQED2AV7A/wGJwTnB7MEHgjTBI4HfgSfBvAD7AWFA90FfANlBs0D DQcxBEUHUwTPBg0E7wWHA0MFIANCBSAD4gWAA5MG6QOwBvoDEwacAzYFGQPjBOgCeAVBA5sG 7QNzB20EYQdkBH0G2wN3BUADAAX5AjoFHAO6BWcD9gWLA7wFaQNOBSgDDwUCAy4FFQOKBUsD 3AV7A+wFhQO1BWUDTAUnA+EE5wKqBMYC0QTdAlEFKQPiBX8DHQajA80FdAMmBRADrQTIAtgE 4gK3BWYD2AYSBJEHfwRvB2wEZAbNA88E3AJKA/QBaAJuAYECfQFuAwoCmAS8AjMFGAPFBNcC hwMZAk0CXgH1ASoBvgKhARMEbAIEBfsC/QT3AjcEgQJ3Aw4CbwMLAkIEiAJ0BT4DUwbCA2AG ygOLBUwDJQR3ArQCnQHJARABxwEPAa4CmQELBGgCIgUNA1wFMAOiBMECeQMRAqQCkwGqApYB gwMXAqEEwAJNBScDFQUFAwIEYwKSAocBZAHUAOwAjAA/Ab0AEgI7AfwCxgGmAywC9QNaAvAD WAKzAzMCVQP7AfYCwwHIAqcB6gK8AVID+QG8AzoC3QNMApIDIAIKA88BmgKMAXcCdgGTAogB sAKZAZQCiAE3AlEBwwEMAWkB1wBLAcUAaQHWAKYB+wDPARQBsgECATsBvACaAFwANwAiAGkA QAA2AbkAPgJVAf8CyAE6A+sBFAPUAeUCuAHlArkB/ALGAegCugF/AnwBzwETAQoBnwBkADsA BQACABAACQCMAFMAPQG8AIkB6gDDAHQAvP5A/xr8rv0R+nn8m/kz/Lj63fxs/OD9dP18/jH9 Vf4F/KL95vr3/Jn6yvw1+yb9N/zA/fb8Mf4N/T/+ePzm/X77Uv2I+sD8B/pz/EL6lvwq+yD9 RfzI/eX8J/6e/P79m/tk/Yf6vvwi+oP8rvrW/MX7fP2Z/Pr9hfzv/Xz7UP0M+nb8BfnZ++74 zPu0+UH8rPrU/BL7Ev2O+sT8e/kf/LH4p/vs+Mv7MPqL/LH7cf1a/NX9kvte/bH5QPzR9yL7 Bveq+qv3DPsz+fT7mvrK/CD7Gv20+tr85/lg/HH5Gfy5+UT8qfrT/NH7g/22/Av+Dv1A/tn8 IP5F/Mf9j/tc/e76/PyA+rv8Vfqi/HT6tfzg+vX8jftb/WT83P1G/WH+E/7a/rf+PP8x/4X/ iP+5/8T/3P/o//H/AQAAABEACgAeABIAGwAQAPL/+P+O/73/6/5b/x3+4P5K/WP+pvwB/mD8 2P2J/PH9Df0//pr9k/7H/a7+SP1i/iv8uP3q+vr8JfqF/EL6lfwf+xn9Mfy7/d38Iv7l/Cj+ ivzx/UX8yP11/OT9F/1F/uX9wP6J/iH/y/5H/6H+MP8b/t/+Uf1o/mr83v2X+2D9CfsM/ej6 +fw++yz99PuX/cr8F/5p/Xb+f/2E/vr8NP4r/Ln9t/t0/Sz8uf2U/Y/+R/+S/1IAMQASAAoA qP40/+D8Jf6X+2H9N/so/Zv7Y/1T/ND9//w3/mv9d/6F/Yb+Tv1m/u/8Lv7C/BL+Ef1C/tX9 tv6E/h7/cP4R/2D9cP7n+5D9DfsO/YX7Vv0Z/Uf+zf5J/5D/vf8Q/3D/1f21/sf8F/6N/PP9 KP1P/iz+6v4o/4D/5f/w/24AQQDmAIkAbwHaABICOwG5Ap8BNgPpAVQD+wH/AsgBYQJpAc8B FAGMAesAhgHoAGIB0wC+AHEAiP+5/yr+6P4+/Vz+OP1a/gn+1f4h/3v/xP/d/3n/r/9L/v7+ 1/wf/uT7j/0B/J/9LP1R/t/+Vf9iADoAMgG2ADcBugCyAGkA8P/3/xn/d/8x/u3+T/1m/rb8 DP7A/BH+iv2J/sX+Rf/J/+D///8AAEf/k/8j/uT+XP1u/nv9gP5d/gb/RP+Q/2j/pv+R/ib/ S/1l/oT87v3T/B3+AP7Q/if/f/9l/6T/f/4b/xL9Qv4Z/K/9P/zE/WX9dP7F/kX/dP+t//v+ Zv+b/ZP+Gvyu/VH7N/2t+239+Pwy/oX+H/+e/8X/5v/x/4X/uP/j/lf/UP7//s79s/4w/VX+ aPzc/ar7bP1Y+zr9nvtk/Ur8zP3k/Cb+CP08/q38Bv4h/LL9vft3/av7bP3O+4H98fuX/ev7 k/20+3L9UPs2/c366Pw3+o/8rPk9/FT5CfxQ+QX8pfk5/DH6i/y8+t78GvsW/T/7K/1B+y79 Qvsu/VT7Of1s+0b9bPtI/UT7L/38+gX9vvrf/Lf62/wA+wb9k/te/T78xP2t/Ab+kPz0/dL7 hP3L+uj8J/qG/In6wPwE/KH93P26/un+W/9e/gj/e/zo/XX6tPy4+UT82/rx/D/9Xf6K/7n/ kABWAAoABgCU/ij/JP1N/nb85v26/A7+pf2a/qL+MP8d/3n/xf5E/7f9o/56/Oj9pPto/XP7 TP2n+2v9xft9/Yv7Wv0z+yb9L/sk/cn7ff3U/B7+4v29/oT+Hv+S/ib/F/7e/kD9Xf5S/NH9 uvt1/eH7jf3a/CH+OP7x/kb/kv+K/7r/IP97/53+Lf97/hj/rv44/8T+RP9s/g//0v20/nr9 gP7H/a3+m/4s/3X/rv/X/+j/kv+//9P+Tf/2/cr+Zf1z/nf9fv4//vX+Xv+f/x8AFADr//P/ zP5J/479jP4t/VL+EP7Z/qv/zv/vAI4AGwGoAC0AGwDC/kL/e/2A/qz8Bf5o/N79sfwI/mn9 dv44/vH+j/4k/xr+3/4p/VD+lfz4/Q79QP50/hT/1//n/0UAKQCZ/8P/jP4j/w3+2P5m/gz/ Fv91/1r/nf/h/lX/Dv7Y/pP9jv7n/b/+Af9o/3UARQC8AQgBagJwAVcCZAGrAf0A0gB9AE8A LwBpAD8A+wCWAIwB6wCpAfwAMAG1AFkANQB+/7L/6/5a/8j+Rv8a/3j/uP/U/z4AJQBAACYA i/+6/3P+FP+g/Zb+nf2V/mb+Df9b/57/vf/Y/0H/jv8+/vT+X/1v/ir9UP7E/az+8P5f/0wA LQBwAdsABwI1Ad8BHQEJAZ0A3//s/9v+Uv9f/gj/iv4h/zr/i/8zAB4AKgGxANkBGgERAjoB xgEOATABtQCqAGUAewBJAKQAYgDqAIsAAgGZAMoAeABVADQA4//v/7X/0//3//r/oQBgAF8B 0gCoAfsADQGgALD/0f9P/v/+1f23/rD+OP9hADoA4QEeAVQCYwGvAQEBlABYALj/1f9r/6j/ hf+4/8v/4f8gABMAdABFAJcAWgBDACgAb/+q/3j+F//k/b/+5P2+/h7+4v4E/tL+Y/1z/rH8 CP6b/Pv9b/15/rf+PP+e/8b/kP++/6/+OP+3/aT+bv15/ij+6P6Q/77/4ACGAFMByQCNAFQA 5f5Y/z39W/6A/Oz9IP1K/r3+P/92AEYAeQHhAHQB3ACfAF4Acv+s/1X+A/+Q/Y3+Xv1v/uL9 vf79/mb/QQAmAB4BqgBKAcQA4QCFAEkALADl//D/3P/q/zEAHgDcAIIAuwEHAXYCdwGcAo0B +gEuAfQAkQBRADAApwBjANMBFgEXA9YBywNBAu0DVQIVBG0CywTZAvMFiQPmBhoEFAc1BH4G 3QOnBVsDAAX6ApYEugIkBHYCfQMTArQCmwH5ASwBXgHQAMwAeQBBACcA7P/0//j/+/9ZADUA ywB4ABkBqABhAdIA4wEeAZwCjQEZA9cBzgKrAacB/QA/ACYAZv+k/33/sv8qABoAvABwAMgA dwBuAEEADQAIANr/6v+//9n/r//Q/+f/8v/MAHkAeAJ4AXQEpwL2BYwDaQbPA9wFfAPqBOwC TQSPAm4EowI7BRwDSAa7AwQHKwT/BikEIQakA8ME1QKTAyACHQPaAV8DAQK7AzgCagMIAiYC RgF1AEQAU/+Z/3T/rP/AAHIAbAJwAYsDGwKdAyYCswKbATIBtQCN/7v/Nf7u/pH9jf7x/cb+ Qv+P/+kAiwDvAScBnAH2AAkABQAu/uv+Xf1u/mL+Cf/1AJEA5wNSAuMFgAM3BrIDRQUiAyIE dALsA1UCEwUEAxEHNATCCDUFAAlaBVkHXwRXBJQCNwG4AD7/jf/+/mb/CgAGAEsBxADCAQwB LgG0ABUADABG/5L/PP+L/83/4f9zAEQAwwB0ALgAbgCbAFwAqABkAN8AhAAOAaEAEQGiAOMA hwCYAFsAPAAkANf/6P92/67/Nv+J/zT/hv9b/53/fP+y/2f/pf8f/3r/3/5U/+f+Wv9J/5P/ z//i/xwAEQD1//n/Xf+f/6D+Lv8p/uj+Q/73/uH+Vv+c/8T/5v/w/3j/rv+R/iX/4/2+/hH+ 2v4f/3r/UAAwAJ8AXwCB/7X/X/1v/lr7PP2O+sT8Y/tD/Vr9bf6C/7X/BQGbAJIB8ABMAcYA iwBTAKP/yf/R/kz/Lf7q/rP9of5B/V7+tvwL/hz8sP2++3j98PuV/cr8F/71/cn+0P5L/+D+ Vf86/vL+ff2B/mn9dv5L/vz+v//Z/+8AjgAsAbMAZgA8ACf/f/8w/u3+Av7Q/qH+MP+2/9T/ wAByAEUBwgD4AJMA2f/p/13+CP9G/WL+OP1Y/jX+7/57/7H/AQABAEX/kf/O/bH+0Pwb/j79 Xf74/mL/2QCCAKUB+gDwAI4Ab/+q/1f+A/9l/gv/av+m/3sASACrAGUAqP/M/9r9uf4l/Lb9 bftH/SD8sv0D/tL+SwAsAPsBLQGCAn4B+AEsAQgBnQBmAD0AWAA0AJcAWgCmAGMAPQAlAHz/ sv/P/kv/rP42/0//lv+VAFgA8wEpAacClAEiAkUBhABOALP+Ov/a/bn+iv4i/y0AGwBtAdkA QgHAANb/5/9l/gz/Kf7o/kT/kf+uAGcAIAGrADoAIwDQ/kv/IP7i/tD+S/9uAEEA3AEaATEC TgFKAcQAwv/b/3f+F/8c/uH+4/5W/2kAPgDcARsBZAJsAa0B/wAyAB0A//5n//L+YP8RAAoA gQHlADQCTwG6AQcBggBOAHL/q/8m/3//nv/G/2cAPQANAaAAWgHNAEcBwgDYAIEAFAANAB7/ ev9D/vf+1v22/vv9zf6U/if/U/+Z/+3/9P8gABMAzv/j/wf/bP8c/uD+kf2N/tf9uP76/mP/ eABHAJMB8ADIAQ8BHQGpABQADQBO/5b/K/+C/6f/zP9wAEMAEgGkACoBsACGAFAAUv+Z/wr+ 1f5M/WT+f/2D/qL+MP9HACoA1QEXAdACrQH1AsIBSgJdARoBqADy//j/Y/+i/7X/0/+fAF4A ZQHUAGIB0wCAAEsAUP+Y/5n+Kv+7/j//cf+r/yQAFgBqAD4ARQAqAAAAAADc/+v/8//4/0sA LADoAIkArgEAAU0CXwFWAmMBlAHxAGEAOQBq/6f/Pv+N/9j/6P+yAGoAQwG/AGgB1wBiAdMA bwHaAIIB5QBoAdYAIQGrAPsAlgBRAcgAHAJCAd4CtQEFA80BcQJ0AZMB8AAXAaYAVwHLAB8C QwHnAroBPwPvARAD0QGKAoMB+QEsAZAB7gBnAdUAegHhAKoB/QC9AQkBiAHoAA8BoQCIAFEA NwAgADYAIABoAD0AjgBVAIcAUQBbADYAKwAZAAkABQD1//n/5v/x/9v/6v/j/+7/+v/8/xcA DQAoABgAOAAiAF4AOACqAGUADwGhAGwB2ACfAfcAnwH3AH0B4gBYAcwAUQHIAJAB7gAqAkkB CwPPAdcDSQIDBGMCKwPiAXYB3gCq/83/zP5J/3H/q/9FAcIAKAPgAeQDTwLzAsEB2QCBAML+ Qv++/an+K/7p/qL/x/9ZAc0AoQKQASgD4QHzAsEBOAJRAU4BxgCZAFwAbQBBANcAgACJAeoA 9gErAbABAQG+AHEAq//O/yv/gf+p/8z//QCWAHcCdwFOA/cBBgPMAcMBCwE8ACQAX/+h/9T/ 5v+cAfQADwRqAjcGswNRB1oEIwc+BAYGlAOZBLwChQMYAjMD6AHBAzsC1wThArUFZAN9BUMD zQNCAi0BtAD+/mb/lv4p/0cAKQD0AsEByATYAnwEqgJCAlcBlf/A/xX+3P5z/hT/GAAOAMAB CgFkAmwBwQELAUkALAC//kL/1P21/uH9vP7V/k//KwAaACUBrgBDAb8AoABeAOn/8v/e/+z/ sABpANgBGAF8AnoBGgJBAecAiQCT/7//tf47/2f+DP9Y/gT/M/7t/vb9yv71/cn+h/4g/7H/ 0f8PAaEABQI0ASACQgFPAcgA/P/+/8X+RP8l/ub+Pv70/tX+Tv+P/77/KwAZAJEAVwC1AGwA ewBJAM//4v/b/lL/Jv7m/kr+/P6B/7X/SwHFAJcCiwF5AngB3wCEAMT+RP+S/Y7+If7j/g8A CgD+AS8BigKCAVMByQA+/43/wP2q/tD9s/5F/5D/LwG0ALkCnwHCAzwCrwTKAsgFcAO1Bv0D vwYEBIAFRQNbA/8BQQG/AA8ACQAHAAQA5QCIAEACVwHEAz0CCAX+AmUFNQNDBIkCrwEAAb/+ QP8a/Ub+1P22/ogAUQBuAwoCigSzAg4D0QHc/+v/6Pwo/uP7j/03/Vj+6//z/1kCZQE1A+kB QQJXAVgANQDf/lX/3v5U/18AOQBiAmoBjAMcAhYD1QFQAcgAYP+i/2P+Cv+x/jn/wv/b/64A ZwDTAH0AJAAVAAP/av/r/cP+Sv1k/nP9e/56/hj/CwAHAFsBzgCCAeUALAAaAP79z/5Q/M/9 L/y7/YD9g/75/mT/If97/4r9iv5I+zL9HfqA/Bv7Fv3B/av+ZgA9AH8B4wC9AHAAF/92/9b9 tv6R/Y7+BP7S/pb+Kf8J/23/kf++/0sALADXAIAAkgBWAEv/lP+1/aL+8/ww/qr9nf5N/5b/ gQBMADIAHgCX/in/B/08/u38LP6Y/ir/8QCOAEMCWAGIAekAG/94/3/86/1j+0H9kvz2/Yn/ uf+8AqABZgSeAoQDFwJqAD8ArPwG/kr6m/yD+r38Cf09/jMAHgAHAjUBkgHvAHb/rf9Y/Wv+ qvwE/qr9nP5l/6T/jgBTAGcAPQA4/4j/6v3C/mP9cf4B/tH+iP+5/0EBvwBOAl8BEgI6AYIA TABd/gb/0fwb/sn8F/5G/vr+VQAzAMwBEQEqAkoB4wEfAdIBFAFWAmQB7wK/AcICpAF0AdwA n//G/1r+Bv9Q/gD/Nv+I/xwAEAA8ACQAlP+//8n+Rv+N/iX/Hf95/xsAEADsAI0AHQGqAJ0A XQDB/9r/DP9v//D+X/+D/7b/ZgA9APwAlgDWAH8ADAAIAC3/gv/H/kf/9P5h/07/l/9k/6P/ Jf9//wD/aP9o/6X/XQA3AF8B0QDZARkBoAH3AAgBnQCFAE8ALgAbAL7/2P/v/l7/8v3I/mf9 dP7y/cb+o//I/8wBEQFbA/8BhAMYAjwCVQFFACoAwP5C/4P+Hf+j/8n/ZQHUALwCoQH6AsYB PQJVAU4BxwD9AJcAeAHgADkCUwGKAoIBLwJNAZsB9ABzAdwA4wEeAXMCdQGBAn4B4wEfARoB qADYAIAAUwHJACQCRwG3Ap0B1QKuAcICpAHPAqsB7AK9AdACrAFyAnQBVwJkASwD4wEDBfsC AgcrBPIHuQQ8B0wEfAVCAwsEZwLmA1IC6gTsAhAGmwNTBsMDgQVHA0gEjAKLAxsCrQMwAmoE oAIfBQwDUAUqA/EE8AJUBJQC6wNWAvQDWgJSBJICmgS8Al4EmAJ/AxQCXgJpAZ4B9wCzAQMB ggJ/AXsDEQIDBGMC7ANVAocDGAJHA/IBaQMHAsoDQQIiBHUCPwSGAhgEbgK8AzgCPwPuAbsC oAFlAm4BeQJ4AQIDyQGrAy4C2gNKAgcDzQEpAbEA0v5N//P8L/5f/Nf9Vv1r/mD/of97AeEA pQKTAVgCZQHSAHwA5/5Z/3z9gf79/Db+Ov1Z/rP9ov4P/tj+Xf4H/9r+Uf+H/7n//////8f/ 3f/Y/lD/zP2x/n79gv5I/vv+qP/M/4QATwAOAAgAaf4O/5/8/v3t+5X92fwg/uj+Wv/8AJYA EAI6AcoBEQGWAFgARP+Q/5T+J//e/lX//P/+/2wB2ACiApABVwP8AZ0DJgLKA0ECIARzApwE vgIBBfoCHgUKAxMFBQM2BRkDxgVvA5wG7QMvB0UEBQctBCkGqgM5BRsDDQUCAx8GpAMWCM8E 8wnrBZ4KUAalCbwFgQd1BFYFLANGBIoCwQTUAlUGwwMACMEE3QhFBacIJAXHB6AE/AYmBM0G CwRAB1AE1wepBO4HtwQyB0cE6gWEA+oE7AIUBQQDqwb3A/8IWQW2Cl4GtwpfBg0JYgX9BigE JgaoA0cHVASiCbsFigvcBq4L8gYXCgAGBwjGBPQGIgRzB24E9AhTBU8KIQagClIGwgnNBSUI 1wR+Bt0DZgU2Ay8FFQPPBXMD4AYWBNEHpQQ6COQEEwjMBLsHmASUB4IEvQeaBAEIwwQnCNoE HgjTBOgHtARoB2cEZwbOA/cE8wK+AzkCvgM6AooFTAOPCBcFLwumBskLAgfuCecFuwYBBBUE bQJZA/0BjQS1ApMG6QMRCMwERQjrBD0HTgSVBVEDHgRyAocDGQI0BIAC8wWKA/AHuAQLCWAF kAgXBcwGCwT8BPYCcASkApMFUQOOB34E6AhMBaYIJQX/BikEKAURA1oElgLpBOsCKAapAwEH KwTjBhgEHQaiA4UFSAO6BWgDpwb1A5wHhwTnB7MEXwdjBHcG1wPWBXgD6QWDA5YG6gNvB2sE 7we3BMcHoATwBiIEtgVlA5YEugIcBHECjgS1ArEFYgPcBhUEVQdcBMoGCgSQBU4DWwSXAtgD SQJCBIgCVQUrA3kG2QMYBzgE2AYSBN8FfgPFBNcCPwSGAowEtQIgBQwD9wT0AosDGwJ7AeEA RgAqABIBowCLAxwC9wWMA5QG6QMNBQEDwgKkAYgB6QAXAj4BnQMmAqsExgKWBLoC2ANKAlMD +gFAA+4BBwPMAf8BLwFLACwA4v5V/8X+RP8gABQAJgJHAZMDIQKBAxUCzQESASP/fP+w/Aj+ l/th/WP82f2b/iv//ACVADQCTwHWARcBjgBUAJz/xf/L/+H/7wCOADQCTwHYArEBtQKcARwC QQFpAdcAsgBqAOL/7/8A/2f/UP7+/jj+8f4F/2r/sABpALcCngFHBIwClwS7AmQDBAI9AbwA Of+J/0z+/P61/jv/+P/7/08ByAAjAkUBLQJLAWoB2AAlABcACP9t/+v+XP8uABwAJwJIAXAD CwIQA9IBfwHlAFoANQDOAHoASgJcAeoCvAFoAdYAsv45/1D9Z/4L/2//CgPPAVEGwQNdBskD SwP2AZr/w//l/cD+1v5O/xkBpwD/AsgB4QNOAg0EaALJA0EC3QKzASYBrwBi/6P/7f5d/3cA RgAmA98BDAUBA70E0AJzAnQBxf/d/1T+Av+j/jD/HAAQAMUBDQHjArcBHgPaAVsCZgHJAHgA FP9z/yf+5v6k/jH/TgAuACwCSwE8A+sBLQPjAXsCegHWARcBjQHsAHQB3QA6AbsA1wCAAIsA UwCUAFcA3gCEAA8BoQDDAHQA8v/3/wj/bP+z/jv/ZP+j/+sAjAB+AnsBPgPuAdsCswHTARUB AAGYAOkAiwBZAcwAogH4AEABvgBQAC8AZ/+k/yT/fv/Q/+T/PgG9AOQCuAHwA1cClAMhAoIB 5gBo/g7/zvuA/SD7Gv2h/P/9DP9u/4MATwACAAEAEv7a/i/8u/1u+0n9tPtz/SP8tP0b/LD9 z/uC/dj7h/1m/Nz9/Pw1/uP8Jv7o+5H9hvq//IT5JfxW+Qr89Plo/AD7B/38+539afzd/eH7 jf1p+qz8nPib+4f39vr09zj71vlV/DP8vv3c/br+Nf7w/oH9hf5x/OH9gftT/bv63vzw+Wb8 Gfnl+4L4jPuP+JP7ZvkT/NT67fxq/N39sv2h/mL+Cv96/hj/NP7v/vn9y/4b/uD+mv4q/wz/ b//e/lP/vv2o/ur7kv0q+of8VvkK/M75Ufw3+yf9oPz+/SD9S/5g/Nn9wvri/Af52/vS9yL7 VPfY+m/36PoJ+EP7Ifnq+5X6yPzc+4n9Ivy0/fj6Av3T+Lz77vac+mT2SfpB98z6bPh/+5L4 lfs+98z6RPWe+QD03vg/9AP5svXf+VX32fpe+Hf7ufit+9P4vPsK+d37UvkH/Gb5Evwb+eb7 lfiW+xv4Tvvi9yz79vc4+0n4avvK+Lf7V/kK/L35RvzN+VH8kvku/EX5APwo+e/7TvkE/Ib5 J/yQ+Sz8TfkE/NP4vPtY+HP7HfhP+1/4d/tL+QP8zPro/GD82f0q/VD+ePzn/Wv6r/wZ+Ez7 8Pad+rb3Evvb+Vn84PuM/W384P1R+zf9lvkw/K34pftV+Qn8Nvsn/T79Xf5z/hT/ev4Y/5/9 lf6H/PD91vuG/f/7n/0l/U7+Ev9y/zoBuwDxAr8BtQM1AmEDAgIoAkgBeQBIAOf+Wf8V/tz+ jv4j/1cANACzApoBVASSAiAEdAIHAjUBJv9+/wH9OP5o/N395Pwm/kL9YP66/A7+i/tZ/bX6 2vzt+vz8+fuc/dn8If62/Av+kPtc/SX6hfxO+QX8WfkM/Pv5a/yt+tX8F/sV/SL7HP3W+u78 RfqX/Jf5MPwZ+eb7J/nu+/X5Z/xn+0T9Iv1L/rD+OP+u/8//6P/y/3D/qv+w/jj/Wv4E/wD/ aP+XAFoAQwJYAcoCqQF4AeAAvf5B/wD8oP2o+tP8FvsU/XL84/1h/XH+Gf1G/uP7jf3H+uX8 q/rT/K/7cP1G/WH+pP4y/zz/jP/Z/lH/jf2L/qb7af23+UP8j/iT+8v4t/ti+qr8dPzl/bL9 of5A/V3+X/tA/Vn5C/yo+KL77/lk/Hb85f2n/jP/GP93/5L9j/41+yb9rfk9/Aj6c/zs+5P9 5P3A/nf+Fv9E/WD+Rfsx/QT6cfxh+qj87fuV/Uj9Yv40/Vb+f/tT/Rn55ftf99/6OvfJ+qX4 oPvj+vb89fwx/gr+1v7B/ar+Nvy//Q36dvw2+F/7lff++nr4h/tv+rH8cPzi/X/9gv5G/WH+ SfzK/Xj7T/2S+179i/zy/Zv9k/6+/aj+ifzx/ZH6xfwn+e37c/ka/Jb7YP15/hf/iQBRAN0A hADe/+z/3v5T/wr/bf98AEoANAJQAf0CxwFdAmcB2wCBAHX/rf/J/kf/tf47/5v+K/8A/s/+ 7vws/t/7i/1X+zv9j/tc/Vj80/1Q/Wb+Gf7d/oD+HP+C/h7/Nv7v/rD9n/4C/Tn+Q/zG/ZX7 YP0i+xv99voA/ev6+/zM+uj8h/q//GT6qvzb+vD8LPy5/QH+0P6J/7n/BQADAG//qf+S/ib/ g/4d/8D/2v/EAQ0BSwP2AUUD8QGWAfIAQP+O/7T9ov7c/br+gP+z/2wB2QBBAlgBYAHRAFT/ mv93/X7+9/wy/g/+2f7i/+7/HgGrAPAAjwB//7P/tP2i/oD87P1L/Mz90vwc/pH9jf4c/uH+ S/78/iL+5P7M/bH+lv2Q/tn9uf6x/jj/tf/T/xIACwAa/3f/7Pwr/p36zPyI+Sf8Ufqg/Gv8 4P1//hr/c/+s/zL/hv+L/iL/Xf4H/+r+W/+z/9P/CwAHAKX/yv+7/j7/xP2s/hn9R/7V/B7+ 6vwq/j/9Xf6o/Zz+6v3D/tD9s/5i/XH+7/wt/tz8Iv5P/Wf+Ef7a/rX+O//s/lz/rP41/xr+ 3/5a/Wz+iPzx/eD7jP3A+3n9cfzh/b39qP7e/lT/7f5c/6H9l/66+3X9m/rK/E77Nv2m/Zv+ QwAoAHkB4ACAAEwA8v3I/lX7Ov0V+nv8u/rd/ND8G/5Z/53/ZwHWAIACfQGZAosBDgI4AW0B 2QAvAbMAawHXAK8BAQFQAckA+f/7/xj+3/68/BD+yPwW/jb+8P77//z/wQByAPL/9/8q/uj+ uvwO/q38Bv7//c/+wf/b/+AAhQDnAIkALAAbAFf/m//b/lL/v/5B/9X+Tv8M/2//Zv+k/9D/ 5P/8//7/n//G/7/+Qv/c/bn+iP2I/u79xv6d/iz/6v5a/4X+H/+//aj+N/1Y/l/9cP4n/uf+ MP+F/xUADQCKAFIASgAsACD/e/9C/V/+g/tV/Qr7DP1f/Nj9yP5G/5UAWgBvAEIAb/4S/xn8 rv0X+xT91fuG/WX9c/53/hf/j/4k/x/+4v63/aP+Rf1g/kr8y/23+tz8cvkZ/Kn5O/y5+3T9 nv4t/7wAbwAQAaIA6v/0/1v+Bv8+/Vz+pvwC/j38w/3R+4P9mvtj/ev7kv3P/Br+Bf7T/jf/ iP8ZAA8AcwBEABgADwAp/4H/Ov7x/h7+4v5Q/5j/ZAHUADkD6gGvAzECeAJ4AT8AJQAe/uH+ 6vwr/tT8Hf51/Xz+JP
Reply by ●January 22, 20152015-01-22
This is an interesting, and annoying, noise! I will pass this along as an option for the students to explore and let you know if we find anything useful. Thanks for all the comments on this thread -- there is a lot of good stuff! Allen>This is a multi-part message in MIME format. >--------------070103070707040001090005 >Content-Type: text/plain; charset=windows-1252; format=flowed >Content-Transfer-Encoding: 7bit > > >Allen: > >Please find attached a noise that is the bane of my existence, my >"Ahab's Whale". > >The sample includes the breath of the speaker (who *did* inhale), and it >comes from here: > >https://www.youtube.com/watch?v=Aju752l0tP4 >(the noise starts at minute 1 and goes all the way to the end) > >Feel free to add a chapter on how to remove it. ;-) > >TIA, > >-Ramon > > > > >On 1/21/2015 8:29 AM, AllenDowney wrote: >> Last week I posted blog article on Chapter 4 of Think DSP, which isabout>> noise: >> >> http://thinkdsp.blogspot.com/2015/01/think-dsp-chapter-4-noise.html >> > >--------------070103070707040001090005 >Content-Type: audio/wav; > name="WhatKindOfNoiseIsThis.wav" >Content-Transfer-Encoding: base64 >Content-Disposition: attachment; > filename="WhatKindOfNoiseIsThis.wav" > >UklGRqRIAgBXQVZFZm10IBAAAAABAAIARKwAABCxAgAEABAAZGF0YYBIAgDl//D/sv/R/6L/ >yP+2/9T/5P/w/xoADwBGACkAZwA9AIMATwChAGAAvwByANAAfADMAHoAsQBpAIcAUQBaADYA >LAAbAP3////V/+f/vP/Y/7D/0v+i/8n/dv+u/yb/fv/R/kz/qf40/87+S/8z/4f/pP/K/+v/ >8//u//b/v//a/4H/tf9X/5v/VP+b/3v/sf+3/9X/7f/z/////v/u//X/2//o/+z/9P8xABwA >hQBNAKMAYABRAC8Ai/+6/4X+H/+E/YT+uPwM/iv8uP3C+3r9Xvs+/fX6AP2Y+sj8VPqg/DL6 >i/wW+nz86flh/Kz5PPyI+Sf8uvlF/Fz6pvxH+zH9Ivy0/av8BP7i/CT+BP06/k79Zf6t/Z/+ >2/26/ov9i/6+/BH+uft1/dn68PxQ+p78Evp6/O/5ZvzJ+U/8k/ku/FL5CPwF+dr7svip+2T4 >e/sz+F37JvhV+zb4X/tK+Gv7XPh2+3H4gvuV+Jf7xfiz+/T4z/sW+eT7Mfn0+1H5Bvxz+Rv8 >h/km/Ir5KPyL+Sn8oPk1/ML5SvzE+Uv8d/kc/OT4xPtd+HT7Tfhq+9T4u/un+Tn8RPqV/Ev6 >mvzO+U/8M/nz+934wPvl+MX7G/nm+zr5+Psf+ej71Pi7+3z4iPs3+F77G/hO+zj4X/uG+I37 >7PjK+zz5+vtZ+Qz8R/kB/Cv58fsv+fL7VvkK/If5KPyj+Tj8nPk0/Hr5IPxQ+Qf8J/nt+/z4 >1vvV+L/7tfit+6L4oPuS+Jb7gPiM+3H4hPtz+IX7jviU+7n4rvvh+MX79vjS+/v41fsE+dv7 >HPnp+zn5+ftL+QT8S/kE/EH5/vs5+fr7Pvn7+075Bfxs+Rf8mvkz/Nj5WPwO+nf8IPqA/AD6 >bvzH+Uz8q/k6/NH5Ufw5+o/8rPrV/PH6/Pzn+vf8pvrQ/F36pPwv+on8JfqD/DT6jPxJ+pj8 >YPqm/HP6sfx/+rj8evq1/Gf6qvxc+qT8dfqz/Lj62/wR+xD9Uvs3/Vv7O/0v+yL9+PoB/d76 >8vz0+gD9Lvsi/Wr7R/2P+1z9l/th/Yz7XP2B+1X9g/tW/Zj7Y/3A+3r99PuZ/SX8tv1G/Mv9 >UPzQ/UT8yf0r/Lv9IPy1/UH8yP2l/AT+Sf1l/gD+0f58/hz/hf4g/xb+3/5z/X7++Pw0/tz8 >JP4R/UP+Vv1r/nH9ev5d/XD+Pf1b/jP9Vv5D/WD+Wf1s/mP9c/5q/Xf+gP2E/q/9oP7k/b7+ >B/7S/hH+2f4Q/tj+Gf7d/jL+6v5O/vz+Zv4K/3b+FP+F/h3/k/4l/5P+JP98/hb/UP79/iT+ >4/4P/tb+G/7e/jz+8v5i/gj/gv4c/5/+LP/B/kD/7P5b/x//eP9G/5D/U/+Y/0f/kv8s/4L/ >Fv91/xb/df8m/37/L/+E/xj/dv/e/lT/mv4t/3T+Fv9//h3/tP48//L+Yv8f/33/Nv+J/zn/ >jf8x/4f/Gf95//T+Y//N/kv/uP4//7P+Pf+g/jH/YP4L//X9zP6Y/ZP+lP2R/gj+1v7V/k// >pf/L/zYAIQBoAD8ASwAtAPn//f+E/7f/Af9o/4r+Iv83/vD+C/7W/vH9x/7S/bP+r/2f/qT9 >l/6//af+9v3J/h3+3/4d/t7+Bf7R/v39zP4Z/tv+RP71/lr+A/9L/vr+Kv7l/hH+2P4M/tX+ >D/7V/gz+1f4O/tX+Iv7i/kb++P5g/gf/Yv4I/1T+Af9S/v/+ZP4K/3H+Ev9h/gn/R/76/lv+ >Bv/L/kj/d/+v//3///8JAAYAkv/A/+3+X/9s/hL/Kf7q/v/90v7E/a/+ff2F/lf9bP5n/Xf+ >m/2W/sb9r/7X/br+5v3C/hT+3f5d/gn/n/4w/7T+PP+Z/i3/bP4T/0X++/4o/un+GP7g/hz+ >4f41/vD+VP4C/1P+Av8f/uL+zv2y/p79lf6s/Z7+2/26/ur9wv63/aT+Z/10/kD9XP5d/W3+ >lv2P/q79nf6g/ZX+sv2f/i/+6f4Q/2//8f/1/2UAOwBNACsA4P/r/3b/q/85/4f/F/9z//L+ >Xf/F/kP/nf4r/3v+F/9Q/v7+DP7W/sr9r/64/aT+5P2+/i/+6v5a/gT/Rf74/gj+1f7U/bb+ >w/2s/sn9r/7R/bT+1f23/uT9wP4B/tL+HP7i/iP+5f4b/uD+Gf7g/i7+7f5D/vn+OP7z/gr+ >2P7f/b7+3P28/gD+0v4e/uP+Df7a/uH9v/7X/bn+J/7p/sz+Sv+L/7z/KwAbAKcAZAAdAawA >oQH5AB4CQwFvAnMBjAKEAZ8CjwHaArMBQQPwAaQDKgKyAzMCQgPwAWsCbwFtAdkAkABVAAAA >///B/9n/uv/V/8j/3v/J/97/rv/O/4H/s/9d/53/U/+Y/1//nv9n/6P/Wf+a/zj/h/8Z/3X/ >C/9t/wn/a/8A/2X/7v5b/+3+W/8j/3v/mf/C/zMAHQC7AG4ACAGcABkBpwAOAaAA/wCXAPkA >lADvAI4A2gCBAL0AcQCiAGEAjwBVAHsASQBdADkANQAgAAgABQDc/+z/t//W/5z/xv+S/7// >nf/H/7b/1f/L/+P/x//g/6T/yv9z/6//Uv+a/0//mP9q/6n/lP/C/7//2//a/+v/2f/r/7H/ >0/9i/6T/CP9u/8P+Rf+m/jT/of4x/4r+I/9J/vv+6v3D/pn9kv5w/Xr+af12/mH9cf5M/WT+ >S/1k/pD9jP4z/u3+Cv9t/8b/3P8ZAA4A+P/6/4z/uf8Y/3b/0f5L/8P+Q//j/lT/EP9w/zD/ >g/8v/4H/B/9r/8/+SP+l/jD/ov4u/8v+Rv8D/2j/NP+E/03/lP9d/53/ef+u/6v/zf/q//L/ >GgAOACQAFAAEAAIAyf/f/4z/u/9f/6H/UP+X/1v/nv98/7H/qv/N/93/7P8PAAoAOQAjAFoA >NwBxAEUAiABSAKsAZwDjAIkAKAGxAGQB1gB5AeMAWQHQAAsBoQCtAGkAYwA+AEkALQBbADgA >hQBSAKsAZwC6AHAArwBpAJsAXQCSAFgApQBkANMAfwALAZ8AKwGzACABrADhAIUAfgBMACAA >EwDq//L/8f/3/y4AGwCCAEwAxAB0ANYAfgC2AGsAgABKAFsANABiADgAjABQALYAagC5AGsA >hABMAC8AGgDq//D/3P/n/wMA//86ACAAVAAwADgAHwDz//b/pv/I/2v/pf9G/5D/Lf+B/xH/ >cf/0/l//1/5O/7z+Pv+Z/iv/cv4T/1P+Af9W/gL/h/4g/93+U/82/4j/cv+s/4f/uf+G/7r/ >g/+4/4L/tv92/6//VP+c/yT/f//+/mn/8v5i//f+Zf/z/mP/1v5R/6H+Mf9t/hP/UP4D/0n+ >/f5G/vz+Pv73/jz+9v5Z/gf/nv4v//X+Y/80/4n/QP+O/yP/ff8F/2z/F/92/2r/p//v//b/ >jwBVADsBuwDlASABfwJ7AfQCwAEwA+QBPAPrAT8D7AFoAwQCxAM7AjgEfwKJBK4CkQS1AmEE >lwIjBHMCAwRgAvcDWQLLAz8CTwP1AXsCdgGAAeEArwBmAEAAIwArABgAOwAhADYAHwACAP// >tv/T/4H/s/+A/7T/p//L/9H/5P/j//D/6f/z/wgABQBcADcA2wCDAEUBwwBcAdAACAGfAG0A >QwDU/+f/b/+t/07/mv9X/5//Zv+n/2z/q/9q/6v/aP+p/2f/qP9p/6n/cf+u/4f/uv+r/9H/ >0P/n/9r/7P+4/9j/dv+x/y//hf8F/2z/Bv9t/yT/fv8//47/P/+N/yH/e//3/mL/2f5R/87+ >Sf/L/kj/w/5C/6T+MP9y/hL/Of7v/gL+z/7a/bb+xv2q/sb9qv7P/a/+2/23/t39t/7Y/bX+ >2f21/uX9vf71/cb+/P3K/v/9zP4e/uD+if4e/0//lP9XADIAXwHPACwCSgGoApIB5AK2AfQC >wAHQAqwBZwJtAbgBBAHoAIoANQAgAMv/4f+s/8//u//Y/9T/6P/q//T/9v/8//L/+f/b/+3/ >vf/b/6r/z/+8/9n/6//4/xoAEgAlABoADwAMAPD/+f/m//P/+v8AABQADgAUAA8A+////9v/ >7P/E/9//vv/a/7z/2v+7/9n/wP/b/9H/5f/l//D/7f/0/+//9v8PAAkAfQBIAEsBwwBZAmMB >UgP2AeADTALcA0oCWQP8AZcChwHgARoBYwHPACcBrAAVAaIABQGYAN0AgACkAF4AewBGAH0A >RgCsAGIA5QCFAAABlgDvAIsAxgByAKUAYACfAFwAoABdAJQAVgByAEIASgAqADQAHQAzAB4A >NwAhAC0AHAAZABAADAAIABoAEAA/ACgAZAA9AHEARgBlAD4ATQAxAEAAKQBNADEAdQBJALQA >cAD1AJYAGgGsAA4BpQDLAH0AZQBBAP7/AwCx/9X/hv+8/3P/r/9s/6v/bf+r/3T/sP+C/7j/ >mP/E/7n/1//u//f/NgAhAH8ASwCrAGYAqQBlAIgATwBuAEAAggBMAMgAdAAUAaIAMAGyAP8A >lQCbAFkAPAAgABEABgAnABQAYwA3AJUAVACcAFgAdwBCAEEAIwAeAA4AIAAOADwAHwBWAC8A >VgAvADgAHgAgABAARgAnANEAewDIAQ0B+QLDARsEcALwBO4CZAU0A48FTgOcBVYDpQVdA6QF >XAN3BUIDCAX/Ak4EkwJiAwYCawJ0AZIB8wD1AJYAmgBgAHoATQB2AEsAdwBLAHMASQByAEkA >fwBRAJoAYQCxAG4AqwBrAHoATQAtAB8A4//y/7v/2f/A/97/5v/z/xMADQAxAB8APgAmAEUA >KQBPAC8AWwA1AFkANABBACYAGgANAAcAAQAuABgAnABZADABsgDBAQcBMAJIAXgCcgGiAowB >sgKTAYwCfQEkAkEBjwHnAAEBkwCtAGEAnwBZAK4AYgCqAF8AeABDACgAEwDO/97/d/+r/yb/ >ev/e/lH/u/48/8r+Rv8B/2j/Ov+L/07/l/87/4z/IP98/yD/ff9C/5L/df+x/6T/zf/E/+D/ >1//s/9r/7v/Q/+n/v//f/8D/4P/j//X/HgAZAFQAOAB0AEsAnwBlAA0BpgDYAR4B0AKzAZgD >KALfA1ICpwMwAjID6gHPAq4BmwKPAXwCfQFVAmUBHAJDAeUBIAHDAQsBtAEDAa4B/gCvAf4A >uQEDAcQBCgG/AQYBmAHtAFgBxwAfAaUACwGYAB4BowA9AbYAUAHBAFIBwgBIAbwAMgGvAAwB >mQDaAHsAuABoAMoAcgAQAZwAZQHPAJQB6wCGAeMAVgHIADEBswAnAa0AJQGsABQBpAD7AJUA >9QCSABQBpAA/Ab8ATwHKADcBuwAQAaUACQGiADMBvAB2AeQArAEEAcIBEQHGARUBzwEaAdcB >HgHEARMBggHtABwBsACvAG4AVwA7ACIAGwAPAA8AHQAXAFIANQCqAGoAGgGsAIsB7wDoASYB >HgJFASYCSQEEAjQBxgEPAYIB5QBFAcEADwGfANIAewCMAFAAVgAvAFEAKwCNAE4A7QCHAEEB >uQBlAc4AZAHNAGcBzwCJAeMAvQEBAdsBFAHJAQkBlQHqAGoB0QBpAdAAjAHmALEB/AC4AQEB >nAHxAHEB1wBRAcQARAG9AD8BuwAvAbMACwGeANsAggC3AG4AtgBuAOUAiwAzAboAhwHtAMoB >EwH0AS4BGAJEAUYCYAF4An4BlwKRAYUChwE8AlsB1QEeAXoB6ABMAc0AVAHSAH4B6gCzAQoB >6AEoARUCQwE5AlgBSAJfAToCVwESAkAB8AEqAQACMwFgAmsBFQPWAf4DYALqBOsCtgVjA1YG >wQPQBgoENAdGBIsHeATTB6IEDQjEBDkI3QRVCO4EXQjyBFEI6wQ7CN8EKgjVBC4I1QRICOUE >cQj9BKAIGwXXCDsFFglgBVsJigWbCbEFwgnIBcYJywWwCb8FlAmvBXwJoQVkCZIFQAl+BQ0J >YAXPCD0FnQggBYYIEwWSCBwFtQgxBdwISAXwCFUF4ghMBboINQWMCBsFbggKBWsIBwV0CA0F >dQgOBWcIBwVaCP8EZAgEBYgIGQWvCDAFsAgxBXYIDQUNCM8EmQeKBD0HUgQABy4E1gYTBKsG >+QN8Bt0DTwbBAzEGrwMoBqoDLgarAzwGtANNBr4DWwbFA18GxgNaBsMDWAbCA2gGygOTBuQD >1AYKBBQHLwQ6B0YEOwdHBCEHNgT+BiIE5gYUBOQGEgT0BhwEBAcmBAMHJgTlBhQErAbyA2oG >zAM5Bq8DLgapA0wGuwOEBt4DwwYEBPYGIwQQBzIEDAcxBOsGHQSxBv0DdAbZA0QGvAMrBq8D >KQauAy8GsgMwBrMDKQavAyAGqgMbBqcDGAamAw8GoQP2BZID0wV8A7AFaAOcBVsDkwVWA4YF >TgNiBTgDIgUSA9oE6AKgBMUCigS2ApkEvgK2BNACyATZAsUE1wK1BM0CrATHArUEzALLBNcC >2QTgAtME3ALABNACsgTIArUEyALMBNUC6QTmAvkE8AL1BO0C4wTiAsoE1AKvBMMClASzAnkE >ogJdBJMCRwSGAjkEfgIsBHYCGwRtAgwEZAL/A10C+QNZAvcDWgL2A1gC8ANVAugDUgLoA1MC >7wNXAvgDXQL9A2AC8wNaAtsDTgK8AzoCmAMmAnUDEQJMA/kBHgPfAfECxQHLAq0BswKgAagC >mQGdApMBigKIAW4CdwFKAmEBKwJPARUCQQEBAjYB6wEoAdQBGgHIARIB0wEYAfQBLAEhAkcB >TgJgAXECdAGRAoYBsAKZAcgCpwHKAqcBowKQAVcCYgH2ASgBmQHwAFEBxQAgAagAAQGVAO8A >igDmAIUA5QCEAOkAhgDtAIkA8wCMAAIBlQAfAaYAQwG8AF4BzABiAc8ATAHDAC8BsQAhAakA >LgGxAFABxgB0AdsAjQHsAJsB9ACoAfsAuAEGAcEBCwG3AQYBlwH0AHUB4ABiAdQAYQHVAGQB >1wBeAdIAVAHOAGcB2QCtAQIBGAJBAXcCewGdApIBhgKFAVYCaAE8AlgBQgJbAVUCZgFSAmQB >MAJQAf8BMgHRARcBqgEAAYEB5gBUAcsALQG0ABsBqQAbAagAHQGpABEBoQD4AJIA3QCCAMgA >dQCuAGUAiQBPAGYAOwBgADYAgwBLALcAagDMAHcAkQBTAAYAAQBN/5P/jP4g/9f9tP4y/VL+ >ovz9/Tj8vv0A/J395vuN/cb7e/2J+1f9NPsl/e/6+/zN+uj8wPrh/KX60fx2+rX8Ufqg/HL6 >s/zs+vz8nvtl/UL8x/2v/Ar+8fww/i79VP5+/YT+1/26/iT+5/5X/gb/gf4g/7P+Pf/b/lT/ >zv5L/3P+Fv/X/br+Lf1V/qf8Bf5V/NP9JPy2/f/7oP3d+439yfuA/cn7f/3S+4X91vuG/cr7 >gP26+3X9r/tv/bH7cP27+3f90fuD/f/7nf1a/NL95/wm/pb9j/5C/vX+w/5B/wb/af8Y/3P/ >Dv9u//v+Yv/i/lT/r/42/03+/P65/aT+B/05/lz81P3X+4b9g/tT/VT7OP09+yv9Pvsq/Vj7 >O/2G+1f9s/ty/cL7e/2p+239d/tO/UP7MP0c+xn98voB/bX62/xi+qr8D/p5/Nf5V/zB+Ur8 >v/lK/Lv5Rvyu+T/8pPk4/Kf5O/yz+UH8vflH/Lz5SPy8+Ub8yPlN/OL5XPz2+Wj87/lk/Mn5 >TfyZ+TH8d/kd/Gz5Fvxx+Rn8ePkd/Hz5H/yE+SX8kvkt/KD5Nvyi+Tf8lfkv/ID5I/xw+Rn8 >YvkR/FT5B/xC+f77N/n3+0D5/Ptf+RD8ifko/Kz5PPzG+Uv81/lV/OL5Xfzk+V780vlT/Kn5 >O/xy+Rj8Ovn4+w/53/v2+ND79fjP+wv53Pst+fH7TfkE/F75D/xn+RT8efkf/KP5N/zU+Vf8 >6vli/Mz5UfyS+S78dvke/KT5OfwX+n78kvrI/Nf68fzU+u78ovrQ/Gj6rfww+oz88fln/Kz5 >Pfx4+R/8evkf/Kn5OvzY+Vb80flS/Ib5Jfwj+en75fjF++z4yfsk+en7WfkJ/Gn5E/xV+Qf8 >O/n3+y/58PtA+fr7ZPkP/JD5Kfyz+T78v/lG/LX5Qfym+Tj8qPk6/Mf5TPzx+Wf8/vlv/NL5 >VfyB+Sb8Qfn/+0T5AfyP+S789Plr/D36lvxW+qT8W/qn/HH6tfyb+s78svrc/JT6yfxD+pj8 >9vlq/PD5Zvw9+pT8tfrb/BD7EP0i+xr98Pr9/Kr60/x4+rX8cPqw/I/6wvzD+uD8+PoB/R77 >GP0m+xz9EPsO/e/6/Pzd+vH85fr2/Pr6A/0I+wv9//oG/ef6+PzW+u781frt/N368vzl+vb8 >5vr4/OH69PzY+u78yPrm/K361fyL+sD8dPqz/HL6sfyC+rn8lfrF/KX6z/y5+tr82Prs/AL7 >Bf0i+xj9IfsY/Qf7CP31+v78DvsN/Vr7Ov28+3X9Bvyi/ST8s/0n/Lb9Lvy7/Ur8zf11/Of9 >l/z8/aj8Bv62/A/+1Pwi/gf9QP5A/WL+ZP14/nH9gP52/YT+hf2L/qH9nP68/az+yP2z/sT9 >sf7B/a7+yf2y/uD9vv7+/c/+IP7j/kL+9f5k/gr/f/4Y/5D+If+u/jP/BP9l/6r/yP+NAE8A >ZAHOAN4BFQHWARIBbAHSAOIAgQBxAD0AJwASAPH/8v/A/9X/kf+7/2z/pf9R/5b/N/+H/xv/ >d/8H/23/Cv9v/yH/fP86/43/SP+V/0r/l/9V/57/fP+0/7r/2v/3//7/FgAQAA0ACgDh/+// >p//N/27/q/8+/43/EP9y/9z+Uv+f/i3/X/4H/zT+7f4p/uf+N/7v/kT+9v48/vP+Mv7s/kr+ >/P6i/jH/J/+A/5f/w/+2/9f/e/+z/xD/df+x/j3/dv4a/1z+C/9Q/gT/Uv4F/2v+FP+U/iz/ >sP49/6v+Of+G/iL/X/4L/0n+/v48/vX+G/7f/tz9uf6Y/ZD+cP13/m/9df57/Xr+d/13/mj9 >bv5t/XH+nP2L/uH9tP4W/tP+JP7b/hv+1f4X/tT+IP7b/iP+3P4G/s3+0v2v/qb9l/6c/ZL+ >pv2Z/q/9oP6z/aP+xf2x/gH+0/5Q/gX/hv4n/4T+Jv9b/g7/Pf79/k7+Bv93/h//iv4q/3T+ >Hf9P/gf/TP4D/3j+Hf+w/j7/yf5M/7r+Qf+o/jT/s/47/+H+Vf8N/27/GP9z/wr/a/8G/2j/ >H/92/0v/j/9w/6X/gP+v/4X/s/+Y/7//tv/R/8n/3P/D/9r/q//N/5j/w/+c/8X/qv/O/6// >0v+i/8n/hf+6/2v/qv9X/5//RP+T/zP/if88/47/gv+3/x4AEwAFAZsABgIzAeYCtgF6Aw4C >vwM1AtUDQgLsA04CKARxAo4ErQICBfICVAUjA1MFIgPzBOgCSASEAoMDEALTAqgBUQJbAfsB >KQG+AQgBjQHsAF4B0gA4AbwAJAGxACQBtAAvAbwANgHCACcBuQD8AKEAwQCAAIcAXQBVAEAA >KQAmAPX/BQCv/9v/Y/+v/yX/h/8B/3H/8v5m/+j+X//a/lX/0f5O/9r+Uf/8/mP/Kv99/1T/ >k/9x/6P/j/+0/7j/y//t/+v/HwAJAEQAHQBYACkAagA1AIEAQgCOAEsAfgBEAFAAKAAQAAMA >2P/j/7b/0f+i/8f/kf++/4P/tv+H/7v/rf/S/+z/+P8rAB4AWAA5AHEASACGAFUAnABhAKQA >ZgCQAFkAYgA8ACwAHAAJAAYA+v/9/+3/9P/Y/+f/xv/a/8j/2//j/+v////6/wEA+//y//T/ >AAD8/1wAMwAKAZsAywEPAUoCXAFVAmQB+QEuAXIB3wD8AJsArQBtAHoAUABUADoANQApAB4A >HAARABUABQAOAO7/AQDO/+3/rP/Y/5L/yP99/7n/Zv+r/0j/l/8g/3///f5n/+b+WP/j/lT/ >8f5Z/wP/Y/8H/2T/9f5X/9X+Qv+2/i//qP4m/6r+J/+w/ir/pv4k/4j+E/9i/v3+Pf7o/h/+ >2P4F/sr+8P3A/ur9vv78/cn+Gf7e/i3+7P4l/un+Cf7a/vH9zv74/dP+H/7r/kn+Bv9Z/g// >Q/4C/xT+6P7p/c3+0v2//tj9wf71/dH+Hf7p/kT+//5Z/gj/Vv4G/0r+/f5E/vj+T/7+/mD+ >B/9k/gf/V/7+/kr+9v5X/v7+gP4V/6X+LP+q/i//if4c/2D+BP9V/v7+Zf4K/2/+EP9R/v/+ >Ff7c/uX9wv7v/cn+K/7s/mf+Ef9z/hn/Tv4E/yL+6v4j/un+Xv4M/7P+P//5/mf/Gv96/xr/ >ef8O/3D/Av9o//X+X//n/lT/2v5M/8j+QP+x/jL/mP4h/43+Gv+j/if/4P5K/yn/dv9Q/43/ >N/+A/+b+UP+H/hj/SP7z/jr+7f5H/vj+Vv4B/1T+Av9J/v7+Rv7+/k7+Bf9d/g//Z/4X/23+ >HP95/iP/jf4x/6r+Q//G/lL/2P5d/+H+Yv/h/mH/2v5c/83+U/+9/kj/wv5I//j+Z/91/6// >NgAgABoBpQD1ASYBtAKUAVoD9gH8A1YCmgSyAhgF/AJLBRoDFgX7AokEpwLLAzUCCQPEAVsC >XAHFAQUBRAG6ANwAfQCVAFQAaQA7AEYAKQAfABQA+v/+/+f/9f/v//v/CQALABMAEgDy//// >r//X/2P/qv8t/4r/E/94/wH/b//k/l3/vP5D/53+L/+Z/iz/s/46/9z+Uf/8/mT/Ev9v/yn/ >fP9R/5L/jP+1/8v/2//4//b/DQACABQABwAeAA4AMgAaAEoAKgBaADQAVwA0AEcAKwAzACEA >HQAVAAcACAD2/wAA8v///wYADAAtACQAUwA6AGAAQgBLADYAIwAdAP7/BgDo//n/4f/y/93/ >7//Z/+r/2v/q//L/9v8vABgAnQBYAD4BtwD8ASYBpgKJAfsCuwHbAqcBWgJbAcAB/gBXAcAA >MwGrACYBowD8AIwArABdAHAAPACQAFAAKQGsAAECLwHIAqcBPwPxAWQDCAJXAwMCMgPuAfIC >yQGXApUBMQJZAdsBJwGmAQcBgwHzAF4B3QAsAb8ABAGmAPkAngAEAaQADAGmAPkAmADQAIAA >sgBrALIAaQDDAHEAxwBzALMAZQCZAFUAlwBSALIAYQDSAHQA3QB6AMwAcAC4AGQAsABhAK8A >YQCdAFYAdABAAE4AKgBHACcAXAA1AGQAOwA2ACEA3v/t/5f/xv+p/8//FgARAKEAZQD1AJcA >6gCQAJcAXwBCACwAGgATAB8AFQA0ACEAPgAmADgAIQAoABcAFQAKAPb/9f/P/97/s//N/7b/ >z//e/+X/GQAIAEkAJgBeADIAXgAzAF0AMwBiADYAZwA6AFoANQA1AB8AAAACANL/6f+5/9r/ >tP/Z/7j/3P+6/9//t//d/7T/3f+7/+L/y//r/9v/9f/j//n/3v/3/93/9P/t//3/FgATAE8A >MwB+AE4AkgBYAIwAUgCDAEsAjQBPAKsAYADMAHEA3AB5ANQAcwC/AGYAsABcAKwAWQCsAFgA >owBUAJMASwCGAEQAiABGAJcAUACsAF0AvQBpAMwAdADgAIIA/ACUABoBqQAzAboAQgHDAEwB >ywBVAdIAXgHYAGIB2wBaAdgASAHNADMBwQAqAboAMQG/AE4B0AB8AeoArAEHAdIBGwHhASMB >3AEeAdsBHgEEAjUBdAJ2AS0D4wENBGcC3AThAmsFNgOvBV0DxgVqA+AFegMfBqADdwbUA7IG >+AOWBugDBgaTAyQFDgMzBH8CcwMOAvkCxgGvApoBagJyARUCPwGzAQYBWgHQABgBqQDsAI4A >0AB9AMAAcwDBAHQA0QB8AOUAhwDxAI0A8QCNAPIAjAAGAZYAMQGwAGwB0QCjAfEAyAEHAdsB >EgHdARMB0wEMAcEBAgGuAfcApwH0ALgB/wDaARQB9wEmAfoBKgHjAR0BwgELAasBAQGuAQQB >vwEQAcsBGQHGARcBtgEOAaEBBAGYAf8AmwEBAaMBBwGoAQoBpgEJAZoBAgGNAfoAkQH7AKkB >BwHRAR0B9QEyAQECNwHzAS0B2AEbAcgBDgHNARAB4QEaAesBHwHkARgBzgEJAbcB+gCqAfIA >ogHtAJgB5wCKAd8AhQHbAJEB4wCqAfIAuAH7AKwB9QCPAeQAhwHhAMUBCAFkAmgBUwP3AVkE >lAIwBRUDoAVaA5gFVQMsBRcDjAS3Au0DWQJyAxECIQPiAeYCvgGpApoBYAJtARUCQAHcAR0B >vwEMAb0BCgHEAQ0BxQENAbkBBgGmAfoAkQHtAIAB4gB0Ad0AcQHaAHIB2wB3Ad8AgQHkAI4B >7gCjAfoAvQENAdkBHAHlASYB2gEfAbcBDAGKAfIAYQHbAEMByAApAbkADQGpAPIAmQDkAJEA >7wCXABUBrQBAAcUAWAHSAEwByAAgAawA6ACJAL8AbwC4AGkAzgBzAO8AhQANAZUAHwGeACsB >pAA4AawATAG1AFwBvgBcAb8ARgGxACMBnQD/AIkA4QB4AMcAaQCxAF8ArQBeANEAdgAlAasA >jgHrANwBHAHdAR8BkwH1ACsBuQDeAI4AxQCAAMcAgwC4AHsAiQBfAFkARABVAEEAkgBlAPYA >nwBKAdIAcwHoAHkB6gCAAe0AnAH8ALgBCwGzAQcBfwHkADIBtQD5AJIA8ACMAAsBmwAnAaoA >KQGrABgBnwAQAZsALAGrAGcB0ACtAfoA4gEaAfkBKQH2ASgB5gEfAdEBFAHCAQwBwAEKAdAB >FQH3ASwBJgJJAU8CYQFlAm0BbgJyAXkCeAGSAoYBuAKbAdECqQHKAqMBoQKJAWoCZwFMAlUB >XAJdAZMCfAHVAqIBAgO9AQ0DwwEBA7sB8AKxAeMCqgHeAqkB2QKnAdYCpwHcAqwB7wK5AQQD >yAEKA84B6wK+AacCmAFOAmYB+gE2AbgBEQGSAfwAgwH1AIIB9QB+AfIAbAHpAEQB0QASAbIA >7wCcAPQAngAmAbkAbwHkALEBCgHfASEB9wEsAQoCNQEeAj4BLwJGATgCSgFAAksBVwJWAX8C >bwGxAosB0gKdAdYCngHHApYBuAKMAbECiQGtAocBoQKBAZcCfAGhAoQBygKcAfoCuwELA8cB >5wKzAaYCjAF6AnQBhAJ8AbkCnAHnArgB6QK5Ab4CnwGLAoABaQJsAVcCYAFAAlMBIQI/ARAC >NAEkAj4BVwJbAYICdQGAAnIBVQJYASoCPgEpAj0BTwJTAXICaQFpAmQBLwJDAeUBGAGpAfYA >gAHfAFMBxgAWAaMA2ACAALMAbAC1AG4AxQB5AMoAfAC4AHMAqQBrALoAdADkAI0ADwGmACQB >sQAzAbkAbQHZAPsBKwHWAqsByQM6Ap8EtwJABRQDvQVbAywGnAOPBtMDzQb3A9sG+wO+BukD >mwbSA4kGyAONBskDjQbJA3QGuQNABpwDAgZ4A9cFYAPOBVsD6AVsAxcGigNDBqcDWwa2A1AG >sQMpBpsD+AV/A9EFagO/BWEDvgVhA8UFZgPNBWsD1wVxA98FdQPfBXUDywVqA6AFTgNoBS0D >OAUOAxoF/AIQBfUCDgXyAgoF7wIABekC+gTlAvsE5AL/BOcCAgXoAv4E5gL0BOAC5wTZAt0E >1ALZBNIC2gTUAtsE1QLbBNYC2QTUAtEE0QLCBMcCqAS5AoIEoQJTBIYCKgRsAg4EXAICBFMC >+QNMAt4DOwKpAxkCbgPzAUED1wE4A9ABUQPcAXkD8gGfAwcCvgMXAtgDJgLuAzEC9AMzAukD >LALXAyECzwMdAt8DJgL4AzYCBQQ+AvYDNwLXAycCvQMYArQDFQK4AxgCtwMbArADGAKtAxcC >sgMcArMDHwKkAxcCfQMAAlMD6AFGA+ABWwPsAX4DAgKRAwsChQMEAmcD8QFTA+MBUQPhAVcD >5AFcA+UBXQPlAWgD6wGAA/gBmQMGApoDBQKBA/UBXQPgAUwD1gFbA98BfAP0AZYDAgKTAwEC >dwPxAVAD2gEsA8YBEAO3Af4CrAH1AqcB8QKlAekCoQHQApEBngJzAVsCSwEeAiUB/gERAQkC >FQE2Ai8BbgJOAZoCaAGuAnIBsQJyAbkCdAHUAoIB+gKYARMDpgEDA5oBwQJzAWgCPgEfAhIB >+QH+APcB/QACAgUBDwINARwCFwEwAiQBPwIvATgCLgEQAhcB0AH0AJcB1AB6AcQAcgHCAGMB >ugA+AaUACAGGANgAaAC4AFYAqABMAJ4ARgCYAEEApABIAM0AXwAEAX4AMgGWAEYBoQBKAaMA >WAGpAHoBuwCdAdAApAHSAH8BvABCAZYACwF1AO0AYwDXAFcArQA/AGIAEgAHANz/u/+x/4// >mP96/43/av+G/1X/ef9D/3D/Pf9v/0P/c/9H/3T/Qv9z/zv/bv9C/3L/Wv+B/3//lf+c/6T/ >qf+r/7D/r/+9/7P/zv+9/9X/v//D/7L/l/+Y/2P/eP84/13/Gv9K/wT/Pv/v/jD/3f4m/9j+ >JP/c/in/4P4r/87+I/+n/g//fv74/nH+8/6Q/gj/zf4v/wz/Vv8t/23/LP9u/xb/ZP8D/1n/ >BP9a/xz/a/9E/4P/bf+a/4v/rP+U/7H/if+q/3L/mv9W/4f/Ov92/yT/Z/8T/1v/BP9R//z+ >Sv/9/kr/DP9Q/yX/Xv9B/27/WP97/2D/gf9b/37/Uf94/07/d/9Z/3//bv+N/3//mf+E/53/ >eP+Z/2f/kv9d/43/YP+Q/2n/l/9w/53/c/+h/3j/pP+I/67/pP+//8n/1f/w/+z/FAABADoA >FwBgACwAhwBDAK0AWADTAG0A/ACFACcBnQBMAbIAXwG8AFsBugBGAa0AMQGhADIBoQBLAbEA >cQHJAI4B3QCaAeUAkwHiAIUB3QB9AdsAgwHhAI8B7ACdAfYAqQEBAbQBCAG+AREBzQEcAd8B >JwHzATUBCgJEASECUgE1Al4BRQJnAVACbQFXAnABWAJwAVICawFIAmMBQQJfAUsCYgFrAnUB >lgKNAbsCogHGAqcBtgKcAZ4CjgGQAoYBkgKIAY4ChQFiAm0B9wEvAVQBzwCWAF8A5//6/2r/ >sf8n/4z/DP99//P+cP/E/lb/eP4q/yL++v7g/dP+vv3B/rP9u/6k/bP+gP2e/k39f/4b/WH+ >9vxM/uL8QP7V/Df+y/ww/sb8Lf7D/Cr+s/wh/o78Cv5Y/Or9LvzR/ST8yv0n/M39E/zC/cb7 >lf1U+1L9+/oe/fL6HP04+0f9j/t9/bT7lf2a+4f9bPtu/WL7av2L+4T9wfun/db7tv3E+6z9 >pPub/aH7mf27+6n90fu3/cD7rf2K+4z9Uftr/Tr7Xf1M+2f9cvt8/Yr7i/2K+4n9ffuA/Xf7 >fP2F+4P9nvuS/bL7nP2v+5z9mfuO/X37fv1r+3P9a/t0/Xv7ff2M+4r9mvuT/aT7m/2y+6T9 >wvuv/c37uP3G+7b9sPuq/Zj7nf2O+5n9lPud/Zv7ov2O+5z9ZvuE/TH7Zv0G+0z97/o//ev6 >Pf3l+jr92Poy/cP6Jv2z+hz9rvoZ/bn6H/3Q+iz96fo7/fv6Rv0A+0n98/pD/dT6Mf2v+hv9 >kPoJ/YD6Af2C+gP9k/oO/an6HP26+ij9w/ov/cH6L/21+in9nvod/YP6Df1h+vv8O/rk/BH6 >zPzj+bD8tPmW/Iz5fvx0+XD8b/lt/H/5dvyb+Yb8vvmc/Oz5tvwz+t/8pfoj/Uj7g/0G/PP9 >ufxe/j/9rP6P/d3+w/37/vn9HP87/kP/dP5k/3b+Z/8n/jj/j/3e/tf8cf4s/A3+rfvC/Vn7 >kf0d+2796PpQ/bX6Mv2J+hr9a/oJ/Vv6//xY+v/8YvoF/XT6EP2O+iD9qvox/bz6O/3E+kD9 >x/pC/c76Rv3Z+k393vpQ/dL6Sv26+jv9p/ov/af6L/29+jz90vpJ/dX6S/3J+kT9zPpH/Qf7 >af2G+7b9PPwi/gT9mP60/QL/NP5Q/3n+ef92/nf/J/5I/6D9+f4C/Zr+dvxI/hX8Dv7Z++r9 >rvvR/Yv7vP1v+6v9Y/uk/Wb7pf1r+6j9Y/uj/VT7mv1R+5f9afuk/Zr7wf3T++P9/fv7/RL8 >B/4U/An+C/wC/vn7+f3m++392fvk/dv75v3y+/X9FPwJ/iv8F/4x/Bz+KPwW/h78EP4j/BT+ >M/wd/kH8Jv5F/Cj+RPwp/kv8Lf5f/Dn+evxK/pL8V/6h/GH+tPxr/tX8fv4F/Zv+Nv25/lP9 >yv5T/cj+P/29/jP9tv5G/cD+e/3g/sX9DP8J/jT/L/5K/y3+SP8I/jH/0/0T/6r9+v6Y/e/+ >mv3w/p398v6O/en+av3T/jz9uP4V/aD+9/yO/tv8f/6//G3+pfxe/pb8Vv6T/FP+lPxR/of8 >S/5v/Dz+VPwr/j78Hf4k/A7+/vv3/dr73/3g++T9Rvwf/iH9oP5J/lH/eP8EAGoAkwAJAfIA >ZgEoAZYBRQGwAVMBvwFdAdkBbAENAooBUQKzAYACzwFmAr8B8QF6AUEBEQGIAKMA7v9HAHL/ >/v8C/7v/mf58/z3+Rv///SL/2f0J/7r99/6b/eX+j/3d/qn97P7m/RD/KP43/0z+S/9J/kj/ >Nf49/y3+OP84/j3/R/5G/0v+SP9C/kP/N/46/yf+Mf8M/iD/6P0K/9X9//7u/Q3/Nf42/4P+ >ZP+m/nn/j/5r/1j+Sv8p/i7/Ef4e//j9EP/M/fX+kf3S/m/9vv6D/cj+u/3q/u39B//4/Q3/ >4f3//s398v7S/fX+5v0A//X9B//2/Qj/Af4P/y7+Kf91/lL/sP52/8H+f/+j/m3/d/5R/1z+ >Qf9W/j3/Uf46/z/+MP8p/iL/Hv4a/yf+H/8x/iX/LP4i/xP+Ev/1/QH/5/34/uz9+v4C/gf/ >MP4j/4r+Vv8j/7L/7/8rALkAowBFAfQAbQEMATwB7wDbALUAagByAPP/KwBw/9v/6f6L/3j+ >R/83/h//Lv4Z/0f+KP9h/jf/b/4//3f+Q/+J/k3/qv5h/9P+eP///pH/Lf+s/2L/zP+W/+r/ >tP/8/6z/9v+H/+D/Z//M/3D/0v+n//H/7/8dAB8AOAAiADkABQAoAOL/EwDP/wcAxP8BAK// >8/+H/9z/Wf++/0L/sf9e/8L/vf/6/1sAVwAvAdQAJgJnASwDAgIgBJMC5QQHA2gFVgO0BYED >3wWaAwEGsAMiBsEDLAbIA/sFqgN0BVkDnwTaAqIDRAK4ArgBCAJQAacBFAF9AfwAbAHxAFkB >5wA7AdMAIQHEAB8BwQA7AdMAaQHtAIcB/wB0AfQAJgHEALcAggBXAEgAJwAsAC4ALwBNAEIA >YgBNAF4ASwBDADoAIQAlAP7/EADf//7/1v/4/wAAEQBnAE0A7wCdAFcB3ABlAeMADwGvAIcA >XgASABkA2//3/9T/8//S//P/sv/e/3H/t/8j/4r/4f5h/7n+SP+y/kT/yv5S//D+af8K/3j/ >9v5t/6r+Pf8y/vf+tv2t/lL9cf4Q/Un+4/wu/r38F/6U/P/9Z/zj/Tb8x/0L/K398vue/fb7 >oP0U/LH9M/zD/UL8zP1C/Mv9UPzU/YX88/3d/Cf+LP1W/k39av5E/WT+PP1f/lv9b/6d/Zf+ >1f24/tb9uf6i/Zr+Yv10/kD9X/5A/WD+Sv1l/kr9Zf5I/WP+WP1s/nj9gP6S/Y/+jP2L/m/9 >ef5e/W/+cf17/p/9lf64/aT+nv2U/lr9a/4R/UH+5/wm/tn8H/7W/B3+zPwW/rv8DP6q/AP+ >mfz4/Xr85f1R/M39Mfy5/Tb8vf1q/Nv9ufwK/v/8NP4e/UX+Cv06/s78Ff5+/OX9Nvy8/Rb8 >qP0u/LX9b/zc/bH8A/7O/BT+uPwI/pH88P2G/Or9rPwA/un8JP4N/Tn++Pwt/rT8BP5h/NL9 >Jfyw/Q/8ov0h/Kz9UvzJ/ZL88P3M/BL+5fwi/tT8F/60/AT+r/wB/tz8HP4r/Uv+bf1y/nz9 >ev5f/Wn+Sf1b/mL9av6q/ZX+/f3F/i3+4/4y/ub+Jv7f/ij+4P48/uz+Vf76/ln+/v5M/vT+ >Pf7s/kH+7v5R/vj+YP4B/2z+B/+I/hj/2v5J/3r/qf9aACwARgG6AAcCLAFtAmkBbAJpARkC >NwGUAecAAwGRAIsASgBEAB8ALwAUADkAGQBJACQATAAlAEIAHwAzABcAMQAVAD4AHABUACoA >cgA7AKMAWAD4AIsAgQHdADACRQHbAqoBSgPsAVMD8QHwArYBSAJTAZkB6wAbAZ4A6ACCAPwA >jgA2Aa8AbwHSAIoB4gB1AdQANQGvAO0AhADGAG0A4gB/AEIBtwC6Af4ABAIqAf0BJgG5Af0A >dgHWAHIB0wCvAfgA+QEjAQ8CMQHeARQBhwHgAEIBuAAtAasAMAGtACgBqAACAZIAzwBzAKkA >XQCiAFgArQBfAMQAbQDiAH4ABQGUACYBqAAxAa4AGQGgAO4AhgDWAHcA5AB/AAYBlAAXAZ0A >9wCLALUAYwB4AEAAaAA1AIcASQC+AGkA7wCFAAABkADqAIIArQBfAF8AMAAuABMASQAkAMMA >bABsAdEA7QEdAf4BKAGeAe8AEgGcAK0AYACRAFAApQBaAK4AYACRAFAAXgAxACwAEwAAAPn/ >yv/Z/3v/qv8i/3b/3P5L/8P+PP/P/kP/5P5R/+3+Vf/m/lH/2f5J/9f+SP/m/lH/Bf9j/yn/ >eP9E/4n/Tf+N/0T/iP9J/4z/hP+t/wIA+f+nAFsALgGsAF8ByQAvAa0AyABwAGMAMwAfAAsA >9//0/+v/7f8NAAAAfABDAEIBuQAxAkgBAQPDAX8DDQK1Ay4C1gNCAhAEZQJhBJUCpQS7ArAE >xAJ4BKICDARiAoQDEAL1ArsBbQJrAf0BJwGyAfsAiwHjAHQB1gBSAcEAGQGfANEAdACUAE8A >cAA7AGMAMwBiADIAXQAuAE0AJQAsABEA+f/z/77/0f+R/7b/iv+x/63/xv/g/+X/9//y/9P/ >3f9//6z/J/93//X+Wv/4/lz/IP9z/07/j/9y/6T/jP+z/6f/xP/L/9j/7P/s/wAA+P8BAPn/ >/f/2//3/9v8EAPr/BQD7//D/7v++/8//fP+o/0L/hf8j/3P/JP90/zr/gP9U/4//bP+e/4P/ >q/+a/7j/r//F/8D/z//O/9j/4//j//X/7//1/+//0P/Z/4n/r/9E/4X/Kv92/03/i/+W/7b/ >1//d//D/7P/u/+z/8f/t/wgA+v8dAAcAEAD//9f/3P+d/7v/pv+//xwABADtAIEA3AEPAaMC >hQEUA8kBKQPVAfICswGHAnQBBQInAYUB2wAfAZ0A2AB0AKwAWACGAEIAXgArADQAEAAKAPj/ >6f/k/9L/2P/K/9L/0//X//D/5/8cAAMATgAhAHYANwCGAEIAfgA8AGIAKwBAABcAJQAIABMA >/P/9//D/2P/a/6D/uP9d/5D/Kf9w/xP/Y/8h/2v/Rv+B/3L/m/+b/7L/uv/F/9L/0//h/9z/ >6//i//v/7P8QAPj/IQACACQABAAPAPj/6v/h/8f/zP+x/7//pP+4/5f/r/+J/6j/h/+m/6X/ >t//W/9X/BwDy/x8AAAAcAP7/EAD3/xAA9/8XAPv/HQD+/xoA/f8dAP//NgANAGAAJgB9ADcA >agAqACEAAADF/8j/iP+j/43/pv/I/8n/EAD0/zcACgAhAP7/1//Q/3//nv9K/37/Uf+B/4n/ >o//M/8v/8f/h//L/4P/q/93/9v/k/xUA9v8pAAIADQDx/7z/wf9R/4L/8P5I/6T+G/9l/vX+ >L/7V/hH+xP4f/sz+VP7r/o/+Dv+k/hn/ff4C/zP+1v7w/a7+0v2d/ub9p/4k/s3+fv4C/+D+ >O/8s/2j/R/94/zL/a/8K/1T///5N/yb/Y/9q/4z/pP+v/7X/uf+Z/6j/af+L/0T/df9B/3X/ >bf+P/7z/vv8TAPL/QQANACkA/v/c/9H/lv+o/5v/q//5/+P/gQAzAOwAdAAUAYwADQGHAAEB >fwD/AH8A+QB7ANcAZgCeAEUAaAAjAEgAEAApAP7/5//W/3n/k/8D/0//wf4m/87+Lf8V/1j/ >bP+L/7T/tv/w/9n/KgD9/2EAHACAAC4AeAArAFAAEwAcAPP/5//V/7b/uP+L/5//dv+S/4X/ >nP+6/7z/+P/h/x4A9v8bAPX////k/9//0v/C/8H/nv+t/2z/jv8+/3L/O/9x/2//j//F/8L/ >CADq/xcA8//9/+P/6P/X//3/4v81AAQAZQAfAFwAGgARAO3/qf+w/1//hP9j/4X/uP+5/zcA >AwCcAEAAswBNAG0AJAD8/+H/q/+x/6//tP8DAOb/bQAlAKwATACxAE4AowBHALYAUgDzAHcA >KwGYACABkgDDAFwAQgANAN//1P++/8H/yv/H/9X/zv/G/8X/r/+2/6r/tP/K/8j/CADr/2UA >IgDrAHMArgHlAJcCcAF1A/QBGgRVAo8EnAISBeoCzQVYA6cG2QM8BzIEHAcgBDIGlAPHBL0C >ZgPrAXwCYQEpAjABRAJAAYICZQGdAnYBcQJcAQICGgGFAdEAQAGoAFwBuQDIAfkAOAI8AWMC >VgE2AjsB3wEIAaYB5QC1Ae8ADQIiAZECcQEoA8sBtAMeAgoEUAL8A0gChAMBAuECoAFzAl4B >bQJbAa0CgAHRApQBoQJ5AU0CRgE6AjsBngJ4AUoD3gHKAyoCyQMpAl8D7AHrAqYBrwKDAaQC >fgGRAnIBUgJNAf4BHAHAAfcAoQHmAIEB0wBDAa0A8gB/AMAAYQDIAGYA/ACFADIBpQBUAboA >awHIAIMB1gCJAdkAXAG+APUAgQCKAEAAYAAnAJEARQDlAHYAAgGGALcAWgArAAcAuf/D/5// >s//g/9r/PAASAHYAMwBjACgAAQDu/2v/lf/d/kD/pf4h/wD/Vv/g/9z/4AB2AHgB0QBZAb4A >pQBUAND/1v9C/4L/EP9k/wT/Xv/o/k3/s/4v/4P+Ef9m/gD/S/7w/hf+0v7X/az+xv2i/hH+ >zv6w/iz/U/+N/6T/vP+I/6z/Nv97/wf/X/83/3r/tf/G/0UAGwCYAEwAhwBCACUACQCy/8X/ >cP+d/4f/q//k/+L/RQAcAG8ANgBQACQADAD7/9b/3P/G/9L/yP/U/8L/0v/D/9P/AQD4/7gA >ZADjARcBNgPhAUwEhgLhBOACBQX0AvUE6wLzBOsCEgX9AjQFEQMsBQwD4gTeAl4EkALDAzUC >LwPcAasCjQEyAkYBvQEAAVIBvwADAZEA3gB8AOMAfgD8AI0AEQGZABYBnQAVAZ0AEwGbAAgB >lQDvAIcAywBxALAAYQCxAGIAywByANsAfQDJAHIAmQBWAHUAQACEAEkAvwBtAPgAjwAIAZkA >+ACOAP8AkgBdAcoAIQJAAScD2wEzBHoCGgUDA8cFagM3Bq0DbQbMA3IG0ANgBsUDUwa8A1UG >vgNjBscDdgbSA48G4AO4BvoD8gYcBBoHNAQLBysEwQYABGgGygM9BrIDYQbHA7UG+QMBBycE >HQc5BBEHMQT9BiYE+wYkBP8GJwT9BiUE7QYdBNsGEgTKBgYErgb3A4kG4ANtBs8DgAbbA9IG >CwQ7B0kEawdlBDAHQgSkBu8DKQalAyAGoAOkBu4DcQdoBCAIzgRrCPsEVgjwBB4IzgT8B7sE >Agi+BBIIyAQCCL8EwQeaBGEHYAQLBzAE5AYYBOkGGwT2BiME3QYWBJAG6AMtBq4D7wWIAwEG >lANeBssDxgYIBPYGJQTLBgsEYgbNAwUGlQPtBYYDJwaoA4kG4QPUBg4E5QYXBMgGBQSrBvQD >sQb2A88GBwTaBg0EpAbuAywGpgORBUkDCwX5AroEygKrBMEC0gTYAiQFCgOQBUkD/AWKA0kG >ugNsBs8DbQbRA24G0gOEBuADqgb3A8gGCgTRBhEE1QYTBOcGHgT/Bi4E/AYsBL4GCQRVBsoD >9QWQA80FdwPYBX8D4gWDA7cFaANUBS0D7QTuAqsExgKcBLwCowS+AqIEvgKXBLYCkQSxAooE >rAJuBJwCLARzAskDOAJoA/0BHgPSAeQCsAGfAogBSQJTAfEBIQG4AQABqgH4ALYBAAHEAQoB >0wEVAekBIgECAjMBBgI4AeUBJAGuAQUBlQH4AMUBFQEvAlQBlgKSAbcCpQGAAoUBGgJIAb4B >EAGLAfIAiwHxALMBCQEAAjQBYgJtAbUCnQHOAqsBngKNAUkCWQEMAjMBEQI0AUoCVQGGAnYB >lwKAAXsCcAFHAlABDAItAckBBAFzAdIAFwGbANMAdADGAG4A7QCGACUBqQBEAb4AQAG8ACIB >rQAKAaAADAGiACUBsgBDAccAUwHRAE0B0ABAAcgASgHOAHkB6wC3AREBzwEfAZAB+AD8AKAA >XABAAAIACQAXABUAdABKAMcAeADZAIIAugBtAKUAXgDKAHMAIwGnAH4B2gCpAfMAlQHlAFgB >wQAWAZoA9QCFAAsBkABbAcIAywEFASICOQEvAkIB6gEbAYYB4QBAAboAMAGxAC0BsgD9AJgA >kgBZAB4AFgDn//j/BAALAEsANwB2AFIAbABMAE0AOgBOADwAfABXAK8AdgC6AHoAjwBhAFUA >PQA7ACwATwA2AHwATwCeAGIAoABfAIUATQBnADoAYgA0AIoASgDfAHsAPgGyAHMB0QBWAb8A >8QCBAIUAQQBfACoAkgBJAOcAfAABAY0AqQBaAPj/8v80/3//lP4j/xz+3f6r/Zz+NP1X/s78 >HP6d/AL+pvwJ/sL8HP6+/Bv+iPz8/T380f0L/LT9Evy3/Uj82P2V/Af+5fw1/i/9YP57/Yz+ >zf26/i7+8/6m/jj/Mf+I/7f/1f8GAAIA8v/0/2r/of+K/hr/j/2D/rj8Av4t/K799vuM/f37 >j/0d/KL9Lfys/Rn8oP3j+4L9rvti/aT7Xf3d+4H9SPzC/bD8Af7Z/B3+pvz//SD8sv13+1D9 >6Pr9/KL61vy3+uX8E/sd/Yj7ZP3d+5f98vul/cP7if1t+1b9F/sj/ef6Bf32+g79UPtB/e37 >nv2n/Ar+N/1e/lf9b/7z/DH+RfzI/b77dv2w+2v9EPyi/Xj83v13/N397vuI/Sf7Ev2l+sP8 >svrL/DH7F/27+2j98vuK/cn7cv13+0P9QPsj/Tz7Iv1Q+zD9W/s4/Uz7Mv0s+yH9BfsL/dD6 >7vyI+sb8L/qS/Nz5Yvyg+UH8fvks/F/5G/wy+QL8Afnk++T40/vx+Nn7IPn2+1b5FPxy+SX8 >c/kk/HT5IvyQ+TH80/lY/B/6g/xR+p/8Wfqh/Ej6lfxQ+pf8lPq+/BX7Cf2l+179Dfyb/S38 >rv0U/J/98fuJ/eT7gv3q+4X93ft//Zv7Wf0r+xb9vvrY/Jb6wvzR+uf8W/s7/fL7lv1L/Mz9 >OvzF/cf7gv0h+yL9kvrP/E76pvxe+rL8pPrc/O36CP0f+yb9Pfs3/WP7Tv2c+3D92PuS/fT7 >of3l+5j9xfuD/bf7ef3L+4P97PuV/f/7n/0R/Kj9VPzO/fn8Lf77/cb+HP9w/woA/P+bAFMA >4AB6AAEBjQAVAZoAFwGaAPcAhgDCAGgAkwBNAHUAPABLACUA5P/o/yf/e/8w/uj+Qf1c/p78 >/f1d/Nj9aPzh/Yf89f2J/Pf9T/zX/ej7mv2H+2H9aftR/a/7ev03/Mz9rPwR/r38Gv5e/OL9 >3/uW/aj7dP3s+5v9ffzw/fH8M/7z/DP+hvzw/fH7l/2O+1n9hftT/dP7gP1Y/Mz98/wn/or9 >gP4E/sf+Pv7q/jT+4/77/cH+xP2g/rH9lf7B/aD+0f2q/rH9l/5R/WD+yvwS/lX8zf0l/LL9 >SfzK/ab8Av4B/Tv+K/1V/iH9Uf4O/Ub+JP1V/nn9iv7q/c3+Mf75/iL+8P7A/bb+PP1n/tP8 >KP6e/Aj+lvwC/qT8Cv67/Bb+2fwn/v38O/4a/Ur+KP1P/ij9Tv4y/VP+Wf1p/qT9k/4E/sr+ >bP4H/97+Sv9u/57/KgAOAAgBkADcAQ4BbgJlAZkCfwFgAl4B9QEgAZEB5QBPAb8AHgGjAM4A >dgBEACYAkv+///j+ZP+r/jj/r/49/9L+VP/V/lf/nv43/0n+Bv8K/uL+AP7d/if+9P5s/hz/ >wv5Q/yb/i/+H/8P/tf/e/4z/w/8O/3f/gv4i/0D++P54/hn/BP9p/33/r/+D/7H/9v5c/w7+ >0f43/U7+1/wU/ir9RP4i/tb+Z/+Y/3sAOwDlAHsAfwA+AIT/q/+C/hH///3F/ij+3/67/jn/ >Pf+H/0r/kv/j/lb/Xf4I/yT+6f5q/hT/B/90/5b/yv+7/+L/Yf+t/7n+Sv8T/uj+m/2h/kj9 >cf7+/ET+tvwY/pb8Bf7N/CT+WP11/un9yf4Y/uP+sv2k/uD8Jf4Z/Kz9x/t7/QX8nP2J/Or9 >8Pwl/vr8Kv66/AL+gPze/aP88/1O/Vj+Yf77/oT/qP9JAB8AagAzAOr/6P8f/3D/gP4T/1v+ >AP+l/i7/Cf9r/yb/f//a/lT/Vv4H//L9zv7i/cb+FP7m/kP+A/8w/vj+3P3G/n/9kf5b/Xz+ >g/2U/sz9v/7r/c/+tv2w/kH9Z/7E/Bv+ffzv/X/87/2z/Av+9/wz/jn9WP52/Xj+oP2Q/qf9 >k/5//Xn+Of1P/gv9Mv4d/Tz+bf1q/r39mv7P/aT+lP2C/j/9UP4T/Tf+LP1I/nD9cf6p/ZX+ >vP2i/rP9oP6k/Zj+if2L/lT9bv4N/UX+5Pwu/hj9T/7A/bT+oP45/1T/pv+R/8v/Sv+h/67+ >RP/8/dv+Y/1//gD9Qv7p/DT+KP1X/qL9nv4e/ub+Yv4N/2D+Cf9E/vb+Q/7z/l7+Av9m/gX/ >If7b/pX9hf4P/Tb+6/wf/kb9Vf7m/bT+av4C/5z+IP+J/hX/Z/4B/2D+AP97/hD/pf4r/9H+ >SP/2/l//Bv9q/+7+X/+0/j7/ff4g/4r+KP/p/mL/Zf+t/5f/zP8+/5j/f/4n/9L9v/6o/af+ >Ef7l/rj+SP8p/4v/LP+L/9f+V/9o/hP/Av7V/rf9pv6V/ZH+vP2m/kf++P4S/27/xP/X/xAA >AwDt/+z/qP/C/5f/t//L/9b/AAD1/+L/5P9h/5f/v/44/1b++v5M/vT+gf4V/77+PP/k/lP/ >8f5c/+T+Vv+1/jz/c/4X/1r+Cf+3/kP/pf/Q/84AgQCkAQIBwwEVAU4BzwDJAIAAqwBvAAIB >ogBvAeMAiAHxAC8BvACPAFsA4f/z/0L/lP+7/kL/Z/4N/3H+Ev/n/lb/hv+z/+T/6v+9/9P/ >Ov+E/8/+Q//d/kz/Yv+a/wMA+v9eADAAVQArABAAAgDK/9j/qf/G/7r/0P/1//T/SwAoAJYA >VwCYAFoALgAcAHj/sv/Q/k//jv4q/8n+T/9I/5r/uv/f/wIACQAxACQAaQBFAKsAbADSAIIA >vgB2AHsATQAnABsA2v/t/4j/vf8j/3//q/44/0P++v77/c3+v/2o/mX9cf7X/Bz+RfzC/RD8 >of2I/On9sP2X/iP/dP9RACcAvwBrAFkAMABz/6n/m/4p/07+/f6q/jT/af+m/wYABAAkABQA >uf/V/x3/eP+3/j3/vP5A/wn/b/9O/5j/RP+U/+X+Xv9h/hD/Bf7b/gj+3f5w/hr/C/91/4n/ >vv+r/9H/bf+p/w3/bv/g/lL/EP9v/3r/rf/R/+L/1v/m/4z/u/8x/4T/Av9o/xn/d/9p/6X/ >1f/k/zsAIACAAEYAfABEACIADACS/7j/IP91/xz/c/+Q/7r/MQAcAJIAWAByAEcA7P/5/1P/ >nv/6/mr//P5q/zv/j/+H/7r/tv/U/7b/1P+V/8D/bv+o/2P/o/98/7P/k//D/2v/rP/t/mP/ >Sv4B/+/9yv40/vL+Gv95/1AALwBsAdUANwJLAa4CkQHqArMB9wK9Ae0CtwH8AsIBXQP+AQwE >ZwKnBMUCmwS/Ap8DKAL5AS0BZQA8AIL/s/9p/6T/tP/P/+f/7f/S/+H/mv/B/27/qf9V/5z/ >Of+O/xf/e/8K/3X/Kv+J/2L/qv90/7P/Pv+S/9/+Vf+l/jL/y/5G/0j/kP/o/+7/bgA/AK4A >ZQCKAFEA6f/y/+z+Xf8B/tH+vf2q/n3+G/8HAAQAowH3AKECiwHdAq0BwgKcAd8CrQFiA/sB >DQRjAo4EsgLVBN8CEQUEA1oFMgODBUwDQQUmA4UEtgKZAygC5QK8AYQCgQE+AlUBxAEOARYB >pAB9AEoARAApAGwAQwCqAGkAtQBxAIQAVAA/ACsABQAIANr/7f+3/9f/sP/R/93/6f8sABYA >UAAqAAoA//9z/6b/BP9l/y3/fv/h/+v/kQBUAKEAXwAAAP//Nv+I//n+Y/+F/7b/eABFADYB >tQB1AdkAZAHQAGABzwCGAeUAlwHxAEYBwwCPAFgAyP/j/1X/oP9e/6b/s//Z//n/AQDw//z/ >lf/F/x//ff/P/kz/2f5S/zj/iv+r/83/0P/k/2X/pv+D/h//lv2R/h/9S/5T/Wn++/3M/qb+ >Mf8E/2j/Ef9u//X+XP/N/kP/iP4b/x7+2/6u/Zn+hv2C/tv9tv6U/iX/Uf+W/7//2P/M/+H/ >s//S/7P/0//O/+P/0//n/5T/wv8c/3j/n/4w/07+AP8l/un+Af7U/sX9sP5+/Yf+UP1s/kX9 >Zf5I/Wj+NP1a/gf9P/7j/Cn+9fwy/kz9Zv7M/bL+TP79/rb+PP8O/2//X/+e/6H/xf/E/9n/ >vv/V/6f/yP+t/8v/5//t/0QAJACRAFMAnQBaAGEANgD+//v/qv/K/4H/sv+G/7b/pf/I/9j/ >5/8iABQAgABMANgAgQD3AJUAtABuABcAEQBf/6T/6v5f//n+Z/+F/7v/RwAvANwAiAD6AJkA >mABfAO3/+P9Q/5r/Ef9z/03/lf/m//D/kwBXAA4BoQAzAbcAFgGlAOQAhwDDAHMAuQBtAL0A >bwDPAHgABAGXAGoB1ADcARYBBQIuAZcB7QCTAFMAV/+X/3D+Dv81/u3+ov4u/2D/oP8aABAA >qwBnABsBqQBxAd0ApAH6AKcB/QCKAewAeAHgAI8B7gC/AQwB1wEaAb4BDAGSAfMAjgHxAMMB >EAHyASwBtgEJAeUAjADP/+X/Ff91/zf/if8sABkAXgHOABMCOgHnAR8BCgGcABMACgCe/8T/ >6v/y/8wAeADUARQBlwKIAdwCsQGqApIBMQJLAbAB/gBbAcsATgHDAIsB6ADzAScBTAJcAU4C >XgHZARkBEgGlAGMAPQBAACkAzQB8AL4BDAGDAoABqQKXASoCTAF1Ad8AEgGlAEcBxQDyASsB >qwKYAQIDzAHEAqgBCAI3ARsBqQBdADcAFgAOAFMAMQDZAIAAQgG/AEwBxAABAZcArgBmAKIA >XgDhAIQALwGzAEgBwgAnAa0ABAGZABkBpQBiAdEApQH4AKQB+QBnAdMAKAGvAB8BqgBIAcEA >YAHQACgBsACTAFgAy//i/xP/dP+i/jH/j/4m/9/+Vv99/7T/NwAiAMUAdgDsAI4ApwBlADAA >HQDk//L/FwAQAOMAiQAnAkkBkAMfArIEzAIuBRUD1gThAsgDPgJqAm8BNwG3AIUATQBZADMA >fQBJAKYAYQClAGIAbwBBABYADQC+/9j/iv+6/5H/vf+//9j/3//r/77/1/9d/5//Av9n//b+ >Yf9N/5b/xP/c//b/+/++/9r/Sf+U//D+YP/T/k7/y/5K/5v+LP9K/vv+Hv7h/lb+Av/U/k7/ >Lf+D/wX/a/9s/hH/0f21/qb9m/4D/tL+q/43/1r/nv8BAAEAugBvAIwB6gBFAlgBqQKUAakC >lAF6AncBaAJsAZYCiAHwAr4BTgP3AZsDJQLUA0cC9gNbAv0DXwLxA1gC+gNdAkgEiwLSBN0C >UAUoA2kFNwMDBfoCawSfAg8EaQIwBH0CqQTGAiIFDwNeBTIDXwUzA1MFKwNRBSsDUAUpA0cF >JANGBSIDbgU5A8EFawMYBp4DNgaxAxcGngPvBYgDDgaaA5UG6gNhB2MEHwjVBIwIFwWOCBcF >NgjiBLMHlARMB1YERQdRBMUHngSnCCQFiwmsBf0J8QXOCdUFKwl0BXcICQUACMME0QenBMIH >nQS7B5kEyQehBAkIxwR+CAwF+ghWBUcJhAVRCYsFOgl9BTEJdwVJCYUFawmbBW4JnAU6CX0F >3ghFBX8IDQVICO0ESwjuBIAIDgXFCDcF8ghRBewITgW5CC8FeAgJBVAI8QRQCPEEbAgBBY8I >FgW1CCwF5QhJBSAJbAVLCYYFQQmABfcIVAWTCBoFYQj7BJEIGQUWCWgFqQm/BfgJ7QXkCeEF >iAmqBR8JbAXVCEAFrwgoBZcIHAV1CAYFQAjnBAUIxQTZB6wEygejBN0HrgQFCMYENAjiBF0I >+QR6CAoFhAgPBXMIBgU7COQE3QesBHEHbAQlBz8EGQc4BD0HTwRZB2AENAdKBMwGDARfBssD >Pwa4A5UG6QMwB0YEsweTBM8HowRzB2sE0QYMBDIGrwPHBW8DnwVYA7AFYgPjBYIDGQaiAyQG >qQPlBYIDXgUyA74E0gJKBIsCLAR5AlAEjgJ3BKUCYgSaAvsDXAJlAwUC4gK5Aa4CmwHhArkB >ZQMIAgAEZAJhBJwCSASMAqgDLQLGAqUBFgI8AQMCMAGhAo4BlAMfAkYEigJABIcCewMSAmAC >bAGDAekAQAHCAI4B7wATAj0BdAJ1AY0ChAGBAnsBiQKAAbcCmwHuArsB8wK/AbICmgFMAl4B >AwIzAQICNQE7AlYBbgJ1AWQCbgEeAkIBzwEUAbAB/wDLAQ4B9wEoAQICLwHYARYBmQHxAHgB >3gCTAfEA5gEjAUkCXgGBAoABWwJpAb4BCwHDAHUAvv/Y/xf/df8V/3P/o//G/1sAMwDLAHYA >yAB1AIQATgBOAC8ATAAwAF8APABVADQAIwAXAPr//v8EAAIAMQAeAE4ALgA4AB8AFAAJACoA >FgCRAFQA/wCXAPwAlgBNAC8AOf+M/1f+Bv8c/uP+hv4h/zz/jf/j/+//ZQA8ANwAggBUAcgA >rwH+AMMBCgGSAe0AUQHIAEEBwAB5AeEA2gEcATcCUwFsAnMBcAJ1AUYCWwHwASgBhQHnACgB >rwD5AJMA8QCOAOsAiwDNAHkArgBmAMMAdAAmAbAApwH9AO0BJgHBAQwBUQHKAAQBmwAXAaYA >aAHWAJoB8wB0AdwAJQGsAAoBngBfAc8A9gEpAWcCbgFqAnABAwIzAW8B2wDnAIoAhQBQAGQA >PACoAGQAZAHTAGMCbAEmA+ABKwPhAVICYAESAaMAIwAUAAAA//+XAFsAbAHYAPQBKQH2ASoB >hgHpAO4AjwBzAEQARgAqAH0ASgAFAZwAkgHvAMoBDwF6AeEA0wB9AEgAKgBBACUAxQB0AHcB >3gDkAR8B1wEYAXQB3QAEAZwAtQBtAHgASQAyACAA6f/z/7v/1v/K/9//DAAHAFEALwBrAD4A >VAAxACsAGQAaAA4ANwAhAHwATADJAHoA9ACSANAAfgBTADMAo//J/xL/cv/1/mD/Y/+h/xYA >DACWAFYAhABNAOD/6/8I/2z/cP4T/17+CP/G/kf/Zf+m/+P/8v///wEAmf/D/8v+SP/s/cP+ >ef1//s79r/7a/k7/GAAMANIAewCTAFcAfv+z/y3+7P5R/Wv+Sv1n/v390f76/mf/wv/c//3/ >/v+f/8X/4/5U/z3+8f4g/uD+tf44/6n/y/9dADcASQAsAGL/pP8q/uv+Vv1u/lH9av70/cr+ >vP5B/yb/fv8J/2z/j/4i///9zP6G/YT+H/1G/q38BP4b/K/9Z/tF/aj61fwD+nT8kfkw/FD5 >Cvwk+e/77fjN+6z4pPuM+JD7s/im+xz55PuF+SL8m/kw/Ej5APzE+LL7cviD+5j4nPs++f/7 >Rfqb/IP7WP3O/Bv+1/23/jL+7f6S/Yz+Fvyp/V/6o/w++fj7J/nr++j5X/zV+u38Q/sx/fL6 >Av0X+n/8Ffnm+z/4Zvu29xP7e/fu+nv37vqT9/v6mff++nH35vos9776+vah+v32pPok97z6 >KffA+tH2jfoi9iX6ZPWz+f70d/kt9ZL55/X++eH2kvqz9w37BPg9+7j3EfsH96j6dvZT+o/2 >ZfqP9/76KPny+7T63fyZ+2X9s/tz/Vf7O/0W+xP9Qfss/cL7eP0y/Lr9LPy2/Yz7WP2H+r78 >h/kn/PX40fv9+Nj7efki/AH6cfww+o784vle/EP5/vun+KD7U/hu+1X4bfuQ+JH75/jF+0H5 >/PuA+SP8h/kn/EP5AfzW+MD7fviN+3L4hfus+Kf78fjO+xP54PsZ+eT7L/nw+1/5DPx1+Rr8 >Ofn3+7v4rfti+Hn7pPih+475Lfyq+tf8Y/tE/W/7S/39+gb9Xfqm/Lj5QvwC+dT7QPhh+8T3 >F/vx9zP73vjC+x36gPwD+wv9K/sj/bb63vwY+oH8uvlI/Lv5R/wV+nr8wfrf/Kz7bP2V/PX9 >Cv06/sD8D/7h+4v9B/sL/bj63/z6+gb9RPsz/QP7Df0s+o38Pvn9+9j4v/s3+fX7FPp4/Pr6 >//yb+1/98vuU/RL8qP0O/Kb99PuY/eb7kv0U/K79jfz3/Sv9Vf6x/aP+Cf7V/lD+/v61/jj/ >NP+E/6P/xf/W/+P/3v/o//P/9/8uABsAXgA6ACcAGQBf/6X/Rf79/lj9b/74/DX+HP1J/mn9 >dP58/X7+N/1V/sn8Ev53/OH9aPza/ZD89P24/Az+qPwG/lH80/3P+4f9ZPtH/UL7Mf11+079 >0/uE/SD8sP09/MH9Nvy7/Sz8tf04/L39XPzS/Yz88v3N/Br+Hv1M/m/9fv6e/Zn+j/2R/lf9 >bv4w/VT+Rv1g/o79if7N/a3+zP2t/pP9iv5Z/Wj+TP1j/mX9c/5u/Xr+R/1m/gz9Qv73/Db+ >MP1Y/qD9mf7//dD+Gf7e/uX9vf6J/YX+Nv1U/g79PP4i/Un+cv16/uz9xP5h/gv/nf4v/4n+ >JP9G/v3+C/7a/v790P4M/tf+Bf7R/tP9sv6V/Yz+kf2J/vH9xP6Y/if/KP9+/0b/kf/g/lf/ >RP76/uz9xv45/vX+L/+G/2UAPgBHAcMAcwHbAOsAigAdAA4AiP+2/2H/nv98/6//dP+r/wn/ >bf9K/vz+h/2K/v78Of6z/A3+ePzp/Sf8uP3J+3/9ivtZ/Yv7WP3D+3n9BPyf/Sf8tP0n/LX9 >Hfyx/Sn8t/1W/NP9mvz9/eL8KP4Y/Uf+Mv1X/jP9V/4u/VP+Ov1a/mT9cv6b/ZL+tf2h/on9 >h/4N/T3+dfzk/Rb8rP07/MP95/wp/s39sv51/hf/jf4l/xf+3/5r/Xf+7fwt/sv8F/7h/CT+ >7/wt/tH8Gv6j/P/9m/z7/dv8If5G/WD+p/2b/tT9tv7M/bD+n/2X/lr9bv78/Db+lPz3/VP8 >0f1y/OP9/vw1/r79p/5J/vr+V/4C/+P9vv48/Vv+wvwS/rH8Cf4H/Tz+hP2H/tD9tf6r/Z3+ >D/1B/kb8yv3J+3/98fuW/bb8C/6k/Zn+Jf7j/ub9v/4U/UL+M/y8/bz7dv3P+4P9M/y//Y/8 >9/2k/AL+Yvzb/ev7k/1y+0v9M/sm/V/7P/39+5v91fwd/o79iv7X/bb+pv2Y/jD9VP7D/BT+ >iPzx/Xr86f1+/Oz9g/zw/ZL89/20/Av+8fwu/j39W/6E/YT+p/2Z/of9hf4R/T/+YvzY/bv7 >df1l+0T9fvtS/d37jP07/MT9c/zm/Y/89v28/BD+A/05/k39Zf59/YD+m/2S/tn9tf5M/vv+ >0v5M/xj/df/o/ln/ZP4N//T9yv7x/cr+Yv4N//r+Zv9T/5r/Ov+L/8H+QP8d/t/+jf2I/iz9 >T/4A/TX+9fwv/vD8Lf7g/CT+yPwY/sL8FP7V/CD+8vwy/vr8Nf7Y/CH+rfwF/rb8Cv4V/UH+ >nf2R/u79wv61/aL+/fw1/iv8uP3B+3r9Cfyn/en8LP7w/cj+nP4u/6T+Mv8T/tv+T/1m/tf8 >Hv4A/Tb+uP2i/o/+Iv8O/2//AP9n/5/+Lv9K/vz+P/73/mL+DP9v/hT/SP78/gz+2P74/cv+ >Hv7g/lb+Av9p/gz/Uv7//kH+9P5g/gf/oP4v/73+Qf98/hv/8v3J/oT9iP6b/Zb+VP4D/2H/ >ov8/ACYAhwBPACgAFgBv/6j/yv5F/4b+Hv+f/i3/xv5F/6r+Nf82/vH+qv2f/mj9dv6g/Zf+ >Jf7n/o7+JP+S/ib/TP76/hz+3/5h/gf/Jf98/x0AEADtAIsAYwHUAIsB6wCGAegAXwHSABEB >pACYAFwADgAJAKX/yv96/7D/gf+0/4b/tv9P/5b/zv5J/y7+6/7H/a3+1f23/lP+Av/l/lj/ >F/93/7b+PP/9/c7+fP2A/q79nv6f/i7/3f/q/8oAdwAFAZsApwBiABMACwCs/87/kP+9/5r/ >xP+T/8H/Xf+f/wb/bP+//kL/vP4//xz/ef/b/+j/yQB2AKgB+wBEAlkBkgKHAbECmQHKAqkB >+ALFATID6AFeAwECWQP/ARYD1wGdAo0BDQI3AYsB6gAxAbUA/gCXANIAfACOAFQANwAhAPj/ >+//8//7/TQAvAL8AcgAaAakASwHFAGUB1ACDAeYAlAHwAGsB1wDsAIwAQAAlAL//2f+0/9L/ >IgAWAM0AewBnAdYAzAERAfYBKwHvAScBuwEHAV4B0AD2AJIAqwBkAJIAVwCwAGgAAQGYAJoB >9ACRAoYB2ANLAioFEwMpBqoDpwb2A8QGBgTGBgcE0wYPBNUGEQSnBvQDSAa7A+UFgQOoBVwD >gwVFA0oFJQP+BPgC6ATrAl4FMQNdBsgDawdqBO0HtwStB5AEBQcsBIwG5QOIBuEDtQb8A44G >5QPRBXUDtQTMAqsDLQLyAsEBegJ6AQ0COQGjAfoAcQHbAKEB+QAXAj8BbwJyAUgCWwGXAfIA >uABtADIAHgBiADoATgHGAKQCkgH2A1wC8ATxAnkFQgOmBVwDpgVcA5sFVgOSBU8DiQVKA4kF >SwOYBVMDqwVeA5YFUgMmBQ8DQwSIAhED0wHXARgB2ACBADUAHwDq//P/5v/x/w8ACQA7ACMA >KwAZAK3/z//W/k//C/7V/s39sv5f/gf/hP+2/6IAYQAbAagAtQBsALD/0f+e/i7/Av7R/hL+ >2f6W/in/Gv93/zH/hf/F/kX/M/7t/g3+1/6w/jj/8P/2/yYBrwClAfoALgG0ABIACwDm/lj/ >Ff7c/rT9ov6c/ZT+uf2k/gj+1P6E/h7//f5l/yv/gf/o/lr/Xf4H/9v9uf6r/Zz+2/25/k3+ >/P7X/k//Uf+Y/5f/wv+H/7j/Hv96/5D+Jv80/u/+TP78/sn+R/9T/5n/g/+2/yr/gf9u/hH/ >qP2c/jj9Wf5U/Wr+9v3K/tj+UP+I/7n/o//I/w//cf8i/uT+eP1//pT9j/6M/iP/AQABAGQB >0wBBAlgBaQJvAeABHgHNAHoAdf+u/zf+8P5o/XX+LP1R/mH9cP69/af+Df7X/kj++v50/hT/ >f/4c/1L+Af///c7+4P29/l/+CP+F/7f/1wCAAJ0B9QBsAdgAhgBQAJH/vv8T/3T/FP90/z3/ >jP9G/5L/N/+I/0H/jv9x/6r/lf/B/3T/rP8O/3D/qf40/5P+J//a/lH/Sf+S/5n/w/+r/83/ >jv+9/17/oP8x/4T/Ef9y/wv/bv8e/3r/OP+K/zH/hf/6/mX/rv43/4j+If+r/jb///5n/0D/ >jv86/4v/+/5k/8r+SP/v/l3/cf+q/xUADQB4AEcAUAAvAJ//x/++/kH/M/7u/nH+E/96/7D/ >0wB+AMMBDQHJAQ8B9gCRANr/6v8U/3T/6P5a/yT/ff9t/6j/k//A/6j/y//H/93/8f/3/wsA >BwAWAA4AOwAjAKYAYwBBAb8AswEDAaEB+QD/AJgAJwAXAJP/v/+G/7j/2//q/yoAGQAcABEA >oP/H//H+X/9o/g7/UP4A/7f+PP9m/6T/AAAAACoAGwDP/+L/JP99/5f+Kf+D/h3/AP9o/9v/ >6f+yAGsALwGzABYBpQBvAEIAgv+2/8n+SP+y/jr/WP+c/14AOAAlAa4APAG7ALEAaQAHAAQA >z//j/zUAHwDvAI8AgwHmAJwB9QBBAb8ArQBnACIAFADN/+H/wv/b//7//v9bADUAmgBcAIcA >UAAiABQAqP/M/2j/pf+B/7X/0//l/yIAFABKACsATwAuAEcAKwA4ACEAHQARAPf/+//W/+f/ >yP/e/7f/1P9//7L/Hf96/8v+SP/V/k7/Vf+c/xMACwCiAGAAxAB1AI4AVABKACwAOgAiAFsA >NwCJAFEApwBiALoAbgDMAHoAywB4AI8AVQAUAAsAi/+7/1H/mP+f/8f/ZgA9AEYBwgDSARUB >wgEMARgBpQAdABIAP/+N/+D+Vf8p/4D/7P/0/78AcgA7AbsAPAG7AOwAjACSAFYAWAA0ADgA >IgAmABgAOAAhAJIAVwA5AboA7QElAUcCWgECAjIBPAG7AFYANAC1/9T/gv+1/7n/1v9IACsA >IAGrABgCPgHSAq4B4wK4AR0CQQHLAHkAn//G/zH/hP+c/8T/cQBDAAgBnQAFAZsAhABPAPr/ >+//V/+f/OAAhAO4AjgCjAfkAFgI9ATQCUAEaAkAB5gEhAawB/gBqAdcAIAGqAN4AhADHAHYA >7gCNADoBugBqAdcARAHBAMcAdgA5ACIA+f/8/zEAHAC2AGsAJwGvAEEBvgALAaAA0gB9ANoA >gQAqAbAAgQHlAJMB8ABIAcIAvwBxAD8AJAD3//v/7//2/wsABgApABkAPQAkAEMAJwBDACgA >SQAsAFoANQCEAE0AzwB6ADsBuwC3AQQBHwJDAVQCYgFCAlcB8gEnAYYB5wAkAa4A6QCKANEA >ewDEAHQArABlAIEASwBhADgAcgBEAMwAeABNAcQArwH/AKsB/QAnAa4AUQAvAIb/t/8h/3r/ >TP+V//H/9v/GAHQAbgHYAKAB9gBFAcAAigBRANT/5P+N/7r/2//p/3wASADpAIkAtgBrAOz/ >8/8J/2z/pv4y/wj/a//x//X/2QCAAFcBygBZAcwAEwGhAMoAdgCjAF8ApQBgAMYAdADzAI4A >BwGaAN0AgQBtAD8A6//y/6n/yv/b/+j/ZgA7AO8AjAAsAbAAFwGjAOQAhADFAHQAxQBzANEA >eADgAIIABQGZAEABuwBpAdQAQQG9ALgAagADAP7/fv+v/1v/m/+C/7H/t//S/+L/6/8ZAAwA >cQA/AMYAcgDTAHoAfwBIABEABgD4//j/XQA0AP0AkwBZAcoANgG0ANQAegCnAF8A6QCHAHkB >3AASAjcBogKNAVAD9AExBHkCEwUAA6AFVQO1BWADgAVAA0kFIQMXBQIDnwS7Aq4DKgJ1AnEB >gQHgAEMBuwCjAfQAGQI7ASwCRQHTARABYwHPACkBqgAYAaEAAgGVANcAewDDAG8A7wCJAD8B >uQBfAcsAHAGjAKIAWgBUACwAZgA3AKEAWgCYAFQAEAADAEH/if+l/iz/lv4j/xf/b//j/+n/ >pgBdABoBogAaAaIAqABeAPz/+f93/6n/Zf+f/8T/1/8+ACAAdQBAAFkAMAArABUAMAAXAFsA >MQBdADIA+v/3/1X/lP/K/kL/j/4g/4r+G/91/g//UP76/mj+CP8D/2X/9//2/6sAYQCgAFoA >2v/k/+3+WP9s/gv/df4Q/6/+Mv+6/jr/iv4e/1j+//5H/vb+N/7s/ub9vP5O/WL+vPwM/oX8 >6/2r/AH+3vwg/tP8Gv6Y/Pb9k/z1/TD9Uv58/hf/KAAWAL8BCAHzAr8BvQM3Aj8EhQKzBMkC >NwUYA8wFcQNDBrkDUgbCA70FaQOWBLsCOQPrARgCPgFpAdYAEgGkAMgAeABcADkA3//u/37/ >tP9Q/5n/SP+U/1D/mv9m/6f/lf/E/93/7/8TAA8ABwAJALX/2P9R/5z/Kv+G/2j/q//g//P/ >NQAlABYAEwCF/73/2/5Y/4/+LP/q/mL/vf/g/4MAVgCyAHIAJgAfAEb/m//E/k7/Cf92/+D/ >9/+XAGQAiwBdAK//2v+U/jP/8/3T/hr+6/7G/lL/ZP+v/47/yf9K/6D/5P5k/6P+P/+T/jb/ >lv43/4n+Mf9l/hz/Nv4A/w/+6f4E/uL+Hv7y/lz+GP+v/kr/Av97/0//qf+Z/9b/5/8EACoA >LABHAD4ALQAuAPD/CwC2/+n/n//b/6X/4P+z/+j/vP/t/8//+f/9/xYAQQA9AHIAXAB1AF0A >TwBIACQALQAMACAAAwAbAOj/CwCs/+j/Xv+5/xT/jv/h/nD/1f5p/xP/jv+5//H/tQCHAKIB >EwHzAUQBYQHuAEYARgBt/8X/i//X/6gAgAAUAlkB5ALVAZ4CrAF4Af0AJwA1AFj/uv9Z/7r/ >BgAiAPIArwClARgBzwEyAXkB/wABAbgA4QCkAFsB7QBGAnoBJwP+AYkDOQJWAxsCxALEAR4C >YgGKAQoBHwHKAAEBtwBtAfgAcgKUAcoDXwLuBA0DhQVmA6YFegPMBZEDWAbkA0EHbwQoCPcE >sQhJBc4IWQWsCEYFewgoBT8IBQX+B94E0AfCBNoHyAQdCPAEWQgTBUEIBQXSB8IEYgd9BFoH >egTfB8gEoAg7BSYJigUkCYkFoQg7Bd4HxgQnB1kEvAYZBNIGJgRuB4MEVggLBQcJdQUVCXwF >fwghBcQHtASJB48EBgjYBOQIXQWHCb4FlwnHBSwJhQWbCDAFGgjhBKQHmwQ1B1gE/gY3BD4H >XQT4B8sEugg+Be4IXAVSCP4EOQdXBE4GygMRBqYDfgblAyUHSASUB4oElweLBEwHXQTlBiAE >iAboAz4GuwMHBpoD5AWEA9sFfgPwBYoDHwakA04GwANYBsUDGwagA6EFVwMwBRQDIAUJA5YF >TgNOBrsDygYEBLEG9AMbBpoDggU+A1gFJQOwBVgDOwaqA6YG6gPhBgwEFgcpBGAHVQSlB34E >rgeCBHAHXQQoBzEEIwctBHAHWwTSB5QE8AelBKsHewQwBzEEyQb0A5UG1AN9BsUDWgauAyUG >jwP5BXMD8wVvAxQGgwNDBp8DZQaxA2kGswNKBqAD+gVwA3oFIwPjBMkCbwSDAlcEcwKnBKMC >OAX4AsYFTAMfBoEDOwaQAyQGggPnBV0DgAUfA/UEzAJnBHcCEgREAhwESgJxBHwCugSnAqkE >nAI1BFcCwQMRAsoDFQKABIICgAUaA/wFYwNZBQEDsgMGAtkB7QDUAFEAHQF8AFsCOAGuAwAC >WARlAjEETwKTA/AB8wKRAYECTQEzAh4B+AH7AO0B9QA3AiABxQJ0ATsDuwEiA6sBQAIlAdwA >UgCb/5L/Lv9R/+H/vP9pAaUA/gKVAcADCAI8A7sBuQHTABYA2v9G/1//pf+Y/8cARAC8AdYA >zwHgAP4AZQD0/8f/d/99/9j/tv/EAEIAnAHEAO8B9QC1AdMAOwGKANIATQCjADIApwAzAMsA >SAACAWsATAGWAKQBywDyAfkADwILAd8B7wBmAacAzgBOAF4ACwBTAAUArwA9ADUBjQCIAb8A >cwGyAAcBcwCZADEAeQAdAL0ARgA2AZAAlAHIAJwBzQBKAZ4AygBTAFsAEQAmAPH/MwD6/10A >EwBvAB8AQQAFANn/x/9k/4L/G/9W/xj/V/9T/3r/pP+q//T/2v9DAAwAqABGACIBkQCfAdsA >/AETASoCMAErAjEBGgIpARUCJQEoAjEBTgJJAWoCWQFUAk4B8wEUAUwBsgCEADwAxf/L/w7/ >YP9E/uj+Uv1Y/lb8w/2o+1z9lftS/Rb8n/24/AH+8Pwj/nD81/1k+zj9UvqX/Ln5PPzJ+Uf8 >VPqb/P/6AP1u+0P9Zvs//eD67/wD+m38MPnw+8z4tfsZ+eT7/Pls/Av7Dv3F+3393PuM/V37 >Qf2c+s78Afpz/NH5WPwY+oP8qPrY/DL7Kv1p+039KPsn/Yj6yPzQ+Vv8U/kT/EP5CfyT+Tn8 >Bvp+/Fb6rvxb+rL8GPqK/Lb5Ufxy+Sr8evkv/NP5ZPxW+rL8w/r0/Of6Cv29+vD8afq//Bz6 >k/zw+Xj83vlu/OT5cvwO+oz8evrN/Cv7N/31+679e/z//Wb88/2h+379bfrI/FL5IPze+Nv7 >a/kw/Of6Ev3e/D3+qv5O/7//9f/y/xMAgP/P/9f+a/9W/h7/Fv74/vL95P68/cP+X/2M/u38 >Sv6H/A7+Q/zm/Sn81v0x/Nr9Vfzx/Yb8Dv6v/Cb+vPwv/qf8Iv55/Af+TPzs/TL83P0z/N39 >Rvzq/WD89/10/AT+gPwM/oz8Ev6Z/Br+o/wh/qX8If6c/B3+lPwZ/qD8H/69/DD+yfw3/pn8 >G/4n/Nb9tvuU/bP7kf1c/Pf9dP2d/lz+Jv91/jX/qf27/n78C/69+5j93Puq/an8JP6P/az+ >+/3s/sT9zP4l/W3+gfwM/if81v0t/Nj9gfwL/vL8T/5H/YD+VP2I/h79aP7a/D/+yPw0/vr8 >U/5L/YP+ff2f/nT9mv5L/YL+J/1s/hf9Yv4b/WX+Qf17/q79vP5s/iz/NP+j/4L/0f/3/n7/ >x/3K/qr8IP5b/PD9AP1T/hj++P7r/nX/Kf+a/w7/i/8O/4r/Uv+y/5j/2/+D/87/+f59/zT+ >CP+B/Zz+/PxN/qL8Gf55/P/9nPwU/hz9YP7A/cH+Gv72/tn90P4d/V/+a/z2/Uf83/3J/C3+ >kv2k/iD++P4w/gH/6f3X/qb9sP6v/bT+A/7m/mn+Iv+W/j3/Yf4e/9j9y/45/Wz+2vw1/vT8 >RP6E/Zj+QP4I/83+XP/2/nX/zP5b/4r+M/9t/iL/g/4v/6/+Sf/O/lv/2f5i//T+cv9R/6j/ >DAAYABQBtQAmAlcB9ALRAVQDCgJbAw4CVAMKAoQDJgL/A28CmATKAhAFEQM8BSsDIwUcA9YE >7wJfBKcCqQM7AqoCowF/AfEAZABJAI3/yP8S/4D/7f5q/xL/f/9u/7b/3//4/xkAHADY//T/ >CP94//T90/4Y/VH+0/wp/ir9W/7N/bv+Z/4X/9L+V/8b/4L/UP+i/2L/rf80/5H/zv5T/2f+ >F/9E/gH/fP4j/+b+Yv84/5L/Qv+Y/wn/dv+t/j//S/4F//D9z/6e/Z3+Yv16/j79ZP4d/VH+ >2Pwm/lP82f2x+3b9OPsw/S/7Kv2M+2H9+/uj/Rv8tv3R+4n9YftH/T/7Mf2m+3D9bPzl/Rn9 >S/5S/W3+Fv1K/rv8FP6Z/P79y/wc/ij9Uv5u/X3+hP2J/nT9f/5f/XP+Xf1y/nH9fP6W/ZP+ >yP2w/uX9wv7E/a7+S/1l/pz8/v0f/LP9P/zF/R39Sv5v/hP/rP/P/2oAQACaAFwAcABDACgA >GADb/+n/g/+0/xn/dv+n/jH/Kv7n/o39if7J/BT+CPyh/aj7af33+5f93/wh/uD9uf5b/gH/ >Av7M/g79O/4X/Kf9nvtf/cv7ev1g/NP9+vwu/kP9Wf4i/UX+rfz+/SD8q/3B+3L9uvtt/Qj8 >m/18/OD93PwZ/gj9M/4C/S7+4fwa/sD8Bv60/P/91vwS/kL9U/7//cT+8f5T/+n/5v/HAGkA >lAHjAGUCXwEvA9YBuAMnAr0DKwI6A9wBcwJlAdABAwGUAd8AxAH8AEMCRwH2ArEBuwMmAlUE >gQJqBI0CywMuArEChwG/AfYAkAHZAD8CQgFSA+UBEwRWAh0EXAKkAxQCKQPLAQwDuQFGA9sB >jQMFAp8DEAJ7A/oBRQPaASIDwwEcA8ABLgPKAU0D3QF2A/QBpQMQAtoDMAIjBFsCiwSYAgMF >3wJXBRADTwULA90EyAI9BGgCzgMmAsoDIwIdBFUCdQSIAosElQJWBHQCBQRGAs4DIwK+AxoC >wAMbArkDFgKhAwgChAP3AWUD5AFCA88BFQO0AeYCmQHQAooB5wKXATEDxAGeAwUCDgRGAlsE >dQJsBH8COQRhAsoDHgI7A8kBtwJ7AW0CTwF9AlgB3gKRAVAD1AFsA+UB5QKVAdUB9ADGAFIA >bAAcACYBigClAnABJQRUAuoExwLKBLUCLgRZAqsDCgKEA/MBowMFAtADIAIFBD8CXwR1At0E >wQJGBf8CTgUEA+gEyAJeBHUC/gM9AtgDJgKgAwUCDQOuASMCIgEwAZIAhwAuADEA+/8CAOD/ >xP+7/2n/hv/3/kH/af7t/rz9hv4V/ST+yfz2/RL9Iv68/Yj+LP7L/tT9lv65/O79ifs6/Q77 >8fyD+zj9bPzC/Qf9H/7p/A3+QPyp/YP7Of3/+uz8uPrB/JH6q/yO+qn8x/rM/C37Cf2G+z79 >lvtI/V77Jv0c+wH9Fvv9/Ez7Hv2E+0D9hftB/UT7Gv3b+t38bvqd/Bn6avz++Vv8UvqN/DP7 >E/1j/Mn9Wv1b/or9ef7U/A7+pPtZ/an6xPxf+pr80vre/KL7W/1d/Mr9sfz8/Yb84/0E/Jf9 >hvtM/Xj7Rf0T/KL9If1E/gj+zv4p/uH+Vv1l/v77mf3g+u/8k/rC/D37Kf2a/Pf9OP7v/qb/ >yf99AEkAgQBOAM7/4//i/lb/Zf4O/67+Of9v/67/8f/6/5//y/+H/iX/T/1s/q/8Df7r/DL+ >vv2w/qT+Of8u/43/Kf+K/5X+M/+c/Z/+rvwR/lD82/3T/Cr+9v3X/vH+bf8G/3n/Gv7w/tz8 >Mf4s/Mr9a/zx/Tj9a/7V/cj+1f3J/mX9h/4B/U3++/xJ/jz9cP57/Zf+k/2k/o79ov6G/Z7+ >ev2X/mH9if5Q/X/+fP2a/gX+7P6//lr/Pv+n/zT/ov+x/lX/Iv4A/+/94v4l/gP/dP4y/3f+ >NP8M/vX+cP2Y/gv9XP4n/W7+vv3J/nX+Nf/R/mz/f/47/5D9r/6E/A/+AvzC/XP8Bv6y/cL+ >Cf+P/7D/9P9K/7j/I/4H///8Wv6U/Bz+Fv1p/hr+A//e/nn/yP5q/8D9z/5K/PD9N/tN/S/7 >SP1J/PD9/f3z/nf/1P8hADoA8/8dAFn/wv/Y/nf/pv5Y/6f+Wf+f/lb/bv43/xH+Af+K/bH+ >1vxE/gz8zf2E+3z9qvuS/an8K/4k/gv/U/+//4P/3f+M/kn/8PxU/ob7fP3u+iL9Vvtg/Xf8 >DP7H/dP+uv5j//P+hv9m/jH/af2b/ov8Fv5B/Ov9lfwd/if9c/6E/ar+kf2y/qX9vf4k/gj/ >C/+R/8//BgDA//3/n/5Q/9z8Rf5h+2P96vob/Z/7h/0U/WT+kv5G/4H/1P+e/+b/C/+O/zb+ >D/+n/bn+vP3F/mT+Kf8s/5//fv/R/yH/mf9g/ib/1P3S/uf93P58/jX/EP+M/yH/lv+T/kH/ >tv2+/vz8Tv6m/Br+svwi/v/8Tv5r/Y/+2v3Q/if+/v4f/vn+q/2z/vb8SP5b/Or9L/zP/X78 >/v0D/Uz+V/1//kb9c/7t/D7+n/wP/pT8Cf7I/Cf+9vxB/tH8K/5H/Nn9hftm/ej6B/23+un8 >/voT/Yv7Zv0O/LP9TPzZ/T/80f0V/Lf9Bvyu/TX8yv2T/P/96Pwy/gT9Qv7i/C7+sPwQ/q38 >Df74/Dn+cf2B/tv9wP4K/tv+B/7a/gn+2/4z/vL+ev4c/6z+Ov+o/jb/dv4Y/zz+9f4E/tT+ >tf2l/jP9Vv6b/Pz9TvzN/Z78/f19/YH+av4O/9H+S/9+/hr/zf2v/lz9bP6X/Y/+af4L/27/ >pv9GACYAzAB2AA8BnQAkAakAJQGpADUBsgCFAeEAKAJCAegCtAFYA/cBHgPTAT8CTgEYAZ4A >FAAEAGX/m/8H/2P/8v5W/zz/gv/p/+n/rQBdAAIBkACJAEcAcf+h/2z+Bf8e/tX+mP4f/1L/ >jv+i/73/XP+S/9j+RP+U/hz/uv4x/xL/Zv9R/4v/Zf+W/2b/l/9k/5b/Sf+G/wH/W/+z/iz/ >qv4n/wf/Xv+O/63/1//Z/7n/x/+F/6j/wP/L/6UAUwDrARUB9wK0AWQD9AEwA9YBmgJ9Ac0B >AgHNAGoAqP+9/7T+K/9a/vX+yv42/7f/xP+OAEUA2ABwAH4AOwDA/8n/8P5O/0/+7v4G/sL+ >Ov7h/vH+Tv/p/+L/rQBWANgAbwBnACwAxP/L/2T/k/92/5z/w//L//T/6P/j/97/rv+//4f/ >p/+H/6j/rP+9//L/5/9bACYAzwBrAA8BkADQAGsADQD3/yj/bv+s/iX/6/5L/7L/wP9xADMA >rABVAFAAHgC0/8H/Sf+C/1D/hv+7/8b/RgAYAKsAVQDBAGIAlABHAF0AJwBaACYApgBRAA4B >kAAwAaQA0ABrABgA//+L/6n/pv+5/3gANwCKAdsANAI/AQoCJgEmAZ8ABADy/yX/bf/a/kL/ >LP9y/+//5//aAHEAjgHcALsB+ABEAbEAXAAnAH3/ov8b/2j/bP+Z/1AAHwByAc0AgAJsAVID >6QHiAz8CPQR1AnEElQKUBKkCxATFAh0F+wKrBU8DSwavA7IG7AOGBtEDmAVFAxUEXwKCAm8B >fgHVAGEBxAD/ASEBuwKSAfcCtQF3AmgBgwHYAK8AWgBoAC8AqABVABABkwAzAagA7QCAAG4A >MwAJAPj/9P/q/yAABABMACAAPgAXAO7/6P+T/7H/c/+f/6D/uv/f/9//1P/Y/17/k//K/jr/ >of4i/zX/ev9HAB4AKAGjAD4BsACBAEEAif+u/xX/af92/6L/ZAAwAEcBtwCoAfAAcwHQAOMA >fABGAB4A3f/g/9T/2/80ABQA1gB0AFkBwgBfAcYA3AB3ACgADgDQ/9n/IAAIAPQAhwDUAQwB >WQJbAWICYAECAigBXQHFAJMATgDm/+f/v//Q/20AOADSAQwBQQPmAegDSgJmA/wBDwIxAasA >XQDa/+H/sv/J/+P/5/8hAAsAdQA+ACEBpABFAlIBpQMkAsYE0QI7BRYD4wTiAuoDTQKoAo4B >dwHZAJ0AVwAvABYAIAANAEEAIQBmADgAgQBIAJYAVACoAF4ApQBdAHwARQBFACQAOAAdAHwA >RwD5AJEASQG/AAkBmQAtABgAGv90/1/+Bf9g/gb/HP92/0IAJABjAdAAGwI/ASkCSAF5Ad4A >QQAlAAb/af9e/gf/kP4l/2D/oP8xAB0AgQBNAEIAJwDT/+X/of/I/9D/5P8kABYATwAwADUA >IAD+/wEA3//t/+z/9f8MAAkAIgAWACEAFgATAA4ABAAFAOz/+P+6/9r/YP+k/+f+XP9//h7/ >Yv4O/77+RP93/7L/KwAeAF8APADd//D/+P5n/1n+CP99/h7/Sv+Z/xIAEAAkABkAav+s/3/+ >IP8m/uz+pv44/4j/vv8OAA0AyP/k/+/+Y/8T/uL+rv2k/tD9uf5I/gD/1/5W/1L/n/+P/8T/ >Z/+s/9v+WP8u/vL+2v3A/iL+6v7Y/lf/cf+y/3j/t//v/mX/Q/4A//P9z/4n/u7+qv48/y3/ >iv9//7v/m//N/4//xf9j/6r/J/+G//n+bf/x/mf//P5u/+X+YP+U/jD/Qf7+/l3+EP8s/4r/ >ZwBGAGEB2wCAAe0AuwB3AKX/0//t/mT/2/5b/zL/jv91/7b/Yv+q/xf/ff/x/mf/NP+O/97/ >9P+uAHEAUAHQAIsB8wBuAeIAVwHUAMEBEwHsAsUBlgTDAgsGoAOZBvQDHgarAywFGwObBMUC >7AT0AusFjAP2BisEjweHBKoHlgSNB4UEZwduBBkHQARxBtwDfgVMA6sEzgJsBKkC1QTnAoQF >TwPtBY0D2wWCA4QFTgNeBTcDsQVpA2AG0QP/BjEEIAdDBJkG8gOhBWADrQTOAjMEhgJuBKkC >PgUkAz8GvQMEBzIEWgdlBF4HZwRMB10EUAdfBGIHaQRdB2YEKQdIBNwGGQSlBvgDrQb9AwMH >MQSdB4sEYQgABScJdgW9CdAF8AnuBaYJwQXoCFEF8Ae9BBIHOASfBvMD0AYSBKMHjwTNCEAF >xQnTBQMK+AVZCZIFFwjTBOMGHARPBsQDfwbfAyYHQwTcB7AEZQgABcoIPQUfCW8FVgmQBUYJ >hgXaCEUFOAjlBKkHkQRnB2kEeAdzBLYHlwT2B70EFAjPBPgHvgSUB4QEBgcvBJgG7QOiBvMD >QAdRBCUI2QTHCDgFvgg0BR0I1QRTB1sEzgYNBLIG/APSBg8E9wYlBA4HMgQhBz0EKQdCBAcH >LgSmBvUDMAavA/AFiAMTBp4DdAbXA7cG/gOfBvADQwa5A/YFiwP1BYsDMwavA2oG0ANbBscD >/gWQA3MFPgPpBOsCgwSvAmQEnAKmBMMCRwUjAwcGlQOABtwDXwbKA6oFXQPABNICHQRxAv8D >XwJGBIsCrATHAvEE7wILBf8CGgUHAz8FHgODBUYD0wV2AwYGlAPwBYgDdgU+A6UEwQK8AzcC >FgPVAfwCxgF3Aw8CSwSNAhQFBAN2BT4DPgUdA3kEqAJwAwkClAKHAUkCWwGvApcBhgMXAkoE >jAKSBLgCSgSMArUDNAIzA+UB8AK+Ad4CswHfArUB+wLEAVUD+gH+A18CwgTUAjsFGwMbBQgD >ZQScAnMDDQKvApgBWAJjAWMCagGXAooBuAKdAaECjwFVAmIB7AEjAYwB6wBcAc4AcwHbANkB >GQGLAoMBdQMNAmoEoAImBQ4DYAUxA/cE8gIWBG0CIwPdAXkCeAEzAk4BIAJDAQwCNwH5AS0B >JwJHAcACogGdAyUCQwSIAjwEhAJ1Aw4CVAJjAWwB1wAfAaoAeQHgAD4CVAEeA9oBywNBAgkE >ZQKxAzEC3AKyAfEBJwFxAdsAqgH9AHYCdgFXA/sB0gNFAsADOwJaA/4B/ALGAeQCtwEVA9QB >cAMLAs0DQwL+A18C3ANMAlYD/AGMAoMBzAESAWgB1QBzAdwAuwEHAfQBKQH8AS0B6gEkAewB >JgEBAjEB6wEkAWoB1wCAAEwAi/+5/wf/bP84/4n//f/+/+AAhQBlAdQAUQHIAL8AcQAPAAkA >of/H/6H/xv/6//3/ZQA7AI4AVABQAC8Axf/d/z//jP8S/3L/c/+s/1IAMQBZAc4ACgI3Af4B >LwErAbEA/v///y3/hP9E/5D/OAAhAHEB2wAoAkgB/gEvATIBtgBhADkA+//9//r//f8LAAcA >//8AAP//AABaADUAGAGnAN0BGwEjAkYBuQEGAeQAiAA0AB8ABQADAEsALQCvAGgA3wCFAMcA >dwCFAE8ARwArADAAHQBIACsAggBOAKoAZgCJAFEAAwACAEr/k//H/kb/1f5O/3X/rf9HACoA >4wCHACgBsABOAcYAkwHwAPIBKAEnAkgB+QEtAYgB6AAvAbQAKgGxAFcBywBSAckA6QCLAFIA >MQANAAgAbwBDAE4BxwAqAkoBgwJ+ATgCUQGCAeUAxwB3AEoALAAoABgAUAAwAJ8AXgDkAIgA >+gCVANcAgQCVAFgAVQAyACIAFADu//X/sv/R/47/vP/B/9r/XwA5ACkBsACaAfQATwHGAE8A >LgAg/3v/af4N/37+Gv9B/47/RAApABYBpgB5AeAAWgHNAMcAdwDn//H/+f5k/0f++v4T/tr+ >bf4R/y//g/8NAAgAtABsAOAAhQBuAEIAdP+t/0L+9/5B/V7+vvwQ/rb8C/7l/Cb+/fw2/vz8 >Nf4l/Uz+u/2n/rX+O/+c/8T/5f/w/1b/nf9B/vb+SP1i/vf8Mv5t/Xf+Tv7+/hT/dP9Y/5z/ >A/9q/0r+/P5//YP+8/wv/tn8If47/Vr+7/3G/qn+NP8T/3P/+v5j/2j+Df+k/Zn+DP0//uT8 >J/4m/U7+lP2Q/t79vP7X/bf+hf2G/hX9Qv65/A3+mPz5/b/8Ef4f/Ur+iv2K/rv9pf5+/YL+ >4Pwk/i38uf3D+3r9wPt5/eD7i/28+3b9Mvsk/aP60Py0+tr8uPt0/VL9af6p/jT/+/5k/zb+ >8P79/Db+Jfy1/ST8tP3V/B3+rv2f/jL+7v45/vL++/3N/tj9uP4Z/t/+v/5B/2j/pv+M/7r/ >0f5M/3j9fv5K/Mv9HPyw/Sj9T/7I/kb/4f/u/7j/1v99/hn/GP1G/m784P2y/An+Zf10/tb9 >tv61/aP+Pv1d/ur8K/4K/T7+l/2S/lb+A////mf/Xv+g/1v/nv8G/2v/kv4n/0H+9f42/u/+ >aP4O/7H+Of/0/mH/Kf+B/1H/mP9d/57/Qv+P/yP/ff9L/5T/4//u/68AaAAKAZ4AaQBAAOL+ >Vv85/Vn+YvzY/cX8E/73/cv+Kf+A/8X/3f/Q/+T/qv/N/5X/wf+O/73/eP+v/13/n/91/67/ >2P/o/1QAMwCHAE8AMwAfAHX/rf+i/jD/Av7Q/qb9mv53/X/+Vv1r/h/9Sf6v/Af+8fuW/Q77 >D/1i+qj8RfqX/LD61vwn+x79I/sc/YP6vvy/+Uf8dvkd/Ob5Yfyx+tf8Nfsn/ST7HP2v+tf8 >SfqZ/Cf6h/wr+on8GPp8/O35Y/zw+WX8b/qx/Hf7Tv3O/Bn+I/7l/jL/hf/G/97/x//f/1L/ >mP/K/kj/u/4//3X/rf+9AHEA6QEjAV8CaQEFAjQBUwHJANcAgAC/AHEAwgBzAHcARgC0/9L/ >pv4y/5H9jv6d/Pz93fuL/XD7Sf17+1D9BPyi/b38D/4f/Ur+1fwe/vv7nP0R+xH9l/rH/K36 >1fwS+xL9XPs+/U77Nv3y+v/8f/q6/DX6jvxG+pn8wvrh/JD7Xf1y/OT9IP1L/nL9e/6B/YT+ >mv2T/v39zf6v/jj/gP+0/ywAGgCMAFQAqgBlAJ4AXgCKAFEAdwBIAGwAQABkADwAXQA4AGEA >OQB+AEoAwQBzAB8BrABuAdoAeAHfACkBsQCuAGcAXAA2AGgAPgDCAHMAFgGmABoBqADHAHYA >WgA1ABkADwAgABMAVQAzAJUAWADVAH8AIQGsAHsB4gDMAREB7gEmAc8BEgF9AeMAHwGqANQA >fQC3AG0A3gCDAEkBxADeARwBXAJnAXoCeQEcAkEBcwHdAOgAiQDQAHwAOAG6ANkBGQFHAloB >QAJWAccBDwEWAaUAawBAAOP/7/9r/6f/1/5P/wj+0/4F/Tr+/vuf/S77Iv2x+tn8fPq4/Gv6 >r/xs+q/8gvq7/LT62vzu+vz89/oC/aX60PwF+nH8Z/kU/CH57PtO+QT8pvk5/MP5S/xp+RT8 >wPix+y34WvsU+Ez7nvic+6/5PvwD+wj9RfzI/SD9S/5X/Wz+7Pws/ir8uP2N+1r9bvtJ/cj7 >fv03/MD9VfzS/QP8ov19+1D9FfsU/e36/Pza+vH8pfrQ/D36k/zK+U/8d/ke/Er5Avwo+e77 >//jW+9b4vvu6+K37nfib+074bfu79xb7Hfe3+uD2lPpf9976ffiJ+7X5Qvxg+qn8NPqN/F/5 >Dvxl+Hv7yfce+9D3Ivt0+IP7evkf/ID6uvwc+xj9C/sN/Vf6ovxv+Rn87PjL+zr5+vtQ+p78 >w/t7/Qz9Pv7T/bT+FP7b/vv9zP69/af+gf2D/l79b/5V/Wv+Vf1p/jr9Wv7u/C3+f/zr/Q78 >p/27+3f9d/tO/R/7Gf2j+s/8KfqH/P/5bvxJ+pr81vru/DH7JP3++gb9QfqW/GL5Efzp+Mj7 >HPnn+9v5WPyt+tb8GvsW/ef69/wy+oz8YfkQ/Ob4x/sK+dv70PlS/AX7Cf1c/Nb9lv2R/nv+ >GP/d/lP/n/4v/8/9sv7A/BH+5vuP/ZH7Xf22+3P98vuY/eT7j/14+0796fr6/Ib6vvxp+q38 >dvq1/JT6x/zR+ur8QPsu/cn7f/0T/Kv90fuD/RP7E/1D+pb80flS/Mj5TfzV+VX8rfk9/F/5 >D/xR+Qf8zPlR/Kn60/xk+0L9l/th/Ub7Mf3N+un8d/q2/E/6nvw6+pH8P/qU/JD6xPw9+yv9 >+PuZ/Tv8w/3K+3/9CPsM/bz63/xt+0j93fwi/in+6P54/hf/nf2V/i38uf3++gX9kvrG/Nr6 >8fxn+0T9yft+/dP7hf2b+2T9Vfs6/Tb7J/1f+z/9zPt//Uz8zP2h/P/9ovz//WH82f0t/Lr9 >WvzW/Qf9O/78/c3+x/5F/wD/aP+J/iH/o/2Y/r/8EP41/L79D/yo/Rb8rf0Q/Kf9Avyh/Tr8 >wv36/DT+K/7p/kv/lf/L/+D/df+s/6H+L//r/cP+sf2h/tb9tv7s/cP+p/2b/iH9Sv7B/BH+ >4fwk/nr9gP4v/uv+g/4d/zP+7v5e/W7+cfzh/fb7mf1H/Mr9WP1r/qz+Nv+c/8T/tf/U/wn/ >bf8O/tj+VP1p/iH9S/5d/W7+vf2o/gT+0v4N/tf+w/2s/hn9Rv4p/Lf9Rvsw/eL69fw2+yf9 >CPyk/cH8Ev7i/Cb+X/zY/an7a/1Q+zf9nvtk/WT82/0v/VP+hv2G/jr9Wv52/OX9rftu/Wr7 >Rv0A/J/9UP1o/sX+RP+l/8r/k/+//8T+Rf/R/bT+N/1Y/gz9Pv4Q/UH+Dv0//hH9QP5J/WT+ >v/2o/jL+7f5U/gH/E/7b/q39nf5x/Xv+h/2I/tP9tf4o/uj+Yf4J/2v+D/8m/uf+jv2M/tT8 >Hf5y/OL92fwg/gf+1P5j/6L/GAAPALv/1/+R/iX/W/1t/r78EP7W/B7+Rv1h/pv9lP6d/Zb+ >X/1x/h39Sf4Z/Ub+gv2F/lv+Bf9U/5n/6v/y/67/z/+6/j7/tP2j/mn9df4e/uL+Vf+b/zIA >HQApABgAb/+q/7P+Ov95/hj/t/49/+3+XP+s/jb/8P3G/hn9R/6h/P79yfwX/oz9i/6g/i// >jf+8/9j/6P9M/5X/Nv7v/kf9Yv4r/VH+/P3O/iP/fP/A/9v/W/+e/zL+7f4Q/UD+qvwF/kH9 >X/6T/ib/IAATAHYB3wBKAlwBiwKDAW8CcwFoAm4B4gK3AeUDUQLsBO0CLAUTAz0EhQJyAnUB >swBrANT/5v8BAAEAuQBvADwBuwAcAakAbABAAIj/uf/Y/lD/q/41/x3/ef8ZABAARgHCABYC >PgEgAkMBXgHQAEUAKQBr/6f/Iv98/1X/mv+w/9D/+P/7/yQAFQA6ACIAJwAYAML/2////mf/ >FP7c/mL9cv44/Vn+rv2f/p3+Lf+//9n/ugBvAD0BvAAUAaQAZQA8ALn/1f+p/8z/XgA4AFsB >zgDGAQ4BLgG0APD/9//w/l7/0v5N/1r/nv+p/8z/Fv91/+b9wP4V/UT+ff2D/gb/bP+xAGgA >ZwHWANwAgwCu/8//x/5G/6T+Mv8R/3L/fP+x/3n/sP8A/2j/Uv4A/8P9rP6j/Zf+G/7g/h3/ >eP8xABwApQBjAAIAAQB2/hf/4Pwk/jj8wP3b/CH+Of7y/k3/lf9f/6D/iP4h/4L9hf4R/UL+ >ff2B/oD+G/+E/7b/AQAAALH/0f+x/jn/gP2D/sz8Gf4a/Uf+VP4B/8n/3/+TAFcASAAqAED/ >jv9D/vj+4/2+/gn+1f4x/uz+8v3H/m39eP4L/T/+EP1C/kv9ZP5V/Wn+/fw2/n786v0+/MT9 >dPzl/QP9Of6i/Zj+GP7d/lX+A/9a/gX/Lf7q/uv9w/7V/bX+Hf7i/r3+QP9j/6H/wv/b//L/ >+P9iADoAbwHaAOwCvQEsBHoCjwS2AhwEcgJ4Aw8CTQP3AbQDMwIdBHIC7gNWAhQD1AELAjgB >YAHRACwBswAaAagA4wCHAJgAWwCKAFIA1AB+AB8BqgDgAIQA3v/s/3v+Gf9x/Xv+S/1k/gz+ >1v5A/47/VAAyAO0AjQAEAZoAyQB3AIIATgBkADsAfQBLAK0AZwC4AG4AhgBQADgAIQAdABIA >ZAA8AOkAiwA/Ab4ABgGdAEsALQB+/7P/Iv98/1n/nf/M/+D/9v/7/5z/xf/8/mb/ov4x//P+ >YP/e/+z/6QCLAH0B4gBTAckAkQBWALD/0P8l/33/JP99/5L/v/8nABgAnQBdANMAfQDVAH4A >0wB+AAUBnACPAe0AXQJnASED3AFzAw0CFQPWASUCRgEWAaUAZwA9AFIAMQCzAGoAKwGyAHEB >2gBoAdcAFQGlAIYATwDg/+3/gv+1//f/+v+aAfQAGwRxAoAG3QOdB4gE+gYmBCQFDwNeAwAC >pgKTAQ4D0gHGAz4C4wNQAiMD3gESAjwBhwHpAOkBIwHgArYBngMmAnwDEgJuAnIBBwGcAAsA >BwD8//3/wwB0ANEBFAF4AncBWwJnAaMB+ADZAIEAhwBQANkAggCKAesAEwI7AQkCNgFjAdQA >eABHANf/5//3//r/5ACIADACTgEZA9cBBAPLAfYBKgGqAGUALAAbABoBpwAsA+MBaAU3A84G >CwQHBy4EhwbiAxMGnAMfBqMDnQbvAykHQgR1B28EdwdwBFMHWwQ2B0kESQdVBKwHkARmCP4E >QgmBBcYJzwWDCagFbggCBQ4HMwQzBq8DVAbDAz4HTwQ5COQEjwgXBRUIzgQzB0gEkgbpA6IG >8QNgB2IEcAgEBVYJjQXDCc4FrwnDBWAJkwUvCXYFRgmEBW8JnAU3CXoFVQj0BAAHKgTlBYED >uAVmA58G7wMSCMwEOwl+BY0JrgUVCWcFWAj2BN8HrQTkB7AEUgjyBPQIUwWdCbcFIQoFBlUK >JQYdCgMGjAmtBeIISAVqCAEFOwjlBCgI2gTtB7YEYAdiBJwG7wPtBYYDnQVXA8kFcQNZBsYD >/QYnBFMHWwQUBzUEQwa5A0QFIgOoBMQC2AThAs0FcwMXBzcEHwjUBIwIFQVbCPgExQegBP4G >KAQlBqcDXgUwA+kE6wINBQED2AV7A/wGJwTnB7MEHgjTBI4HfgSfBvAD7AWFA90FfANlBs0D >DQcxBEUHUwTPBg0E7wWHA0MFIANCBSAD4gWAA5MG6QOwBvoDEwacAzYFGQPjBOgCeAVBA5sG >7QNzB20EYQdkBH0G2wN3BUADAAX5AjoFHAO6BWcD9gWLA7wFaQNOBSgDDwUCAy4FFQOKBUsD >3AV7A+wFhQO1BWUDTAUnA+EE5wKqBMYC0QTdAlEFKQPiBX8DHQajA80FdAMmBRADrQTIAtgE >4gK3BWYD2AYSBJEHfwRvB2wEZAbNA88E3AJKA/QBaAJuAYECfQFuAwoCmAS8AjMFGAPFBNcC >hwMZAk0CXgH1ASoBvgKhARMEbAIEBfsC/QT3AjcEgQJ3Aw4CbwMLAkIEiAJ0BT4DUwbCA2AG >ygOLBUwDJQR3ArQCnQHJARABxwEPAa4CmQELBGgCIgUNA1wFMAOiBMECeQMRAqQCkwGqApYB >gwMXAqEEwAJNBScDFQUFAwIEYwKSAocBZAHUAOwAjAA/Ab0AEgI7AfwCxgGmAywC9QNaAvAD >WAKzAzMCVQP7AfYCwwHIAqcB6gK8AVID+QG8AzoC3QNMApIDIAIKA88BmgKMAXcCdgGTAogB >sAKZAZQCiAE3AlEBwwEMAWkB1wBLAcUAaQHWAKYB+wDPARQBsgECATsBvACaAFwANwAiAGkA >QAA2AbkAPgJVAf8CyAE6A+sBFAPUAeUCuAHlArkB/ALGAegCugF/AnwBzwETAQoBnwBkADsA >BQACABAACQCMAFMAPQG8AIkB6gDDAHQAvP5A/xr8rv0R+nn8m/kz/Lj63fxs/OD9dP18/jH9 >Vf4F/KL95vr3/Jn6yvw1+yb9N/zA/fb8Mf4N/T/+ePzm/X77Uv2I+sD8B/pz/EL6lvwq+yD9 >RfzI/eX8J/6e/P79m/tk/Yf6vvwi+oP8rvrW/MX7fP2Z/Pr9hfzv/Xz7UP0M+nb8BfnZ++74 >zPu0+UH8rPrU/BL7Ev2O+sT8e/kf/LH4p/vs+Mv7MPqL/LH7cf1a/NX9kvte/bH5QPzR9yL7 >Bveq+qv3DPsz+fT7mvrK/CD7Gv20+tr85/lg/HH5Gfy5+UT8qfrT/NH7g/22/Av+Dv1A/tn8 >IP5F/Mf9j/tc/e76/PyA+rv8Vfqi/HT6tfzg+vX8jftb/WT83P1G/WH+E/7a/rf+PP8x/4X/ >iP+5/8T/3P/o//H/AQAAABEACgAeABIAGwAQAPL/+P+O/73/6/5b/x3+4P5K/WP+pvwB/mD8 >2P2J/PH9Df0//pr9k/7H/a7+SP1i/iv8uP3q+vr8JfqF/EL6lfwf+xn9Mfy7/d38Iv7l/Cj+ >ivzx/UX8yP11/OT9F/1F/uX9wP6J/iH/y/5H/6H+MP8b/t/+Uf1o/mr83v2X+2D9CfsM/ej6 >+fw++yz99PuX/cr8F/5p/Xb+f/2E/vr8NP4r/Ln9t/t0/Sz8uf2U/Y/+R/+S/1IAMQASAAoA >qP40/+D8Jf6X+2H9N/so/Zv7Y/1T/ND9//w3/mv9d/6F/Yb+Tv1m/u/8Lv7C/BL+Ef1C/tX9 >tv6E/h7/cP4R/2D9cP7n+5D9DfsO/YX7Vv0Z/Uf+zf5J/5D/vf8Q/3D/1f21/sf8F/6N/PP9 >KP1P/iz+6v4o/4D/5f/w/24AQQDmAIkAbwHaABICOwG5Ap8BNgPpAVQD+wH/AsgBYQJpAc8B >FAGMAesAhgHoAGIB0wC+AHEAiP+5/yr+6P4+/Vz+OP1a/gn+1f4h/3v/xP/d/3n/r/9L/v7+ >1/wf/uT7j/0B/J/9LP1R/t/+Vf9iADoAMgG2ADcBugCyAGkA8P/3/xn/d/8x/u3+T/1m/rb8 >DP7A/BH+iv2J/sX+Rf/J/+D///8AAEf/k/8j/uT+XP1u/nv9gP5d/gb/RP+Q/2j/pv+R/ib/ >S/1l/oT87v3T/B3+AP7Q/if/f/9l/6T/f/4b/xL9Qv4Z/K/9P/zE/WX9dP7F/kX/dP+t//v+ >Zv+b/ZP+Gvyu/VH7N/2t+239+Pwy/oX+H/+e/8X/5v/x/4X/uP/j/lf/UP7//s79s/4w/VX+ >aPzc/ar7bP1Y+zr9nvtk/Ur8zP3k/Cb+CP08/q38Bv4h/LL9vft3/av7bP3O+4H98fuX/ev7 >k/20+3L9UPs2/c366Pw3+o/8rPk9/FT5CfxQ+QX8pfk5/DH6i/y8+t78GvsW/T/7K/1B+y79 >Qvsu/VT7Of1s+0b9bPtI/UT7L/38+gX9vvrf/Lf62/wA+wb9k/te/T78xP2t/Ab+kPz0/dL7 >hP3L+uj8J/qG/In6wPwE/KH93P26/un+W/9e/gj/e/zo/XX6tPy4+UT82/rx/D/9Xf6K/7n/ >kABWAAoABgCU/ij/JP1N/nb85v26/A7+pf2a/qL+MP8d/3n/xf5E/7f9o/56/Oj9pPto/XP7 >TP2n+2v9xft9/Yv7Wv0z+yb9L/sk/cn7ff3U/B7+4v29/oT+Hv+S/ib/F/7e/kD9Xf5S/NH9 >uvt1/eH7jf3a/CH+OP7x/kb/kv+K/7r/IP97/53+Lf97/hj/rv44/8T+RP9s/g//0v20/nr9 >gP7H/a3+m/4s/3X/rv/X/+j/kv+//9P+Tf/2/cr+Zf1z/nf9fv4//vX+Xv+f/x8AFADr//P/ >zP5J/479jP4t/VL+EP7Z/qv/zv/vAI4AGwGoAC0AGwDC/kL/e/2A/qz8Bf5o/N79sfwI/mn9 >dv44/vH+j/4k/xr+3/4p/VD+lfz4/Q79QP50/hT/1//n/0UAKQCZ/8P/jP4j/w3+2P5m/gz/ >Fv91/1r/nf/h/lX/Dv7Y/pP9jv7n/b/+Af9o/3UARQC8AQgBagJwAVcCZAGrAf0A0gB9AE8A >LwBpAD8A+wCWAIwB6wCpAfwAMAG1AFkANQB+/7L/6/5a/8j+Rv8a/3j/uP/U/z4AJQBAACYA >i/+6/3P+FP+g/Zb+nf2V/mb+Df9b/57/vf/Y/0H/jv8+/vT+X/1v/ir9UP7E/az+8P5f/0wA >LQBwAdsABwI1Ad8BHQEJAZ0A3//s/9v+Uv9f/gj/iv4h/zr/i/8zAB4AKgGxANkBGgERAjoB >xgEOATABtQCqAGUAewBJAKQAYgDqAIsAAgGZAMoAeABVADQA4//v/7X/0//3//r/oQBgAF8B >0gCoAfsADQGgALD/0f9P/v/+1f23/rD+OP9hADoA4QEeAVQCYwGvAQEBlABYALj/1f9r/6j/ >hf+4/8v/4f8gABMAdABFAJcAWgBDACgAb/+q/3j+F//k/b/+5P2+/h7+4v4E/tL+Y/1z/rH8 >CP6b/Pv9b/15/rf+PP+e/8b/kP++/6/+OP+3/aT+bv15/ij+6P6Q/77/4ACGAFMByQCNAFQA >5f5Y/z39W/6A/Oz9IP1K/r3+P/92AEYAeQHhAHQB3ACfAF4Acv+s/1X+A/+Q/Y3+Xv1v/uL9 >vf79/mb/QQAmAB4BqgBKAcQA4QCFAEkALADl//D/3P/q/zEAHgDcAIIAuwEHAXYCdwGcAo0B >+gEuAfQAkQBRADAApwBjANMBFgEXA9YBywNBAu0DVQIVBG0CywTZAvMFiQPmBhoEFAc1BH4G >3QOnBVsDAAX6ApYEugIkBHYCfQMTArQCmwH5ASwBXgHQAMwAeQBBACcA7P/0//j/+/9ZADUA >ywB4ABkBqABhAdIA4wEeAZwCjQEZA9cBzgKrAacB/QA/ACYAZv+k/33/sv8qABoAvABwAMgA >dwBuAEEADQAIANr/6v+//9n/r//Q/+f/8v/MAHkAeAJ4AXQEpwL2BYwDaQbPA9wFfAPqBOwC >TQSPAm4EowI7BRwDSAa7AwQHKwT/BikEIQakA8ME1QKTAyACHQPaAV8DAQK7AzgCagMIAiYC >RgF1AEQAU/+Z/3T/rP/AAHIAbAJwAYsDGwKdAyYCswKbATIBtQCN/7v/Nf7u/pH9jf7x/cb+ >Qv+P/+kAiwDvAScBnAH2AAkABQAu/uv+Xf1u/mL+Cf/1AJEA5wNSAuMFgAM3BrIDRQUiAyIE >dALsA1UCEwUEAxEHNATCCDUFAAlaBVkHXwRXBJQCNwG4AD7/jf/+/mb/CgAGAEsBxADCAQwB >LgG0ABUADABG/5L/PP+L/83/4f9zAEQAwwB0ALgAbgCbAFwAqABkAN8AhAAOAaEAEQGiAOMA >hwCYAFsAPAAkANf/6P92/67/Nv+J/zT/hv9b/53/fP+y/2f/pf8f/3r/3/5U/+f+Wv9J/5P/ >z//i/xwAEQD1//n/Xf+f/6D+Lv8p/uj+Q/73/uH+Vv+c/8T/5v/w/3j/rv+R/iX/4/2+/hH+ >2v4f/3r/UAAwAJ8AXwCB/7X/X/1v/lr7PP2O+sT8Y/tD/Vr9bf6C/7X/BQGbAJIB8ABMAcYA >iwBTAKP/yf/R/kz/Lf7q/rP9of5B/V7+tvwL/hz8sP2++3j98PuV/cr8F/71/cn+0P5L/+D+ >Vf86/vL+ff2B/mn9dv5L/vz+v//Z/+8AjgAsAbMAZgA8ACf/f/8w/u3+Av7Q/qH+MP+2/9T/ >wAByAEUBwgD4AJMA2f/p/13+CP9G/WL+OP1Y/jX+7/57/7H/AQABAEX/kf/O/bH+0Pwb/j79 >Xf74/mL/2QCCAKUB+gDwAI4Ab/+q/1f+A/9l/gv/av+m/3sASACrAGUAqP/M/9r9uf4l/Lb9 >bftH/SD8sv0D/tL+SwAsAPsBLQGCAn4B+AEsAQgBnQBmAD0AWAA0AJcAWgCmAGMAPQAlAHz/ >sv/P/kv/rP42/0//lv+VAFgA8wEpAacClAEiAkUBhABOALP+Ov/a/bn+iv4i/y0AGwBtAdkA >QgHAANb/5/9l/gz/Kf7o/kT/kf+uAGcAIAGrADoAIwDQ/kv/IP7i/tD+S/9uAEEA3AEaATEC >TgFKAcQAwv/b/3f+F/8c/uH+4/5W/2kAPgDcARsBZAJsAa0B/wAyAB0A//5n//L+YP8RAAoA >gQHlADQCTwG6AQcBggBOAHL/q/8m/3//nv/G/2cAPQANAaAAWgHNAEcBwgDYAIEAFAANAB7/ >ev9D/vf+1v22/vv9zf6U/if/U/+Z/+3/9P8gABMAzv/j/wf/bP8c/uD+kf2N/tf9uP76/mP/ >eABHAJMB8ADIAQ8BHQGpABQADQBO/5b/K/+C/6f/zP9wAEMAEgGkACoBsACGAFAAUv+Z/wr+ >1f5M/WT+f/2D/qL+MP9HACoA1QEXAdACrQH1AsIBSgJdARoBqADy//j/Y/+i/7X/0/+fAF4A >ZQHUAGIB0wCAAEsAUP+Y/5n+Kv+7/j//cf+r/yQAFgBqAD4ARQAqAAAAAADc/+v/8//4/0sA >LADoAIkArgEAAU0CXwFWAmMBlAHxAGEAOQBq/6f/Pv+N/9j/6P+yAGoAQwG/AGgB1wBiAdMA >bwHaAIIB5QBoAdYAIQGrAPsAlgBRAcgAHAJCAd4CtQEFA80BcQJ0AZMB8AAXAaYAVwHLAB8C >QwHnAroBPwPvARAD0QGKAoMB+QEsAZAB7gBnAdUAegHhAKoB/QC9AQkBiAHoAA8BoQCIAFEA >NwAgADYAIABoAD0AjgBVAIcAUQBbADYAKwAZAAkABQD1//n/5v/x/9v/6v/j/+7/+v/8/xcA >DQAoABgAOAAiAF4AOACqAGUADwGhAGwB2ACfAfcAnwH3AH0B4gBYAcwAUQHIAJAB7gAqAkkB >CwPPAdcDSQIDBGMCKwPiAXYB3gCq/83/zP5J/3H/q/9FAcIAKAPgAeQDTwLzAsEB2QCBAML+ >Qv++/an+K/7p/qL/x/9ZAc0AoQKQASgD4QHzAsEBOAJRAU4BxgCZAFwAbQBBANcAgACJAeoA >9gErAbABAQG+AHEAq//O/yv/gf+p/8z//QCWAHcCdwFOA/cBBgPMAcMBCwE8ACQAX/+h/9T/ >5v+cAfQADwRqAjcGswNRB1oEIwc+BAYGlAOZBLwChQMYAjMD6AHBAzsC1wThArUFZAN9BUMD >zQNCAi0BtAD+/mb/lv4p/0cAKQD0AsEByATYAnwEqgJCAlcBlf/A/xX+3P5z/hT/GAAOAMAB >CgFkAmwBwQELAUkALAC//kL/1P21/uH9vP7V/k//KwAaACUBrgBDAb8AoABeAOn/8v/e/+z/ >sABpANgBGAF8AnoBGgJBAecAiQCT/7//tf47/2f+DP9Y/gT/M/7t/vb9yv71/cn+h/4g/7H/ >0f8PAaEABQI0ASACQgFPAcgA/P/+/8X+RP8l/ub+Pv70/tX+Tv+P/77/KwAZAJEAVwC1AGwA >ewBJAM//4v/b/lL/Jv7m/kr+/P6B/7X/SwHFAJcCiwF5AngB3wCEAMT+RP+S/Y7+If7j/g8A >CgD+AS8BigKCAVMByQA+/43/wP2q/tD9s/5F/5D/LwG0ALkCnwHCAzwCrwTKAsgFcAO1Bv0D >vwYEBIAFRQNbA/8BQQG/AA8ACQAHAAQA5QCIAEACVwHEAz0CCAX+AmUFNQNDBIkCrwEAAb/+ >QP8a/Ub+1P22/ogAUQBuAwoCigSzAg4D0QHc/+v/6Pwo/uP7j/03/Vj+6//z/1kCZQE1A+kB >QQJXAVgANQDf/lX/3v5U/18AOQBiAmoBjAMcAhYD1QFQAcgAYP+i/2P+Cv+x/jn/wv/b/64A >ZwDTAH0AJAAVAAP/av/r/cP+Sv1k/nP9e/56/hj/CwAHAFsBzgCCAeUALAAaAP79z/5Q/M/9 >L/y7/YD9g/75/mT/If97/4r9iv5I+zL9HfqA/Bv7Fv3B/av+ZgA9AH8B4wC9AHAAF/92/9b9 >tv6R/Y7+BP7S/pb+Kf8J/23/kf++/0sALADXAIAAkgBWAEv/lP+1/aL+8/ww/qr9nf5N/5b/ >gQBMADIAHgCX/in/B/08/u38LP6Y/ir/8QCOAEMCWAGIAekAG/94/3/86/1j+0H9kvz2/Yn/ >uf+8AqABZgSeAoQDFwJqAD8ArPwG/kr6m/yD+r38Cf09/jMAHgAHAjUBkgHvAHb/rf9Y/Wv+ >qvwE/qr9nP5l/6T/jgBTAGcAPQA4/4j/6v3C/mP9cf4B/tH+iP+5/0EBvwBOAl8BEgI6AYIA >TABd/gb/0fwb/sn8F/5G/vr+VQAzAMwBEQEqAkoB4wEfAdIBFAFWAmQB7wK/AcICpAF0AdwA >n//G/1r+Bv9Q/gD/Nv+I/xwAEAA8ACQAlP+//8n+Rv+N/iX/Hf95/xsAEADsAI0AHQGqAJ0A >XQDB/9r/DP9v//D+X/+D/7b/ZgA9APwAlgDWAH8ADAAIAC3/gv/H/kf/9P5h/07/l/9k/6P/ >Jf9//wD/aP9o/6X/XQA3AF8B0QDZARkBoAH3AAgBnQCFAE8ALgAbAL7/2P/v/l7/8v3I/mf9 >dP7y/cb+o//I/8wBEQFbA/8BhAMYAjwCVQFFACoAwP5C/4P+Hf+j/8n/ZQHUALwCoQH6AsYB >PQJVAU4BxwD9AJcAeAHgADkCUwGKAoIBLwJNAZsB9ABzAdwA4wEeAXMCdQGBAn4B4wEfARoB >qADYAIAAUwHJACQCRwG3Ap0B1QKuAcICpAHPAqsB7AK9AdACrAFyAnQBVwJkASwD4wEDBfsC >AgcrBPIHuQQ8B0wEfAVCAwsEZwLmA1IC6gTsAhAGmwNTBsMDgQVHA0gEjAKLAxsCrQMwAmoE >oAIfBQwDUAUqA/EE8AJUBJQC6wNWAvQDWgJSBJICmgS8Al4EmAJ/AxQCXgJpAZ4B9wCzAQMB >ggJ/AXsDEQIDBGMC7ANVAocDGAJHA/IBaQMHAsoDQQIiBHUCPwSGAhgEbgK8AzgCPwPuAbsC >oAFlAm4BeQJ4AQIDyQGrAy4C2gNKAgcDzQEpAbEA0v5N//P8L/5f/Nf9Vv1r/mD/of97AeEA >pQKTAVgCZQHSAHwA5/5Z/3z9gf79/Db+Ov1Z/rP9ov4P/tj+Xf4H/9r+Uf+H/7n//////8f/ >3f/Y/lD/zP2x/n79gv5I/vv+qP/M/4QATwAOAAgAaf4O/5/8/v3t+5X92fwg/uj+Wv/8AJYA >EAI6AcoBEQGWAFgARP+Q/5T+J//e/lX//P/+/2wB2ACiApABVwP8AZ0DJgLKA0ECIARzApwE >vgIBBfoCHgUKAxMFBQM2BRkDxgVvA5wG7QMvB0UEBQctBCkGqgM5BRsDDQUCAx8GpAMWCM8E >8wnrBZ4KUAalCbwFgQd1BFYFLANGBIoCwQTUAlUGwwMACMEE3QhFBacIJAXHB6AE/AYmBM0G >CwRAB1AE1wepBO4HtwQyB0cE6gWEA+oE7AIUBQQDqwb3A/8IWQW2Cl4GtwpfBg0JYgX9BigE >JgaoA0cHVASiCbsFigvcBq4L8gYXCgAGBwjGBPQGIgRzB24E9AhTBU8KIQagClIGwgnNBSUI >1wR+Bt0DZgU2Ay8FFQPPBXMD4AYWBNEHpQQ6COQEEwjMBLsHmASUB4IEvQeaBAEIwwQnCNoE >HgjTBOgHtARoB2cEZwbOA/cE8wK+AzkCvgM6AooFTAOPCBcFLwumBskLAgfuCecFuwYBBBUE >bQJZA/0BjQS1ApMG6QMRCMwERQjrBD0HTgSVBVEDHgRyAocDGQI0BIAC8wWKA/AHuAQLCWAF >kAgXBcwGCwT8BPYCcASkApMFUQOOB34E6AhMBaYIJQX/BikEKAURA1oElgLpBOsCKAapAwEH >KwTjBhgEHQaiA4UFSAO6BWgDpwb1A5wHhwTnB7MEXwdjBHcG1wPWBXgD6QWDA5YG6gNvB2sE >7we3BMcHoATwBiIEtgVlA5YEugIcBHECjgS1ArEFYgPcBhUEVQdcBMoGCgSQBU4DWwSXAtgD >SQJCBIgCVQUrA3kG2QMYBzgE2AYSBN8FfgPFBNcCPwSGAowEtQIgBQwD9wT0AosDGwJ7AeEA >RgAqABIBowCLAxwC9wWMA5QG6QMNBQEDwgKkAYgB6QAXAj4BnQMmAqsExgKWBLoC2ANKAlMD >+gFAA+4BBwPMAf8BLwFLACwA4v5V/8X+RP8gABQAJgJHAZMDIQKBAxUCzQESASP/fP+w/Aj+ >l/th/WP82f2b/iv//ACVADQCTwHWARcBjgBUAJz/xf/L/+H/7wCOADQCTwHYArEBtQKcARwC >QQFpAdcAsgBqAOL/7/8A/2f/UP7+/jj+8f4F/2r/sABpALcCngFHBIwClwS7AmQDBAI9AbwA >Of+J/0z+/P61/jv/+P/7/08ByAAjAkUBLQJLAWoB2AAlABcACP9t/+v+XP8uABwAJwJIAXAD >CwIQA9IBfwHlAFoANQDOAHoASgJcAeoCvAFoAdYAsv45/1D9Z/4L/2//CgPPAVEGwQNdBskD >SwP2AZr/w//l/cD+1v5O/xkBpwD/AsgB4QNOAg0EaALJA0EC3QKzASYBrwBi/6P/7f5d/3cA >RgAmA98BDAUBA70E0AJzAnQBxf/d/1T+Av+j/jD/HAAQAMUBDQHjArcBHgPaAVsCZgHJAHgA >FP9z/yf+5v6k/jH/TgAuACwCSwE8A+sBLQPjAXsCegHWARcBjQHsAHQB3QA6AbsA1wCAAIsA >UwCUAFcA3gCEAA8BoQDDAHQA8v/3/wj/bP+z/jv/ZP+j/+sAjAB+AnsBPgPuAdsCswHTARUB >AAGYAOkAiwBZAcwAogH4AEABvgBQAC8AZ/+k/yT/fv/Q/+T/PgG9AOQCuAHwA1cClAMhAoIB >5gBo/g7/zvuA/SD7Gv2h/P/9DP9u/4MATwACAAEAEv7a/i/8u/1u+0n9tPtz/SP8tP0b/LD9 >z/uC/dj7h/1m/Nz9/Pw1/uP8Jv7o+5H9hvq//IT5JfxW+Qr89Plo/AD7B/38+539afzd/eH7 >jf1p+qz8nPib+4f39vr09zj71vlV/DP8vv3c/br+Nf7w/oH9hf5x/OH9gftT/bv63vzw+Wb8 >Gfnl+4L4jPuP+JP7ZvkT/NT67fxq/N39sv2h/mL+Cv96/hj/NP7v/vn9y/4b/uD+mv4q/wz/ >b//e/lP/vv2o/ur7kv0q+of8VvkK/M75Ufw3+yf9oPz+/SD9S/5g/Nn9wvri/Af52/vS9yL7 >VPfY+m/36PoJ+EP7Ifnq+5X6yPzc+4n9Ivy0/fj6Av3T+Lz77vac+mT2SfpB98z6bPh/+5L4 >lfs+98z6RPWe+QD03vg/9AP5svXf+VX32fpe+Hf7ufit+9P4vPsK+d37UvkH/Gb5Evwb+eb7 >lfiW+xv4Tvvi9yz79vc4+0n4avvK+Lf7V/kK/L35RvzN+VH8kvku/EX5APwo+e/7TvkE/Ib5 >J/yQ+Sz8TfkE/NP4vPtY+HP7HfhP+1/4d/tL+QP8zPro/GD82f0q/VD+ePzn/Wv6r/wZ+Ez7 >8Pad+rb3Evvb+Vn84PuM/W384P1R+zf9lvkw/K34pftV+Qn8Nvsn/T79Xf5z/hT/ev4Y/5/9 >lf6H/PD91vuG/f/7n/0l/U7+Ev9y/zoBuwDxAr8BtQM1AmEDAgIoAkgBeQBIAOf+Wf8V/tz+ >jv4j/1cANACzApoBVASSAiAEdAIHAjUBJv9+/wH9OP5o/N395Pwm/kL9YP66/A7+i/tZ/bX6 >2vzt+vz8+fuc/dn8If62/Av+kPtc/SX6hfxO+QX8WfkM/Pv5a/yt+tX8F/sV/SL7HP3W+u78 >RfqX/Jf5MPwZ+eb7J/nu+/X5Z/xn+0T9Iv1L/rD+OP+u/8//6P/y/3D/qv+w/jj/Wv4E/wD/ >aP+XAFoAQwJYAcoCqQF4AeAAvf5B/wD8oP2o+tP8FvsU/XL84/1h/XH+Gf1G/uP7jf3H+uX8 >q/rT/K/7cP1G/WH+pP4y/zz/jP/Z/lH/jf2L/qb7af23+UP8j/iT+8v4t/ti+qr8dPzl/bL9 >of5A/V3+X/tA/Vn5C/yo+KL77/lk/Hb85f2n/jP/GP93/5L9j/41+yb9rfk9/Aj6c/zs+5P9 >5P3A/nf+Fv9E/WD+Rfsx/QT6cfxh+qj87fuV/Uj9Yv40/Vb+f/tT/Rn55ftf99/6OvfJ+qX4 >oPvj+vb89fwx/gr+1v7B/ar+Nvy//Q36dvw2+F/7lff++nr4h/tv+rH8cPzi/X/9gv5G/WH+ >SfzK/Xj7T/2S+179i/zy/Zv9k/6+/aj+ifzx/ZH6xfwn+e37c/ka/Jb7YP15/hf/iQBRAN0A >hADe/+z/3v5T/wr/bf98AEoANAJQAf0CxwFdAmcB2wCBAHX/rf/J/kf/tf47/5v+K/8A/s/+ >7vws/t/7i/1X+zv9j/tc/Vj80/1Q/Wb+Gf7d/oD+HP+C/h7/Nv7v/rD
Reply by ●January 22, 20152015-01-22
On Wed, 21 Jan 2015 09:52:00 -0800 (PST), radams2000@gmail.com wrote:>This effect is the basis for bass extension algorithms where you create har= >monics to get fake bass from small speakers. But my experience is that it d= >oesn't work so well. What happens when the input signal is not a solo instr= >ument with a periodic waveform? Then it just makes a mess of things. Commer= >cial bass-boost algorithms combine harmonic generation with old-fashioned d= >ynamic bass boost to handle the non-harmonic cases like a kick drum. But th= >ey don't mention this in their advertising.=20 > >Regarding the mechanism for how the ear perceives the missing fundamental, = >I don't believe that there is any explicit autocorrelation mechanism. A mor= >e likely explanation is the modulation of the envelope of the signal which = >will occur at the fundamental frequency even if the fundamental is not pres= >ent.=20I've long suspected this was the explanation. When you look at a "missing fundamental" waveform on a scope, the periodicity at the (missing) fundamental is very obvious. With 0-phase harmonics you see one cycle of a big sinusoid (of roughly the highest component frequency) which repeats at the missing fundamental frequency. Between those peaks are lower-level ripples. All it would take is a nonlinearity in the ear to convert the "missing" fundamental into a real tone. However, when I mentioned this to some of the guys in the hearing research lab where I used to work, they assured me that others had investigated this and ruled it out. I don't recall the exact experiment, but I *think* it was something like an attempt to cancel the "missing" fundamental with an out-of-phase sine wave. I do recall that I was never really convinced. As Tim mentions, the ear deconstructs the incoming sound to component frequencies via the equivalent (for this discussion anyway) of a bank of filters. Each filter's output is a pulse train of neural spikes at a rate proportional to the amplitude of its "characteristic frequency". The pulse rate is very low, typically a few hundred Hz. An important point, which many folks have a hard time keeping in mind, is that in general there is no real "frequency content" in neural firing rates...they encode *amplitude* of their characteristic frequency. The system encodes audio frequency by the position of the active fibers across the whole set, not the signal on any single fiber. (Just like bank of filters with rectified-and-filtered outputs, each feeding a VCO whose pulse rate varies with amplitude.) However, even though the pulses can't follow the characteristic frequency, they tend to synchronize to it such that the neuron is more likely to fire on a peak of the component when it does fire, after which it may remain in a "refactory" state for multiple cycles until it fires again. This is all statistical, not a hard lock, but it is very clear in a time histogram of spike firings. The parallel bundle of neurons, each carrying its own spike train for its own characteristic frequency, then proceed out to the cochlear nucleus and on up to higher brain centers. Any sort of correlation (or envelope detection) would then have to be performed by summation of spike trains from multiple neurons onto an intermediate neuron, again all statistical... if enough spikes arrive within a small-enough time window such that their (weighted) sum exceeds the firing threshold for that neuron, then it fires. The cochlear nucleus contains lots of intermediate neurons doing all sorts of combination tricks as a preliminary stage of auditory processing, before handing things off to the higher brain centers. There may be simple ways to recover a missing fundamental that could be done right there. I've failed to keep up with the field, however, so I don't know the current thinking. Bob Masta DAQARTA v7.60 Data AcQuisition And Real-Time Analysis www.daqarta.com Scope, Spectrum, Spectrogram, Sound Level Meter Frequency Counter, Pitch Track, Pitch-to-MIDI FREE Signal Generator, DaqMusiq generator Science with your sound card!
On 1/22/2015 8:42 AM, AllenDowney wrote:> This is an interesting, and annoying, noise! I will pass this along as an > option for the students to explore and let you know if we find anything > useful. > > Thanks for all the comments on this thread -- there is a lot of good > stuff! > > Allen >Professor Downey: I will post something like a 1-minute, 4-minute and the full audio in some Internet file service (DropBox, etc.) For those who are not aware: you can take a file with human voice plus noise and use several packages which *attempt* to repair (denoise) it. The obvious solution is to remove *stuff* from it. That process is not unlike that performed by a cancer surgeon: what exactly to remove and what to leave in?? The problem is that of false positives and false negatives: (a) Sometimes you (and/or the software app) are not aggressive enough. Too much of the noise remains, but at least the human sounds like a human. (b) Sometimes you go overboard. All the noise is removed and then some! The person's voice sounds unnatural. This sound is variously known as "wine glass" or "metallic bubbles". See my thread: "The 3 Interactive Ways to Perform Noise Reduction/Removal" in this NG. A 4th. way was discovered. Thanks again for helping me capture my "Moby Dick". -Ramon "Captain Ahab" Herrera http://en.wikipedia.org/wiki/Captain_Ahab_%28Moby-Dick%29
