Hi, I am currently working on a program using FFTW-> http://www.fftw.org . My basic C program to compute the 2D Fourier transform of a bunch of data works fine when I compile it with gcc. However, I would like to incorporate that code into a larger program that I wrote with C++. Unfortunately, I cannot get my program to compile with g++. I compile it as follows: g++ ft2d.c -o ft2d -I/usr/local/include -L /usr/local/lib -lfftw3 -lm The errors I get are: ft2d.c: In function `int main()': ft2d.c:13: invalid conversion from `void*' to `double (*)[2]' ft2d.c:14: invalid conversion from `void*' to `double (*)[2]' Here is my code: #include <fftw3.h> #include <math.h> int main(void) { fftw_complex *in, *out; fftw_plan p; int nx = 5; int ny = 5; int i; /* Allocate the input and output arrays, and create the plan */ in = fftw_malloc(sizeof(fftw_complex) * nx * ny); out = fftw_malloc(sizeof(fftw_complex) * nx * ny); p = fftw_plan_dft_2d(nx, ny, in, out, FFTW_FORWARD, FFTW_ESTIMATE); /* Now fill the input array with the input data */ /* We'll simply make a sine wave */ for (i = 0; i < (nx * ny); i++) { in[i][0] = sin(i / 10.0 * M_PI); /* Real part */ in[i][1] = 0.0; /* Imaginary part */ } /* Actually execute the plan on the input data */ fftw_execute(p); /* Print out the results */ for (i = 0; i < (nx * ny); i++) printf("Coefficient %d: %f%+f*i\n", i, out[i][0], out[i][1]); /* Clean up after ourselves */ fftw_destroy_plan(p); fftw_free(in); fftw_free(out); return 0; } Eventually I will do something more complex than a sine wave, but you get the idea. If anyone knows what the problem is, I would greatly appreciate any help. This is all that fftw.org has about calling it from C++: http://fftw.org/faq/section2.html#cplusplus Thanks in advance!! --Erica
Calling FFTW from C++? (x-posted)
Started by ●September 15, 2004
Reply by ●September 15, 20042004-09-15
"Erica" <erica@technodyke.com> wrote in message news:346a55df.0409151004.7edf489e@posting.google.com...> Hi, > > I am currently working on a program using FFTW-> http://www.fftw.org . > My basic C program to compute the 2D Fourier transform of a bunch of > data works fine when I compile it with gcc. However, I would like to > incorporate that code into a larger program that I wrote with C++. > Unfortunately, I cannot get my program to compile with g++. > > I compile it as follows: > > g++ ft2d.c -o ft2d -I/usr/local/include -L /usr/local/lib -lfftw3 -lm > > The errors I get are: > > ft2d.c: In function `int main()': > ft2d.c:13: invalid conversion from `void*' to `double (*)[2]' > ft2d.c:14: invalid conversion from `void*' to `double (*)[2]'This is one of the differences between C++ and C. In C void* automatically converts to any other pointer, in C++ you must cast.> > Here is my code: > > #include <fftw3.h> > #include <math.h> > > int main(void) > { > fftw_complex *in, *out; > fftw_plan p; > int nx = 5; > int ny = 5; > int i; > > /* Allocate the input and output arrays, and create the plan */ > in = fftw_malloc(sizeof(fftw_complex) * nx * ny);in = (fftw_complex*)fftw_malloc(sizeof(fftw_complex) * nx * ny);> out = fftw_malloc(sizeof(fftw_complex) * nx * ny);out = (fftw_complex*)fftw_malloc(sizeof(fftw_complex) * nx * ny); That should do it. john
"Erica" <erica@technodyke.com> wrote in message news:346a55df.0409151004.7edf489e@posting.google.com...> Hi, > > I am currently working on a program using FFTW-> http://www.fftw.org . > My basic C program to compute the 2D Fourier transform of a bunch of > data works fine when I compile it with gcc. However, I would like to > incorporate that code into a larger program that I wrote with C++. > Unfortunately, I cannot get my program to compile with g++. > > I compile it as follows: > > g++ ft2d.c -o ft2d -I/usr/local/include -L /usr/local/lib -lfftw3 -lm > > The errors I get are: > > ft2d.c: In function `int main()': > ft2d.c:13: invalid conversion from `void*' to `double (*)[2]' > ft2d.c:14: invalid conversion from `void*' to `double (*)[2]' >You don't note in your code what lines 13 and 14 are, but if I'm counting correctly, the errors are on the fftw_malloc lines, right? You probably need to cast the results of those function calls to (fftw_complex *). It appears that the fftw_malloc call returns a void*, and the compiler is complaining about that type not matching your in and out variables' declared type. -Howard> Here is my code: > > #include <fftw3.h> > #include <math.h> > > int main(void) > { > fftw_complex *in, *out; > fftw_plan p; > int nx = 5; > int ny = 5; > int i; > > /* Allocate the input and output arrays, and create the plan */ > in = fftw_malloc(sizeof(fftw_complex) * nx * ny); > out = fftw_malloc(sizeof(fftw_complex) * nx * ny);
That did the trick...thanks!! "Howard" <alicebt@hotmail.com> wrote in message news:<DA%1d.594287$Gx4.169205@bgtnsc04-news.ops.worldnet.att.net>...> "Erica" <erica@technodyke.com> wrote in message > news:346a55df.0409151004.7edf489e@posting.google.com... > > Hi, > > > > I am currently working on a program using FFTW-> http://www.fftw.org . > > My basic C program to compute the 2D Fourier transform of a bunch of > > data works fine when I compile it with gcc. However, I would like to > > incorporate that code into a larger program that I wrote with C++. > > Unfortunately, I cannot get my program to compile with g++. > > > > I compile it as follows: > > > > g++ ft2d.c -o ft2d -I/usr/local/include -L /usr/local/lib -lfftw3 -lm > > > > The errors I get are: > > > > ft2d.c: In function `int main()': > > ft2d.c:13: invalid conversion from `void*' to `double (*)[2]' > > ft2d.c:14: invalid conversion from `void*' to `double (*)[2]' > > > > You don't note in your code what lines 13 and 14 are, but if I'm counting > correctly, the errors are on the fftw_malloc lines, right? You probably > need to cast the results of those function calls to (fftw_complex *). It > appears that the fftw_malloc call returns a void*, and the compiler is > complaining about that type not matching your in and out variables' declared > type. > > -Howard > > > Here is my code: > > > > #include <fftw3.h> > > #include <math.h> > > > > int main(void) > > { > > fftw_complex *in, *out; > > fftw_plan p; > > int nx = 5; > > int ny = 5; > > int i; > > > > /* Allocate the input and output arrays, and create the plan */ > > in = fftw_malloc(sizeof(fftw_complex) * nx * ny); > > out = fftw_malloc(sizeof(fftw_complex) * nx * ny);
Reply by ●September 16, 20042004-09-16
erica@technodyke.com (Erica) wrote:> > My basic C program to compute the 2D Fourier transform of a bunch of > data works fine when I compile it with gcc. However, I would like to > incorporate that code into a larger program that I wrote with C++. > Unfortunately, I cannot get my program to compile with g++. > > I compile it as follows: > > g++ ft2d.c -o ft2d -I/usr/local/include -L /usr/local/lib -lfftw3 -lm > > The errors I get are: > > ft2d.c: In function `int main()': > ft2d.c:13: invalid conversion from `void*' to `double (*)[2]' > ft2d.c:14: invalid conversion from `void*' to `double (*)[2]'IMHO if you want to mix C and C++ in a project, you should leave your C files as .C files, (and compile them with gcc not g++). If you include the corresponding .H file from a C++ source file do this: extern "C" { #include "ft2d.h" }; Alternatively you could write a wrapper file that uses this, that would avoid having to do this in every other unit that has to include the C header. There's a chapter in the c.l.c++ FAQ about mixing C and C++ in projects, have a read of it and see if there is any more advice.
Well, looks like you need an explicit cast from the void* data type here. But that's basic C/C++ language stuff and has nothing to do with FFTW. -- Stephan M. Bernsee http://www.dspdimension.com
