Hi, all, Who can tell me the difference between defining Heap size using DSP/BIOS configuration tool and using linker option "-heap"? If both are defined, which is the valid one? The same question also comes to me when talking about "stack size". Thanks for any comments and suggestion! Rose
Heap size definition using DSP/BIOS configuration tool or using linker options?
Started by ●September 20, 2004
Reply by ●September 22, 20042004-09-22
I believe that both heaps are "valid." Typically if you were NOT using BIOS then you would declare your heap in the linker options so that it would allocate some space for it. You would then use malloc() in order to use memory from that heap. With BIOS it is typical to declare your heaps in BIOS by checking the "create a heap in this memory" box. You would then use MEM_alloc() to use memory from the various heaps. I suppose you could use both simultaneously but I think it makes more sense to just pick one or the other. If you use both then the linker will include the code for both functions in your .out file which will just unnecessarily bloat your memory usage. Brad "rose" <axlrose@263.net> wrote in message news:6ff10342.0409191928.41f63d85@posting.google.com...> Hi, all, > > Who can tell me the difference between defining Heap size using > DSP/BIOS configuration tool and using linker option "-heap"? If both > are defined, which is the valid one? > > The same question also comes to me when talking about "stack size". > > Thanks for any comments and suggestion! > > Rose
