Hi Everybody, I have a problem that I thought would be pretty common, but I haven't found a good solution yet. The problem is basically this: I have to accommodate a frequency offset of 1450Hz on a signal coming in at 1200sym/sec. If I sample 6 times a symbol, I get the required bandwidth to satisfy Nyquist's, but the correlator length is too much for the dsp to handle. Does anybody have any ideas or any suggestions as to where to look? Thanks in advance! -Frank
Frequency offset vs. Symbol Rate Problem
Started by ●November 4, 2004
Reply by ●November 4, 20042004-11-04
"Frank Cassidy" <nemesis@lost-wanderer.com> wrote in message news:abf316e4.0411041343.5be7f78a@posting.google.com...> Hi Everybody, > > I have a problem that I thought would be pretty common, but I haven't > found a good solution yet. The problem is basically this: I have to > accommodate a frequency offset of 1450Hz on a signal coming in at > 1200sym/sec. If I sample 6 times a symbol, I get the required > bandwidth to satisfy Nyquist's, but the correlator length is too much > for the dsp to handle. Does anybody have any ideas or any suggestions > as to where to look? Thanks in advance!Frank, It's not clear that you *are* satisfying the Nyquist criterion. You haven't revealed the modulation method for those symbols. The bandwidth isn't necessarily connected to the symbol rate. It's the modulation method that would be used to convert the symbol rate to the bandwidth. For example, if you are using binary signalling in an 8-bit per symbol alphabet then the bandwidth would be in excess of 8 times the symbol rate. Also, you say there's a "frequency offset" but don't describe what this really means. So, if one were to guess it might sound like you have a situation where the symbol rate matches the bandwidth - as might be true for PAM so the sample rate is 6x1200=7200Hz?. However, when there's a frequency offset then this might have to be included in the necessary bandwidth. 1200+1450=2650. The ratio of 7200/2650 is 2.72 which *may* be adequate sampling in a practical situation. Much depends on the details here..... Fred
Reply by ●November 5, 20042004-11-05
nemesis@lost-wanderer.com (Frank Cassidy) wrote in message news:<abf316e4.0411041343.5be7f78a@posting.google.com>...> Hi Everybody, > > I have a problem that I thought would be pretty common, but I haven't > found a good solution yet. The problem is basically this: I have to > accommodate a frequency offset of 1450Hz on a signal coming in at > 1200sym/sec. If I sample 6 times a symbol, I get the required > bandwidth to satisfy Nyquist's, but the correlator length is too much > for the dsp to handle. Does anybody have any ideas or any suggestions > as to where to look? Thanks in advance! > > -FrankOne approach, if you have enough compute power, is to shift the signal by a set of offsets between -1450 and +1450 Hz in steps small enough to satisfy your detector and look for a detect at each offset. Another approach is to generate an AFC signal with a discriminator that is proportional to the offset, use the AFC to bring the signal to near baseband, then run your detector. What modulation are you using? John
Reply by ●November 6, 20042004-11-06
On 4 Nov 2004 13:43:04 -0800, nemesis@lost-wanderer.com (Frank Cassidy) wrote:>Hi Everybody, > >I have a problem that I thought would be pretty common, but I haven't >found a good solution yet. The problem is basically this: I have to >accommodate a frequency offset of 1450Hz on a signal coming in at >1200sym/sec. If I sample 6 times a symbol, I get the required >bandwidth to satisfy Nyquist's, but the correlator length is too much >for the dsp to handle. Does anybody have any ideas or any suggestions >as to where to look? Thanks in advance! > >-FrankThere are lots of tradeoffs to consider for this sort of thing. The first question I'd ask is how quickly do you have to acquire the signal? If you can spend some time to find it you can make it pretty easy. If you have to acquire it quickly, then there are various techniques that can be tried, and many of these trade off speed of acquisition for probability of acquisition or something like that. As others have mentioned, there are some other fundamentals that are helpful, like what type of modulation, receiver architecture, etc. Eric Jacobsen Minister of Algorithms, Intel Corp. My opinions may not be Intel's opinions. http://www.ericjacobsen.org
