Which audio format is used between ICs?
Started by Kai Markus Tegtmeier June 24, 2003
Hello to everyone! I'm a newbie in DSP, so please excuse my
stupid question:
What serial digital audio format is normally used between ICs in a
circuit? Is it sort of PCM or S/PDIF or AES? or just right- or left-
justfied serial signal?
Many thanx in advance for your answers!
KMT
On Tue, 24 Jun 2003 20:35:36 +0200, Kai Markus Tegtmeier said to the
parser:
> Hello to everyone! I'm a newbie in DSP, so please excuse my > stupid question: > > What serial digital audio format is normally used between ICs in a > circuit? Is it sort of PCM or S/PDIF or AES? or just right- or left- > justfied serial signal? > > Many thanx in advance for your answers! > > KMT
That depends on the DSP and the codec. AC97, I2C (2-wire) and SPI are the ones I've worked with. Hooking up DSPs to AC97 codecs usually involves a bit of low-level coding. A lot of DSPs support the AC97 clocking, and call themselves "AC97-ready", but they don't have any support for the actual framing of the protocol or anything, so you have to write that all yourself. AC97 codecs also seem to be dying out of late. My Philips and TI reps. have both said that the AC97 codecs from those two companies are being phased out. 2-wire and SPI seem more widespread these days, and I know that in the TI world, they have a lot of ready-made software for talking to these codecs. Michael
Michael, thanx for your answer! It helped me a lot in understanding DSP and
the use of DSP ICs!
Best regards from Germany
Kai
Kai Markus Tegtmeier wrote:
> Hello to everyone! I'm a newbie in DSP, so please excuse my > stupid question: > > What serial digital audio format is normally used between ICs in a > circuit? Is it sort of PCM or S/PDIF or AES? or just right- or left- > justfied serial signal? > > Many thanx in advance for your answers! > > KMT > >
I2S: http://www.es.lth.se/home/tlt/dicp/2002/images/I2SBUS.pdf Regards, Iwo
