Tim Wescott <tim@wescottnospamdesign.com> writes:> [...] > I suspect that N may be quite large, and the attack could easily be > defeated by wrapping your cryptographic algorithm by a process that > schedules the outgoing message so the reply always takes the same > amount of time to be sent, no matter how long the actual cryptography > took.Damn, Tim! Why spoil a perfectly good theoretical discussion with a practical suggestion like that? -- % Randy Yates % "Rollin' and riding and slippin' and %% Fuquay-Varina, NC % sliding, it's magic." %%% 919-577-9882 % %%%% <yates@ieee.org> % 'Living' Thing', *A New World Record*, ELO http://home.earthlink.net/~yatescr
AES timing attacks
Started by ●December 4, 2004
Reply by ●December 4, 20042004-12-04
Randy Yates wrote:> Tim Wescott <tim@wescottnospamdesign.com> writes: > >>[...] >>I suspect that N may be quite large, and the attack could easily be >>defeated by wrapping your cryptographic algorithm by a process that >>schedules the outgoing message so the reply always takes the same >>amount of time to be sent, no matter how long the actual cryptography >>took. > > > Damn, Tim! Why spoil a perfectly good theoretical discussion with > a practical suggestion like that?Oh gosh, I'm sorry. I'll go put on my sackcloth shirt, and roll around in last week's burn pile, OK? -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Bob Cain wrote:> Karl Malbrain wrote: > > > Those times are milliseconds. The attack either adds or not a fewcpu> > cycles to those times. karl m > > Does he present a full attack with this method or only claim > possible vulnerability because some information about the > key is extracted? If the latter, how signifigant is it?Professor Bernstein has only linked his work to the work of Professor Boneh, who presents an attack on RSA encryption used by SSL over a network. So far it is only a suggestion that the two attacks could be linked. The question in this thread is how many messages would be theoretically required. So far it's only 1,000. karl m
Tim Wescott wrote:> Randy Yates wrote: > > > Tim Wescott <tim@wescottnospamdesign.com> writes: > > > >>[...] > >>I suspect that N may be quite large, and the attack could easily be > >>defeated by wrapping your cryptographic algorithm by a process that > >>schedules the outgoing message so the reply always takes the same > >>amount of time to be sent, no matter how long the actualcryptography> >>took. > > > > > > Damn, Tim! Why spoil a perfectly good theoretical discussion with > > a practical suggestion like that? >The problem with the practical suggestion you make is that it would slow down AES encryption time for 16 bytes from 500 cycles currently, to the time for 192 DRAM accesses, which I've been hearing over on comp.arch run 250 cycles each. We're looking to avoid this factor of 100 slowdown on the Athlon and Pentium platforms. Going back to your earlier answers -- someone suggested we might delay the algorithm to 10% of the worst case time (the 192 DRAM accesses is worst case) and get an exponential effect on the number of attack-trial encryptions required over the channel? Thanks again for your assistance. karl m
Reply by ●December 5, 20042004-12-05
Tim Wescott wrote: > [...] This means that if the > variance in your network turn-around time is v, and if the difference > between message times is t_d, you need to collect somewhere on the order > of N = v / t_d^2 of each type of message if you want to discern a > difference. I think you mean N = (v / t_d)^2. -- --Bryan
Bryan Olson wrote: > > Tim Wescott wrote: > > [...] This means that if the > > variance in your network turn-around time is v, and if the difference > > between message times is t_d, you need to collect somewhere on the order > > of N = v / t_d^2 of each type of message if you want to discern a > > difference. > > I think you mean N = (v / t_d)^2. Oops, my mistake. The variance is already in seconds^2. -- --Bryan
Bryan Olson wrote:> Bryan Olson wrote: > > > > > Tim Wescott wrote: > > > [...] This means that if the > > > variance in your network turn-around time is v, and if thedifference> > > between message times is t_d, you need to collect somewhere onthe> order > > > of N = v / t_d^2 of each type of message if you want to discerna> > > difference. > > > > I think you mean N = (v / t_d)^2. > > Oops, my mistake. The variance is already in seconds^2.Over a wide area network the variance is likely 10^12. With a message length of 1K bits and a DS3 transfer rate of 45 mbs, that's 45K encryptions/second which makes for 50+ years. Do you know the optical circuit data rate? karl m
Bryan Olson wrote:> Bryan Olson wrote: > > > > > Tim Wescott wrote: > > > [...] This means that if the > > > variance in your network turn-around time is v, and if thedifference> > > between message times is t_d, you need to collect somewhere onthe> order > > > of N = v / t_d^2 of each type of message if you want to discerna> > > difference. > > > > I think you mean N = (v / t_d)^2. > > Oops, my mistake. The variance is already in seconds^2.On a wide area network I estimate the variance is going to run 10^12. With a DS3 connection of 45mbs that's about 50 years to gather enough trial encryptions. karl m
"Randy Yates" <yates@ieee.org> wrote in message news:653hpr4e.fsf@ieee.org...> Tim Wescott <tim@wescottnospamdesign.com> writes: > > [...] > > I suspect that N may be quite large, and the attack could easily be > > defeated by wrapping your cryptographic algorithm by a process that > > schedules the outgoing message so the reply always takes the same > > amount of time to be sent, no matter how long the actual cryptography > > took. > > Damn, Tim! Why spoil a perfectly good theoretical discussion with > a practical suggestion like that? > --Hello Randy, The RSA algo has a similar vunerability and the standard work around was to make the encryption/decryption process a constant time one. Clay
Reply by ●December 6, 20042004-12-06
Karl Malbrain wrote: > Over a wide area network the variance is likely 10^12. Standing by itself and with no unit, that's not meaningful. Tim had it right (sorry about my previous confusion): The key parameters in this case are the deterministic difference in turn-around time due to message content and the variance in turn- around time from the network. We can compress this to a single parameter: the signal to noise ratio. The signal is the expected time difference caused by the key/message values, and the noise is the standard deviation in the network turn- around time. Both are in seconds, so the ratio is a unit-less constant. In this case, working with noise/signal is a little more convenient than signal/noise. We expect the signal to become larger than the noise when the number of messages exceeds the square of the single-message noise/signal. > With a message > length of 1K bits and a DS3 transfer rate of 45 mbs, that's 45K > encryptions/second which makes for 50+ years. > Do you know the optical circuit data rate? karl m Those numbers don't really tell us anything. If the standard deviation in the time is 1000 times as large than the key-dependent effect, then we expect to need on the order of a million messages. -- --Bryan
