Hello Earthlings, I recently ran across some material in Vaidyanathan's "Multirate Systems and Filter Banks" DSP book that discusses a way to improve the computational efficiency of polyphase filters used in non-integer decimation applications. Vaidyanathan's description (starting on page 128, and derived from a 1987 conference paper by C.-C Hsiao) sounds interesting except for one tiny little thing. To implement this "nice trick, as Vaidyanathan calls it, we have to implement the inverse of a delay. What I mean by that is: if a single-sample delay is represented by z^(-1), 1/z, Vaidyanathan shows an element in his Figure 4.3-8 block diagrams represented by a "z" (z to the plus one power)!!! It looks something like: ??? Delay Delay |----| |-----| |-----| x(n)-->| z |--*-->| 1/z |--*-->| 1/z |--> a(n) |----| | |-----| | |-----| | | | |------------> b(n) | |-------------------------> c(n) I've read his description just about as thoroughly as I can, but I still can't figure out how we can implement that initial "time advance by one sample" operation shown above. I took a look at the original Hsaio conference paper, but found no discernable explanation for that troubesome "z" operation. I even went through Stephan Hawking's "A Brief History of Time" book to see if there was some way to travel into the future to obtain future time samples. I had no luck reading either Hsaio's or Hawking's material. Can the decimation scheme in Vaidyanathan's Figure 4.3-8 block diagrams actually work in our universe? :-) Gosh, ... I know I'm making some sort of silly mistake here, but I'm darned if I can figure what it is? Hey wait a second. After typing this post it just occurred to me that maybe this "nice trick" can only be used "offline", the situation where all the x(n) time samples are available before the decimation process begins. However, neither Vaidyanathan nor Hsaio mentioned (as far as I know) an "offline only" restriction for their decimation filters. Anyway, I'd sure appreciate it if one of you guys could straighten me out. Thanks Guys, [-Rick-]
A question from Vaidyanathan's "Multirate Systems" book
Started by ●December 6, 2004
Reply by ●December 6, 20042004-12-06
Rick Lyons wrote:> Hello Earthlings, > > I recently ran across some material in > Vaidyanathan's "Multirate Systems and Filter Banks" > DSP book that discusses a way to improve the > computational efficiency of polyphase filters > used in non-integer decimation applications. > > Vaidyanathan's description (starting on page 128, > and derived from a 1987 conference paper by > C.-C Hsiao) sounds interesting except for one > tiny little thing. To implement this "nice trick, > as Vaidyanathan calls it, we have to implement the > inverse of a delay. What I mean by that is: > if a single-sample delay is represented by > z^(-1), 1/z, Vaidyanathan shows an element in > his Figure 4.3-8 block diagrams represented by > a "z" (z to the plus one power)!!! > > It looks something like: > > ??? Delay Delay > > |----| |-----| |-----| > x(n)-->| z |--*-->| 1/z |--*-->| 1/z |--> a(n) > |----| | |-----| | |-----| > | | > | |------------> b(n) > | > |-------------------------> c(n) > > I've read his description just about as thoroughly > as I can, but I still can't figure out how we can > implement that initial "time advance by one sample" > operation shown above. > I took a look at the original Hsaio conference paper, > but found no discernable explanation for that > troubesome "z" operation. I even went through > Stephan Hawking's "A Brief History of Time" book > to see if there was some way to travel into the > future to obtain future time samples. I had no luck > reading either Hsaio's or Hawking's material. > > Can the decimation scheme in Vaidyanathan's > Figure 4.3-8 block diagrams actually work in our > universe? :-) > > Gosh, ... I know I'm making some sort of silly mistake > here, but I'm darned if I can figure what it is? > > Hey wait a second. After typing this post it just > occurred to me that maybe this "nice trick" can only > be used "offline", the situation where all the x(n) > time samples are available before the decimation > process begins. However, neither Vaidyanathan nor > Hsaio mentioned (as far as I know) an "offline only" > restriction for their decimation filters. > > Anyway, I'd sure appreciate it if one of you guys could > straighten me out. > > Thanks Guys, > [-Rick-] >Hi Rick, I don't know the exact details without looking at the book more closely, but instead of advancing the signal - can you delay all the others by a sample. If you are combining different signals what is important is the relative difference not the absolute one. Cheers, David
Rick Lyons wrote:> Hello Earthlings, > > I recently ran across some material in > Vaidyanathan's "Multirate Systems and Filter Banks" > DSP book that discusses a way to improve the > computational efficiency of polyphase filters > used in non-integer decimation applications. > > Vaidyanathan's description (starting on page 128, > and derived from a 1987 conference paper by > C.-C Hsiao) sounds interesting except for one > tiny little thing. To implement this "nice trick, > as Vaidyanathan calls it, we have to implement the > inverse of a delay. What I mean by that is: > if a single-sample delay is represented by > z^(-1), 1/z, Vaidyanathan shows an element in > his Figure 4.3-8 block diagrams represented by > a "z" (z to the plus one power)!!! > > It looks something like: > > ??? Delay Delay > > |----| |-----| |-----| > x(n)-->| z |--*-->| 1/z |--*-->| 1/z |--> a(n) > |----| | |-----| | |-----| > | | > | |------------> b(n) > | > |-------------------------> c(n) > > I've read his description just about as thoroughly > as I can, but I still can't figure out how we can > implement that initial "time advance by one sample" > operation shown above. > I took a look at the original Hsaio conference paper, > but found no discernable explanation for that > troubesome "z" operation. I even went through > Stephan Hawking's "A Brief History of Time" book > to see if there was some way to travel into the > future to obtain future time samples. I had no luck > reading either Hsaio's or Hawking's material. > > Can the decimation scheme in Vaidyanathan's > Figure 4.3-8 block diagrams actually work in our > universe? :-) > > Gosh, ... I know I'm making some sort of silly mistake > here, but I'm darned if I can figure what it is? > > Hey wait a second. After typing this post it just > occurred to me that maybe this "nice trick" can only > be used "offline", the situation where all the x(n) > time samples are available before the decimation > process begins. However, neither Vaidyanathan nor > Hsaio mentioned (as far as I know) an "offline only" > restriction for their decimation filters. > > Anyway, I'd sure appreciate it if one of you guys could > straighten me out.Isn't offline rather similar to making the pipe a bit longer. :-) Steve
"Rick Lyons" <r.lyons@_BOGUS_ieee.org> wrote in message news:41b470cc.196117296@news.sf.sbcglobal.net...> > Hello Earthlings, > > I recently ran across some material in > Vaidyanathan's "Multirate Systems and Filter Banks" > DSP book that discusses a way to improve the > computational efficiency of polyphase filters > used in non-integer decimation applications. > > Vaidyanathan's description (starting on page 128, > and derived from a 1987 conference paper by > C.-C Hsiao) sounds interesting except for one > tiny little thing. To implement this "nice trick, > as Vaidyanathan calls it, we have to implement the > inverse of a delay. What I mean by that is: > if a single-sample delay is represented by > z^(-1), 1/z, Vaidyanathan shows an element in > his Figure 4.3-8 block diagrams represented by > a "z" (z to the plus one power)!!!I've had the same problem when I've used his text to solve some polyphase decomposition problems. The way I dealt with it was to add a fixed delay equal to the largest positive power of z at the input. This would give me a z^0 and several z^-ve values (depending on my resampling ratios). So I then implemented them as delays and jumped around the time advance that his text suggests. It seemed to make sense to me and the fact that my design worked made me feel a little better about it. Hope this helps. Cheers Bhaskar> > It looks something like: > > ??? Delay Delay > > |----| |-----| |-----| > x(n)-->| z |--*-->| 1/z |--*-->| 1/z |--> a(n) > |----| | |-----| | |-----| > | | > | |------------> b(n) > | > |-------------------------> c(n) > > I've read his description just about as thoroughly > as I can, but I still can't figure out how we can > implement that initial "time advance by one sample" > operation shown above. > I took a look at the original Hsaio conference paper, > but found no discernable explanation for that > troubesome "z" operation. I even went through > Stephan Hawking's "A Brief History of Time" book > to see if there was some way to travel into the > future to obtain future time samples. I had no luck > reading either Hsaio's or Hawking's material. > > Can the decimation scheme in Vaidyanathan's > Figure 4.3-8 block diagrams actually work in our > universe? :-) > > Gosh, ... I know I'm making some sort of silly mistake > here, but I'm darned if I can figure what it is? > > Hey wait a second. After typing this post it just > occurred to me that maybe this "nice trick" can only > be used "offline", the situation where all the x(n) > time samples are available before the decimation > process begins. However, neither Vaidyanathan nor > Hsaio mentioned (as far as I know) an "offline only" > restriction for their decimation filters. > > Anyway, I'd sure appreciate it if one of you guys could > straighten me out. > > Thanks Guys, > [-Rick-] >
Hi Rick, It seems that many of us have got into the trouble of the "non-causality" created by that z^(+1) in Vaidyanathan's book. Just to complement whay Bhaskar wrote, have a look at this thread in comp.dsp archives http://tinyurl.com/668qw I hope this helps in clarifying, as it did for me. Regards, -- Jaime Andr�s Aranguren Cardona jaac@nospam.sanjaac.com SanJaaC Electronics Soluciones en DSP www.sanjaac.com (Remove "nospam" from e-mail address) "Rick Lyons" <r.lyons@_BOGUS_ieee.org> escribi� en el mensaje news:41b470cc.196117296@news.sf.sbcglobal.net...> > Hello Earthlings, > > I recently ran across some material in > Vaidyanathan's "Multirate Systems and Filter Banks" > DSP book that discusses a way to improve the > computational efficiency of polyphase filters > used in non-integer decimation applications. > > Vaidyanathan's description (starting on page 128, > and derived from a 1987 conference paper by > C.-C Hsiao) sounds interesting except for one > tiny little thing. To implement this "nice trick, > as Vaidyanathan calls it, we have to implement the > inverse of a delay. What I mean by that is: > if a single-sample delay is represented by > z^(-1), 1/z, Vaidyanathan shows an element in > his Figure 4.3-8 block diagrams represented by > a "z" (z to the plus one power)!!! > > It looks something like: > > ??? Delay Delay > > |----| |-----| |-----| > x(n)-->| z |--*-->| 1/z |--*-->| 1/z |--> a(n) > |----| | |-----| | |-----| > | | > | |------------> b(n) > | > |-------------------------> c(n) > > I've read his description just about as thoroughly > as I can, but I still can't figure out how we can > implement that initial "time advance by one sample" > operation shown above. > I took a look at the original Hsaio conference paper, > but found no discernable explanation for that > troubesome "z" operation. I even went through > Stephan Hawking's "A Brief History of Time" book > to see if there was some way to travel into the > future to obtain future time samples. I had no luck > reading either Hsaio's or Hawking's material. > > Can the decimation scheme in Vaidyanathan's > Figure 4.3-8 block diagrams actually work in our > universe? :-) > > Gosh, ... I know I'm making some sort of silly mistake > here, but I'm darned if I can figure what it is? > > Hey wait a second. After typing this post it just > occurred to me that maybe this "nice trick" can only > be used "offline", the situation where all the x(n) > time samples are available before the decimation > process begins. However, neither Vaidyanathan nor > Hsaio mentioned (as far as I know) an "offline only" > restriction for their decimation filters. > > Anyway, I'd sure appreciate it if one of you guys could > straighten me out. > > Thanks Guys, > [-Rick-] >
Reply by ●December 8, 20042004-12-08
On Mon, 6 Dec 2004 12:55:30 -0500, "Jaime Andr�s Aranguren Cardona" <jaac@nospam.sanjaac.com> wrote:>Hi Rick, > >It seems that many of us have got into the trouble of the "non-causality" >created by that z^(+1) in Vaidyanathan's book. > >Just to complement whay Bhaskar wrote, have a look at this thread in >comp.dsp archives http://tinyurl.com/668qw I hope this helps in clarifying, >as it did for me. > >Regards, > >-- >Jaime Andr�s Aranguren CardonaHello Jaime, thanks, I'll take a look at that thread. [-Rick-]
On Mon, 6 Dec 2004 09:23:22 -0800, "Bhaskar Thiagarajan" <bhaskart@my-deja.com> wrote: (snipped)> >I've had the same problem when I've used his text to solve some polyphase >decomposition problems. >The way I dealt with it was to add a fixed delay equal to the largest >positive power of z at the input. This would give me a z^0 and several z^-ve >values (depending on my resampling ratios). So I then implemented them as >delays and jumped around the time advance that his text suggests. >It seemed to make sense to me and the fact that my design worked made me >feel a little better about it. > >Hope this helps. > >Cheers >BhaskarHi Bhaskar, it sounds like you solved this problem. Sorry to be so "thick-skulled", but can you answer a couple of questions for me? Looking at the following block diagram, how can I add delays so that sample x(n+1) is available to me at time instant n? ??? Delay Delay |----| |-----| |-----| x(n)-->| z |--*-->| 1/z |--*-->| 1/z |--> a(n) |----| | |-----| | |-----| | | | |------------> b(n) | |-------------------------> x(n+1) Can you tell me what your term "z^-ve" means? I'd sure like to figure this out. Thanks Bhaskar, [-Rick-]
"Rick Lyons" <r.lyons@_BOGUS_ieee.org> wrote in message news:41b78cd4.399900843@news.sf.sbcglobal.net...> On Mon, 6 Dec 2004 09:23:22 -0800, "Bhaskar Thiagarajan" > <bhaskart@my-deja.com> wrote: > > (snipped) > > > >I've had the same problem when I've used his text to solve some polyphase > >decomposition problems. > >The way I dealt with it was to add a fixed delay equal to the largest > >positive power of z at the input. This would give me a z^0 and severalz^-ve> >values (depending on my resampling ratios). So I then implemented them as > >delays and jumped around the time advance that his text suggests. > >It seemed to make sense to me and the fact that my design worked made me > >feel a little better about it. > > > >Hope this helps. > > > >Cheers > >Bhaskar > > Hi Bhaskar, > > it sounds like you solved this problem. > Sorry to be so "thick-skulled", but can you answer a > couple of questions for me? > > Looking at the following block diagram, how can I add > delays so that sample x(n+1) is available to me > at time instant n? > > > ??? Delay Delay > > |----| |-----| |-----| > x(n)-->| z |--*-->| 1/z |--*-->| 1/z |--> a(n) > |----| | |-----| | |-----| > | | > | |------------> b(n) > | > |-------------------------> x(n+1) > > > Can you tell me what your term "z^-ve" means?Hi Rick Sorry, I shouldn't have assumed that "z^-ve value" would read as "z raised to negative values"...anyways, that's what I meant. In your diagram, you have taken one segment of the diagram from the book - I'm not sure how I can help solve just this one section without using the other half. If you see the diagram, one branch uses x(n+1) and the other branch uses x(n). My method was to apply a z^-1 to both branches. This would result in x(n) for the top branch and x(n-1) for the bottom branch. In the end, I think it is important to preserve the fact that the top branch leads the bottom by 1 unit of delay. I'd be glad to answer more questions if you have any - not that I can promise I'll have answers but I'll certainly try. Cheers Bhaskar> > I'd sure like to figure this out. > Thanks Bhaskar, > [-Rick-]
Reply by ●December 12, 20042004-12-12
On Wed, 8 Dec 2004 16:04:28 -0800, "Bhaskar Thiagarajan" <bhaskart@my-deja.com> wrote: (snipped)>Hi RickHi Bhaskar, I haven't been ignoring you, I've just been pretty busy. (snipped)> >If you see the diagram, >one branch uses x(n+1) and the other branch uses x(n). >My method was to apply a z^-1 to both branches. This would result in x(n) >for the top branch and x(n-1) for the bottom branch. In the end, I think it >is important to preserve the fact that the top branch leads the bottom by 1 >unit of delay.Yes Yes Yes! Darn, ... as you say I was focusing in on only part of the system instead of looking at the whole system. I wonder why neither Vaidyanathan nor C.-C Hsiao explained this issue (to guys like me) as well as you just did.>I'd be glad to answer more questions if you have any - not that I can >promise I'll have answers but I'll certainly try.Good job Bhaskar! That's *another* beer I owe you! (I hope you're keeping track.)>Cheers >BhaskarThanks, ... I won't make this mistake again! [-Rick-]
