You should be able to do this. In the same place where you can choose decimal or hexadecimal there should also be a choice for float. Are you maybe using a really old version of CCS? Go to Help -> About and see which version you're using. Also, what processor are you working on? 2812? Brad "Curl" <Mr.Bilou@microsoft.fr> wrote in message news:4189f12b$0$32013$636a15ce@news.free.fr...> Good Morning > > I never understood how to used watch window in CCS. > I can watch a 16-bits variable with desired format > (hexadecimal,decimal) . But I am unable to watch a 32-bits variable > (floating point for example). > > For example > in Data memory I have a 32-bits variable > 0x100: 0x3f80 > 0x101: 0x0000 > > 0x3f800000 is 1 in 32-bits Floating Point Format. > > What is the syntax in the watch window to correctly see the value of > this variable ? > > Thank you for your answer. >
Re: [CCS] Watch Window
Started by ●November 4, 2004
