Jerry Avins wrote:> > > > -jim > > You're right: I overlooked DC. After the needed low-pass filter, > [1 0 1 0 1 0] should become [.5 .5 .5 .5 .5 .5], so is doesn't matter > whether even samples are chosen, or odd. >Yes, but the low pass filter is not "needed" here. The puzzle was about aliasing and its effects. Consider what you,re example demonstrates: if a signal is limited to the frequency band [0..fs/4] then we can discard every other sample (even or odd) and the result will always have exactly half the amplitude of the original. So for there to be any kind of puzzle the signal needs to not be properly bandlimeted (or made bandlimited by filtering). As someone else pointed out in order for the result to have the same amplitude as the original (twice what it would have for a properly bandlimited signal) there must be for every frequency in the 0..fs/4 range a corresponding frequency in the fs/4..fs/2 range that gets aliased and exactly doubles the amplitude. So the puzzle could have been what does the above described time sequence look like. -jim ----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! >100,000 Newsgroups ---= East/West-Coast Server Farms - Total Privacy via Encryption =--- -----------== Posted via Newsfeed.Com - Uncensored Usenet News ==---------- http://www.newsfeed.com The #1 Newsgroup Service in the World! -----= Over 100,000 Newsgroups - Unlimited Fast Downloads - 19 Servers =-----
Another DSP puzzle
Started by ●December 13, 2004
Reply by ●December 20, 20042004-12-20
Reply by ●January 17, 20052005-01-17
Hi KD, KEDI wrote:> Hi Rick (and Jitendra), > > > I hope Jitendra doesn't mind me stepping in to clarify a few things > here. >Not at all..> >>w_jk(t) = 2^(j/2)w(2^j t - k)<< > > This is the standard notation in wavelet theory. However, to avoid > confusion, I am going to replace j with n so that no one mistakes itas> sqrt(-1): > > W_nk(t) = 2^(n/2) * W(2^n * t - k) > > W_nk(t) is the nth "daughter wavelet" at step k. W(t) is the mother > wavelet. (A mother wavelet can be any time-limited function such as a > rectangle function.) This equation relates a daughter function to its > mother. You can see a wavelet example here: > http://mathworld.wolfram.com/HaarFunction.html > > 2^(n/2) is the normalizing factor to make every daughter eual intotal> energy. nth and (n+1)th daughter wavelets differ in frequency by a > factor of 2. Therefore, DFT of (n+1)th daugher has the same shape as > DFT of the nth daughter decimated by 2. Nomalization will make theDFTs> equal in magnitude as well. > > This property of "2" successive daughter wavelet functions, though > similar to what we are talking about here, is not the property we are > looking for in "a" time sequence. >Thanks for the explanation. I couldn't have done better than this.. Daughter wavelets can also be viewed as filtered and resampled versions of the mother wavelet. So one daughter wavelet can be seen as filtered and resampled version of another daugther wavelet. A point to note here though is that the shape need not be preserved when going from one daughter to another. I guess I interpreted the puzzle to be: construct a sequence that when filtered and down-sampled will give rise to another sequence that has the same DFT amplitudes. However, if we can't modify the shape, there isn't much that can be done.> > BTW, Rick, I am a DSP newbie and I love your book! I am about tofinish> reading every single page! Where can I get an errata sheet of your2nd> edition? THANK YOU! > >You may find it interesting that wavelets and filter banks in DSP are related. In fact, certain wavelets can be generated by iterating filterbanks and the discrete wavelet transform of a sequence can be computed using filter banks. If you have Matlab, you may want to check an excellent wavelet toolbox (Wavelab) from Stanford University: http://www-stat.stanford.edu/~wavelab/ Cheers Jitendra> Best Regards. > > KD
Reply by ●January 19, 20052005-01-19
Hi Jitendra Thank you, for your link and info. The toolbox looks fascinating! Hope to have some time to look at it in detail later. Best regards. KD Jitendra Rayala wrote:> Hi KD, > You may find it interesting that wavelets and filter banks in DSP are > related. In fact, certain wavelets can be generated by iterating > filterbanks and the discrete wavelet transform of a sequence can be > computed using filter banks. If you have Matlab, you may want tocheck> an excellent wavelet toolbox (Wavelab) from Stanford University: > > > http://www-stat.stanford.edu/~wavelab/ > Cheers > Jitendra
