The 32 bit data types of the Blackfin processors should preserve more bits of precision than a 16 bit fixed point processor, if the FFT routines make use of the 32 bit data types. Can anyone comment on whether this is the case, and how well the precision is maintained in the calculations? How much precision would result from a library FFT routine of 2048 points of 10 bit data after an FFT is performed? Thanks.
Blackfin FFT precision
Started by ●July 1, 2003
Reply by ●July 2, 20032003-07-02
Ed wrote:> The 32 bit data types of the Blackfin processors should preserve more bits > of precision than a 16 bit fixed point processor, if the FFT routines make > use of the 32 bit data types. Can anyone comment on whether this is the > case, and how well the precision is maintained in the calculations?Dunno about the details of the Blackfin> How > much precision would result from a library FFT routine of 2048 points of > 10 > bit data after an FFT is performed? Thanks.Take a look at the recent "scaling fixed point fft" thread where this was discussed. The gist is for a 2^P point transform you need to allow for P/2 bits of growth in the amplitude of sinusiods wrt white noise. So for 16 bits, 2^11 point transform you only really have 16-5.5 = 10.5 bits of useful dynamic range with a fixed point FFT, which seems OK if your input is only 10 bits anyway. Using bits 15..6 and scale by 1/2 on each FFT pass is the way to go in this case I think. Regards -- Adrian Hey
