Hi all, These two terms from two different domain confused me a lot. FT is for deterministic analysis, whereas PSD is the FT of the autocorrelation function, which is for stochastical signal analysis... Am I right? I am wondering if we use Matlab generate some random signal, and treat it as a dterministic signal, and take its FT, versus using Matlab to take its PSD, Should these two things somehow related? In what capacity are they related?
taking Fourier Transform of random signal vs. taking PSD of random signal?
Started by ●November 24, 2004
Reply by ●November 24, 20042004-11-24
kiki wrote:> Hi all, > > These two terms from two different domain confused me a lot. > > FT is for deterministic analysis, whereas PSD is the FT of the > autocorrelation function, which is for stochastical signal analysis... > > Am I right? > > I am wondering if we use Matlab generate some random signal, and treat it as > a dterministic signal, and take its FT, versus using Matlab to take its PSD, > > Should these two things somehow related? > > In what capacity are they related? > >Yes, kinda. The power spectral density of a signal is the fourier transform of the expected value of the autocorrelation function, so you can never actually measure it (you can only measure samples of the signal and make guesses). Assuming that you could measure a signal, autocorrelate it, and get a result that is largely representative of the expected value of the autocorrelation of the signal, you can use the fact that the autocorrelation operation convolves the signal with it's time-reversed self. This means that the Fourier transform of the autocorrelated signal is the Fourier transform of the signal times the complex conjugate of the signal, which is just the amplitude squared of the Fourier transform of the signal. Matlab, I believe, also does some bin averaging, because the Fourier transform of a truly random signal has quite a bit of hash on it in the frequency domain which generally isn't representative of the true signal. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
