Challenge: An IIR high-pass filter (Cheby1, 2.order, DF1) must be switched from one frequency to another without causing (considerable) overshoot. Changes in amplitude and phase should be smooth. There's not much processor time left for additional calculations. Therefore I watch out for a tiny but smart solution. Approach: I chose DF1 form because it stores only those values which enter or leave the filter. (Input values are independent of coefficient changes, output signal values are at least bounded and somehow predictable.) Seems to be closer to the goal than with DF2 or others. When switching occurs, storage elements hold "wrong" values. That is why ringing, overshoot etc. occurs. "Preloading" with the correct values would completely avoid any distortion, but I guess it cannot be done because of the infinite recursion. Compensation by running old and new filter set in parallel (with input of the old one grounded) and adding the output signals improves the behaviour but not in all cases. And, it's expensive (time). What I do currently, is this: Filter coefficients are changed without taking care of the stored values. After the filter output there's a limiting stage which compares input and output values and takes the lower one. But this approach is not satisfying. Any hints / ideas are welcome. Bernhard -- before sending to the above email-address: replace deadspam.com by foerstergroup.de
change filter freq. w/o glitches
Started by ●June 24, 2003
Reply by ●June 24, 20032003-06-24
Bernhard Holzmayer wrote:> But this approach is not satisfying. > Any hints / ideas are welcome.Computational intensive: Run two filters in parallel, with equal delay. Fade between one output to the other. bye, -- Piergiorgio Sartor
Bernhard Holzmayer wrote:> Challenge: > An IIR high-pass filter (Cheby1, 2.order, DF1) must be switched from > one frequency to another without causing (considerable) overshoot. > Changes in amplitude and phase should be smooth. > There's not much processor time left for additional calculations. > Therefore I watch out for a tiny but smart solution.You could apply a 1st-order lowpass to each coefficient (filter the filtercoeffs). If this is done as background process, triggered every 4 (8, 16 ...) samples, it doesn't cost very much. This works for 1st and 2nd order filters (DF1, kanonical #1, less good for DF2 / kanonical #2). With orders higher than 2, poles run temporarily outside the unitcircle. (This applys not to cascaded filters of order 2). Regards Mattias
Hello Bernhard, Some time ago I encountered a problem similar to yours. The simple solution is to run the old and the new filters in parallel and mix their outputs slowly changing the proportion. However that might be expensive. The permanent modification of the IIR filter coefficients by small amount on every clock cycle is not good because the filter can occasionally run into unstable operation area. You can change the filter from old to new by several intermediate steps. The overshoots are going to be smaller by the number of steps. The good, but expensive solution is to switch the filter to new coefficients and modify memories in the way the output response is continuos. That should be done separately for feedback and feedforward filter paths. For Chebyshev-1 feedforward path the feedforward memory is multiplied by the difference in feedforward gain. In the feedback path, the memories are modified to match first two points of impulse response. Vladimir Vassilevsky, Ph.D. DSP and Mixed Signal Design Consultant http://www.abvolt.com Bernhard Holzmayer wrote:> > Challenge: > An IIR high-pass filter (Cheby1, 2.order, DF1) must be switched from > one frequency to another without causing (considerable) overshoot. > Changes in amplitude and phase should be smooth. > There's not much processor time left for additional calculations. > Therefore I watch out for a tiny but smart solution. > > Approach: > I chose DF1 form because it stores only those values which enter or > leave the filter. (Input values are independent of coefficient > changes, output signal values are at least bounded and somehow > predictable.) > Seems to be closer to the goal than with DF2 or others. > > When switching occurs, storage elements hold "wrong" values. > That is why ringing, overshoot etc. occurs. > "Preloading" with the correct values would completely avoid any > distortion, but I guess it cannot be done because of the infinite > recursion. > > Compensation by running old and new filter set in parallel (with > input of the old one grounded) and adding the output signals > improves the behaviour but not in all cases. And, it's expensive > (time). > > What I do currently, is this: > Filter coefficients are changed without taking care of the stored > values. After the filter output there's a limiting stage which > compares input and output values and takes the lower one. > > But this approach is not satisfying. > Any hints / ideas are welcome. > > Bernhard > > -- > before sending to the above email-address: > replace deadspam.com by foerstergroup.de
In article 4984413.0sRMePMuDS@holzmayer.ifr.rt, Bernhard Holzmayer at holzmayer.bernhard@deadspam.com wrote on 06/24/2003 08:40:> Challenge: > An IIR high-pass filter (Cheby1, 2.order, DF1) must be switched from > one frequency to another without causing (considerable) overshoot. > Changes in amplitude and phase should be smooth. > There's not much processor time left for additional calculations. > Therefore I watch out for a tiny but smart solution. > > Approach: > I chose DF1 form because it stores only those values which enter or > leave the filter. (Input values are independent of coefficient > changes, output signal values are at least bounded and somehow > predictable.) > Seems to be closer to the goal than with DF2 or others. > > When switching occurs, storage elements hold "wrong" values. > That is why ringing, overshoot etc. occurs. > "Preloading" with the correct values would completely avoid any > distortion, but I guess it cannot be done because of the infinite > recursion. > > Compensation by running old and new filter set in parallel (with > input of the old one grounded) and adding the output signals > improves the behaviour but not in all cases. And, it's expensive > (time). > > What I do currently, is this: > Filter coefficients are changed without taking care of the stored > values. After the filter output there's a limiting stage which > compares input and output values and takes the lower one. > > But this approach is not satisfying. > Any hints / ideas are welcome.how about "slewing" the coefficients? r b-j
In article 3EF88453.200B77CC@abvolt.com, Vladimir Vassilevsky at vlv@abvolt.com wrote on 06/24/2003 13:03:> Hello Bernhard, > > Some time ago I encountered a problem similar to yours. > > The simple solution is to run the old and the new filters in parallel > and mix their outputs slowly changing the proportion. However that might > be expensive. > > The permanent modification of the IIR filter coefficients by small > amount on every clock cycle is not good because the filter can > occasionally run into unstable operation area.that depends on the form. the DF1 with complex conjugate poles will not run into unstable areas if the startpoint and endpoint are both stable. slewing can be made slow enough so that artifacts of the slewing won't be large. r b-j
In article bd9p99$pboug$1@ID-168735.news.dfncis.de, Mattias Schick at mattias.schick@lawo.de wrote on 06/24/2003 11:04:> Bernhard Holzmayer wrote: >> Challenge: >> An IIR high-pass filter (Cheby1, 2.order, DF1) must be switched from >> one frequency to another without causing (considerable) overshoot. >> Changes in amplitude and phase should be smooth. >> There's not much processor time left for additional calculations. >> Therefore I watch out for a tiny but smart solution. > > You could apply a 1st-order lowpass to each coefficient > (filter the filtercoeffs). If this is done as background process, > triggered every 4 (8, 16 ...) samples, it doesn't cost very much.this is very good advice. it is very efficient to choose the sample "chunk" or block size in such a way so that you can slew coefficients once per chunk or block. the larger the block, the slower the slewing has to be. check out the limit cycle problem in the slew filters so that coefs don't get stuck on slightly incorrect values (the DC-blocking filter trick i have suggested at dspguru has the solution to that problem).> This works for 1st and 2nd order filters (DF1, kanonical #1, > less good for DF2 / kanonical #2). With orders higher than 2, > poles run temporarily outside the unitcircle.not if they were complex conjugate, and i doubt it if they were real also. oh, perhaps you mean that the orders higher than 2 are not cascaded biquad sections and then, in that case, you are certainly correct.> (This applys not to cascaded filters of order 2).duh. i gotta read through the whole post before responding. :-\ r b-j
"Bernhard Holzmayer" <holzmayer.bernhard@deadspam.com> wrote in message news:4984413.0sRMePMuDS@holzmayer.ifr.rt...> Challenge: > An IIR high-pass filter (Cheby1, 2.order, DF1) must be switched from > one frequency to another without causing (considerable) overshoot. > Changes in amplitude and phase should be smooth. > There's not much processor time left for additional calculations. > Therefore I watch out for a tiny but smart solution. > > Approach: > I chose DF1 form because it stores only those values which enter or > leave the filter. (Input values are independent of coefficient > changes, output signal values are at least bounded and somehow > predictable.) > Seems to be closer to the goal than with DF2 or others. > > When switching occurs, storage elements hold "wrong" values. > That is why ringing, overshoot etc. occurs. > "Preloading" with the correct values would completely avoid any > distortion, but I guess it cannot be done because of the infinite > recursion. > > Compensation by running old and new filter set in parallel (with > input of the old one grounded) and adding the output signals > improves the behaviour but not in all cases. And, it's expensive > (time). > > What I do currently, is this: > Filter coefficients are changed without taking care of the stored > values. After the filter output there's a limiting stage which > compares input and output values and takes the lower one. > > But this approach is not satisfying. > Any hints / ideas are welcome. > > > Bernhard >You've received some good suggestions. One that hasn't been mentioned that may be good would be this: As a variant to low-pass filtering the coefficients or slewing their values in a brute-force numerical scheme (with the problem of pole movement that's been mentioned), would your application support storing a number of filters so that as you select the next filter, you slew the filter response instead of *directly* changing the coefficients? This way, the coefficients could be a table lookup and the coefficient changes would be appropriate for the filter response. That is, the filter coefficients would change according to the value of coefficient that's needed for a good filter. Otherwise, if you operate on the coefficients directly, the filter could look strange part way through I would think. Example: A high-pass filter that needs to move from 0.4(fs/2) to 0.8(fs/2). Could you design and save filters at increments of 0.01(Fs/2) across the range and switch from one to the next until the desired high pass filter is reached? There's been no mention of filter impulse response vs. change rate. If you use the scheme suggested above, is it OK to switch filters at a rate that's greater than 1 change per effective length of the impulse response? I rather suspect not. And, I have no idea - haven't tried it. That by itself would be an interesting study. Probably someone has done it. Fred
Reply by ●June 25, 20032003-06-25
Lots of good hints! Since it seems helpful, I'll give some more details below:> Challenge: > An IIR high-pass filter (Cheby1, 2.order, DF1) must be switched > from one frequency to another without causing (considerable) > overshoot. Changes in amplitude and phase should be smooth. > There's not much processor time left for additional calculations. > Therefore I watch out for a tiny but smart solution. > > Approach: > I chose DF1 form because it stores only those values which enter > or leave the filter. (Input values are independent of coefficient > changes, output signal values are at least bounded and somehow > predictable.) > Seems to be closer to the goal than with DF2 or others. > > When switching occurs, storage elements hold "wrong" values. > That is why ringing, overshoot etc. occurs. > "Preloading" with the correct values would completely avoid any > distortion, but I guess it cannot be done because of the infinite > recursion. > > Compensation by running old and new filter set in parallel (with > input of the old one grounded) and adding the output signals > improves the behaviour but not in all cases. And, it's expensive > (time). > > What I do currently, is this: > Filter coefficients are changed without taking care of the stored > values. After the filter output there's a limiting stage which > compares input and output values and takes the lower one.Background: For direct replacement of an analog filter solution, I have to design a digital solution which behaves as similar as possible like the analog implementation (at least not worse). Signal source is a demodulator which provides orthogonal vector components, which are treated as individual channels in parallel (X and Y components of the signal vector). signal frequency range: DC - 20kHz sliding filter freq. range: 1Hz .... 16kHz sampling frequency is 48kHz I'm working with a Sharc DSP (21161), currently on EZ-KIT base. 24bit floating point samples/coefficients/code. Filtering is done with two application specific higher-order butterworth filters (high pass and low pass) which are adjustable, but not changing during measurements. Then there's this Cheby-Filter, which is moving during measurements. Measurement speed (there's an input for it) defines the cutoff frequency of this filter; this means, fc is application dependent. Although I don't take it into account up to now: speed is changing smoothly because masses must be accelerated, thus filter movement is a bit predictable. I can do a table lookup to find the coefficients (that's how it's done in the analog solution). Table entries can be logarithmically spaced. Another approach, which I prefer, is: I retrieved a polynomial approximation of the coefficients over frequency and evaluate the polynomials when speed changes. There is some time available to apply the improvement (slewing or whatever): the filter is currently moved every 100ms. I could imagine to apply some interpolation algorithm on the filter coefficients. After this filtering we mainly search for peaks on the signal vector, within a certain phase sector. Therefore it's important that filter movement doesn't influence vector phase (signal independency ?) and that no peaks are introduced which might be interpreted as peaks coming from the signal. Bernhard -- before sending to the above email-address: replace deadspam.com by foerstergroup.de
robert bristow-johnson wrote:> In article 3EF88453.200B77CC@abvolt.com, Vladimir Vassilevsky at > vlv@abvolt.com wrote on 06/24/2003 13:03: > >> Hello Bernhard, >> >> Some time ago I encountered a problem similar to yours. >> >> The simple solution is to run the old and the new filters in >> parallel and mix their outputs slowly changing the proportion. >> However that might be expensive. >> >> The permanent modification of the IIR filter coefficients by >> small amount on every clock cycle is not good because the filter >> can occasionally run into unstable operation area. > > that depends on the form. the DF1 with complex conjugate poles > will not run > into unstable areas if the startpoint and endpoint are both > stable. slewing can be made slow enough so that artifacts of the > slewing won't be large. > > r b-jindeed, slewing coefficents might be a very straight-forward solution. thanks for the hint. I checked different structures because I wanted to develop polynomial approximations for online calculation of the coefficients. DF1 showed a very secure behaviour: it will not become instable when interpolating between coefficients. However, usability depends if the interpolation of coefficients can be done easy and fast enough because it must be done at every sample. Bernhard -- before sending to the above email-address: replace deadspam.com by foerstergroup.de
