I'm trying to learn the new fixed point toolbox for Matlab V7.0 R14. I have the following Section of floating point code... y = randn(1,2)/64; X = zeros(2,1); X(1) = y(1) + y(2); X(2) = (y(1) - y(2))/sqrt(2); (which is a two point butterfly in a DCT if you are interested). What do i do to convert this to fixed point? Here is my (not very good) attempt. ******************************************************************* % first generate 18 bit random numbers for y y = randn(1,2)/64; y = fi(y,1,18,17,'RoundMode','floor'); % then define fixed point representation of X F = fimath('ProductMode','SpecifyPrecision',... 'SumMode','SpecifyPrecision',... 'ProductWordLength',32,... 'ProductFractionLength',16,... 'SumWordLength',32,... 'SumFractionLength',16,... 'RoundMode','floor'); % do we need to initialize X? (I used the zeros function in floating point) X(1) = F.add(x(1),x(2)); X(2) = F.sub(x(1),x(2)); % eh, no idea how to divide, because divide is defined for numerictypes X(2) = F.divide(X(2),fi(sqrt(2));??? *********************************************************************** Please help?
Fixed Point Toolbox
Started by ●September 15, 2004
Reply by ●September 15, 20042004-09-15
Hi, Your fixed-point implementation could look something like this: % Create your fimath (and attach it to y too) F = fimath('ProductMode','SpecifyPrecision',... 'SumMode','SpecifyPrecision',... 'ProductWordLength',32,... 'ProductFractionLength',16,... 'SumWordLength',32,... 'SumFractionLength',16,... 'RoundMode','floor'); % Set up y with this fimath F yfi = fi(y,1,18,17); yfi.fimath = F; % For X, use the fimath you created and lets say (since that info is not here) % that X too is a s18q17 (same as y) N = numerictype(yfi); X = fi(zeros(2,1),N,F); % Then X(1) = yfi(1) + yfi(2); X(2) = N.divide(yfi(1)-yfi(2),fi(sqrt(2))); % You could also compute the 1/sqrt(2) and store it in a fi % to get X(2) using the * operator onebysqrt2 = fi(1/sqrt(2),1,Somewordlength,Somefractionlength); onebysqrt2.fmath = F; X(2) = (yfi(1)-yfi(2))*onebysqrt2; Hope this helps, Ashok Charry The Mathworks "porterboy" <porterboy76@yahoo.com> wrote in message news:c4b57fd0.0409150441.71f4e3ed@posting.google.com...> I'm trying to learn the new fixed point toolbox for Matlab V7.0 R14. > I have the following Section of floating point code... > > y = randn(1,2)/64; > X = zeros(2,1); > X(1) = y(1) + y(2); > X(2) = (y(1) - y(2))/sqrt(2); > > (which is a two point butterfly in a DCT if you are interested). What > do i do to convert this to fixed point? Here is my (not very good) > attempt. > ******************************************************************* > % first generate 18 bit random numbers for y > y = randn(1,2)/64; > y = fi(y,1,18,17,'RoundMode','floor'); > > % then define fixed point representation of X > F = fimath('ProductMode','SpecifyPrecision',... > 'SumMode','SpecifyPrecision',... > 'ProductWordLength',32,... > 'ProductFractionLength',16,... > 'SumWordLength',32,... > 'SumFractionLength',16,... > 'RoundMode','floor'); > > % do we need to initialize X? (I used the zeros function in floating > point) > X(1) = F.add(x(1),x(2)); > X(2) = F.sub(x(1),x(2)); > > % eh, no idea how to divide, because divide is defined for > numerictypes > X(2) = F.divide(X(2),fi(sqrt(2));??? > *********************************************************************** > Please help?
Reply by ●September 16, 20042004-09-16
Thanks Ashok, that was very useful.> % For X, use the fimath you created and lets say (since that info is not > here) > % that X too is a s18q17 (same as y) > N = numerictype(yfi); > X = fi(zeros(2,1),N,F);Suppose X is not the same as y. Will the divide function still work, even though the numerictypes are different? Or do they have to be cast to the same type?
Hi, Yes, X can have a different numerictype and the divide would still work. % Say X is a s16q15 Nx = numerictype(X); Nx.divide(X,yfi) % will work and the result will be a s16q15 However, I'd rather not use divide in your fixed-point implementation. The better practice is to compute the 1/sqrt(2) and store that as a constant (fi) and use multiply instead. "porterboy" <porterboy76@yahoo.com> wrote in message news:c4b57fd0.0409152341.41f14c2c@posting.google.com...> Thanks Ashok, that was very useful. > > > % For X, use the fimath you created and lets say (since that info is not > > here) > > % that X too is a s18q17 (same as y) > > N = numerictype(yfi); > > X = fi(zeros(2,1),N,F); > > Suppose X is not the same as y. Will the divide function still work, > even though the numerictypes are different? Or do they have to be cast > to the same type?
