HW-based MPEG-2 to MPEG-4 converter needed
Started by Herbert Haas July 2, 2003
Hi,
as mentioned in the subject line, I am looking for a MPEG-2 to MPEG-4
converter, which is implemented in hardware.  AFAIK, only
software-based solutions are available.
Thanks for any help,
Herbert
On Thu, 03 Jul 2003 00:33:40 +0200, Herbert Haas wrote:
> as mentioned in the subject line, I am looking for a MPEG-2 to MPEG-4 > converter, which is implemented in hardware. AFAIK, only > software-based solutions are available.
You will have to be a heck of a lot more specific. Audio or video or both? If audio, which spec(s) and layers? If video, which profiles and levels? What systems layer(s) for MPEG-2? None? Program stream? Transport stream? What part of the MPEG-4 spec is the target? Realtime or not? I know more about MPEG-1 and -2 than -4, so there are probably more issues for MPEG-4. -- Matthew Donadio (m.p.donadio@ieee.org)
Hi Matthew,
Unfortunately I do not know any profiles and codecs at the moment.  If
it helps, the MPEG-2 streams contain digital TV which I want to
convert as a single AV-Object into MPEG-4.  I want to offer my
customers a MPEG-4 based menu so that my customers can select among
several TV channels and Video (near) oon-demand streams or games etc.
Thanks, best regards,
Herbert
On Wed, 02 Jul 2003 18:09:03 -0400, Matthew Donadio
<m.p.donadio@ieee.org> wrote:
>On Thu, 03 Jul 2003 00:33:40 +0200, Herbert Haas wrote: >> as mentioned in the subject line, I am looking for a MPEG-2 to MPEG-4 >> converter, which is implemented in hardware. AFAIK, only >> software-based solutions are available. > >You will have to be a heck of a lot more specific. > >Audio or video or both? > >If audio, which spec(s) and layers? > >If video, which profiles and levels? > >What systems layer(s) for MPEG-2? None? Program stream? Transport stream? > >What part of the MPEG-4 spec is the target? > >Realtime or not? > >I know more about MPEG-1 and -2 than -4, so there are probably more issues >for MPEG-4.
Matthew Donadio wrote:
> I know more about MPEG-1 and -2 than -4, so there are probably more issues > for MPEG-4.
Yep. The MPEG-4 format is so broad that you can do almost everything. bye, -- Piergiorgio Sartor
