Question about comparing PSD's
Started by Amras November 16, 2004
Hi,
 How can we compare the Power Spectral Densities of two signals ? I do
not want a visual technique. One method would be to compute the CDF's
of the PSD's and compare those using a confidence test.Is there any
other technique.
Thanks,
Sarma
sarma.vangala@gmail.com (Amras) writes:
> Hi, > How can we compare the Power Spectral Densities of two signals ? I do > not want a visual technique. One method would be to compute the CDF's > of the PSD's and compare those using a confidence test.Is there any > other technique. > Thanks, > Sarma
What are you trying to accomplish? Are you trying to find out if two signals are correlated? Why not use a cross-correlation function? -- % Randy Yates % "Maybe one day I'll feel her cold embrace, %% Fuquay-Varina, NC % and kiss her interface, %%% 919-577-9882 % til then, I'll leave her alone." %%%% <yates@ieee.org> % 'Yours Truly, 2095', *Time*, ELO http://home.earthlink.net/~yatescr
Kulback divergence.
Hi,
 Thanks for the replies. I am working on a signal processing technique
where a machine has to take a decision based on the PSD's of two
incoming signals. So I was wondering if there is a mechanism to
convert the entire PSD plot to a simple (if possible) single value.
Thanks,
Sarma
Stan Pawlukiewicz <spam@spam.mitre.org> wrote in message news:<cnd5g0$gg$1@newslocal.mitre.org>...
> Amras wrote: > > Hi, > > How can we compare the Power Spectral Densities of two signals ? I do > > not want a visual technique. One method would be to compute the CDF's > > of the PSD's and compare those using a confidence test.Is there any > > other technique. > > Thanks, > > Sarma > > Kulback divergence.
On 2004-11-17 05:09:03 +0100, sarma.vangala@gmail.com (Amras) said:
> Hi, > Thanks for the replies. I am working on a signal processing technique > where a machine has to take a decision based on the PSD's of two > incoming signals. So I was wondering if there is a mechanism to > convert the entire PSD plot to a simple (if possible) single value. > Thanks, > Sarma
You could probably use the higher moments of the distribution such as skewness and kurtosis to characterize and compare the two PSDs... -- Stephan M. Bernsee http://www.dspdimension.com
"Amras" <sarma.vangala@gmail.com> wrote in message
news:ae49a4ed.0411162009.43bdeb9b@posting.google.com...
> Hi, > Thanks for the replies. I am working on a signal processing technique > where a machine has to take a decision based on the PSD's of two > incoming signals. So I was wondering if there is a mechanism to > convert the entire PSD plot to a simple (if possible) single value. > Thanks, > Sarma >
Hello Sarma, If the PSDs are single parameter PSDs, then the answer is a simple yes. If the PSDs have two or more parameters, which ones do you wish to discard? Clay
> > Kulback divergence. >
I'll see your Kullback and raise you a Leibler.
Peter Kootsookos wrote:
> Stan Pawlukiewicz <spam@spam.mitre.org> wrote > > >>Kulback divergence. >> > > > I'll see your Kullback and raise you a Leibler.
So called.
On 18 Nov 2004 17:33:38 -0800, p.kootsookos@iolfree.ie (Peter
Kootsookos) wrote:
>Stan Pawlukiewicz <spam@spam.mitre.org> wrote > >> >> Kulback divergence. >> > >I'll see your Kullback and raise you a Leibler.
Hi Dr. K, hope ya' know I have the most *profound* respect for you, ... but I must ask: "Did you forget to take your medication today? :-) [-Rick-]
r.lyons@_BOGUS_ieee.org (Rick Lyons) wrote
> hope ya' know I have the most *profound* respect > for you, ... but I must ask: "Did you forget to take > your medication today? :-)
;-) I've just usually heard what StanP was referring to as the "Kullback-Leibler" divergence. See, e.g. http://www.cis.hut.fi/aapo/papers/NCS99web/node26.html Ciao, Peter K.
