Hi all I want of interface a Ti's stereo codec tlc320ad77 to Analog devices hammerhead sharc DSP 211161N, it was a simple codec with a simple serial interface, my problem is that the codec uses data in data out with a common CLK signal but in dsp the sports don't support full duplex connection i have to use a pair of sports to do the same, now there is another problem i have to derive a common CLK signal because the codec takes only one SCLK signal so i thought of using a or gate with 2 inputs from the 2 sports CLK signal( and setting same clk rate for the 2 sports) and connecting it to the codec CLK signal similarly for LRCLK. do this setup will work or it is better to give CLK and LRCLK from one sport?? bye puvi
adsp - 211161N sport i2s mode
Started by ●December 4, 2004
Reply by ●December 4, 20042004-12-04
puviarasu@gmail.com (puvi) wrote in news:bf6d9dab.0412032216.30d8ee02 @posting.google.com:> Hi all > I want of interface a Ti's stereo codec tlc320ad77 to Analog devices > hammerhead sharc DSP 211161N, it was a simple codec with a simple > serial interface, my problem is that the codec uses data in data out > with a common CLK signal but in dsp the sports don't support full > duplex connection i have to use a pair of sports to do the same, now > there is another problem i have to derive a common CLK signal because > the codec takes only one SCLK signal so i thought of using a or gate > with 2 inputs from the 2 sports CLK signal( and setting same clk rate > for the 2 sports) and connecting it to the codec CLK signal similarly > for LRCLK. > > do this setup will work or it is better to give CLK and LRCLK from > one sport?? > > bye > puvi >No! Assuming that the DSP is providing the CLK, you configure one clock as an output and the other as an input. Then you can connect them together. This is done all the time. -- Al Clark Danville Signal Processing, Inc. -------------------------------------------------------------------- Purveyors of Fine DSP Hardware and other Cool Stuff Available at http://www.danvillesignal.com
> > serial interface, my problem is that the codec uses data in data out > > with a common CLK signal but in dsp the sports don't support full > > duplex connection i have to use a pair of sports to do the same, now > > there is another problem i have to derive a common CLK signal because > > the codec takes only one SCLK signal so i thought of using a or gate > > with 2 inputs from the 2 sports CLK signal( and setting same clk rate > > for the 2 sports) and connecting it to the codec CLK signal similarly > > for LRCLK. > > > > Assuming that the DSP is providing the CLK, you configure one clock as an > output and the other as an input. Then you can connect them together. This > is done all the time.And feed the CODEC's clock signal with the DSP driven SCLK. For example, on the DSP side, configure Tx SCLK as output, and Rx SCLK input. Connect both the DSP Rx SCLK and the CODEC SCLK to the DSP Tx SCLK. -- Jaime Andr�s Aranguren Cardona jaac@nospam.sanjaac.com SanJaaC Electronics Soluciones en DSP www.sanjaac.com (Remove "nospam" from e-mail address)
