Hello, I writing an application using the full TI kit : Code composer studio, DSP/BIOS,... and i need to know the CPU usage. The TI's DSP/BIOS include an IDL thread which can be used to see CPU usage using RTDX (jtag, debugger...). But the application i made run on a proprety acquisition board. So the idea is to uses this IDL thread in order to monitor the CPU usage. Unfortunatly, the TI's API do not leave access to this information. I do not want to make my own low priority thread in order to compute the CPU usage. Is someone has an idea on how to use the DSP/BIOS idl thread in order to monitor the CPU usage without making extra code ? Think
DSP/BIOS : IDL Thread : CPU Usage
Started by ●December 5, 2004
Reply by ●December 6, 20042004-12-06
Those IDL threads that calculate CPU load are intended to be used by viewing them through Code Composer Studio. Go to the DSP/BIOS menu and select CPU Load Graph. Did you want to somehow use that load information in your application? Brad "seb" <germain1_fr@yahoo.fr> wrote in message news:23925133.0412051141.4b8b5c04@posting.google.com...> Hello, > > I writing an application using the full TI kit : Code composer studio, > DSP/BIOS,... and i need to know the CPU usage. > The TI's DSP/BIOS include an IDL thread which can be used to see CPU > usage using RTDX (jtag, debugger...). > > But the application i made run on a proprety acquisition board. So the > idea is to uses this IDL thread in order to monitor the CPU usage. > Unfortunatly, the TI's API do not leave access to this information. > > I do not want to make my own low priority thread in order to compute > the CPU usage. > > Is someone has an idea on how to use the DSP/BIOS idl thread in order > to monitor the CPU usage without making extra code ? > > Think
