Block Diagrams
Started by Tim Wescott October 31, 2004
On Fri, 05 Nov 2004 07:39:42 -0800, Tim Wescott wrote:
> Michael Hemmer wrote: > >> Active8 wrote: >> [http://www.wescottdesign.com/articles/BlockDiagrams/BlockDiagrams_html_m3f7dd27a.gif >> >> in http://www.wescottdesign.com/articles/BlockDiagrams/BlockDiagrams.html] >> >>> Yeah. I see the blocks. The graphics are fine even squinting. For >>> some reason though, the math graphic to the right of the limiter >>> block doesn't render. It downloads and views in a viewer, >> >> Hmm... Which viewer? ImageMagick Display doesn't display the image at >> all, while Internet Explorer and XnView show only the upper two thirds >> of it (the latter even using magenta as the background color), so I >> suspect the file might indeed be erroreous (due to a loose >> interpretation of the specs or whatever). >> >>> but >>> Firefox msgs that it can't be displayed... the message overflows the >>> space allowed for the image so I don't know wtf. >> >> "The image ... cannot be displayed, because it contains errors." is the >> message shown by Mozilla in the "Properties" dialog when opening the >> image file alone. (Heaven knows why it's not there when viewing the >> whole page.) Chances are you'll find that information in the same place >> within Firefox as well. >> >> Michael > > Hm. That must have happened when I uploaded it - it was (he says > plaintively) fine when I checked it on my machine. I'll have to fix that.
It happens. BTW, WS_FTP [Pro] rules. The train is pretty obnoxious, though. -- Best Regards, Mike
On Fri, 05 Nov 2004 14:15:23 +0100, Michael Hemmer wrote:
> Active8 wrote: > [http://www.wescottdesign.com/articles/BlockDiagrams/BlockDiagrams_html_m3f7dd27a.gif > in http://www.wescottdesign.com/articles/BlockDiagrams/BlockDiagrams.html] > >> Yeah. I see the blocks. The graphics are fine even squinting. For >> some reason though, the math graphic to the right of the limiter >> block doesn't render. It downloads and views in a viewer, > > Hmm... Which viewer?
Oh... Irfan view. But I see what looks like two corrupted, horizontal lines just below the lower extent of the brackets where it should be pink - like you'd see if you scanned a figure and the caption turned out like two single pixel lines. -- Best Regards, Mike
