Hi, We're implementing a VoIP-device for a university project. To handle the sound part of the device we're using a Blackfin 532 from Analog Devices As a start we want to provide G.711a- and ulaw for the user and later if time permits a lower bitrate codec such as g.726. Our problem is that we're stuck in selecting an external audio codec. What we would like to see in an external audio codec is: - should run on 3.3v (at least this is preferred but if needed we will add a 5v supply on our PCB) - configureable through the Blackfin SPORT (others seem to use SPI, but the SPI on the blackfin is allready running in slave mode connected to our master MCU) We have been looking at ADI's selection of external audio codecs and so far we've found the "AD1981BL - Low Voltage AC'97 SoundMAX Codec" http://www.analog.com/en/prod/0%2C2934%2CAD1981BL%2C00.html which appears to meet our requirements. However as we're both very new to the world of DSP we want to make sure that the AD1981BL will be able to do the G.711a- and ulaw sampling before we design our development PCB. As I understand G.711 encoding is converting 13 bits(A-law)/14 bits(U-law)linear PCM samples to 8 bits compressed samples and vice versa for decoding. I would just assume that the external codec should then just be able to sample signals at 8000 samples/second with at least 14 bits resolution. The documentation for the BL1981L states that it will do Full-Duplex sample rates from 7040 hz to 48000hz in 1 hz steps at 16-bit resolution so to me this seems ok. But is that all I have to take into account? Are there any other important parameters that I must consider? Any pointers, pro/cons on choosing this codec for a VoIP solution? Best regards Nikolaj
Choosing external audio codec for VoIP-solution using a Blackfin
Started by ●November 7, 2004
Reply by ●November 7, 20042004-11-07
You are using a Blackfin just to do G.711? Just how big a hammer do you use to crack nuts? :-) Most cheap telephony codecs actually output G.711. Most times in VoIP a DSP is decoding G.711 from a codec so it can re-encode in something more sophisticated. Steve Nikolaj K. wrote:> Hi, > We're implementing a VoIP-device for a university project. To handle > the sound part of the device we're using a Blackfin 532 from Analog > Devices As a start we want to provide G.711a- and ulaw for the user > and later if time permits a lower bitrate codec such as g.726.
Reply by ●November 8, 20042004-11-08
Steve Underwood wrote:> You are using a Blackfin just to do G.711? Just how big a hammer do you > use to crack nuts? :-)Bigger is better ;-). No seriously as we are limited in time for this project we focus more on the networking area of the WLAN VoIP phone - that is developing a stable IP-stack and SIP-stack and a WLAN-driver. However at a later point some other students at the university with more DSP knowledge than us might want to take over the project and implement Codecs like iLBC, Speex, G.72x - perhaps even MP3/WMA for streaming netradio - which can't be done by a simple telephony codec. Therefore a DSP like Blackfin is put in between the external codec and our master processor. As I understand the Blackfin SPORT will do G.711 in hardware so at this point where no sofisticated codecs has been implemented the Blackfin is merely a bridge from the external Codec to my master-processor. However I'm still in doubt if the AD1981BL will meet the requirements that might exist for delivering samples to the Blackfin SPORT for G.711 A/U. /Nikolaj
Reply by ●November 19, 20042004-11-19
Hi, I'm pretty sure that the SPORTs on the Blackfin are able to receive/transmit 8bit uLaw/ALaw encoded data. So the DSP would be used for something where you really need the computational power. For instance, since the ol' times of the 2181, in the EzKit lite, the AD1847 could deliver and receive 8 bit aLaw/uLaw data, and the 2181's SPORTs could handle it. IOther AC'97 codecs used in ADI's EzKits could do the same: the AD1819, the AD1881A, etc. Anyway, it seems that you want a codec that could provide enough bits and adequate sampling rates for speech processing... G.711 seems to be just the starting point, and you want the same hardware setup for later moving to lower bitrate speech processing/compression algos. Am I right? If that's the case, I think that any current audio/speech codec could suit your needs. AC'97 codecs are interesting in the sense that they can be configured from the serial ports, no need for external control ports like I2C or SPI. The AD1881A could do the job, and is a 3.3V part, at least for the digital section. It seems that the AD1981 could do it too (I haven't looked at the datasheets, but I had experience with the AD1881A), and both seem to have the same price tag, at least at Digikey, around US$7.9 in unit quantities. Regards, -- Jaime Andr�s Aranguren Cardona jaac@nospam.sanjaac.com SanJaaC Electronics Soluciones en DSP www.sanjaac.com (Remove "nospam" from e-mail address) "Steve Underwood" <steveu@dis.org> escribi� en el mensaje news:cmmlg1$m7k$1@home.itg.ti.com...> You are using a Blackfin just to do G.711? Just how big a hammer do you > use to crack nuts? :-) > > Most cheap telephony codecs actually output G.711. Most times in VoIP a > DSP is decoding G.711 from a codec so it can re-encode in something more > sophisticated. > > Steve > > > Nikolaj K. wrote: > > > Hi, > > We're implementing a VoIP-device for a university project. To handle > > the sound part of the device we're using a Blackfin 532 from Analog > > Devices As a start we want to provide G.711a- and ulaw for the user > > and later if time permits a lower bitrate codec such as g.726. >
Reply by ●November 22, 20042004-11-22
Jaime Andr�s Aranguren Cardona wrote:> Hi, > > I'm pretty sure that the SPORTs on the Blackfin are able to receive/transmit > 8bit uLaw/ALaw encoded data. So the DSP would be used for something where > you really need the computational power. >Correct - at least according to the datasheet. I haven't done real life testing with SPORT hardware G.711 companding - I've only done G.711 in software using the BF533 om my EZKit.> Anyway, it seems that you want a codec that could provide enough bits and > adequate sampling rates for speech processing... G.711 seems to be just the > starting point, and you want the same hardware setup for later moving to > lower bitrate speech processing/compression algos. Am I right?Yes this is indeed the case.> If that's the > case, I think that any current audio/speech codec could suit your needs. > AC'97 codecs are interesting in the sense that they can be configured from > the serial ports, no need for external control ports like I2C or SPI.The abillity to configure the codec through the SPORT is very important to us which was also why I started to explore the AC'97 codecs.> The > AD1881A could do the job, and is a 3.3V part, at least for the digital > section. It seems that the AD1981 could do it too (I haven't looked at the > datasheets, but I had experience with the AD1881A),Yes, but as you say only the digital supply is 3.3v - the analog supply requires 5V according to the datasheet. This is however not a big issue as we could just put at 5v regulator on the board, but since the AD1981BL is a true 3.3V part I've decided to take my chances with it and save the PCB space.> Regards,Thank you very much for your input. I'm now more confident in implementing an AC'97 based codec for my design. Best regards Nikolaj
