Hello, I am developing a software modulator and am currently working on the qpsk portion of it. This problem will apply to pretty much all modulation schemes however. Let me first explain my algorithm: This program needs to be very fast (capable 100 mhz sampling rates) so I am pregenerating all of my samples. The user inputs the center frequency and the sampling rate and I fill a series of buffers with a period worth of samples for each of the 4 phase offsets (0,pi/2,pi,3pi/2). The problem comes in with my calculation of how many samples are needed for a period. If the center frequency is 1Mhz and sample rate is 10 Mhz there is no problem. The number of samples/period is (sample rate)/(frequency) = 10 samples. Now, if I use a frequency of 1.2 Mhz and a sample rate of 20 Mhz, I get 16 2/3 samples in a period. Obviously I cannot represent 2/3 of a sample and my timing is thrown off. This problem also occurs when deciding how many samples should be output for a symbol. If (sample rate)/(symbol rate) doesn't come out to be an integer, my timing is thrown off for the symbol rate. Any ideas? I have thought about some kind of sample averaging method, but I am not sure.
Software modulation timing issue
Started by ●November 22, 2004
Reply by ●November 29, 20042004-11-29
Well i know no one responded, but I thought possibly someone would be interested in the solution. Lets say we have a symbol rate of 1.2 Mhz and sample rate of 20 Mhz. 20 / 1.2 = 16 2/3 To account for the problematic 2/3 sample, we simply over compensate and under compensate with relation to the fractional sample. So for 16 2/3 samples we use 16 and 17 samples. Since the fraction is 2/3 we output the following: symbol n: 17 samples symbol n+1: 17 samples symbol n+2: 16 samples This pattern will then repeat.
