Hi all DSP experts :-) I have a problem with the McBSP receive interrupt on the 2812 DSP from Texas. Do anyone have working code on this DSP ? I have done much the same as on the 5510 DSP where I did not have this problem, so I do not understand why it is not working here ? Thanks in advance. Torgeir -- Best regards Torgeir Jakobsen Development Engineer, Technology Department Aanderaa Instruments AS e-mail: torgeir.jakobsen@aanderaa.no Phone: +47 55109977 Fax: +47 55109910
Texas DSP 2812 and McBSP
Started by ●November 30, 2004
Reply by ●November 30, 20042004-11-30
There are more things you need to enable to get interrupts on the 2812 than there are on the 5510. Are you sure that you have enabled the PIE, set the proper bit in the PIEIER for the McBSP interrupt, acknowledged the PIE (PIEACK), set the corresponding IER bit, and cleared the INTM bit? Also, are you sure that you have configured the McBSP to generate a receive interrupt? Are you seeing the RRDY flag which indicates there is data in the McBSP to be read? Brad "Torgeir Jakobsen" <torgeir.jakobsen@aanderaa.no> wrote in message news:41acb09f$1@news.wineasy.se...> Hi all DSP experts :-) > > I have a problem with the McBSP receive interrupt on the 2812 DSP from > Texas. Do anyone have working code on this DSP ? > I have done much the same as on the 5510 DSP where I did not have this > problem, so I do not understand why it is not working here ? > > Thanks in advance. > > Torgeir > > -- > Best regards > Torgeir Jakobsen > Development Engineer, Technology Department > Aanderaa Instruments AS > e-mail: torgeir.jakobsen@aanderaa.no > Phone: +47 55109977 > Fax: +47 55109910 > >
Reply by ●December 1, 20042004-12-01
Thank you Brad, I have done the things you describe: - Enabled PIE - Set PIEIER for McBSP receive interrupt - Acknowledged the PIE - Set IER - Cleared INTM. First it looked like RRDY was not set, but now the RRDY is set. I have also enabled the transmit interrupt to see if this was working better. I can see that RRDY and XRDY is set but the PIEIFR register (and PIEACK) does not flag any interrupt, even if McBSP is set to generate interrupt on RRDY and XRDY and the PIEIER is set to enable both interrupts. I am using the sample rate generator, and the clock and frame signals are generated correctly (measured with oscilloscope). Any suggestions ? "Brad Griffis" <bradgriffis@hotmail.com> wrote in message news:4m9rd.1094$nE7.772@newssvr17.news.prodigy.com...> There are more things you need to enable to get interrupts on the 2812than> there are on the 5510. Are you sure that you have enabled the PIE, setthe> proper bit in the PIEIER for the McBSP interrupt, acknowledged the PIE > (PIEACK), set the corresponding IER bit, and cleared the INTM bit? > > Also, are you sure that you have configured the McBSP to generate areceive> interrupt? Are you seeing the RRDY flag which indicates there is data in > the McBSP to be read? > > Brad > > "Torgeir Jakobsen" <torgeir.jakobsen@aanderaa.no> wrote in message > news:41acb09f$1@news.wineasy.se... > > Hi all DSP experts :-) > > > > I have a problem with the McBSP receive interrupt on the 2812 DSP from > > Texas. Do anyone have working code on this DSP ? > > I have done much the same as on the 5510 DSP where I did not have this > > problem, so I do not understand why it is not working here ? > > > > Thanks in advance. > > > > Torgeir > > > > -- > > Best regards > > Torgeir Jakobsen > > Development Engineer, Technology Department > > Aanderaa Instruments AS > > e-mail: torgeir.jakobsen@aanderaa.no > > Phone: +47 55109977 > > Fax: +47 55109910 > > > > > >
