Hi, I am a student working with a TMS320C6713DSK from TI. The dsk functioned properly for a few weeks, during which I ran tutorial programs and other simple projects on it. A few days ago, however, the board suddenly starts to give me problems and I can't even start CCS now. If I boot my PC, connect to the DSK, then run the 6713Diagnostic utility that came with CCS, all the general tests past. Now if I start CCS, the window opens, about 10 seconds later I am forced to exit CCS by this error message: "Error 0x800000A0/-2090 Fatal Error during :Execution, Target Communication, Device Driver: Timeout on Emulator or Target Proessor. It is....." If I simply power cycle the dsk, then run the dianostic utility, it fails at the Emulator diagnostics, or the DSP diagnostics. When I try starting CCS, I get error such as "Can't Initialize Target CPU: Error 0x00000200/-536866794 Error During: OCS Unknown Error I/O Port = 540 Board Name: C6713DSK Cpu Name CPU_1 ...." Could someone give me some advices? I would really appreciate your help. This is the first time I am working with a DSP and I am learning quite slowly. Hwanhee Lee
can't start CCS, 6713 DSK
Started by ●November 12, 2004
Reply by ●November 16, 20042004-11-16
Hwanhee wrote:> If I boot my PC, connect to the DSK, then run the 6713Diagnostic > utility that came with CCS, all the general tests past. Now if I start > CCS, the window opens, about 10 seconds later I am forced to exit CCS > by this error message: > > "Error 0x800000A0/-2090 > Fatal Error during :Execution, Target Communication, Device Driver: > Timeout on Emulator or Target Proessor. It is....."One possibility is that you tried to burn the flash memory with a new image and failed. It this case the DSP could run into a state where CCS can't access it. It can be other reasons as well. Try to press the reset button on the DSK and then quickly click on retry, this usually solves the problem. -- Lars Ljung
Reply by ●November 17, 20042004-11-17
Lars, thanks for you reply. I haven't actually burned anything into the flash, but I still tried the reset followed by clicking on retry. It didn't solve my problem... however I also found out on the yahoo C6x discussion group that quite a number of people have the same problem... Hwanhee Lars Ljung <larslj@kthkth.se> wrote in message news:<jSsmd.16229$up1.9831@text.news.blueyonder.co.uk>...> Hwanhee wrote: > > If I boot my PC, connect to the DSK, then run the 6713Diagnostic > > utility that came with CCS, all the general tests past. Now if I start > > CCS, the window opens, about 10 seconds later I am forced to exit CCS > > by this error message: > > > > "Error 0x800000A0/-2090 > > Fatal Error during :Execution, Target Communication, Device Driver: > > Timeout on Emulator or Target Proessor. It is....." > > One possibility is that you tried to burn the flash memory with a new > image and failed. It this case the DSP could run into a state where CCS > can't access it. It can be other reasons as well. Try to press the reset > button on the DSK and then quickly click on retry, this usually solves > the problem.
Hwanhee wrote:> Lars, thanks for you reply. I haven't actually burned anything into > the flash, but I still tried the reset followed by clicking on retry. > It didn't solve my problem... however I also found out on the yahoo > C6x discussion group that quite a number of people have the same > problem...Are you using USB or a JTAG emulator? There is a utility to reset the emulator, this could help. Maybe it could be something with the configuration, are you sure it matches your DSP/DSK? I don't have any other ideas to solve it. -- Lars
Hi Lars, After trying really hard to remember what exactly I did before the board broke.... I realized I was indeed experimenting with the FlashBurn Utility Tutorial that came with the DSK -- now I've finally learnt what is wrong with it!!! When you mentioned 'reset' followed by 'retry', did you mean: 1. power cycle the DSK 2. start CCS 3. when the error message occurs, push 'reset' then click on 'retry'? THANKS!!! Hwanhee Lars Ljung <larslj@kthkth.se> wrote in message news:<jSsmd.16229$up1.9831@text.news.blueyonder.co.uk>...> Hwanhee wrote: > > If I boot my PC, connect to the DSK, then run the 6713Diagnostic > > utility that came with CCS, all the general tests past. Now if I start > > CCS, the window opens, about 10 seconds later I am forced to exit CCS > > by this error message: > > > > "Error 0x800000A0/-2090 > > Fatal Error during :Execution, Target Communication, Device Driver: > > Timeout on Emulator or Target Proessor. It is....." > > One possibility is that you tried to burn the flash memory with a new > image and failed. It this case the DSP could run into a state where CCS > can't access it. It can be other reasons as well. Try to press the reset > button on the DSK and then quickly click on retry, this usually solves > the problem.
Reply by ●November 18, 20042004-11-18
Lars Ljung <larslj@kthkth.se> wrote in message news:<57Qmd.17109$up1.9935@text.news.blueyonder.co.uk>...> Hwanhee wrote: > > Lars, thanks for you reply. I haven't actually burned anything into > > the flash, but I still tried the reset followed by clicking on retry. > > It didn't solve my problem... however I also found out on the yahoo > > C6x discussion group that quite a number of people have the same > > problem... > > Are you using USB or a JTAG emulator? There is a utility to reset the > emulator, this could help. Maybe it could be something with the > configuration, are you sure it matches your DSP/DSK? I don't have any > other ideas to solve it.THANKS :-) I am using the USB and embedded JTAG on the DSK. I have configured CCS for dsk6713.... Hwanhee.
