Jerry Avins wrote:> The first digital > communications systems I know much about were Napoleon's wig-wag > telegraph with left and right standing for one and zero, and Amerindian > smoke signals, which were made by moving a blanket ON and OFF.American Sign Language is digital too, but I don't know when it was developed. ;-) -- Jim Thomas Principal Applications Engineer Bittware, Inc jthomas@bittware.com http://www.bittware.com (703) 779-7770 Unix IS user friendly. It's just more particular about its friends.
Digital modulation!!
Started by ●July 7, 2003
Reply by ●July 11, 20032003-07-11
"Jim Thomas" <jthomas@bittware.com> wrote in message news:3F0EC1FB.27935F43@bittware.com...> Jerry Avins wrote: > > The first digital > > communications systems I know much about were Napoleon's wig-wag > > telegraph with left and right standing for one and zero, and Amerindian > > smoke signals, which were made by moving a blanket ON and OFF. > > American Sign Language is digital too, but I don't know when it was > developed.Hello Jim, Is this meant to be a bad pun? Fingers are also known as digits. Clay> > ;-) > > -- > Jim Thomas Principal Applications Engineer Bittware, Inc > jthomas@bittware.com http://www.bittware.com (703) 779-7770 > Unix IS user friendly. It's just more particular about its friends.
"Clay S. Turner" wrote:> > "Jim Thomas" <jthomas@bittware.com> wrote in message > news:3F0EC1FB.27935F43@bittware.com... > > Jerry Avins wrote: > > > The first digital > > > communications systems I know much about were Napoleon's wig-wag > > > telegraph with left and right standing for one and zero, and Amerindian > > > smoke signals, which were made by moving a blanket ON and OFF. > > > > American Sign Language is digital too, but I don't know when it was > > developed. > > Hello Jim, > Is this meant to be a bad pun? Fingers are also known as digits. >Waddya mean? I thought it was a good pun. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
kbc32@yahoo.com (kbc) wrote in message news:<a382521e.0307102249.19a25f3f@posting.google.com>...> There are only 2 defining notions for digital modulation > 1) the notion of a symbol > 2) a finite-set of waveforms , each typically of same ( symbol ) duration. > > We sent symbol after symbol. Each symbol takes a 'value' from the > finite-set. > > The elements in the set should be as far away from each other by > some criteria. > > (We are now operating in a finite-dimensional vector space. This > helps.) > > Until sampling theorem came, this was useful only for discrete sources > of info. > > Dont confuse this with any discrete-time processing that u may do ( but > that is also being possible due to sampling theorem. )No, I am not confused. But sometimes I have to try to not confuse my students and readers. Thanks for your advise, :-) Ying
Jerry Avins wrote:> > "Clay S. Turner" wrote: > > > > "Jim Thomas" <jthomas@bittware.com> wrote in message > > > American Sign Language is digital too, but I don't know when it was > > > developed. > > > > Hello Jim, > > Is this meant to be a bad pun? Fingers are also known as digits. > > > Waddya mean? I thought it was a good pun.Rats! It was supposed to be a BAD pun! -- Jim Thomas Principal Applications Engineer Bittware, Inc jthomas@bittware.com http://www.bittware.com (703) 779-7770 Unix IS user friendly. It's just more particular about its friends.
On Wed, 09 Jul 2003 12:12:52 -0500, "Dilip V. Sarwate" <sarwate@uiuc.edu> wrote:>Digital modulation is described in the New Testament (Matthew 5:37) >which >specifically recommends binary signaling (instead of M-ary signaling >with M > 2), >and coding with a (2, 1, d = 2) block code, presumably for error >detection. The >verse in question says (in the King James Version) > > "But let your communication be, Yea, yea; Nay, nay: for whatsoever >is more > than these cometh of evil." > >and is part of the Sermon on the Mount....The thing I've always liked about this is that it not only specifies binary communication but also a half-rate repetition code. That was probably state-of-the-art at the time, though... Eric Jacobsen Minister of Algorithms, Intel Corp. My opinions may not be Intel's opinions. http://www.ericjacobsen.org
kbc wrote:>...> > There are only 2 defining notions for digital modulation > 1) the notion of a symbol > 2) a finite-set of waveforms , each typically of same ( symbol ) duration. > > We sent symbol after symbol. Each symbol takes a 'value' from the > finite-set. > > The elements in the set should be as far away from each other by > some criteria. > > (We are now operating in a finite-dimensional vector space. This > helps.) > > Until sampling theorem came, this was useful only for discrete sources > of info. >Don't bet on it. The ships Columbus sailed in had lines specified by a sparse set of points, interpolated with a limber batten. Shipwrights today do the same. Don't let tunnel vision blind you to the wider world. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●July 12, 20032003-07-12
Jerry Avins <jya@ieee.org> wrote in message news:<3F0F0061.C46BE5BC@ieee.org>...> > > > Until sampling theorem came, this was useful only for discrete sources > > of info. > > > Don't bet on it. The ships Columbus sailed in had lines specified by a > sparse set of points, interpolated with a limber batten. Shipwrights > today do the same. Don't let tunnel vision blind you to the wider world. > > JerryAnd sure they would have realised that the points should be reasonably close together for this to work. They were applying the sampling theorem.
kbc wrote:> > Jerry Avins <jya@ieee.org> wrote in message news:<3F0F0061.C46BE5BC@ieee.org>... > > > > > > > Until sampling theorem came, this was useful only for discrete sources > > > of info. > > > > > Don't bet on it. The ships Columbus sailed in had lines specified by a > > sparse set of points, interpolated with a limber batten. Shipwrights > > today do the same. Don't let tunnel vision blind you to the wider world. > > > > Jerry > > And sure they would have realised that the points should be reasonably > close together for this to work. > > They were applying the sampling theorem.They used samples, but they weren't "applying the sampling theorem". It hadn't yet been explicated, and they hadn't the tools to understand it. They didn't understand even algebra. Nevertheless, they built ships. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●July 14, 20032003-07-14
"Jerry Avins" <jya@ieee.org> wrote in message news:3F0C664D.4A5AFAEE@ieee.org... <snip>> You think maybe Dilip holds a copyright? There's a fellow out therewho> uses my sig, but he puts it in quotes. That's enough attribution tomake> me content. (Actually, I'm flattered.) > > Jerry > -- > Engineering is the art of making what you want from things you canget.>���������������������������������������������������������������������� � I've not used your quote as a .sig, but I have quoted it (with attribution) as I think it is absolutely spot on. Regards Ian
