Jim, Can you either stop intentially re-arranging the letters and spacings in the subject line of these posts ... or if it's unintentional, fix your usenet posting application so it stops doing so? It's a little disorientating to have a thread breaking off into 5 or 6 different permutations within the group ( appears to be localized to each of your replies ). Regards, Robert jim <"N0sp"@m.sjedging@mwt.net> wrote:> > >robert bristow-johnson wrote: >> other than the gain getting smaller and smaller, the >> only other effect is to reduce this aperture effect to get closer and closer >> to sampling at the ideal instance. > >This is not true. Even a wide aperture samples just as closely or >possibly even closer to the ideal instance. The regularity and >self-similarity of each acquisition is what effects the capability for >sampling at the ideal instance not the measure of time over which the >sample is acquired as you claim . > >-jim( modify address for return mail ) www.numbersusa.com www.americanpatrol.com
Re: Sampling Theorem and the input S/H, sampling aperture, outputZero Order Hold
Started by ●November 28, 2004
