I am relatively new to DSP and I have what seems like a simple question, but I have not been able to find in answer to it by reading DSP books. If the goal is to design a frequency-selective filter, then is there any reason not to simply take the FFT of a signal (or a window thereof), apply our filter by directly multiplying the filter amplitude response with the FFT of our signal, and then take the IFFT (inverse FFT) to get back the filtered signal? Is there any disadvantage to doing this as opposed to using an FIR or IIR filter? For the mathematically inclined ... Suppose we have a signal x(k) and it's DFT (calculated via FFT) is X(f). We also have a desired filter specification represented by it's amplitude response, A(f). Then, a filtered version of this signal, y(k) can be found: y(k) = IFFT { X(f) A(f) } I tried doing this using MATLAB and some noisy data for the specific case of a highpass filter with a cutoff frequency very close to DC, and it worked great. I simply used an ideal highpass filter characteristic. Is there something I'm missing? If it is this simple, then why do DSP books focus so much on FIR and IIR filters? I figure I'm missing something important and probably "obvious". Please enlighten me ... politely. On a related note .., I was trying to design an FIR filter (using a windowed truncated impulse response) to filter this same data. The problem I was having is that there was an initial transient of relatively long duration and of an amplitude that was several orders of magnitude larger than the "good" filtered data. Is there a way to avoid this - i.e. is there a way to eliminate or greatly minimize this transient? I tried using an IIR filter and the problem was even worse. For this particular application, the data is logged and then stored on a computer, so the processing doesn't need to be real-time, any type of filter (non-causal, etc.) should be fine. Any advice/insight would be appreciated.
Why not just filter directly in the frequency domain using the fft and ifft?
Started by ●December 1, 2004
Reply by ●December 1, 20042004-12-01
todd.leonhardt@gmail.com wrote:> I am relatively new to DSP and I have what seems like a simple > question, but I have not been able to find in answer to it by reading > DSP books. > > If the goal is to design a frequency-selective filter, then is there > any reason not to simply take the FFT of a signal (or a window > thereof), apply our filter by directly multiplying the filter amplitude > response with the FFT of our signal, and then take the IFFT (inverse > FFT) to get back the filtered signal? Is there any disadvantage to > doing this as opposed to using an FIR or IIR filter?Provided that you don't attempt to filter too vigorously, it can work just fine. It's relatively easy when you can FFT the entire signal at once, but not many circumstances allow that. If you need to operate on the signal piecemeal, then special procedures are needed to stitch the filtered signal back together. Look up "overlap-save" and overlap-add".> > For the mathematically inclined ... > Suppose we have a signal x(k) and it's DFT (calculated via FFT) is > X(f). > We also have a desired filter specification represented by it's > amplitude response, A(f). Then, a filtered version of this signal, > y(k) can be found: > y(k) = IFFT { X(f) A(f) } > > I tried doing this using MATLAB and some noisy data for the specific > case of a highpass filter with a cutoff frequency very close to DC, and > it worked great. I simply used an ideal highpass filter > characteristic. Is there something I'm missing? If it is this simple, > then why do DSP books focus so much on FIR and IIR filters? I figure > I'm missing something important and probably "obvious". Please > enlighten me ... politely. > > On a related note .., I was trying to design an FIR filter (using a > windowed truncated impulse response) to filter this same data. The > problem I was having is that there was an initial transient of > relatively long duration and of an amplitude that was several orders of > magnitude larger than the "good" filtered data. Is there a way to > avoid this - i.e. is there a way to eliminate or greatly minimize this > transient? I tried using an IIR filter and the problem was even worse. > For this particular application, the data is logged and then stored on > a computer, so the processing doesn't need to be real-time, any type of > filter (non-causal, etc.) should be fine. Any advice/insight would be > appreciated.Unless an FIR filter is filled with data, the output doesn't follow what the whole filter was designed to do. The not-filled beginning and end are transients. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●December 2, 20042004-12-02
"Jerry Avins" <jya@ieee.org> wrote in message news:317h9pF32kcphU1@individual.net...> todd.leonhardt@gmail.com wrote: > >> I am relatively new to DSP and I have what seems like a simple >> question, but I have not been able to find in answer to it by reading >> DSP books. >> >> If the goal is to design a frequency-selective filter, then is there >> any reason not to simply take the FFT of a signal (or a window >> thereof), apply our filter by directly multiplying the filter amplitude >> response with the FFT of our signal, and then take the IFFT (inverse >> FFT) to get back the filtered signal? Is there any disadvantage to >> doing this as opposed to using an FIR or IIR filter? > > Provided that you don't attempt to filter too vigorously, it can work > just fine. It's relatively easy when you can FFT the entire signal at > once, but not many circumstances allow that. If you need to operate on > the signal piecemeal, then special procedures are needed to stitch the > filtered signal back together. Look up "overlap-save" and overlap-add". >> >> For the mathematically inclined ... >> Suppose we have a signal x(k) and it's DFT (calculated via FFT) is >> X(f). >> We also have a desired filter specification represented by it's >> amplitude response, A(f). Then, a filtered version of this signal, >> y(k) can be found: >> y(k) = IFFT { X(f) A(f) } >> >> I tried doing this using MATLAB and some noisy data for the specific >> case of a highpass filter with a cutoff frequency very close to DC, and >> it worked great. I simply used an ideal highpass filter >> characteristic. Is there something I'm missing? If it is this simple, >> then why do DSP books focus so much on FIR and IIR filters? I figure >> I'm missing something important and probably "obvious". Please >> enlighten me ... politely. >> >> On a related note .., I was trying to design an FIR filter (using a >> windowed truncated impulse response) to filter this same data. The >> problem I was having is that there was an initial transient of >> relatively long duration and of an amplitude that was several orders of >> magnitude larger than the "good" filtered data. Is there a way to >> avoid this - i.e. is there a way to eliminate or greatly minimize this >> transient? I tried using an IIR filter and the problem was even worse. >> For this particular application, the data is logged and then stored on >> a computer, so the processing doesn't need to be real-time, any type of >> filter (non-causal, etc.) should be fine. Any advice/insight would be >> appreciated. > > Unless an FIR filter is filled with data, the output doesn't follow what > the whole filter was designed to do. The not-filled beginning and end > are transients. > > JerrySubject to Jerry's cautions, multiplication in frequency (with an appropriate filter response - thus Jerry's "Provided that you don't attempt to filter too vigorously") can be more computationally efficient by quite a large margin. Fred
"todd.leonhardt@gmail.com" wrote:> > I am relatively new to DSP and I have what seems like a simple > question, but I have not been able to find in answer to it by reading > DSP books. > > If the goal is to design a frequency-selective filter, then is there > any reason not to simply take the FFT of a signal (or a window > thereof), apply our filter by directly multiplying the filter amplitude > response with the FFT of our signal, and then take the IFFT (inverse > FFT) to get back the filtered signal? Is there any disadvantage to > doing this as opposed to using an FIR or IIR filter?Yes, filtering in the frequency domain is far more computationally expensive than doing it in the time domain for most sensible filters. By sensible filters, i just about any IIR filter or any FIR filter with less than 1000 coefficients. For really huge FIR filters then frequency domain methods may be preferable. Erik -- +-----------------------------------------------------------+ Erik de Castro Lopo nospam@mega-nerd.com (Yes it's valid) +-----------------------------------------------------------+ "Anyone who considers arithmetical methods of producing random digits is, of course, in a state of sin." - John Von Neumann (1951)
Erik de Castro Lopo wrote:> "todd.leonhardt@gmail.com" wrote: > > > > I am relatively new to DSP and I have what seems like a simple > > question, but I have not been able to find in answer to it byreading> > DSP books. > > > > If the goal is to design a frequency-selective filter, then isthere> > any reason not to simply take the FFT of a signal (or a window > > thereof), apply our filter by directly multiplying the filteramplitude> > response with the FFT of our signal, and then take the IFFT(inverse> > FFT) to get back the filtered signal? Is there any disadvantage to > > doing this as opposed to using an FIR or IIR filter? > > Yes, filtering in the frequency domain is far more computationally > expensive than doing it in the time domain for most sensible filters.> By sensible filters, i just about any IIR filter or any FIR filter > with less than 1000 coefficients. For really huge FIR filters then > frequency domain methods may be preferable. > > Erik > -- > +-----------------------------------------------------------+ > Erik de Castro Lopo nospam@mega-nerd.com (Yes it's valid) > +-----------------------------------------------------------+ > "Anyone who considers arithmetical methods of producing random > digits is, of course, in a state of sin." - John Von Neumann (1951)My understanding was that the computational efficiency advantages kicked in for far fewer FIR filter coefficients than that. Chapter 18 of Stephen Smith's 'The Scientist and Engineer's Guide to Digital Signal Processing', available at www.dspguide.com, reckons around 40 to 80 coefficients. Smith gives a concise description of FFT convolution. In answer to the original poster's question, and to re-iterate what others have already said in response, it's a good idea! Have a search for 'overlap-add', 'overlap-save' or 'fast convolution'. Picking up on the original poster's phrase 'or a window thereof', note that rectangular windowing is appropriate in this technique. Donald
Todd,> If the goal is to design a frequency-selective filter, then is there > any reason not to simply take the FFT of a signal (or a window > thereof), apply our filter by directly multiplying the filter amplitude > response with the FFT of our signal, and then take the IFFT (inverse > FFT) to get back the filtered signal?The crux of the problem here is in choosing the number of samples of the signal that you want to apply your FFT-IFFT on. Let's understand this. When you multiply a signal by a finite width rectangular pulse (scaled appropriately) in the frequency domain, it is equivalent to convolving the time domain samples with the inverse transform of the rectangular pulse in the time domain. The inverse transform of a finite width rectangular pulse, happens to be a sync pulse, that stretches infinitely from [-inf, +inf] in the time domain. This means that you need to have input signal samples from [-inf, +inf] to do this, that is, take samples from [-inf, +inf], apply the FFT, multiply, and then apply IFFT. Now, you might say that you're just going to take a small subset of the input samples and do this same operation on that subset. But remember, that the moment you decide to take a subset, say from [T1 T2], you're implicitly truncating the impulse response of the filter, that is, you're saying that your infinitely stretching sync pulse now only stretches from [T1 T2]. Try taking the FFT of this truncated sync pulse, and you'll see that its shape in the frequency domain is no longer a rectangular pulse! Instead, you'll see that the truncation in the time domain caused distortions in the frequency characteristics of your filter - both in the passband and in the stopband. So now, you need to redesign your filter by applying some constraints - such as passband ripple, etc. And this opens up a multitude of "windows" :-) Cheers! Ravi Srikantiah
> Now, you might say that you're just going to take a small subset of the > input samples and do this same operation on that subset. But remember, > that the moment you decide to take a subset, say from [T1 T2], you're > implicitly truncating the impulse response of the filter, that is, > you're saying that your infinitely stretching sync pulse now only > stretches from [T1 T2]. Try taking the FFT of this truncated sync pulse, > and you'll see that its shape in the frequency domain is no longer a > rectangular pulse! Instead, you'll see that the truncation in the time > domain caused distortions in the frequency characteristics of your > filter - both in the passband and in the stopband.Sorry, I didn't present this properly. The moment you decide to take a subset of the samples in the time domain, in effect, you're multiplying the time domain signal by a rectangular pulse. Doing so is equivalent to convolving the spectrum of the infinite signal with a sync pulse in the frequency domain. This means that the signal you're working with now is not the original signal but a spectrally distorted one. As you increase the number of samples in your time domain, the sync pulse in the frequency domain gets narrower and narrower until it approaches the ideal impulse (when T1 and T2 are -inf and +inf respectively)
You have to be very careful about what you are doing in the frequency domain, and think about the corresponding effects in the time domain. If you simply brick wall in the frequency domain, then you get serious time aliasing - the end of your signal begins to appear at the beginning. The brick wall filter is infinitely long in the time domain, and cannnot be represented accurately with FFT / IFFT's. Windowed FIR designs are the first crack at handling this. They essentially truncate and smooth out the ends of the infinitely long sequence. This produce effects though in the frequency domain - ripple in the passband, finite attenuation, and a transition width between passband and stopband. Windowed FIR designs are not optimal in any kind of way. Other FIR design techniques allow tradeoffs between the effects I mentioned in the frequency domain (ripple, attenuation, transition width). The FIR's can be implemented using FFTs but to filter a very long time sequence you have to look at techniques like "overlap and save" or "overlap and add", these are techniques to handle the blockiness of the FFT and dividing your input data up into chucks that fit into an FFT. The input transient you discovered is a result of causality. Using a simple brick wall filter (no phase) in frequency assumes you know the what the data is before it arrives - which sadly most of us don't (I don't want to discuss time travel :) ). You can think of this as time shifting your infinitely long (brick wall) filter in time to the right i.e. a time delay. FIR filters get longer when you want less ripple, more attenuation and a smaller transition width. The closer you get to your brick wall filter in frequency domain the closer your FIR filter gets to becoming an infinite sequence. IIR's are a trade off you can achieve similar magnitude response as an FIR, but with much fewer taps (coefficients). Unfortunately you pay for this with the phase. IIR filters have non-linear phase - this may or may not be important depending on your application. FIR can have linear phase if they are symmetric - for more info you'll have to look it up. Most FIR design techniques produce symmetric FIR's (have linear phase - you can think of this as a constant time shift of the signal). Hope that helps. Cheers, David <todd.leonhardt@gmail.com> wrote in message news:1101957855.721740.171340@f14g2000cwb.googlegroups.com...>I am relatively new to DSP and I have what seems like a simple > question, but I have not been able to find in answer to it by reading > DSP books. > > If the goal is to design a frequency-selective filter, then is there > any reason not to simply take the FFT of a signal (or a window > thereof), apply our filter by directly multiplying the filter amplitude > response with the FFT of our signal, and then take the IFFT (inverse > FFT) to get back the filtered signal? Is there any disadvantage to > doing this as opposed to using an FIR or IIR filter? > > For the mathematically inclined ... > Suppose we have a signal x(k) and it's DFT (calculated via FFT) is > X(f). > We also have a desired filter specification represented by it's > amplitude response, A(f). Then, a filtered version of this signal, > y(k) can be found: > y(k) = IFFT { X(f) A(f) } > > I tried doing this using MATLAB and some noisy data for the specific > case of a highpass filter with a cutoff frequency very close to DC, and > it worked great. I simply used an ideal highpass filter > characteristic. Is there something I'm missing? If it is this simple, > then why do DSP books focus so much on FIR and IIR filters? I figure > I'm missing something important and probably "obvious". Please > enlighten me ... politely. > > On a related note .., I was trying to design an FIR filter (using a > windowed truncated impulse response) to filter this same data. The > problem I was having is that there was an initial transient of > relatively long duration and of an amplitude that was several orders of > magnitude larger than the "good" filtered data. Is there a way to > avoid this - i.e. is there a way to eliminate or greatly minimize this > transient? I tried using an IIR filter and the problem was even worse. > For this particular application, the data is logged and then stored on > a computer, so the processing doesn't need to be real-time, any type of > filter (non-causal, etc.) should be fine. Any advice/insight would be > appreciated. >
Thanks for the feedback everyone. I appreciate it. I think I now have a decent understanding of the advantages/disadvantages.
"Erik de Castro Lopo" <nospam@mega-nerd.com> wrote in message news:41AEB6EF.6E1FF508@mega-nerd.com...> "todd.leonhardt@gmail.com" wrote: > > > > I am relatively new to DSP and I have what seems like a simple > > question, but I have not been able to find in answer to it by reading > > DSP books. > > > > If the goal is to design a frequency-selective filter, then is there > > any reason not to simply take the FFT of a signal (or a window > > thereof), apply our filter by directly multiplying the filter amplitude > > response with the FFT of our signal, and then take the IFFT (inverse > > FFT) to get back the filtered signal? Is there any disadvantage to > > doing this as opposed to using an FIR or IIR filter? > > Yes, filtering in the frequency domain is far more computationally > expensive than doing it in the time domain for most sensible filters. > By sensible filters, i just about any IIR filter or any FIR filter > with less than 1000 coefficients. For really huge FIR filters then > frequency domain methods may be preferable.In addition, if you are writing the code yourself from scratch, time-domain filtering can be a whole lot easier to code up than FFT<->filter<->IFFT. A biquad IIR takes just a handful of lines of code, and an FIR with a circular buffer even less. On the other, if you have libraries available to do the FFT already, then maybe it's not an issue. Time-domain uses less memory as well and can be run on a sample-by-sample basis rather than buffering, waiting for a block to arrive, etc. which may be an issue for real-time implementation. YMMV. -Jon
