Hi I am trying to flash a prog (im.out) between 1000h and 4000h on F240, on a Technosoft IMMF240 device which use 0-1000h flash and don't want to overwrite that zone. My CMD is ok, because I can flash using technosoft prog via Serial... But I want to use JTAG interface and the prg2xx prog the test is fine but the writing gives errors : API Error 109, Processor Timeout OTIS Error 0 does anyone knows where is the pb ? thank you for your help please answear by mail :-) ---------------------------------------------------------------------------- ---- Best regards ---------------------------------------------------------------------------- ---- PS here is the cmd line outputs : c:\ti\specdig\prg2xx>btest c:\ti\specdig\prg2xx>echo Commande ECHO activ�e. c:\ti\specdig\prg2xx>prg2xxw95 -p 378 -m 0x0006 -w 6 src\src\c2xx_btx.out im.out Spectrum Digital F2xx Flash Programmer Version 3.3 . . Load Program (algo_file) to DSP . . . Program Device . Finished c:\ti\specdig\prg2xx>prog c:\ti\specdig\prg2xx>Echo Commande ECHO activ�e. c:\ti\specdig\prg2xx>prg2xxw95 -p 378 -m 0x0006 -w 6 src\src\c2xx_bpX.out im.out Spectrum Digital F2xx Flash Programmer Version 3.3 . . Load Program (algo_file) to DSP . API Error 109, Processor Timeout OTIS Error 0 c:\ti\specdig\prg2xx> ---------------------------------------------------------------------------- ---- thanks
F240 Flash pbs using prg2xx
Started by ●June 26, 2003
Reply by ●July 8, 20032003-07-08
any one there ??? thank you for your kind help "Lotfi" <lbaghli(no_spam_at_all)@ifrance.com> a �crit dans le message news: bdp0oh$mun$1@arcturus.ciril.fr...> > Hi > > I am trying to flash a prog (im.out) between 1000h and 4000h on F240, on a > Technosoft IMMF240 device which use 0-1000h flash and don't want to > overwrite that zone. > My CMD is ok, because I can flash using technosoft prog via Serial... > > But I want to use JTAG interface and the prg2xx prog > the test is fine but the writing gives errors : > API Error 109, Processor Timeout > OTIS Error 0 > > does anyone knows where is the pb ? > > thank you for your help > please answear by mail :-) > > > ----------------------------------------------------------------------------> ---- > Best regards > ----------------------------------------------------------------------------> ---- > PS here is the cmd line outputs : > c:\ti\specdig\prg2xx>btest > > c:\ti\specdig\prg2xx>echo > Commande ECHO activ�e. > > c:\ti\specdig\prg2xx>prg2xxw95 -p 378 -m 0x0006 -w 6 src\src\c2xx_btx.out > im.out > > > Spectrum Digital F2xx Flash Programmer Version 3.3 > > . > . Load Program (algo_file) to DSP > . > . > . Program Device > . > > Finished > > c:\ti\specdig\prg2xx>prog > > c:\ti\specdig\prg2xx>Echo > Commande ECHO activ�e. > > c:\ti\specdig\prg2xx>prg2xxw95 -p 378 -m 0x0006 -w 6 src\src\c2xx_bpX.out > im.out > > > Spectrum Digital F2xx Flash Programmer Version 3.3 > > . > . Load Program (algo_file) to DSP > . > API Error 109, Processor Timeout > OTIS Error 0 > > c:\ti\specdig\prg2xx> > > ----------------------------------------------------------------------------> ---- > > thanks > > >
