"gareth" <no.spam@thank.you.invalid> wrote in message news:mcmu7v$3rh$1@dont-email.me...> Although not posting here for some years, I have nevertheless been > a regular reader.This is a serious dissertation and not a troll, and may, indeed, also lay to rest the doubts that many of you had in acceptng the glib explanation of what sampling is all about; so glib that it did not sit well with all the previous maths that you learnt. Gareth, BA, Computer & Communications Engineering, University of Essex, 1972. (Pace the errors caused by typing off-the-cuff, particularly the lack of "n" in "nT")
Big K - laying the ghost to rest
Started by ●February 26, 2015
Reply by ●February 26, 20152015-02-26
"Brian Reay" <no.sp@m.com> wrote in message news:768834759446662030.833121no.sp-m.com@news.eternal-september.org...> > As you say, his post is less than convincing, I gave up on it due to the > 'revisionist' nature, those familiar with his crack pot theories will know > what I mean. >OK, so you don't understand the issues involved, which is hardly surprising, given your poor grasp of the mathematics involved ... -----ooooo----- From: "Brian Reay" <brian.r...@bigfoot.com> Newsgroups: alt.engineering.electrical,uk.radio.amateur Subject: Re: Phase noise Date: Sat, 13 Dec 2003 10:21:54 -0000 Message-ID: <brep3e$2keco$1@ID-140397.news.uni-berlin.de> The term e^(-jwt) isn't some magical time machine relating to "minus time", e^(-jwt) is simply another way of writing 1/(e^jwt) which is a value that decreases as t increasing. -----ooooo----- ... but humility would be preferable to your blustering with personal remarks as youdo above.
On 2/26/2015 6:06 AM, gareth wrote:> "gareth" <no.spam@thank.you.invalid> wrote in message > news:mcmu7v$3rh$1@dont-email.me... >> Although not posting here for some years, I have nevertheless been >> a regular reader. > > Bugger! The perils of composing off-the-cuff where I should have > used (t-nT) and not (t-T), etc, etc.I get what T is and of course nT makes sense, but what is 't'? Is that t0, the starting point corresponding to time where n=0? You have not explained what d() and f() are either. Is d() intended to be the "Diracian Delta" function? Should I assume f() is the function being sampled? If my assumptions are correct I see another mistake. The signal being sampled should not be f(t-nT), it is just f(t). If you use f(t-nT) you will be multiplying both functions shifted in time by the same amount producing the same resulting function shifted in time. In other words it will repeatedly sample the same point at time t0 over and over rather than sampling points of f() spaced T seconds apart. -- Rick
"rickman" <gnuarm@gmail.com> wrote in message news:mcnspe$2e5$1@dont-email.me...> On 2/26/2015 6:06 AM, gareth wrote: >> "gareth" <no.spam@thank.you.invalid> wrote in message >> news:mcmu7v$3rh$1@dont-email.me... >>> Although not posting here for some years, I have nevertheless been >>> a regular reader. >> >> Bugger! The perils of composing off-the-cuff where I should have >> used (t-nT) and not (t-T), etc, etc. > > I get what T is and of course nT makes sense, but what is 't'? Is that > t0, the starting point corresponding to time where n=0? You have not > explained what d() and f() are either.> Is d() intended to be the "Diracian Delta" function?Yes.> Should I assume f() is the function being sampled?Yes> If my assumptions are correct I see another mistake. The signal being > sampled should not be f(t-nT), it is just f(t). If you use f(t-nT) you > will be multiplying both functions shifted in time by the same amount > producing the same resulting function shifted in time.Yes! Mea Culpa!> In other words it will repeatedly sample the same point at time t0 over > and over rather than sampling points of f() spaced T seconds apart.Yes, lools like another booboo on my part, but you are only partially correct in that the reference should be f(nT), the instantaneous value at the sampling instant. Perhaps I should take some time and re-submit after corrections? I acknowledged the typos and shortfalls elsewhere. As you have suggested, t is actual time,.
"gareth" <no.spam@thank.you.invalid> wrote:> "rickman" <gnuarm@gmail.com> wrote in message > news:mcnspe$2e5$1@dont-email.me... >> On 2/26/2015 6:06 AM, gareth wrote: >>> "gareth" <no.spam@thank.you.invalid> wrote in message >>> news:mcmu7v$3rh$1@dont-email.me... >>>> Although not posting here for some years, I have nevertheless been >>>> a regular reader. >>> >>> Bugger! The perils of composing off-the-cuff where I should have >>> used (t-nT) and not (t-T), etc, etc. >> >> I get what T is and of course nT makes sense, but what is 't'? Is that >> t0, the starting point corresponding to time where n=0? You have not >> explained what d() and f() are either. > > >> Is d() intended to be the "Diracian Delta" function? > > Yes. > >> Should I assume f() is the function being sampled? > > Yes > >> If my assumptions are correct I see another mistake. The signal being >> sampled should not be f(t-nT), it is just f(t). If you use f(t-nT) you >> will be multiplying both functions shifted in time by the same amount >> producing the same resulting function shifted in time. > > Yes! Mea Culpa! > >> In other words it will repeatedly sample the same point at time t0 over >> and over rather than sampling points of f() spaced T seconds apart. > > Yes, lools like another booboo on my part, but you are only > partially correct in that the reference should be f(nT), the instantaneous > value at the sampling instant. > > Perhaps I should take some time and re-submit after corrections? >Make sure to include references next time too, son. And maybe if you tried to learn a bit about the subject as well, that might also help. -- STC // M0TEY // twitter.com/ukradioamateur
On 26.02.2015 17:39, gareth wrote:>> Frindly reminder: You can't "lay a ghost to rest" when you resurrect it >> yourself by initially posting about some 10-year-back event. > > It was cole and reay who resurrected it and not I.It was you who started this thread.> No-one who speaks up for decency and maturity in an international forum > makes a fool of himself.You could not be more wrong. Your failure to realize that actually shows your lack of maturity extrodinarily well.> May I suggest that you google for the topic of, "kill file" and act > accordingly?Thanks, buddy, I know what a killfile is. Won't put you in it though because reading your posts makes me slowly realize why everyone is mocking you on here. Cheers, Johannes -->> Wo hattest Du das Beben nochmal GENAU vorhergesagt? > Zumindest nicht �ffentlich!Ah, der neueste und bis heute genialste Streich unsere gro�en Kosmologen: Die Geheim-Vorhersage. - Karl Kaos �ber R�diger Thomas in dsa <hidbv3$om2$1@speranza.aioe.org>
On 2/26/2015 3:07 PM, gareth wrote:> "rickman" <gnuarm@gmail.com> wrote in message > news:mcnspe$2e5$1@dont-email.me... >> On 2/26/2015 6:06 AM, gareth wrote: >>> "gareth" <no.spam@thank.you.invalid> wrote in message >>> news:mcmu7v$3rh$1@dont-email.me... >>>> Although not posting here for some years, I have nevertheless been >>>> a regular reader. >>> >>> Bugger! The perils of composing off-the-cuff where I should have >>> used (t-nT) and not (t-T), etc, etc. >> >> I get what T is and of course nT makes sense, but what is 't'? Is that >> t0, the starting point corresponding to time where n=0? You have not >> explained what d() and f() are either. > > >> Is d() intended to be the "Diracian Delta" function? > > Yes. > >> Should I assume f() is the function being sampled? > > Yes > >> If my assumptions are correct I see another mistake. The signal being >> sampled should not be f(t-nT), it is just f(t). If you use f(t-nT) you >> will be multiplying both functions shifted in time by the same amount >> producing the same resulting function shifted in time. > > Yes! Mea Culpa! > >> In other words it will repeatedly sample the same point at time t0 over >> and over rather than sampling points of f() spaced T seconds apart. > > Yes, lools like another booboo on my part, but you are only > partially correct in that the reference should be f(nT), the instantaneous > value at the sampling instant.That is not right. It is f(t) which is the original function you are sampling. Then d(t-nT) shifts the DD impulse to the time you wish to sample. It is including the nT in both functions that keeps them aligned as you sum over n. Put nT in just one function and then they slide relative to one another and the impulse shifts sampling different points on the f(t) function.> Perhaps I should take some time and re-submit after corrections?Or just take some time off?> I acknowledged the typos and shortfalls elsewhere. > > As you have suggested, t is actual time,.-- Rick
Johannes Bauer <dfnsonfsduifb@gmx.de> wrote:> On 26.02.2015 17:39, gareth wrote: > >>> Frindly reminder: You can't "lay a ghost to rest" when you resurrect it >>> yourself by initially posting about some 10-year-back event. >> >> It was cole and reay who resurrected it and not I. > > It was you who started this thread. > >> No-one who speaks up for decency and maturity in an international forum >> makes a fool of himself. > > You could not be more wrong. Your failure to realize that actually shows > your lack of maturity extrodinarily well. > >> May I suggest that you google for the topic of, "kill file" and act >> accordingly? > > Thanks, buddy, I know what a killfile is. Won't put you in it though > because reading your posts makes me slowly realize why everyone is > mocking you on here. > > Cheers, > JohannesThis is all, sadly, par for the course behaviour for Gareth. He can't help but smear excrement all over himself. He's been particularly deranged lately, though, even more unhinged than usual. It likely stems from some self-inflicted disaster he's suffered, maybe another fight with his postman. -- STC // M0TEY // twitter.com/ukradioamateur
"Stephen Thomas Cole" <usenet@stephenthomascole.com> wrote in message news:mcnvff$eat$1@dont-email.me...> > Make sure to include references next time too, son. And maybe if you tried > to learn a bit about the subject as well, that might also help.It remains that 100% of your postings consist of rather silly and infantile personal remarks. As amateur radio is a technical pursuit, and you yourself elected to cross post to comp.dsp which is even more technical, why not make your first technical post ever, since you first arrived to pollute Usenet just over 2 years ago with your tirades of abuse? I think that you lack any technical acumen and your bluster is your attempt to cover up.
rickman <gnuarm@gmail.com> wrote:> On 2/26/2015 3:07 PM, gareth wrote: >> "rickman" <gnuarm@gmail.com> wrote in message >> news:mcnspe$2e5$1@dont-email.me... >>> On 2/26/2015 6:06 AM, gareth wrote: >>>> "gareth" <no.spam@thank.you.invalid> wrote in message >>>> news:mcmu7v$3rh$1@dont-email.me... >>>>> Although not posting here for some years, I have nevertheless been >>>>> a regular reader. >>>> >>>> Bugger! The perils of composing off-the-cuff where I should have >>>> used (t-nT) and not (t-T), etc, etc. >>> >>> I get what T is and of course nT makes sense, but what is 't'? Is that >>> t0, the starting point corresponding to time where n=0? You have not >>> explained what d() and f() are either. >> >> >>> Is d() intended to be the "Diracian Delta" function? >> >> Yes. >> >>> Should I assume f() is the function being sampled? >> >> Yes >> >>> If my assumptions are correct I see another mistake. The signal being >>> sampled should not be f(t-nT), it is just f(t). If you use f(t-nT) you >>> will be multiplying both functions shifted in time by the same amount >>> producing the same resulting function shifted in time. >> >> Yes! Mea Culpa! >> >>> In other words it will repeatedly sample the same point at time t0 over >>> and over rather than sampling points of f() spaced T seconds apart. >> >> Yes, lools like another booboo on my part, but you are only >> partially correct in that the reference should be f(nT), the instantaneous >> value at the sampling instant. > > That is not right. It is f(t) which is the original function you are > sampling. Then d(t-nT) shifts the DD impulse to the time you wish to > sample. It is including the nT in both functions that keeps them aligned > as you sum over n. Put nT in just one function and then they slide > relative to one another and the impulse shifts sampling different points > on the f(t) function. >I suggest going right back to basics and teaching him from the beginning, this is all too complex for him. Gareth has got himself in way over his head, as per. IIRC, this is exactly how "Big K" came about in the first place, Gareth refused to accept that he didn't have any remote clue about DSP so cooked up his own, personal DSP and then declared that everybody else had always been wrong. He's a deeply peculiar individual. Totally depraved, of course. -- STC // M0TEY // twitter.com/ukradioamateur
