DSP books
Started by DSP curious October 31, 2004
Hi Andor.
Andor> Markus Erne's phd thesis at ETH Zurich might be of interest to
Andor> you: "Signal adaptive audio coding using wavelets and rate
Andor> optimization"
Andor> Regards, Andor
Is it available somewhere online?? (I couldn't find it).
/Mads
Mads G. Christensen wrote:
> Hi Andor. > > Andor> Markus Erne's phd thesis at ETH Zurich might be of interest to > Andor> you: "Signal adaptive audio coding using wavelets and rate > Andor> optimization" > Andor> Regards, Andor > > Is it available somewhere online?? (I couldn't find it).
I couldn't either. But you may want to look at the DAFx homepage, there is quite a lot of wavelet based material online (I saw quite an interesting one which proposed signal processing on the wavlet coefficients). http://www.dafx.de/ Regards, Andor
Andor wrote:
> Bob Cain wrote: > ... > >>They have mostly been useful for data reduction of video >>information and for other kinds of encoding. I'm not sure >>if anyone has tried to apply the same methods to audio but >>my suspicion is that the artifacts, while ok for video and >>fingerprints, would be horrible for audio. > > > Markus Erne's phd thesis at ETH Zurich might be of interest to you: > "Signal adaptive audio coding using wavelets and rate optimization"
I was hoping I'd be contradicted in the above statement by advancements happening since I looked at them. :-) I'm very interested, do you happen to have a link to that? Thanks, Bob -- "Things should be described as simply as possible, but no simpler." A. Einstein
On 2004-11-03 08:48:08 +0100, Bob Cain <arcane@arcanemethods.com> said:
> I was hoping I'd be contradicted in the above statement by advancements > happening since I looked at them. :-)
I think I already did that... :-) -- Stephan M. Bernsee http://www.dspdimension.com
May I also suggest the Wavelet.org page (http://www.wavelet.org) which
issues a Wavelet digest that is highly recommended and keeps you up to
speed on developments in that area.
Stephan M. Bernsee
