The definition of non-minimum phase system is the system whose zeros and poles are outside the unit circle of Z-domain. But what does it mean? What problem does it cause in terms of non-minimum phase? Thank you.
what is non-minimum phase system in essence?
Started by ●November 17, 2004
Reply by ●November 17, 20042004-11-17
Annie Chen wrote:> The definition of non-minimum phase system is the system whose zeros > and poles are outside the unit circle of Z-domain. But what does it > mean? What problem does it cause in terms of non-minimum phase? Thank > you.That's not a definition, but a consequence. Minimum-phase systems are what one commonly builds from passive components (although lattice four-port structures need not be minimum phase). You might take as a definition that no system with the same frequency response can have less phase shift. Their frequency and phase responses are related by classical Bode plots, in which slopes of 20 dB/decade give rise to phase shifts of 90 degrees. More technically, the log magnitude and phase responses form a Hilbert transform pair. Simply put, non-minimum phase implies more phase shift than that. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●November 18, 20042004-11-18
in article 302jnnF2rqa3aU1@uni-berlin.de, Jerry Avins at jya@ieee.org wrote on 11/17/2004 22:37:> Annie Chen wrote: > >> The definition of non-minimum phase system is the system whose zeros >> and poles are outside the unit circle of Z-domain. But what does it >> mean? What problem does it cause in terms of non-minimum phase? Thank >> you. > > That's not a definition, but a consequence. Minimum-phase systems are > what one commonly builds from passive components (although lattice > four-port structures need not be minimum phase). You might take as a > definition that no system with the same frequency response can have less > phase shift. Their frequency and phase responses are related by > classical Bode plots, in which slopes of 20 dB/decade give rise to phase > shifts of 90 degrees. More technically, the log magnitude and phase > responses form a Hilbert transform pair. Simply put, non-minimum phase > implies more phase shift than that.in my mind, the "essence" of the meaning of non-minimum phase system is that it is not a minimum phase system and the essence of the minimum phase system is that, given a particular magnitude response, the min-phase system has less phase shift than all other systems of the same magnitude response. for LTI systems with rational transfer functions (those with poles and zeros), we know that the poles have to be in the left half-plane of the analog s-plane (inside the unit circle of the z-plane), but the zeros can be either side. if the zeros are reflected to the right half-plane, the magnitude response is the same but the phase shift is more than what would be the case if all of the zeros were in the left half-plane. and, it is true (but hard to prove, who can prove it here on comp.dsp?? and without residue theory?) that for rational LTI systems that are minimum phase, that the Hilbert transform of the natural log of the magnitude response is the same as the phase response in radians. r b-j
In article <cc913cd1.0411171905.6141cae0@posting.google.com>, Annie Chen <anniechenming@gmail.com> wrote:>The definition of non-minimum phase system is the system whose zeros >and poles are outside the unit circle of Z-domain. But what does it >mean? What problem does it cause in terms of non-minimum phase?Increased phase results in increased delay thru the system. So a non-minimum phase system will (almost by definition) have a larger phase and thus more delay than would a minimum phase system with the the identical magnitude frequency response. Why the phase (especially near the vicinity of the zero) must decrease when reflecting a zero from outside to inside the unit circle is left as an exercise for the student. IMHO. YMMV. -- Ron Nicholson rhn AT nicholson DOT com http://www.nicholson.com/rhn/ #include <canonical.disclaimer> // only my own opinions, etc.
anniechenming@gmail.com (Annie Chen) wrote in message news:<cc913cd1.0411171905.6141cae0@posting.google.com>...> The definition of non-minimum phase system is the system whose zeros > and poles are outside the unit circle of Z-domain.Wrong. The poles must be inside the unit circle for the system to be both causal and stable. It is the zeros that can be inside or outside the unit circle. If some zeros are outside the unit circle and some are inside, one speaks of a "mixed phase" system. If all the zeros are outside the unit circle, one speaks of a "maximum phase" system.> But what does it mean?The minimum phase property has to do with time delays in the impulse response. Minimum phase systems have an impulse response where the energy is concentrated at an as early time as possible.> What problem does it cause in terms of non-minimum phase?Well, minimum phase systems are easy to handle from a mathemathical point of view. Since all the zeros are inside the unit circle, the inverse filter is stable. One can do certain things with minimum phase systems that one can not do with mixed phase systems. If the system one investigates is not minimum phase, one must be very careful with how one conducts the analysis. The "easy" system identification methods are based on the assumption of minimum phase. If it's sufficient to describe the system in terms of the Power Spectral Density, PDF, of its transfer function, minimum phase techniques are often good enough regardless of whether the system actually is minimum phase, or not. If you need to estimate the time-domain impulse response from a frequency domain measurement, you might find yourself in big trouble if you are only able to estimate the PDF, which does not preserve the phase response of the system. You can estimate the minimum phase impulse response from a PDF. You can not estimate mixed phase impulse responses from a PDF. So if you estimate a minimum phase impulse response for a system that actually is mixed phase, you make a mistake which may or may not be important. It depends on the application.> Thank you.Y' welcome. Rune
robert bristow-johnson wrote: ...> and, it is true (but hard to prove, who can prove it here on comp.dsp?? and > without residue theory?) that for rational LTI systems that are minimum > phase, that the Hilbert transform of the natural log of the magnitude > response is the same as the phase response in radians.If I had known you were coming, I would not only have baked a cake, I would have held my peace. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Rune Allnor wrote: ...> Spectral Density, PDF, ..."PDF" --> probability density function. The identity isn't obvious. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
If we consider a simple stable, 1-st order, low-pass, system (s-z)/(s+p) (with z and p positive), with an "unstable" zero, i.e. in the right half s plane, or outside the unit disk in the Z domain, then physically, it translates into a system with an initial response which is in the opposite direction of the applied stimulus, and of it's long term response (ex. to a step input). A practical example which helps to see this, is in handling a long flexible stick, or beam. A simple, crude approximation would consist of two rigid sticks, joined by some elastic, flexible, spring-like, coupling. If one holds one stick at one end, and applies some torque to change the angular orientation of the overall stick, the other end will inevitably, initially (i.e. at t=0+), turn in the opposite direction. We can then see how this will add to the overall response time, or phase delay in the frequency response. A "stable" zero, on the other hand, ex. (s+z)/(s+p), which effectively adds an anticipative component to the response (the purpose of P in PID-based control), serves to reduce the overall response time, precisely because of it's anticipative character. Such "intuitive" characterization of otherwise technical terminology hopefully serves to get a better "feel" for what's really going on in a system and it's sub-components, and therefore how to better control it.
In article <f56893ae.0411180114.27aced47@posting.google.com>, Rune Allnor <allnor@tele.ntnu.no> wrote:>anniechenming@gmail.com (Annie Chen) wrote in message >news:<cc913cd1.0411171905.6141cae0@posting.google.com>... >> The definition of non-minimum phase system is the system whose zeros >> and poles are outside the unit circle of Z-domain. > >Wrong. The poles must be inside the unit circle for the system to be >both causal and stable. It is the zeros that can be inside or outside >the unit circle.Well, she didn't specify that the system be causal and stable. (for instance, her class project could be to build a hypothetical time machine). And what happens if there enough zeros very close to or on top of a pole outside the unit circle? Couldn't the system then be stable or conditionally stable? IMHO. YMMV. -- Ron Nicholson rhn AT nicholson DOT com http://www.nicholson.com/rhn/ #include <canonical.disclaimer> // only my own opinions, etc.
in article 304dq4F2rv9a0U3@uni-berlin.de, Jerry Avins at jya@ieee.org wrote on 11/18/2004 15:08:> robert bristow-johnson wrote: > > ... > >> and, it is true (but hard to prove, who can prove it here on comp.dsp?? and >> without residue theory?) that for rational LTI systems that are minimum >> phase, that the Hilbert transform of the natural log of the magnitude >> response is the same as the phase response in radians. > > If I had known you were coming, I would not only have baked a cake, I > would have held my peace.why, on earth, for, Jerry??! your common sense wisdom, your experience, etc. are here for us to hear. i would *still* like to read someone prove that for a continuous-time LTI system with a rational transfer function (H(s) is a ratio of polynomials of s, i.e. H(s) has poles and zeros in the s-plane), that having all poles in the left half-plane (necessary for stability) and all zeros in the left half-plane results in the phase response (measured in radians) being the Hilbert Transform of the natural log of the magnitude response. to do it without resorting to residue theory of complex integration would make the explanation more accessible, especially to folks who haven't messed around with a course in complex variables. also to show that if any of those zeros get reflected to the right half-plane, the magnitude response stays the same but there is *more* phase shift than the system with all zeros in the left half-plane (thus justifying the term "minimum phase system" for such a system). i might get to it eventually if no one else does. but i don't have a lot of time as of recent. hey Airy, why don't you try it out? it might be a good way to rehabilitate your reputation on comp.dsp . -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
