Half-Band Filter Length
Started by Randy Yates November 17, 2004
"Randy Yates" <yates@ieee.org> wrote in message
news:llcwzrnt.fsf@ieee.org...
>> >> It is not exactly true that the middle coefficient will be equal to >> the sum of the other coefficients. The sum of the coefficients is >> equal to magnitude response at the zero frequency and for the >> half-band filters the magnitude response at zero frequency is either >> 1-delta or 1+delta where delta is the ripple in the pass- and stopband. > > Why? Why is the response at DC necessarily one of these two values? Why > couldn't it be the case that 1-delta < H(0) < 1+delta?
Randy, I was surprised at this once upon a time - having fiddled quite a bit with the Remez algorithm on potentially more general functions. However, I believe that Rabiner & Gold showed in their book and Parks & McClellan took advantage of the fact that peaks of a minimax approximation appear at the band edges ( i.e. H(0)= |delta| ). So, Juha implies a minimax solution here - and there will be a peak of the error at f=0; H(0)=+/-delta where delta is the peak minimax error or ripple. It is possible to force H(0) to be 1.00000 (or at whatever scale you like) and, thus, H(fs/2)=0 and this comes at the expense of the peak ripple - which will be larger if you force this equality. This zero-forcing constraint may be of some advantage if you plan on using zero stuffing in the frequency domain around fs/2 to get temporal interpolation. That is because there won't be any sharp edges created by the "abrupt" introduction of zeros in frequency - because there will be a double zero at fs/2 after applying this type of half-band filter. Fred
