Various methods for implementing the DCT
Started by Johnsy Joseph ●November 8, 2004
Hello,
A survey of the literature on the net shows people showing how it
could be done using the Cordic algorithm using cordic processing
elements, where in each processing element calculates the cosine, sine
of the angles required for the process. Some other papers showed how
this could be done using distributed arithmetic methods where the
cosine values are stored in lookup tables. Why if we can store the
cosine values in lookup tables do people use cordic processing
elements implemented in hardware to calculate things like the DCT?
Does this have any advantages?
Thanks for the help
Warm Regards
Johnsy
On some processor architectures, memory can be expensive, so a LUT
cannot be done. On the other hand, implementing CORDIC in specialized
hardware can be very fast.
So it really depends on the particular application - and the
environment - what method is best for calculating the DCT (or any other
transform).
Stephan M. Bernsee
http://www.dspdimension.com
Stephan M. Bernsee <spam@dspdimension.com> wrote in message news:<2veib9F2l8l0cU1@uni-berlin.de>...
> On some processor architectures, memory can be expensive, so a LUT > cannot be done. On the other hand, implementing CORDIC in specialized > hardware can be very fast. > > So it really depends on the particular application - and the > environment - what method is best for calculating the DCT (or any other > transform).
If implemented in software polynomial approximations may also be used. One standard method for this is Horner's algorithm but i was wondering if any kind of polynomial approach is used in hardware implementation as well...? -Nithin
Nithin wrote:
> Stephan M. Bernsee <spam@dspdimension.com> wrote in message news:<2veib9F2l8l0cU1@uni-berlin.de>... > >>On some processor architectures, memory can be expensive, so a LUT >>cannot be done. On the other hand, implementing CORDIC in specialized >>hardware can be very fast. >> >>So it really depends on the particular application - and the >>environment - what method is best for calculating the DCT (or any other >>transform). > > > If implemented in software polynomial approximations may also be used. > One standard method for this is Horner's algorithm but i was wondering > if any kind of polynomial approach is used in hardware implementation > as well...?
Horner's method finds roots. How is it used to find trig functions? Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
>>>>> "Jerry" == Jerry Avins <jya@ieee.org> writes:
Jerry> Nithin wrote: >> Stephan M. Bernsee <spam@dspdimension.com> wrote in message news:<2veib9F2l8l0cU1@uni-berlin.de>... >> >>> On some processor architectures, memory can be expensive, so a LUT >>> cannot be done. On the other hand, implementing CORDIC in specialized >>> hardware can be very fast. >>> >>> So it really depends on the particular application - and the >>> environment - what method is best for calculating the DCT (or any other >>> transform). >> >> >> If implemented in software polynomial approximations may also be used. >> One standard method for this is Horner's algorithm but i was wondering >> if any kind of polynomial approach is used in hardware implementation >> as well...? Jerry> Horner's method finds roots. How is it used to find trig functions? It's also a method of evaluating polynomials. You know, instead of x^2+a*x+b directly, you evaluate (x + a)*x + b. Ray
Raymond Toy wrote:
>>>>>>"Jerry" == Jerry Avins <jya@ieee.org> writes: > > > Jerry> Nithin wrote: > >> Stephan M. Bernsee <spam@dspdimension.com> wrote in message news:<2veib9F2l8l0cU1@uni-berlin.de>... > >> > >>> On some processor architectures, memory can be expensive, so a LUT > >>> cannot be done. On the other hand, implementing CORDIC in specialized > >>> hardware can be very fast. > >>> > >>> So it really depends on the particular application - and the > >>> environment - what method is best for calculating the DCT (or any other > >>> transform). > >> > >> > >> If implemented in software polynomial approximations may also be used. > >> One standard method for this is Horner's algorithm but i was wondering > >> if any kind of polynomial approach is used in hardware implementation > >> as well...? > > Jerry> Horner's method finds roots. How is it used to find trig functions? > > It's also a method of evaluating polynomials. You know, instead of > x^2+a*x+b directly, you evaluate (x + a)*x + b.
Evaluating [(x + a)*x + b]x + c with Horner's method needs less computation than working it out directly when x is known? I don't see it. I'll look again. Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
news:2vhgfeF2k0m36U1@uni-berlin.de...
> Raymond Toy wrote: > > > It's also a method of evaluating polynomials. You know, instead of > > x^2+a*x+b directly, you evaluate (x + a)*x + b. > > Evaluating [(x + a)*x + b]x + c with Horner's method needs less > computation than working it out directly when x is known? I don't see > it. I'll look again.
Compared with the "direct method", Horner's method trades multiplies for adds and additionally is computationally more efficient for higher degrees. In the case of a quadratic, there is no computational efficiency gain in an architecture where adds and multiplies cost the same (Horner = 3 adds, 2 multiplies, direct = 2 adds, 3 multiplies). But for a cubic equation, the direct method requires 2 more multiplies and 1 more add, whereas Horner requires only one more multiply and one more add. For higher degrees, the savings is even more pronounced. Also, it may be a bit simpler to implement the Horner method because of the regular structure of the computations. (Don't know if that is an advantage or not.)
Jerry Avins <jya@ieee.org> wrote in message news:<2vhgfeF2k0m36U1@uni-berlin.de>...
> Raymond Toy wrote: > > >>>>>>"Jerry" == Jerry Avins <jya@ieee.org> writes: > > > > > > Jerry> Nithin wrote: > > >> Stephan M. Bernsee <spam@dspdimension.com> wrote in message news:<2veib9F2l8l0cU1@uni-berlin.de>... > > >> > > >>> On some processor architectures, memory can be expensive, so a LUT > > >>> cannot be done. On the other hand, implementing CORDIC in specialized > > >>> hardware can be very fast. > > >>> > > >>> So it really depends on the particular application - and the > > >>> environment - what method is best for calculating the DCT (or any other > > >>> transform). > > >> > > >> > > >> If implemented in software polynomial approximations may also be used. > > >> One standard method for this is Horner's algorithm but i was wondering > > >> if any kind of polynomial approach is used in hardware implementation > > >> as well...? > > > > Jerry> Horner's method finds roots. How is it used to find trig functions? > > > > It's also a method of evaluating polynomials. You know, instead of > > x^2+a*x+b directly, you evaluate (x + a)*x + b. > > Evaluating [(x + a)*x + b]x + c with Horner's method needs less > computation than working it out directly when x is known? I don't see > it. I'll look again. > > Jerry
Hi, I guess you can approximate a trigonometric function with say a least squares polynomial and then evaluate the polynomial to find the value of the trig. function. Nithin
>>>>> "Nithin" == Nithin <nitin_hsn@yahoo.com> writes:
Nithin> Jerry Avins <jya@ieee.org> wrote in message news:<2vhgfeF2k0m36U1@uni-berlin.de>... >> Raymond Toy wrote: >> >> >>>>>>"Jerry" == Jerry Avins <jya@ieee.org> writes: >> > >> > >> > Jerry> Horner's method finds roots. How is it used to find trig functions? >> > >> > It's also a method of evaluating polynomials. You know, instead of >> > x^2+a*x+b directly, you evaluate (x + a)*x + b. >> >> Evaluating [(x + a)*x + b]x + c with Horner's method needs less >> computation than working it out directly when x is known? I don't see >> it. I'll look again. >> >> Jerry Nithin> Hi, Nithin> I guess you can approximate a trigonometric function with say a least Nithin> squares polynomial and then evaluate the polynomial to find the value Nithin> of the trig. function. Yes, that can be done, but typically, it's a minimax polynomial or minimax rational function. You normally want to know what the max error of the approximation will be. Ray
>>>>> "Jon" == Jon Harris <goldentully@hotmail.com> writes:
Jon> "Jerry Avins" <jya@ieee.org> wrote in message Jon> news:2vhgfeF2k0m36U1@uni-berlin.de... >> Raymond Toy wrote: >> >> > It's also a method of evaluating polynomials. You know, instead of >> > x^2+a*x+b directly, you evaluate (x + a)*x + b. >> >> Evaluating [(x + a)*x + b]x + c with Horner's method needs less >> computation than working it out directly when x is known? I don't see >> it. I'll look again. Jon> Compared with the "direct method", Horner's method trades multiplies for adds Jon> and additionally is computationally more efficient for higher degrees. In the Jon> case of a quadratic, there is no computational efficiency gain in an Jon> architecture where adds and multiplies cost the same (Horner = 3 adds, 2 Jon> multiplies, direct = 2 adds, 3 multiplies). But for a cubic equation, the Jon> direct method requires 2 more multiplies and 1 more add, whereas Horner requires Jon> only one more multiply and one more add. For higher degrees, the savings is Jon> even more pronounced. It also typically has much better numerical stability so round-off won't hurt as much. Ray
