I've released the pksampler and pkaudio packages. PKAudio is an audio lib/daemon that makes asynchronous communication with a realtime audio engine from high-level languages like python easy. It is incredibly simple to write extension modules (subclass, implement two simple methods, link with executable), and is a very nice place to start for someone looking to get right to the important part of their dsp application. A Python module is included. PKSampler is a DJ sampler intended for a touch screen. It uses python and qt to animate real 3D widgets created with PoVRay. Check out the screen shots! I'm also working on PKStudio, which is essentially meant to be an open replacement for Propellerhead Software's Reason. It focuses on tools for extending pkaudiod to encourage others to write more dsp modules for it. Read the pkaudio release notes for compilation help. should be simple. PKSampler is written in python, so there isn't any setup. http://pkaudio.sf.net/ http://pksampler.sf.net/ There's lots of directions for this app to take, and I'd like to know if anyone can get pksampler running on their machines. Works best with more than one soundcard! Thanks!
pkaudio/pksampler release
Started by ●September 20, 2004
Reply by ●September 20, 20042004-09-20
Patrick Stinson wrote:> I've released the pksampler and pkaudio packages. > > PKAudio is an audio lib/daemon that makes asynchronous communication with a > realtime audio engine from high-level languages like python easy. It is > incredibly simple to write extension modules (subclass, implement two simple > methods, link with executable), and is a very nice place to start for > someone > looking to get right to the important part of their dsp application. A > Python > module is included. > > PKSampler is a DJ sampler intended for a touch screen. It uses python and qt > to animate real 3D widgets created with PoVRay. Check out the screen shots! > > I'm also working on PKStudio, which is essentially meant to be an open > replacement for Propellerhead Software's Reason. It focuses on tools for > extending pkaudiod to encourage others to write more dsp modules for it. > > Read the pkaudio release notes for compilation help. should be simple. > PKSampler is written in python, so there isn't any setup. > > http://pkaudio.sf.net/ > http://pksampler.sf.net/ > > There's lots of directions for this app to take, and I'd like to know if > anyone can get pksampler running on their machines. Works best with more > than > one soundcard! Thanks!pkzip = Phil Katz's zip. Whence pkaudio? What OS? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
