shankar wrote:> Actually, I also wish to have a magic wand to make everybody > behave as I want them to. :=)The nice thing about newsgroups is that I needn't respond to those who irk me. It's nearly as good as a magic wand. ...> > The statement "linear phase" is equivalent to saying that all tones > suffer equal delay. ( A zero-slope line phase plot will distort, > unless the value of the const phase is -180 degrees. )"Linear phase" means more than that. It means that the phase vs. frequency plot passes through the origin. Constant phase velocity implies only that an extension of it over the band of interest do so.> > Now , consider the cascade of 2 Hilbert filters, mentioned originally. > > Input is f(t). Output is -f(t-p). p is the delay. > What would be p ?Whatever delay makes the HTs causal. Nothing more.> > shankarJerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
180 degree phase shift
Started by ●July 6, 2003
Reply by ●July 8, 20032003-07-08
Jerry Avins <jya@ieee.org> wrote in message news:<3F0AEF55.6F4E7AA4@ieee.org>...> shankar wrote: > > > Actually, I also wish to have a magic wand to make everybody > > behave as I want them to. :=) > > The nice thing about newsgroups is that I needn't respond to those who > irk me. It's nearly as good as a magic wand. > ... > > > > The statement "linear phase" is equivalent to saying that all tones > > suffer equal delay. ( A zero-slope line phase plot will distort, > > unless the value of the const phase is -180 degrees. ) > > "Linear phase" means more than that. It means that the phase vs. > frequency plot passes through the origin. Constant phase velocity > implies only that an extension of it over the band of interest do so. > >Hi Jerry, Is there any specific reason why it should pass through origin! From pure mathematical view phase function is a function of frequency (Angular frequency) so if it forms like y=mx+c where x is angular frequency and c is initial phase offset then it needs not pass through origin and yet can keep it linear. dy/dx i.e group delay also remain constant over all frequency - Am I missing something in your point. Regards, Santosh> > Now , consider the cascade of 2 Hilbert filters, mentioned originally. > > > > Input is f(t). Output is -f(t-p). p is the delay. > > What would be p ? > > Whatever delay makes the HTs causal. Nothing more. > > > > shankar > > Jerry
santosh nath wrote:> > Jerry Avins <jya@ieee.org> wrote in message news:<3F0AEF55.6F4E7AA4@ieee.org>... > > shankar wrote: > > > > > Actually, I also wish to have a magic wand to make everybody > > > behave as I want them to. :=) > > > > The nice thing about newsgroups is that I needn't respond to those who > > irk me. It's nearly as good as a magic wand. > > ... > > > > > > The statement "linear phase" is equivalent to saying that all tones > > > suffer equal delay. ( A zero-slope line phase plot will distort, > > > unless the value of the const phase is -180 degrees. ) > > > > "Linear phase" means more than that. It means that the phase vs. > > frequency plot passes through the origin. Constant phase velocity > > implies only that an extension of it over the band of interest do so. > > > > > Hi Jerry, > Is there any specific reason why it should pass through origin! > From pure mathematical view phase function is a function of frequency > (Angular frequency) so if it forms like y=mx+c where x is angular > frequency > and c is initial phase offset then it needs not pass through origin > and yet can keep it linear. > > dy/dx i.e group delay also remain constant over all frequency - Am I > missing > something in your point. > > Regards, > Santosh > > > > Now , consider the cascade of 2 Hilbert filters, mentioned originally. > > > > > > Input is f(t). Output is -f(t-p). p is the delay. > > > What would be p ? > > > > Whatever delay makes the HTs causal. Nothing more. > > > > > > shankar > > > > JerryAs before, that depends on what you mean by distortion. Constant phase velocity over a band preserves the shape of pulses all of whose components lie within the band. If the pulse is riding on a carrier and the projected slope doesn't go through the origin, the demodulated pulse will be undistorted but the phase of the carrier relative to the edges of the pulse will be constantly changing. "Linear phase" implies constancy down to DC (high-pass filters excepted). As for y=mx+c, what happens when m is zero but c finite? That's constant slope too. You claim that distorts. Again, what do you mean by distortion? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
"shankar" <shankar.news.invalid@web2news.net> wrote in message news:<48992N476@web2news.com>...> To emphasize, the -180 degree system is not distorting, > eventhough each tone suffers a different delay. > > (Otherwise , u have to interpret multiplication by a > negative scalar as "distortion". )I think this is a philisophically debatable point. You can represent the multiplication by a negative scalar as the transfer function, G(jw) = -1 = exp(-jPI) = exp(jPI) This is a transfer function that is continuous and does not pass through the origin (ie. not linear phase). The case of 2 Hilbert transforms taken in series in not a continuous phase response since it has a discontinuity at the origin, and for practically realizable systems will pass through the origin. On that basis I would argue that that two Hilbert transforms in series is not equivalent to negation. Perhaps only for the ideal case and then you have to figure out what influence the discontinuity at the origin has. Why not do the maths and see if you can prove that they are equivalent? Paavo.
Reply by ●July 9, 20032003-07-09
Jerry Avins <jya@ieee.org> wrote in message news:<3F0B3383.936D6692@ieee.org>...> santosh nath wrote: > > > > Jerry Avins <jya@ieee.org> wrote in message news:<3F0AEF55.6F4E7AA4@ieee.org>... > > > shankar wrote: > > > > > > > Actually, I also wish to have a magic wand to make everybody > > > > behave as I want them to. :=) > > > > > > The nice thing about newsgroups is that I needn't respond to those who > > > irk me. It's nearly as good as a magic wand. > > > ... > > > > > > > > The statement "linear phase" is equivalent to saying that all tones > > > > suffer equal delay. ( A zero-slope line phase plot will distort, > > > > unless the value of the const phase is -180 degrees. ) > > > > > > "Linear phase" means more than that. It means that the phase vs. > > > frequency plot passes through the origin. Constant phase velocity > > > implies only that an extension of it over the band of interest do so. > > > > > > > > Hi Jerry, > > Is there any specific reason why it should pass through origin! > > From pure mathematical view phase function is a function of frequency > > (Angular frequency) so if it forms like y=mx+c where x is angular > > frequency > > and c is initial phase offset then it needs not pass through origin > > and yet can keep it linear. > > > > dy/dx i.e group delay also remain constant over all frequency - Am I > > missing > > something in your point. > > > > Regards, > > Santosh > > > > > > Now , consider the cascade of 2 Hilbert filters, mentioned originally. > > > > > > > > Input is f(t). Output is -f(t-p). p is the delay. > > > > What would be p ? > > > > > > Whatever delay makes the HTs causal. Nothing more. > > > > > > > > shankar > > > > > > Jerry > > As before, that depends on what you mean by distortion. Constant phase > velocity over a band preserves the shape of pulses all of whose > components lie within the band. If the pulse is riding on a carrier and > the projected slope doesn't go through the origin, the demodulated pulse > will be undistorted but the phase of the carrier relative to the edges > of the pulse will be constantly changing. "Linear phase" implies > constancy down to DC (high-pass filters excepted).I guess you did not mean constancy of phase over frequency since it is constantly changing with a slope m. Your points are not very clear and I am not fully convinced. Could you give more light and mathematics? As the following website defines linear phase in a similar way I did. See definition. http://ccrma-www.stanford.edu/~jos/mdft/Linear_Phase_Terms.html So if I(wk) becomes 1 then it need not pass through origin. Santosh As for y=mx+c, what> happens when m is zero but c finite? That's constant slope too. You > claim that distorts. Again, what do you mean by distortion? > > Jerry
> On that basis I would argue that that two Hilbert transforms in series > is not equivalent to negation. Perhaps only for the ideal case and > then you have to figure out what influence the discontinuity at the > origin has. Why not do the maths and see if you can prove that they > are equivalent? > > Paavo.Check "fundamentals of linear phase filters for digital comm" in march 00 issue of "rf design" ( rfdesign.com ) i am going through it. shankar
Hello Santosh, For linear phase filters, the phase term can be written as B-A*w where B is one of 0, pi/2, pi and A is positive. When B is pi/2 we get Hilbert transformers, differentiators, etc. Clay "santosh nath" <santosh.nath@ntlworld.com> wrote in message news:6afd943a.0307082242.304b47fa@posting.google.com...> Jerry Avins <jya@ieee.org> wrote in messagenews:<3F0B3383.936D6692@ieee.org>...> > santosh nath wrote: > > > > > > Jerry Avins <jya@ieee.org> wrote in messagenews:<3F0AEF55.6F4E7AA4@ieee.org>...> > > > shankar wrote: > > > > > > > > > Actually, I also wish to have a magic wand to make everybody > > > > > behave as I want them to. :=) > > > > > > > > The nice thing about newsgroups is that I needn't respond to thosewho> > > > irk me. It's nearly as good as a magic wand. > > > > ... > > > > > > > > > > The statement "linear phase" is equivalent to saying that alltones> > > > > suffer equal delay. ( A zero-slope line phase plot will distort, > > > > > unless the value of the const phase is -180 degrees. ) > > > > > > > > "Linear phase" means more than that. It means that the phase vs. > > > > frequency plot passes through the origin. Constant phase velocity > > > > implies only that an extension of it over the band of interest doso.> > > > > > > > > > > Hi Jerry, > > > Is there any specific reason why it should pass through origin! > > > From pure mathematical view phase function is a function of frequency > > > (Angular frequency) so if it forms like y=mx+c where x is angular > > > frequency > > > and c is initial phase offset then it needs not pass through origin > > > and yet can keep it linear. > > > > > > dy/dx i.e group delay also remain constant over all frequency - Am I > > > missing > > > something in your point. > > > > > > Regards, > > > Santosh > > > > > > > > Now , consider the cascade of 2 Hilbert filters, mentionedoriginally.> > > > > > > > > > Input is f(t). Output is -f(t-p). p is the delay. > > > > > What would be p ? > > > > > > > > Whatever delay makes the HTs causal. Nothing more. > > > > > > > > > > shankar > > > > > > > > Jerry > > > > As before, that depends on what you mean by distortion. Constant phase > > velocity over a band preserves the shape of pulses all of whose > > components lie within the band. If the pulse is riding on a carrier and > > the projected slope doesn't go through the origin, the demodulated pulse > > will be undistorted but the phase of the carrier relative to the edges > > of the pulse will be constantly changing. "Linear phase" implies > > constancy down to DC (high-pass filters excepted). > > I guess you did not mean constancy of phase over frequency since it is > constantly changing with a slope m. Your points are not very clear and > I am not fully convinced. Could you give more light and mathematics? > As the following website defines linear phase in a similar way I did. > See definition. > > http://ccrma-www.stanford.edu/~jos/mdft/Linear_Phase_Terms.html > > So if I(wk) becomes 1 then it need not pass through origin. > > Santosh > > > > As for y=mx+c, what > > happens when m is zero but c finite? That's constant slope too. You > > claim that distorts. Again, what do you mean by distortion? > > > > Jerry
"Paavo Jumppanen" <PaavoJumppanen@iname.com> wrote in message news:1a72ed76.0307081452.1c0f974e@posting.google.com...> > On that basis I would argue that that two Hilbert transforms in series > is not equivalent to negation. Perhaps only for the ideal case and > then you have to figure out what influence the discontinuity at the > origin has. Why not do the maths and see if you can prove that they > are equivalent?In Hilbert space: The Hilbert transform of delta(t) is simply 1/(pi*t) Two Hilberts in series result in the convolution of 1/(pi*t) with 1/(pi*t) The result is -delta(t) --- simple negation. And you know that in Fourier space that delta(t) has a flat ampitude response with zero phase shift. In Fourier space: The Fourier transform of an ideal Hilbert transformer impulse response is -j sgn(omega) So the convolution (caused by two Hilberts in series) results in the product of -j sgn(omega) with itself. This results in -1 with a single discontinuity at zero. But when the inverse transform is performed and Dirichlet's theorem about discontinuities is applied, the total impulse response is simply -delta(t). Again simple inversion. Of course practical implementations will have a problem near DC, so a cascade of two practical Hilbert transformers will also have problems near DC Clay> > Paavo.
Paavo Jumppanen wrote:> > > > ... I would argue that that two Hilbert transforms in series > is not equivalent to negation. Perhaps only for the ideal case and > then you have to figure out what influence the discontinuity at the > origin has. Why not do the maths and see if you can prove that they > are equivalent? > > Paavo.Given a signal processed each way, the inverted one delayed to match the double-HTed one, how would you go about telling them apart? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
santosh nath wrote:> > Jerry Avins <jya@ieee.org> wrote in message news:<3F0B3383.936D6692@ieee.org>... > > santosh nath wrote: > > > > > > Jerry Avins <jya@ieee.org> wrote in message news:<3F0AEF55.6F4E7AA4@ieee.org>... > > > > shankar wrote: > > > > > > > > > Actually, I also wish to have a magic wand to make everybody > > > > > behave as I want them to. :=) > > > > > > > > The nice thing about newsgroups is that I needn't respond to those who > > > > irk me. It's nearly as good as a magic wand. > > > > ... > > > > > > > > > > The statement "linear phase" is equivalent to saying that all tones > > > > > suffer equal delay. ( A zero-slope line phase plot will distort, > > > > > unless the value of the const phase is -180 degrees. ) > > > > > > > > "Linear phase" means more than that. It means that the phase vs. > > > > frequency plot passes through the origin. Constant phase velocity > > > > implies only that an extension of it over the band of interest do so. > > > > > > > > > > > Hi Jerry, > > > Is there any specific reason why it should pass through origin! > > > From pure mathematical view phase function is a function of frequency > > > (Angular frequency) so if it forms like y=mx+c where x is angular > > > frequency > > > and c is initial phase offset then it needs not pass through origin > > > and yet can keep it linear. > > > > > > dy/dx i.e group delay also remain constant over all frequency - Am I > > > missing > > > something in your point. > > > > > > Regards, > > > Santosh > > > > > > > > Now , consider the cascade of 2 Hilbert filters, mentioned originally. > > > > > > > > > > Input is f(t). Output is -f(t-p). p is the delay. > > > > > What would be p ? > > > > > > > > Whatever delay makes the HTs causal. Nothing more. > > > > > > > > > > shankar > > > > > > > > Jerry > > > > As before, that depends on what you mean by distortion. Constant phase > > velocity over a band preserves the shape of pulses all of whose > > components lie within the band. If the pulse is riding on a carrier and > > the projected slope doesn't go through the origin, the demodulated pulse > > will be undistorted but the phase of the carrier relative to the edges > > of the pulse will be constantly changing. "Linear phase" implies > > constancy down to DC (high-pass filters excepted). > > I guess you did not mean constancy of phase over frequency since it is > constantly changing with a slope m. Your points are not very clear andI meant constancy of slope. I ought to have been more explicit.> I am not fully convinced. Could you give more light and mathematics? > As the following website defines linear phase in a similar way I did. > See definition. > > http://ccrma-www.stanford.edu/~jos/mdft/Linear_Phase_Terms.html > > So if I(wk) becomes 1 then it need not pass through origin.So there are two cases by that definition: the phase shift is zero or 180 degrees. No problem there. The interesting case I wrote of above where the slope is locally constant, but doesn't pass through the origin. It is then possible to locate a carrier in the locally constant region and transmit undistorted pulses on it, but the phase of the carrier relative to the start of the pulse varies.>... Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
